SR05
TVS Array
GENERAL DESCRIPTION
The SR05 has been specifically designed to protect
sensitive components which are connected to data and
transmission lines from overvoltages caused by ESD
(electrostatic discharge), EFT (electrical fast transients), and
lightning.
SOT-143
FEATURES
• Protects two I/O lines
• Max. peak pulse power : Ppp = 300W at tp = 8/20 us
• Low Capacitance : 5pF Typical
• Low clamping voltage
• IEC 61000-4-2, level 4 ( ESD ), > ±15KV ( air ) ; > ±8KV
( contact )
• IEC 61000-4-5 (Lightning) , 5A (8/20 us)
APPLICATION
• USB Power & Data Line Protection
• Ethernet 10BaseT
• Video Line Protection
• T1/E1 secondary IC Side Protection
• Portable Electronics
• WAN/LAN Equipment
MECHANICAL DATA
• Case material: “Green” molding compound UL flammability
classification 94V-0 (No Br, Sb, Cl)
• Terminals: Lead Free Plating (Matte Tin Finish), solderable
perJ-STD-002 and JESD22-B/02.
• Moisture Sensitivity: Leve 1 per J-STD-020C
• Component in accordance to RoHs 2011/65/EU
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25°C ambient temperature unless otherwise specified.
ABSOLUTE RATINGS
SYMBOL
VALUE
UNIT
Peak pulse power (8/20us waveform)
PPP
300
W
Peak pulse current (8/20us waveform)
IPP
5
A
Operating junction temperature range
TJ
-55 to +125
°C
TSTG
-55 to +150
°C
TL
260
°C
PARAMETER
Storage temperature range
Soldering temperature, t max = 10s
PARAMETER
TEST CONDITIONS
SYMBOL
MIN.
TYP.
Reverse standoff voltage
Breakdown voltage
Reverse leakage current
Junction capacitance
Clamping voltage
MAX
UNIT
VDRM
5
V
I t = 1mA
VBR
6
V
VDRM = 5V
IRM
5
uA
5
10
3
5
9.8
VR = 0V, f = 1MHz,
Between I/O pins and Ground
VR = 0V, f = 1MHz,
Between I/O pins
IPP = 1A (8/20 us)
IPP = 25A (8/20 us)
1/4
pF
CJ
VC
V
SR05
TVS Array
RATING AND CHARACTERISTIC CURVES
12 0
100%
80
Percent of Peak Pulse Current %
Percent of Peak Pulse Current (%)
100% Ipp: 8us
-1
e
50% Ipp: 20us
40
90%
10%
Time (ns)
tr = 0.7 ~1 ns
30 ns
40
Time (us)
60 ns
Figure 2. ESD pulse waveform
according to IEC 61000-4-2
Figure 1. 8/20 us pulse waveform
according to IEC 61000-4-5
10
100
IR / IR (25°C)
Capacitance,(pF)
10
1
0.001
0.01
0.1
1
1
0.1
10
REVERSE,VOLTAGE, (V)
25
50
75
100
125
150
Junction Tempeerature,(°C)
Figure 3. Typical Junction Capacitance
Figure 4. Reverse Leakage Current versus TJ
2/4
SR05
TVS Array
I/O1
+/-8KV
ESD Contact
discharge
V (i/o)
Figure 7. ESD Test Configuration
Figure 8.
Clamped +8 kV ESD voltage waveform
Figure 9.
3/4
Clamped -8 kV ESD voltage waveform
SR05
TVS Array
PACKAGE OUTLINE
SOT-143
SOT-143 Soldering Pad Layout :
4/4
很抱歉,暂时无法提供与“SR05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.38750
- 100+0.36250
- 500+0.33750
- 2000+0.30000
- 5000+0.28750
- 10000+0.28000
