TB2S THRU TB10S
Voltage Range - 40 to 200 V olts
Current - 1.0 Ampere
SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS
Features
TBS
Ideal for printed circuit board
Reliable low cost construction utilizing molded plastic technique
High temperature soldering guaranteed: 260°/10 seconds at 5
lbs., (2.3kg) tension
Small size, simple installation
High surge current capability
Glass passivated chip junction
Mechanical Data
Case : JEDEC TBS Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.003 ounce, 0.098 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
MDD
TB10S
UNITS
1000
700
1000
1.0
V
V
V
A
IFSM
30
A
VF
0.95
V
IR
5
100
uA
RθJA
80
°C/W
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current,
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage drop
per leg at 1A
Maximum DC reverse current
TA=25°C
at rated DC blocking voltage
TA=100°C
Typical thermal resistance
Operating temperature range
storage temperature range
VRRM
VRMS
VDC
IF(AV)
MDD
TB2S
MDD
TB4S
MDD
TB6S
200
140
200
400
280
400
600
420
600
TJ
-55 to +150
TSTG
-55 to +150
MDD
TB8S
800
560
800
pF
°C
°C
NOTES:1.On glass epoxy P.C.B. mounted on 0.05x0.05''(1.3x1.3mm) pads
2.On aluminum substrate P.C.B. with on area of 0.8''x0.8''(20x20mm) mounted on 0.05X0.05''(1.3X1.3mm) solder pad
3.Thermal resistance form junction to ambient and junction to lead mounted on P.C.B. with 0.2X0.2''(5X5mm)
copper pads.
http://www.microdiode.com
Rev:2024A1
Page :1
TB2S THRU TB10S
Ratings And Characteristic Curves
Instantaneous Forward Current, (A)
FIG.1 TYPICAL FORWARD CHARACTERISTICS
FIG.2 FORWARD DERATING CURVE
1.0
1.0
Average Forward Rectified
Current, (A)
Aluminum Substrate
0.4
0.1
0.01
0.75
GLASS
EPOXY
P.C.B
0.5
0.25
RESISTIVE OR INDUCTIVE LOAD
0.8
0.9
1.0
1.1
1.2
1.3
1.4
1.5
Instantaneous Forward Voltage, ( V )
FIG.3 TYPICAL REVERSE CHARACTERISTICS
50
75
100
125
150
Ambient Temperature, (°C )
FIG.4 PEAK FORWARD SURGE CURRENT
35
Peak Forward Surge Current,
(A)
100000
Instantaneous Reverse Leakage
Current, ( A)
25
10000
1000
TA=100°C
100
TA=25°C
10
1.0
30
25
10
5
60
80
100
120
140
Percent Of Rated Peak Reverse Voltage, %
1
10
100
Number Of Cycles At 60Hz
The cruve graph is for reference only, can't be the basis for judgment
Rev:2024A1
Page :2
很抱歉,暂时无法提供与“TB8S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.14250
- 100+0.13300
- 300+0.12350
- 500+0.11400
- 2000+0.10925
- 5000+0.10640
