MMBT3906
TRANSISTOR(PNP)
FEATURES
z Complementary Type The NPN Transistor MMBT3904 is Recommended
z Epitaxial Planar Die Construction
SOT-23
(3)C
1. BASE
MARKING: 2A
2A
2. EMITTER
3. COLLECTOR
(1)B
(2)E
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
-40
V
VCEO
Collector-Emitter Voltage
-40
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current
-200
mA
PC
Total Device Dissipation
200
mW
RθJA
Thermal Resistance Junction to Ambient
625
℃/W
TJ
Junction Temperature
150
Tstg
Storage Temperature
-55 ~ +150
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test
conditions
Min
Max
Unit
Collector-base breakdown voltage
V(BR)CBO IC=-10μA, IE=0
-40
V
Collector-emitter breakdown voltage
V(BR)CEO IC=-1mA, IB=0
-40
V
Emitter-base breakdown voltage
V(BR)EBO IE=-10μA, IC=0
-5
V
Collector cut-off
current
ICBO
VCB=-40V, IE=0
-0.1
μA
Collector cut-off
current
ICEX
VCE=-30V,VBE(off)=-3V
-50
nA
IEBO
VEB=-5V, IC=0
-0.1
μA
hFE(1)
VCE=-1V, IC=-10mA
100
hFE(2)
VCE=-1V, IC= -50mA
60
hFE(3)
VCE=-1V, IC= -100mA
30
Collector-emitter saturation voltage
VCE(sat)
IC=-50mA, IB= -5mA
-0.3
V
Base-emitter saturation voltage
VBE(sat)
IC= -50mA, IB=-5mA
-0.95
V
Emitter cut-off
current
DC current gain
300
Transition frequency
fT
VCE=-20V, IC=-10mA,f=100MHz
Delay Time
td
VCC=-3V,VBE=-0.5V
35
nS
Rise Time
tr
IC=-10mA, IB1=-IB2=-1mA
35
nS
Storage Time
ts
VCC=-3V,IC=-10mA,
225
nS
Fall Time
tf
IB1=-IB2=-1mA
75
nS
CLASSIFICATION OF
Rank
Range
1
300
hFE(1)
O
Y
100-200
200-300
MHz
MMBT3906
Static Characteristic
-500uA
-450uA
-80
IC
COMMON EMITTER
VCE=-1V
-350uA
-300uA
-250uA
-200uA
-40
Ta=100℃
-400uA
-60
hFE
300
COMMON
EMITTER
Ta=25℃
DC CURRENT GAIN hFE
COLLECTOR CURRENT IC (mA)
-100
-150uA
200
Ta=25℃
100
-100uA
-20
IB=-50uA
-0
-0
-4
-8
-12
-16
COLLECTOR-EMITTER VOLTAGE
VCEsat
-500
VCE
-20
-1
-0.3
-10
-3
COLLECTOR CURRENT
(V)
IC
VBEsat
-1.2
IC
-100
-30
(mA)
IC
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
-300
Ta=100℃
-100
Ta=25℃
-30
Ta=25℃
-0.8
Ta=100℃
-0.4
β=10
β=10
-10
-0.0
-1
-3
-30
-10
COLLECTOR CURRENT
IC
-100
IC
-100
-200
-1
-10
-3
(mA)
-100
-30
COLLECTOR CURRENT
VBE
Cob/ Cib
9
IC
VCB/ VEB
f=1MHz
IE=0/ IC=0
Ta=25℃
-30
Cob
Ta=100℃
CAPACITANCE C (pF)
COMMON EMITTER
VCE=-1V
-10
-3
Ta=25℃
-1
Cib
3
-0.3
-0.1
-0.0
-0.2
-0.4
-0.6
-0.8
1
-0.1
-1.0
fT
IC
Pc
300
-10
-3
REVERSE VOLTAGE
V
-20
(V)
Ta
VCE=-20V
o
Ta=25 C
COLLECTOR POWER DISSIPATION
Pc (mW)
TRANSITION FREQUENCY fT (MHz)
600
-1
-0.3
BASE-EMMITER VOLTAGE VBE (V)
400
200
250
200
150
100
50
-3
-10
COLLECTOR CURRENT
2
-300
(mA)
-30
IC
(mA)
-50
50
75
AMBIENT TEMPERATURE
100
Ta
125
150
很抱歉,暂时无法提供与“MMBT3906-2A”相匹配的价格&库存,您可以联系我们找货
