P4SMA SERIES
Transient Voltage Suppressors (TVS) Data Sheet
Features
For surface mounted applications in order to optimize board space
Low profile package
Glass passivated junction
Low inductance
Excellent clamping capability
400W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 1μA above 12V
High Temperature soldering: 260℃/10 seconds at terminals
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020
Safety certification: UL: E244458
Mechanical Data
Case: JEDEC DO-214AC. Molded plastic over glass passivated junction
Terminal: Solder plated, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Standard Packaging: 12mm tape (EIA STD RS-481)
Weight: 0.07g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 400
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
3.3
Watts
IFSM
40
Amps
TJ,TSTG
-65 to +150
Typical thermal resistance junction to lead
RθJL
30
℃/W
Typical thermal resistance junction to ambient
RθJA
120
℃/W
Steady state power dissipation at TA=50℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. Mounted on 5.0mm×5.0mm (0.03mm thick) copper pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Revision:17-Feb-16
www.brightking.com
P4SMA SERIES
Dimensions (SMA/DO-214AC)
Symbol
Millimeters
Inches
Min.
Max.
Min.
Max.
L
3.99
4.50
0.157
0.177
D
2.54
2.79
0.100
0.110
D1
1.25
1.65
0.049
0.065
T
4.93
5.28
0.194
0.208
T1
0.76
1.52
0.030
0.060
d
0.203
0.008
H
2.00
2.50
0.079
0.098
H1
1.98
2.29
0.078
0.090
Electrical Characteristics (TA=25℃)
Part Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
P4SMA6.8A
P4SMA6.8CA
6V8A
6V8C
5.80
6.45~7.14
10
10.5
39.0
1000
P4SMA7.5A
P4SMA7.5CA
7V5A
7V5C
6.40
7.13~7.88
10
11.3
36.3
500
P4SMA8.2A
P4SMA8.2CA
8V2A
8V2C
7.02
7.79~8.61
10
12.1
33.9
200
P4SMA9.1A
P4SMA9.1CA
9V1A
9V1C
7.78
8.65~9.55
1
13.4
30.6
50
P4SMA10A
P4SMA10CA
10A
10C
8.55
9.50~10.50
1
14.5
28.3
10
P4SMA11A
P4SMA11CA
11A
11C
9.40
10.50~11.60
1
15.6
26.3
5
P4SMA12A
P4SMA12CA
12A
12C
10.20
11.40~12.60
1
16.7
24.6
5
P4SMA13A
P4SMA13CA
13A
13C
11.10
12.40~13.70
1
18.2
22.5
1
P4SMA15A
P4SMA15CA
15A
15C
12.80
14.30~15.80
1
21.2
19.3
1
P4SMA16A
P4SMA16CA
16A
16C
13.60
15.20~16.80
1
22.5
18.2
1
P4SMA18A
P4SMA18CA
18A
18C
15.30
17.10~18.90
1
25.2
16.1
1
P4SMA20A
P4SMA20CA
20A
20C
17.10
19.00~21.00
1
27.7
14.8
1
P4SMA22A
P4SMA22CA
22A
22C
18.80
20.90~23.10
1
30.6
13.4
1
P4SMA24A
P4SMA24CA
24A
24C
20.50
22.80~25.20
1
33.2
12.3
1
P4SMA27A
P4SMA27CA
27A
27C
23.10
25.70~28.40
1
37.5
10.9
1
P4SMA30A
P4SMA30CA
30A
30C
25.60
28.50~31.50
1
41.4
9.9
1
P4SMA33A
P4SMA33CA
33A
33C
28.20
31.40~34.70
1
45.7
9.0
1
Revision:17-Feb-16
www.brightking.com
P4SMA SERIES
Part Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
P4SMA36A
P4SMA36CA
36A
36C
30.80
34.20~37.80
1
49.9
8.2
1
P4SMA39A
P4SMA39CA
39A
39C
33.30
37.10~41.00
1
53.9
7.6
1
P4SMA43A
P4SMA43CA
43A
43C
36.80
40.90~45.20
1
59.3
6.9
1
P4SMA47A
P4SMA47CA
47A
47C
40.20
44.70~49.40
1
64.8
6.3
1
P4SMA51A
P4SMA51CA
51A
51C
43.60
48.50~53.60
1
70.1
5.8
1
P4SMA56A
P4SMA56CA
56A
56C
47.80
53.20~58.80
1
77.0
5.3
1
P4SMA62A
P4SMA62CA
62A
62C
53.00
58.90~65.10
1
85.0
4.8
1
P4SMA68A
P4SMA68CA
68A
68C
58.10
64.60~71.40
1
92.0
4.5
1
P4SMA75A
P4SMA75CA
75A
75C
64.10
71.30~78.80
1
103.0
4.0
1
P4SMA82A
P4SMA82CA
82A
82C
70.10
77.90~86.10
1
113.0
3.6
1
P4SMA91A
P4SMA91CA
91A
91C
77.80
86.50~95.50
1
125.0
3.3
1
P4SMA100A
P4SMA100CA
100A
100C
85.50
95.00~105.00
1
137.0
3.0
1
P4SMA110A
P4SMA110CA
110A
110C
94.00
105.00~116.00
1
152.0
2.7
1
P4SMA120A
P4SMA120CA
120A
120C
102.00
114.00~126.00
1
165.0
2.5
1
P4SMA130A
P4SMA130CA
130A
130C
111.00
124.00~137.00
1
179.0
2.3
1
P4SMA150A
P4SMA150CA
150A
150C
128.00
143.00~158.00
1
207.0
2.0
1
P4SMA160A
P4SMA160CA
160A
160C
136.00
152.00~168.00
1
219.0
1.9
1
P4SMA170A
P4SMA170CA
170A
170C
145.00
162.00~179.00
1
234.0
1.8
1
P4SMA180A
P4SMA180CA
180A
180C
154.00
171.00~189.00
1
246.0
1.7
1
P4SMA200A
P4SMA200CA
200A
200C
171.00
190.00~210.00
1
274.0
1.5
1
P4SMA220A
P4SMA220CA
220A
220C
185.00
209.00~231.00
1
328.0
1.3
1
P4SMA250A
P4SMA250CA
250A
250C
214.00
237.00~263.00
1
344.0
1.2
1
P4SMA300A
P4SMA300CA
300A
300C
256.00
285.00~315.00
1
414.0
1.0
1
P4SMA350A
P4SMA350CA
350A
350C
300.00
332.00~368.00
1
482.0
0.9
1
P4SMA400A
P4SMA400CA
400A
400C
342.00
380.00~420.00
1
548.0
0.8
1
P4SMA440A
P4SMA440CA
440A
440C
376.00
418.00~462.00
1
602.0
0.7
1
P4SMA480A
P4SMA480CA
480A
480C
408.00
456.00~504.00
1
658.0
0.6
1
P4SMA510A
P4SMA510CA
510A
510C
434.00
485.00~535.00
1
698.0
0.6
1
P4SMA530A
P4SMA530CA
530A
530C
450.00
503.50~556.50
1
725.0
0.6
1
P4SMA540A
P4SMA540CA
540A
540C
459.00
513.00~567.00
1
740.0
0.5
1
P4SMA550A
P4SMA550CA
550A
550C
467.00
522.50~577.50
1
760.0
0.5
1
Notes: For bidirectional type having VRWM of 10V and less, the IR limit is double.
Revision:17-Feb-16
www.brightking.com
P4SMA SERIES
Ratings and Characteristic Curves (TA=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
100
80
60
40
50
75
100
125
150
175
TA-Ambient Temperature (℃)
Figure 3. Pulse Waveform
150
tr=10µs
Figure 4. Typical Junction Capacitance
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
Peak Value IPPM
100
Half Value IPPM (IPPM/2)
50
10/1000µs Waveform
as defined by R.E.A
td
2.0
3.0
4.0
t-Time (ms)
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
PM(AV), Steady State Power Dissipation (W)
Figure 5. Steady State Power Dissipation Derating
Curve
Revision:17-Feb-16
www.brightking.com
P4SMA SERIES
Recommended Soldering Conditions
Reflow Soldering
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
20-40 seconds
6℃/second max.
8 minutes max.
Marking Code
Revision:17-Feb-16
www.brightking.com
P4SMA SERIES
Part Number Code
Packaging
Tape
7” Reel
Symbol
Dimension (mm)
W
12.00±0.20
P0
4.00±0.10
P1
4.00±0.10
P2
2.00±0.10
D0
Φ1.5±0.10
D1
Φ1.5±0.10
E
1.75±0.10
F
5.50±0.05
A0
2.79±0.10
B0
5.33±0.10
K0
2.55±0.15
T
0.25±0.05
D2
Φ178.0±2.0
D3
Φ50.0Min.
D4
Φ13.0±0.5
W1
16.0±2.0
Quantity: 1000PCS
13” Reel
D5
Φ330.0±2.0
D6
Φ13.5±0.5
H
2.5±1.0
W2
16.0±2.0
Quantity: 5000PCS
Revision:17-Feb-16
www.brightking.com
很抱歉,暂时无法提供与“P4SMA6.8CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.32890
- 500+0.22000
- 2500+0.19140
- 5000+0.17380
- 国内价格
- 10+0.38276
- 100+0.31018
- 300+0.27389
- 1000+0.24668
- 5000+0.22032
- 国内价格
- 10+0.35086
- 100+0.28433
- 1000+0.22612
- 2000+0.22273
- 5000+0.20196
- 国内价格
- 10+0.43632
- 100+0.36116
- 300+0.32357
