LGA0307-102KP52E
LGA0307-102KP52E
    FH(风华)
    AXIAL_D2.8X7MM_TM
    色环电感 1mH 40mA ±10% 33Ω AXIAL_2.8X7MM_TM
LGA0307-102KP52E 数据手册
LGA LGA TYPE COLOR CODE INDUCTORS HOW TO ORDER FOR EXAMPLE LGA 0307 A B - 220 K P 52 C D E F A B Body Dimensions(mm) Product type LGA Axial color code inductor Type Dmax Lmax 0204 2.3 4.2 0307 2.8 7.0 0410 4.0 10.5 0510 5.0 10.5 C Nominal lnductance( H D Tolerance The first two digits are significant, and the third digit is number of zero J 5% K 10% M 20% For example 101=100 H 5R6=5.6 H R22=0.22 H F Lead config uration E Tape& reel Packaging style P Tape& reel T F L VK 52 Tape width 07 Reel 10 Formed lead Axial 12 Straight lead formed 15 Bent lead formed K Bent lead K formed 17 Bulk V Tape width 05 Ammo 20 156 26 26 52 5.08mm Formed lead pitch 7.5mm Formed lead pitch 10.0mm Formed lead pitch 12.5mm Formed lead pitch 15.0mm Formed lead pitch 17.5mm Formed lead pitch 20.0mm Formed lead pitch LGA LGA TYPE COLOR CODE INDUCTORS EXTERNAL DIMENSIONS Dimensions (mm) Type D L t d LGA0204 2.3 4.2 t=5.08 t=7.50 0.6 0.6 0.50 0.05 LGA0307 2.8 7.0 t=10.0 t=12.5 0.6 0.6 0.50 0.05 H 20 LGA0410 4.0 10.5 t=12.5 t=15.0 t=17.5 t=20.0 0.6 0.6 0.6 0.6 0.60 0.05 10.5 t=15.0 t=17.5 t=20.0 0.6 0.6 0.6 0.60 0.05 44 LGA0510 5.0 157 5 (V type) K (VK type) MARKING Nominal inductance Tolerance 1 colorzone 2 colorzone 3 colorzone 1 digit 2 digit 3 digit x10 0 (1) Black 0 0 Brown 1 1 1 x10 (10) Red 2 2 2 x10 (100) Orange 3 3 3 x10 (1000) Yellow 4 4 4 x10 (10000) Green 5 5 x10 5 (100000) Blue 6 6 Purple 7 7 Gray 8 8 White 9 9 Gold / / -1 x10 (0.1) Silver / / x10 -2 (0.01) 4 color zone M 20% J 5% K 10% For example: 22 H, 5% : + + + ; If nominal inductance&tolerance is22 H, 5%,respectively,red+red+black+gold should be marked. 1.0 H, 10% : + + + ; If nominal inductance&tolerance is1.0 H, 10%,respectively,brown+black+gold+silver should be marked. 0.22 H, 20% : + + + ; If nominal inductance&tolerance is0.22 H, 20%,respectively,red+red+silver+black should be marked. :LGA0204 , . NOTE:only the first three color zones are marked on the body of LGA0204,due to the small body size. 158 LGA LGA TYPE COLOR CODE INDUCTORS ELECTRICAL CHARACTERISTICS&TEST CONDITIONS LGA0204 LGA0204 TYPE INDUCTORS ELECTRICAL CHARACTERISTICS&TEST CONDITIONS LGA0204 Type Nominal Inductance ( H) Tolerance Q (min) RDC max Test frequency (MHZ ) SRF (MHZ )min Rated current I DC (mA)max LGA0204-R22 0.22 0.40 400 LGA0204-R27 0.27 0.43 380 LGA0204-R33 0.33 0.48 370 LGA0204-R39 0.39 0.51 LGA0204-R47 0.47 0.56 LGA0204-R56 0.56 0.61 320 LGA0204-R68 0.68 0.67 310 LGA0204-R82 0.82 0.74 290 LGA0204-1R0 1.0 LGA0204-1R2 1.2 LGA0204-1R5 1.5 LGA0204-1R8 35 M 350 25.2 150 0.80 20% 330 270 0.90 11 0 260 1.0 80 250 1.8 1.1 60 240 LGA0204-2R2 2.2 2.2 45 230 LGA0204-2R7 2.7 1.3 40 220 LGA0204-3R3 3.3 1.4 38 210 LGA0204-3R9 3.9 1.6 35 200 LGA0204-4R7 4.7 1.7 32 190 LGA0204-5R6 5.6 1.9 30 180 LGA0204-6R8 6.8 2.0 28 175 LGA0204-8R2 8.2 2.2 26 165 LGA0204-100 10 2.5 24 160 LGA0204-120 12 2.5 22 150 LGA0204-150 15 2.8 20 145 LGA0204-180 18 3.1 18 140 LGA0204-220 22 3.4 17 130 LGA0204-270 27 4.3 16 80 LGA0204-330 33 4.7 14 76 LGA0204-390 39 5.2 13 74 LGA0204-470 47 5.8 12 70 LGA0204-560 56 6.4 11 68 LGA0204-680 68 7.2 10 64 LGA0204-820 82 11 . 0 9.5 46 LGA0204-101 100 12.0 9.0 44 LGA0204-121 120 13.0 8.0 42 LGA0204-151 150 16.0 6.0 39 LGA0204-181 180 18.0 5.5 37 LGA0204-221 220 20.0 5.0 35 Test equipment Ambient temperature Ambient humidity HP4285A K 10% 40 J 5% ( HP4286A, HP4287A ) HP4338B 18~25 45%~75% # The products can be customized according to customer requirement. 159 7.96 2.52 0.796 HM9461 HP42841A LGA0307 LGA0307 TYPE INDUCTORS ELECTRICAL CHARACTERISTICS & TEST CONDITIONS LGA0307 Type Nominal Inductance ( H) LGA0307-R22 0.22 0.40 400 LGA0307-R27 0.27 0.43 380 LGA0307-R33 0.33 0.48 370 LGA0307-R39 0.39 0.51 LGA0307-R47 0.47 0.56 LGA0307-R56 0.56 0.61 320 LGA0307-R68 0.68 0.67 310 LGA0307-R82 0.82 0.74 290 LGA0307-1R0 1.0 0.80 LGA0307-1R2 1.2 0.90 144 260 LGA0307-1R5 1.5 1.0 131 250 LGA0307-1R8 1.8 1.1 121 240 LGA0307-2R2 2.2 1.2 11 0 230 LGA0307-2R7 2.7 1.3 100 220 LGA0307-3R3 3.3 1.4 94 210 LGA0307-3R9 3.9 1.6 65 200 LGA0307-4R7 4.7 1.7 56 190 LGA0307-5R6 5.6 1.9 48 180 LGA0307-6R8 6.8 2.0 37 175 LGA0307-8R2 8.2 2.2 25 165 LGA0307-100 10 2.5 21 160 LGA0307-120 12 2.5 19 150 LGA0307-150 15 2.8 17 145 LGA0307-180 18 3.1 13 140 LGA0307-220 22 3.4 9.6 130 LGA0307-270 27 3.8 7.2 125 LGA0307-330 33 4.1 6.3 120 LGA0307-390 39 4.5 6.3 11 5 LGA0307-470 47 4.9 6.3 11 0 LGA0307-560 56 5.3 6.2 105 LGA0307-680 68 5.8 5.7 100 LGA0307-820 82 6.3 5.3 95 LGA0307-101 100 7.0 4.8 90 LGA0307-121 120 13.0 3.8 90 LGA0307-151 150 15.0 3.5 85 LGA0307-181 180 16.0 3.3 80 LGA0307-221 220 17.0 3.0 75 LGA0307-271 270 19.0 2.8 65 LGA0307-331 330 20.0 2.6 60 LGA0307-391 390 22.0 2.4 55 LGA0307-471 470 24.0 2.25 55 LGA0307-561 560 26.0 2.10 50 LGA0307-681 680 28.0 1.95 45 LGA0307-821 820 30.0 1.85 40 LGA0307-102 1000 33.0 1.40 40 HM9461 HP42841A Test equipment Ambient temperature Ambient humidity HP4285A Tolerance Q (min) RDC max 35 40 M 20% 35 K 10% 40 50 J 5% 50 ( HP4286A, HP4287A ) HP4338B 18~25 45%~75% # The products can be customized according to customer requirement. 160 Test frequency (MHZ ) SRF (MHZ )min Rated current I DC (mA)max 350 25.2 150 330 270 7.96 2.52 0.796 LGA LGA TYPE COLOR CODE INDUCTORS LGA0410 LGA0410 TYPE INDUCTORS ELECTRICAL CHARACTERISTICS & TEST CONDITIONS LGA0410 Type Nominal Inductance ( H) Tolerance Q (min) RDC max Test frequency (MHZ ) SRF (MHZ )min Rated current I DC (mA)max LGA0410-R22 0.22 45 0.10 300 1400 LGA0410-R27 0.27 45 0 . 11 270 1320 LGA0410-R33 0.33 45 0.12 250 1280 LGA0410-R39 0.39 45 0.13 230 1200 LGA0410-R47 0.47 45 0.14 220 11 5 0 LGA0410-R56 0.56 45 0.15 200 11 2 2 LGA0410-R68 0.68 45 0.16 190 1030 LGA0410-R82 0.82 45 10.17 172 980 LGA0410-1R0 1.0 45 0.19 157 920 LGA0410-1R2 1.2 50 0.21 144 880 LGA0410-1R5 1.5 50 0.23 131 830 LGA0410-1R8 1.8 55 0.25 121 790 LGA0410-2R2 2.2 55 0.28 11 0 750 LGA0410-2R7 2.7 60 0.30 100 720 LGA0410-3R3 3.3 65 0.34 94 670 LGA0410-3R9 3.9 65 0.37 65 640 LGA0410-4R7 4.7 70 0.39 56 620 LGA0410-5R6 5.6 70 0.43 48 590 LGA0410-6R8 6.8 75 0.48 37 550 LGA0410-8R2 8.2 80 0.52 25 530 LGA0410-100 10 65 0.58 21 500 LGA0410-120 12 50 0.63 19 480 LGA0410-150 15 50 0.72 17 460 LGA0410-180 18 50 0.77 13 430 LGA0410-220 22 50 0.84 9.6 410 LGA0410-270 27 55 0.94 7.2 390 LGA0410-330 33 55 1.03 6.3 370 LGA0410-390 39 50 1.12 6.3 350 LGA0410-470 47 45 1.22 6.3 340 LGA0410-560 56 40 1.34 6.2 320 LGA0410-680 68 40 1.47 5.7 305 LGA0410-820 82 35 1.62 5.3 290 LGA0410-101 100 30 1.80 4.8 275 LGA0410-121 120 55 3.70 3.8 185 LGA0410-151 150 45 4.20 3.5 175 LGA0410-181 180 50 4.60 3.3 165 LGA0410-221 220 55 5.10 3.0 155 LGA0410-271 270 65 5.80 2.8 145 LGA0410-331 330 65 6.40 2.6 137 LGA0410-391 390 65 7.00 2.4 133 LGA0410-471 470 60 7.70 2.25 126 LGA0410-561 560 60 8.85 2.10 120 LGA0410-681 680 55 9.40 1.95 11 3 LGA0410-821 820 55 10.50 1.85 105 LGA0410-102 1000 50 14.00 1.40 100 HP4338B HM9461 HP42841A Test equipment Ambient temperature Ambient humidity HP4285A M 20% K 10% J 5% ( HP4286A, HP4287A ) 18~25 45%~75% # The products can be customized according to customer requirement. 161 25.2 7.96 2.52 0.796 LGA0510 LGA0510 TYPE INDUCTORS ELECTRICAL CHARACTERISTICS & TEST CONDITIONS LGA0510 Type Nominal Inductance ( H) Tolerance Q (min) ( RDC )max Test frequency (MHZ ) SRF (MHZ )min Rated current I DC (mA)max 1.9 126 1.8 120 9.00 1.5 113 45 10.5 1.2 105 45 14.0 1.0 100 LGA0510-471 470 60 7.70 LGA0510-561 560 50 8.50 LGA0510-681 680 55 LGA0510-821 820 0.796 M 20% LGA0510-102 1000 LGA0510-122 1200 40 16.0 0.95 95 LGA0510-152 1500 40 21.6 0.90 90 LGA0510-182 1800 40 24.0 0.85 85 LGA0510-222 2200 40 34.7 0.80 80 K 10% 0.252 LGA0510-272 2700 40 40.0 0.75 75 LGA0510-332 3300 40 59.5 0.70 62 LGA0510-392 3900 40 66.0 0.65 59 J 5% LGA0510-472 4700 40 74.0 0.60 55 LGA0510-562 5600 30 80.0 0.50 40 LGA0510-682 6800 30 85.0 0.45 35 LGA0510-822 8200 30 95.0 0.40 30 LGA0510-103 10000 20 105.0 0.35 25 Test equipment HP4285A ( HP4286A, HP4287A ) HP4338B Ambient temperature 18~25 Ambient humidity 45%~75% # The products can be customized according to customer requirement. 162 0.0796 HM9461 HP42841A LGA LGA TYPE COLOR CODE INDUCTORS PACKAGING STYLE TAPING DIMENSIONS Unit: mm 6 0.5 :26 Tape width Z L Tape style 26 1.0 L1-L2 0.8 Max 1.0 Max :52 Tape width +2.0 1.2 Max 52 -1.0 163 VERTICAL TAPING DIMENSIONS Unit: mm Codel Dim. Tol. P0 P1 P2 d 12.7 12.7 3.85 6.35 0.6 1.0 0.2 0.7 0.4 P 0.1 W W0 W1 W2 18.5 12 9 1.5 h 0 1.0 1.0 1.0 TAPE&REEL PACKAGING DIMENSIONS 164 1.0 1.5 H0 H1 15-20 32.25 0.5 Max D0 I F 4.0 1.4 5 Max 0.8 0.2 LGA LGA TYPE COLOR CODE INDUCTORS AMMO PACKAGING DIMENSIONS DIMENSIONS OF BOX Unit: mm PACKAGING QUANTITY Unit: Pcs # Packaging according to customer's requirement 165
LGA0307-102KP52E
物料型号:LGA系列轴向色码电感器,包括不同尺寸和型号,如LGA0204、LGA0307、LGA0410和LGA0510。
器件简介:轴向色码电感器是一种被动电子元件,用于滤波、信号处理等。
引脚分配:文档中提到了不同的引脚配置,如直脚轴向、直脚成型、弯脚成型等。
参数特性:包括标称电感量、感量偏差、直流电阻、测试频率、自谐频率和额定电流等。
功能详解:电感器的色码标记说明了其电感值和公差,例如黑色代表0,棕色代表1,红色代表2,以此类推,金和银色用于表示公差。
应用信息:电感器可定制以满足客户要求。
封装信息:提供了不同封装的尺寸和特性,如外部尺寸、轴向封装尺寸、立式卷带尺寸、盒带包装尺寸等。
LGA0307-102KP52E 价格&库存
很抱歉,暂时无法提供与“LGA0307-102KP52E”相匹配的价格&库存,您可以联系我们找货
LGA0307-102KP52E
  • 100+0.09097
  • 500+0.08532
  • 1000+0.07684
  • 5000+0.06554
  • 10000+0.05876
库存:9120
LGA0307-102KP52E
  • 20+0.47740
  • 100+0.28470
  • 500+0.19930
  • 2000+0.14240
  • 4000+0.14240
  • 20000+0.14240
库存:4595
