SS12 THRU SS1200
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 20 to 200 Volts
DO-214AC/SMA
FEATURES
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds at terminals
0.110(2.80)
0.100(2.54)
0.067 (1.70)
0.051 (1.30)
Forward Current - 1.0 Ampere
0.177(4.50)
0.157(3.99)
0.012(0.305)
0.006(0.152)
0.096(2.42)
0.078(1.98)
MECHANICAL DATA
0.060(1.52)
0.030(0.76)
Case: JEDEC DO-214AC molded plastic body
Terminals: leads solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.002 ounce, 0.07 grams
0.008(0.203)MAX.
0.222(5.66)
0.194(4.93)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
MDD Catalog Number
Marking code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
SS15
SS16
SS18 SS110 SS1150 SS1200
MDD MDD MDD MDD
SS12 SS13 SS14 SS15
MDD
SS16
MDD
MDD MDD
MDD
SYMBOLS SS12 SS13 SS14
VRRM
VRMS
VDC
21
30
40
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
UNITS
VOLTS
VOLTS
VOLTS
I(AV)
1.0
Amp
IFSM
30.0
Amps
VF
0.45
0.5
10.0
IR
CJ
RθJA
TJ,
TSTG
0.70
0.55
5.0
90
110
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
0.85
88.0
-50 to +125
-50 to +150
-50 to +150
0.95
0.2
2.0
Volts
mA
pF
C/W
C
C
FIG. 1- FORWARD CURRENT DERATING CURVE
1.0
0.8
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.6
0.4
SS12-SS16
SS18-SS1200
0.2
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES SS12 THRU SS1200
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
24
18
12
6
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
INSTANTANEOUS FORWARD
CURRENT,AMPERES
TJ=25 C
10.0
1
SS12-SS14
SS15-SS16
SS18-SS1150
SS1200
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
50
0.1
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.4
0.6
0.8
1.0
1.2
1.4
60
80
100
1.6
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
PERCENT OF PEAK REVERSE VOLTAGE,%
400
200
TJ=25 C
SS12-SS14
SS15-SS1200
TRANSIENT THERMAL IMPEDANCE,
C/W
0.01
100
NUMBER OF CYCLES AT 60 Hz
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
2
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)!
100
很抱歉,暂时无法提供与“SS16-SMA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.07788
- 100+0.07128
- 500+0.06468
- 1000+0.05808
- 2000+0.05368
- 4000+0.05236
