DB106S
DB106S
    HQ(华秋)
    DBS
    Vr=800V IO=1A VF=1.1V@1A
DB106S 数据手册
MOSPEC DB101S THRU DB107S 50 to 1000 VOLTS 1.0 AMPERE REVERSE VOLTAGE: FORWARD CURRENT: FEATURES DB-S · Plastic material has Underwriters Laboratory Flammability Classification 94V-0 · High surge overload rating of 50 Amperes peak · Ideal for printed circuit board · Glass passivated chip junction MECHANICAL DATA Case: Molded plastic, DB-S Epoxy: UL 94V-O rate flame retardant Terminals: Leads solderable per MIL-STD-202, method 208 guaranteed Mounting position: Any Weight: 0.02ounce, 0.4gram Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Ratings at 25 ℃ ambient temperature unless otherwise specified. Single phase, half wave, 60H Z, resistive or inductive load. For capacitive load, derate current by 20%. Symbols DB101S DB102S DB103S DB104S DB105S DB106S DB107S Units Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 Volts Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 Volts Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 Volts Maximum Average Forward Rectified Current at TA=40℃ (Note 2) I(AV) 1.0 Amp IFSM 50 Amp VF 1.1 Volts Peak Forward Surge Current, 8.3ms single half-sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage at 1.0A DC and 25℃ Maximum Reverse Current at TA=25℃ at Rated DC Blocking Voltage T A=125℃ IR 5.0 500 uAmp CJ 25 pF Typical Thermal Resistance (Note 2) RθJA 40 ℃/W Typical Thermal Resistance (Note 2) RθJL 15 ℃/W TJ,Tstg -55 to +150 ℃ Typical Junction Capacitance (Note 1) Operating and Storage Temperature Range NOTES: 1- Measured at 1 MHZ and applied reverse voltage of 4.0 VDC. 2- Units mounted on P.C.B. with 0.5 x 0.5" (13 x 13mm) copper pads MOSPEC RATINGS AND CHARACTERISTIC CURVES DB101S THRU DB107S
DB106S 价格&库存
很抱歉,暂时无法提供与“DB106S”相匹配的价格&库存,您可以联系我们找货
