DSK12 THRU DSK120
Reverse Voltage - 20 to 200 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
SOD-123FL
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
0.075(1.90)
0.067(1.70)
0.031 (0.80)
0.043 (1.10)
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
0.114(2.90)
0.102(2.60)
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
0.051(1.30)
0.039(1.00)
250 °C/10 seconds at terminals
0.010(0.25)
0.004(0.10)
0.035(0.90)
0.028(0.70)
0.154(3.90)
0.141(3.60)
Mechanical Data
Dimensions in inches and (millimeters)
Case: JEDEC SOD-123FL molded plastic body
Terminals: Solderable per MIL-STD-750,Method
2026 Polarity: Color band denotes cathode end
Mounting Position: Any
Weight : 0.0007 ounce, 0.02 grams
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
DSK12
DSK14
DSK15
DSK16
DSK18
DSK110
DSK115
DSK120
K12
K14
K15
K16
K18
K110
K115
K120
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
UNITS
V
V
V
Maximum average forward rectified current
at TL(see fig.1)
I(AV)
1.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
25
A
Maximum instantaneous forward voltage at 1.0A
VF
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
TA=100℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
0.55
IR
CJ
RJA
0.70
0.3
10.0
0.90
0.85
0.2
5.0
110
80
0.1
2.0
V
mA
pF
100.0
℃/W
TJ
-55 to +150
TSTG
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
http://www.microdiode.com
Rev:2024A3
Page :1
DSK12 THRU DSK120
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
1.2
Average Forward Current (A)
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
10 3
T J =100°C
10 2
T J =25°C
10 1
10 0
80
100
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
500
Junction Capacitance (pF)
1.0
DSK12/DSK14
DSK16/DSK18
DSK110/DSK112
DSK115/DSK120
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
200
100
50
DSK12/DSK14
DSK16-DSK120
10
1
0.1
100
10
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surge Current
Fig.6- Typical Transient Thermal Impedance
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
T J =25°C
1.8
1
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance( °C / W)
Instaneous Forward Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Case Temperature (°C)
Peak Forward Surge Current (A)
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A3
Page :2
DSK12 THRU DSK120
Packing information
unit:mm
P0
P1
Item
d
E
F
B
A
P
D2
D1
C
W1
D
Tolerance
SOD-123FL
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
W
T
Symbol
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-123FL
7"
3,000
4.0
45,000
210*208*203
178
430*430*235
180,000
APPROX.
GROSS WEIGHT
(kg)
9.0
Suggested Pad Layout
Symbol
Unit (mm)
A
1.2
0.047
B
0.047
C
1.2
3.2
0.126
D
2
0.079
E
4.4
0.173
Unit (inch)
Rev:2024A3
Page :3
很抱歉,暂时无法提供与“DSK110”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.32085
- 200+0.10684
- 1500+0.06682
- 3000+0.05302
- 国内价格
- 50+0.13522
- 500+0.10725
- 3000+0.08964
- 6000+0.08036
- 24000+0.07226
- 51000+0.06783
- 国内价格
- 50+0.12395
- 600+0.09831
- 1200+0.09684
- 3000+0.08217
