SBD52C05L01
Electrostatic Discharged Protection Devices (ESD) Data Sheet
Description
The SBD52 series of Transient Voltage Suppressors (TVS) are
designed to replace multilayer varistors (MLVs) in portable
applications such as cell phones, notebook computer, and PDAs.
They offer superior electrical characteristics such as lower clamping
voltage and no device degradation when compared to MLVs. They
are designed to protect sensitive semiconductor components from
damage or upset due to electrostatic discharge (ESD), lightning,
electrical fast transients (EFT), and cable discharge events (CDE).
Features
IEC61000-4-2 ESD 15KV Air, 8KV contact compliance
SOD-523 surface mount package
Protects bi-directional line
Peak power dissipation of 150W under 8/20μs waveform
Working voltage: 5V
Low leakage current
Low operating and clamping voltages
Solid-state silicon avalanche technology
Lead Free/RoHS compliant
Solder reflow temperature: Pure Tin-Sn, 260~270℃
Flammability rating UL 94V-0
Meets MSL level 1, per J-STD-020
Marking: 5C
Pin Configuration
Applications
Cellular handsets & Accessories
Cordless phones
Personal digital assistants (PDAs)
Notebooks & Handhelds
Portable instrumentation
Digital cameras
Peripherals
MP3 players
Maximum Ratings
Rating
Peak pulse power (tp=8/20μs waveform)
ESD voltage (Contact discharge)
ESD voltage (Air discharge)
Storage & operating temperature range
Revision:13-Jan-16
Symbol
Value
Unit
PPP
150
W
VESD
TSTG ,TJ
±8
±15
-55~+150
kV
www.brightking.com
SBD52C05L01
Electrical Characteristics (TJ=25℃)
Parameter
Reverse stand-off voltage
Reverse breakdown voltage
Symbol
Condition
Min.
Typ.
VRWM
5.6
Max.
Unit
5
V
8
V
VBR
IBR=1mA
Reverse leakage current
IR
VR=5V
5
μA
Clamping voltage (tp=8/20μs)
VC
IPP=1A
9.8
V
Off state junction capacitance
CJ
0Vdc,f=1MHz
30
pF
Typical Characteristics Curves
Peak Power Dissipation (%)
Figure 1. Power Derating Curve
Figure 2. Pulse Waveforms
110
100
tr
Peak value Ipp
Waveform
Parameters:
tr=8µs
td=20µs
90
80
70
60
50
40
30
td=t|IPP/2
10
15
30
t-Time (μs)
Figure 4. ESD Clamping(8kV Contact IEC61000-4-2)
Clamping Voltage (V)
Figure 3. Clamping Voltage vs. Peak Pulse Current
Revision:13-Jan-16
www.brightking.com
SBD52C05L01
Recommended Soldering Conditions
Reflow Soldering
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
Revision:13-Jan-16
20-40 seconds
6℃/second max.
8 minutes max.
www.brightking.com
SBD52C05L01
Dimensions (SOD-523)
Dimension (mm)
Symbol
Millimeters
Inches
Min.
Max.
Min.
Max.
A
0.50
0.70
0.020
0.028
B
0.07
0.20
0.003
0.008
C
0.70
0.90
0.028
0.035
D
0.25
0.35
0.010
0.014
E
1.10
1.30
0.043
0.051
F
1.50
1.70
0.059
0.067
G
0.15
0.25
0.006
0.010
Packaging
Tape
Reel
Symbol
Dimension (mm)
W
8.00±0.30
P0
4.00±0.10
P1
2.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
D1
Φ0.50±0.05
E
1.75±0.10
F
3.50±0.10
A
1.00±0.10
A0
0.50±0.10
B
1.80±0.10
B0
1.30±0.10
K
0.65±0.10
t
0.20±0.05
D
Φ178.0±2.0
D2
Φ13.0
W1
9.5
D2
D
Revision:13-Jan-16
W1
Quantity: 3000PCS
www.brightking.com
很抱歉,暂时无法提供与“SBD52C05L01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16860
- 300+0.13583
- 1200+0.11751
- 3000+0.09554
- 国内价格
- 20+0.18393
- 200+0.14818
- 600+0.12820
- 3000+0.10422
- 9000+0.09396
- 21000+0.08835
- 国内价格
- 1+0.45210
- 200+0.15070
- 1500+0.09427
- 3000+0.07480
- 国内价格
- 20+0.47240
- 100+0.28180
- 800+0.19720
- 3000+0.14090
- 6000+0.13390
- 30000+0.12400
