P6KE SERIES
TRANSIENT VOLTAGE SUPPRESSORS
FEATURE
Plastic package.
Glass passivated chip junction in DO-15 Package
600W peak pulse power capability on 10/1000μs waveform.
Excellent clamping capability.
Low zener impedance.
Fast response time: typically less than 1.0ps from 0 Volts to BV min.
Typical IR less than 1μA above 10V.
High temperature soldering guaranteed: 265ć/10 seconds/.375”,
(9.5mm) lead length, 5lbs., (2.3kg) tension.
DO-204AC/DO-15
MECHANICAL DATE
Case: JEDEC DO-15 Molded Plastic.
Terminals: Axial leads, solderable per MIL-STD-750, Method 2026.
Polarity: Color band denoted cathode except bidirectional.
Mounting Position: Any.
Weight: 0.015 ounce, 0.4grams.
DEVICES FOR BIPOLAR APPLICATION
For bidirectional use C or CA suffix for types P6KE6.8 thru types P6KE550 (e.g.P6KE6.8C, P6KE550CA),
electrical characteristics apply in both directions.
MAXIMUM RATINGS AND CHARACTERISTICS
Ratings at 25ć ambient temperature unless otherwise specified.
RATING
SYMBOL
VALUE
UNITS
Peak Pulse Power Dissipation on 10/1000ȝs waveform
(Note1, Fig.1).
PPPM
Minimum 600
Watts
Peak Pulse Current of on 10/1000ȝs waveform.(Note1,Fig.3)
IPPM
See Table
Amps
Steady State Power Dissipation at TL =75ć,Lead lengths.375”,
(9.5mm) (Fig.5).
PM(AV)
5.0
Watts
Peak Forward Surge Current,8.3ms Single Half Sine-Wave
Superimposed on Rated Load, (JEDEC Method) (Note 2,Fig.6).
IFSM
100
Amps
TJ , TSTG
-55 to +175
ć
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25ć per Fig. 2.
2. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum.
1/4
P6KE SERIES
DIMENSIONS
d
s
DIA.
DIA.
L
T
L
DO-204AC/DO-15
Millimeters
Item
Inches
Min.
Max.
Min.
Max.
L
25.40
1.000
T
5.80
7.60
0.230
0.300
d
2.60
3.60
0.104
0.140
s
0.71
0.86
0.028
0.034
ELECTRICAL CHARACTERISTICS
Part Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
NIN.@IT
Breakdown
Voltage
MAX.@IT
Test
Current
Maximum
Clamping
Voltage @IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
UNT-POLAR
BI-POLAR
VRWM(V)
VBR MIN.(V)
VBR MAX.(V)
IT(mA)
VC(V)
IPP(A)
IR(ȝA)
P6KE6.8A
P6KE6.8CA
5.80
6.45
7.14
10
10.5
58.1
1000
P6KE7.5A
P6KE7.5CA
6.40
7.13
7.88
10
11.3
54.0
500
P6KE8.2A
P6KE8.2CA
7.02
7.79
8.61
10
12.1
50.4
200
P6KE9.1A
P6KE9.1CA
7.78
8.65
9.55
1
13.4
45.5
50
P6KE10A
P6KE10CA
8.55
9.50
10.50
1
14.5
42.1
10
P6KE11A
P6KE11CA
9.40
10.50
11.60
1
15.6
39.1
5
P6KE12A
P6KE12CA
10.20
11.40
12.60
1
16.7
36.5
5
P6KE13A
P6KE13CA
11.10
12.40
13.70
1
18.2
33.5
1
P6KE15A
P6KE15CA
12.80
14.30
15.80
1
21.2
28.8
1
P6KE16A
P6KE16CA
13.60
15.20
16.80
1
22.5
27.1
1
P6KE18A
P6KE18CA
15.30
17.10
18.90
1
25.2
24.2
1
P6KE20A
P6KE20CA
17.10
19.00
21.00
1
27.7
22.0
1
P6KE22A
P6KE22CA
18.80
20.90
23.10
1
30.6
19.9
1
P6KE24A
P6KE24CA
20.50
22.80
25.20
1
33.2
18.4
1
P6KE27A
P6KE27CA
23.10
25.70
28.40
1
37.5
16.3
1
2/4
P6KE SERIES
Part Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
NIN.@IT
Breakdown
Voltage
MAX.@IT
Test
Current
Maximum
Clamping
Voltage @IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
UNT-POLAR
BI-POLAR
VRWM(V)
VBR MIN.(V)
VBR MAX.(V)
IT(mA)
VC(V)
IPP(A)
IR(ȝA)
P6KE30A
P6KE30CA
25.60
28.50
31.50
1
41.4
14.7
1
P6KE33A
P6KE33CA
28.20
31.40
34.70
1
45.7
13.3
1
P6KE36A
P6KE36CA
30.80
34.20
37.80
1
49.9
12.2
1
P6KE39A
P6KE39CA
33.30
37.10
41.00
1
53.9
11.3
1
P6KE43A
P6KE43CA
36.80
40.90
45.20
1
59.3
10.3
1
P6KE47A
P6KE47CA
40.20
44.70
49.40
1
64.8
9.4
1
P6KE51A
P6KE51CA
43.60
48.50
53.60
1
70.1
8.7
1
P6KE56A
P6KE56CA
47.80
53.20
58.80
1
77.0
7.9
1
P6KE62A
P6KE62CA
53.00
58.90
65.10
1
85.0
7.2
1
P6KE68A
P6KE68CA
58.10
64.60
71.40
1
92.0
6.6
1
P6KE75A
P6KE75CA
64.10
71.30
78.80
1
103.0
5.9
1
P6KE82A
P6KE82CA
70.10
77.90
86.10
1
113.0
5.4
1
P6KE91A
P6KE91CA
77.80
86.50
95.50
1
125.0
4.9
1
P6KE100A
P6KE100CA
85.50
95.00
105.00
1
137.0
4.5
1
P6KE110A
P6KE110CA
94.00
105.00
116.00
1
152.0
4.0
1
P6KE120A
P6KE120CA
102.00
114.00
126.00
1
165.0
3.7
1
P6KE130A
P6KE130CA
111.00
124.00
137.00
1
179.0
3.4
1
P6KE150A
P6KE150CA
128.00
143.00
158.00
1
207.0
2.9
1
P6KE160A
P6KE160CA
136.00
152.00
168.00
1
219.0
2.8
1
P6KE170A
P6KE170CA
145.00
162.00
179.00
1
234.0
2.6
1
P6KE180A
P6KE180CA
154.00
171.00
189.00
1
246.0
2.5
1
P6KE200A
P6KE200CA
171.00
190.00
210.00
1
274.0
2.2
1
P6KE220A
P6KE220CA
185.00
209.00
231.00
1
328.0
1.9
1
P6KE250A
P6KE250CA
214.00
237.00
263.00
1
344.0
1.8
1
P6KE300A
P6KE300CA
256.00
285.00
315.00
1
414.0
1.5
1
P6KE350A
P6KE350CA
300.00
332.00
368.00
1
482.0
1.3
1
P6KE400A
P6KE400CA
342.00
380.00
420.00
1
548.0
1.1
1
P6KE440A
P6KE440CA
376.00
418.00
462.00
1
602.0
1.04
1
P6KE480A
P6KE480CA
408.00
456.00
504.00
1
658.0
0.9
1
P6KE510A
P6KE510CA
434.00
485.00
535.00
1
698.0
0.9
1
P6KE530A
P6KE530CA
450.00
503.50
556.50
1
725.0
0.8
1
P6KE540A
P6KE540CA
459.00
513.00
567.00
1
740.0
0.8
1
P6KE550A
P6KE550CA
467.00
522.50
577.50
1
760.0
0.8
1
P6KE600A
P6KE600CA
512.00
570.00
630.00
1
828.0
0.75
1
Notes: For bidirectional type having VRWM of 10 volts and less, the IR limit is double.
3/4
P6KE SERIES
RATINGS AND CHARACTERISTIC CURVES
Figure 2 - Pulse Derating Curve
Figure 1 - Peak Pulse Power Rating Curve
Non-repetitive Pulse
Waveform shown in Fig 3.
TA=25ûC
10
1
0.1
1.0μs
10μs
100μs
1.0ms
100
Peak Pulse Power (PPP) or Current (IPPM)
Derating in Percentage, %
PPPM- Peak Pulse Power (kW)
100
0.1μs
(TA=25ć unless otherwise noted)
75
50
25
10ms
td- Pulse Width (sec.)
100 125 150
175 200
10000
tr=10μsec
TJ=25°C
Pulse Width(td) is defined
as the point where the peak
current decays to 50% of IPPM
Peak Value
IPPM
100
Bi-directional V=0V
Uni-directional @VR
Half Value
IPPM IPPM
2
50
100
10/1000μsec. Waveform
as defined by R.E.A
Bi-directional @VR
10
Tj=25C
f=1.0MHz
Vsig=50mVp-p
td
1.0
Uni-directional V=0V
1000
Cj (pF)
IPPM- Peak Pulse Current, % IRSM
75
Figure 4 - Typical Junction Capacitance Uni-Directional
150
2.0
3.0
1
1.0
4.0
10.0
100.0
1000.0
VBR - Reverse Breakdown Voltage (V)
t-Time (ms)
Figure 6 - Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
Figure 5 - Steady State Power Dissipation Derating Curve
6
120
IFSM - Peak Forward Surge Current
(A)
Steady State Power Dissipation (W)
50
TA- Ambient Temperature (oC)
Figure 3 - Pulse Waveform
5
4
3
2
L = 0.375” (9.5mm)
Lead Lengths
1
50
75
100
125
150
175
100
80
60
40
1
TL-Lead Temperature(ºC)
10
Number of Cycles at 60 Hz
4/4
100
很抱歉,暂时无法提供与“P6KE400A”相匹配的价格&库存,您可以联系我们找货
