SD05
SD05
    YENJI(台湾元基)
    SOD-323
    ESD抑制器/TVS二极管 VRWM=5V VC=14.5V SOD323
SD05 数据手册
SD05 THRU SD24 TVS Diodes Features z z z z z z z z z z Small SOD-323 Package Unidirectional Configurations Peak Power Dissipation 350W @8 x 20 us Pulse Low Leakage Fast Response Time < 1 ns Protects One Power or I/O Port ESD Protection to IEC 61000-4-2 Level 4,15KV(Air), 8KV(Contanct) ESD Protection to IEC 61000-4-2 Level 4, 30A 16KV Human Body Model ESD Requirements RoHS Compliant in Lead-Free Versions Applications z z z z z z Cell Phone Handsets and Accessories Microprocessor Based Equiment Personal Digital Assistant (PDA) Notebooks, Destops, and Servers Portable Instrumentation Pagers Periherals Absolute Maximum Ratings Parameter Symbol Value Units PPK 350 W Air ±15 KV CONTACT ±8.0 KV 30 A VPP 16 KV TSTG -55 to 150 °C TJ -55 to 150 °C Peak Power Dissipation (Note 1.) @TL = 25°C IEC 61000-4-2 (ESD) IEC 61000-4-4 (EFT) ESD Voltage Per Human Body Model Storage Temperature Range Operating Junction Temperature Range 1. 8 X 20 us, non–repetitive 1/3 SD05 THRU SD24 TVS Diodes Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified. Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ I PP VRWM Working Peak Reverse Voltage IR Maximum Reverse Leakage Current @ VRWM IT Test Current VBR Breakdown Voltage @ IT IF Forward Current VF Forward Voltage @ IF Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified. VRWM (V) IR(uA) VBR (V)@ IT VC (V) VC (V) IPP C@OV 1MHz @ V RWM (Note 1) @ IPP=5 A* @ Max IPP* (A)* (pF) Device Max Max Min Max mA Typ Max Max Typ SD05 5.0 10 6.2 7.3 1.0 9.8 14.5 20 350 SD12 12 1.0 13.3 15.75 1.0 19 25 15 150 SD15 15 1.0 16.7 19.05 1.0 22 28 12 100 SD24 24 1.0 26.7 30.15 1.0 42 49 10 70 IT *Surge current waveform per Figure 1. 1. V BR is measured with a pluse test current IT at an ambient temperature of 25℃. Fig1. Pulse Waveform Fig2. Power Derating 2/3 SD05 THRU SD24 TVS Diodes Package Dimensions SOD-323 Dim A A1 Millimeters Inches MIN NOM MAX MIN NOM MAX 0.80 0.00 0.90 0.05 1.00 0.10 0.031 0.000 0.035 0.002 0.040 0.004 A3 0.15 REF 0.006 REF b 0.25 0.32 0.4 0.010 0.012 0.016 C 0.080 0.12 0.177 0.003 0.005 0.007 D E 1.60 1.15 1.70 1.25 1.80 1.40 0.063 0.045 0.066 0.049 0.071 0.055 L 0.08 HE 2.30 0.098 0.106 0.003 2.50 2.70 3/3 0.090
SD05
物料型号:SD05至SD24
器件简介:这些是单向配置的小型SOD-323封装的TVS二极管,具有350W的峰值功率耗散能力,低漏电,快速响应时间小于1纳秒。它们可以保护一个电源或I/O端口,符合IEC 61000-4-2的ESD保护标准,并且有铅免费版本符合RoHS标准。
引脚分配:文档中未明确列出引脚分配,但根据二极管的通用特性,阳极(Anode)是正极,阴极(Cathode)是负极。
参数特性:包括最大反向峰值脉冲电流(lpp)、钳位电压(Vc)、工作峰值反向电压(VRWM)、最大反向漏电流(IR)、测试电流(h)、击穿电压(VBR)、正向电流(IF)和正向电压(VF)。
功能详解:这些二极管用于保护电子设备免受静电放电(ESD)和电气快速瞬变(EFT)的影响,适用于手机、微处理器设备、个人数字助理(PDA)、笔记本电脑、服务器、便携式仪器、寻呼机和外围设备。
应用信息:适用于手机、微处理器设备、PDA、笔记本电脑、台式机、服务器、便携式仪器、寻呼机和外围设备。
封装信息:SOD-323封装,提供了详细的尺寸数据,包括长度(L)、高度(HE)、宽度(D)、A1和A的尺寸等。
很抱歉,暂时无法提供与“SD05”相匹配的价格&库存,您可以联系我们找货
