HX6219B332MR
HX6219B332MR
    HX(恒佳兴)
    SOT23-5
    300mA,超低噪声,小封装超快速CMOS LDO稳压器
HX6219B332MR 数据手册
HX6219 300mA,Ultra-low noise, Small Package Ultra-Fast CMOS LDO Regulator General Description Features The 6219 is designed for portable RF and wireless  Ultra-Low-Noise for RF Application applications with demanding performance and space  2.5V- 5.5V Input Voltage Range requirements. The 6219 performance is optimized for  Low Dropout : 220mV @ 300mA battery-powered systems to deliver ultra low noise and  1.8V, 2.8V,3.0V and 3.3V Fixed low quiescent current. The 6219 also works with low-ESR  300mA Output Current, 550mA Peak Current ceramic capacitors, reducing the amount of board space  High PSSR:-76dB at 1KHz necessary for power applications, critical in hand-held  < 0.01uA Standby Current When Shutdown wireless devices. The 6219 consumes less than 0.01µA  Available in SOT23-5 and TSOT23-5 Package in shutdown mode and has fast turn-on time less than  TTL-Logic-Controlled Shutdown Input 50µs. The other features include ultra low dropout voltage,  Ultra-Fast Response in Line/Load transient high output accuracy, current limiting protection, and high   Current Limiting and Thermal Shutdown Protection Quick start-up (typically 50uS) ripple rejection ratio. It is available in the 5-lead of SOT23-5 and TSOT23-5 packages. Typical Application Circuit Ordering Information HX6219 □ □ □ □ □ F: Pb-Free Package Type B3: SOT23-3 B5: SOT23-5 J5: TSOT23-5 Output Voltage Type 18: 1.8V Applications 25: 2.5V  Portable Media Players/MP3 players 28: 2.8V  Cellular and Smart mobile phone 30: 3.0V  LCD 33: 3.3V  DSC Sensor  Wireless Card  Page 1 of 8 HX6219 Pin Configurations Top View VIN 1 GND 2 EN 3 Top View VOUT 5 VIN 4 2 VOUT 1 GND 3 NC TSOT23-5/SOT-23-5 SOT-23-3 Functional Pin Description SOT23-5 SOT23-3 Pin Name Pin Function 1 3 VIN Power Input Voltage. 2 1 GND Ground. 3 - EN Chip Enable (Active High). 4 - NC No Connection. 5 2 VOUT Output Voltage. Page 2 of 8 HX6219 Function Block Diagram Absolute Maximum Ratings  Supply Input Voltage ------------------------------------------------------------------------------------------------------------------------------------- 6.5V  Other Pin Voltage ----------------------------------------------------------------------------------------------------------------------- -0.3V to VIN+0.3V Power Dissipation, PD @ TA = 25°C  T/SOT23-5 ---------------------------------------------------------------------------------------------------------------------------------------------- 500mW  SOT23-3 ------------------------------------------------------------------------------------------------------------------------------------------------ 500mW Package Thermal Resistance  Thermal Resistance(SOT23-5/SOT23) (JA) ------------------------------------------------------------------------------------------------- 195℃/W  Thermal Resistance(SOT23-5/SOT23) (JC) --------------------------------------------------------------------------------------------------- 60℃/W  Maximum Junction Temperature -------------------------------------------------------------------------------------------------------------------- 150℃  Maximum Soldering Temperature (at leads, 10 sec) ------------------------------------------------------------------------------------------ 260℃  Storage Temperature Range ----------------------------------------------------------------------------------------------------------- −65℃ to 150℃ ESD Susceptibility  HBM (Human Body Mode) ----------------------------------------------------------------------------------------------------------------------------- 2KV  MM(Machine-Mode) ------------------------------------------------------------------------------------------------------------------------------------- 200V Page 3 of 8 HX6219 Recommended Operating Conditions  Supply Input Voltage -------------------------------------------------------------------------------------------------------------------------- 2.5V to 5.5V  EN Input Voltage ----------------------------------------------------------------------------------------------------------------------------- 0V toVin+0.3V  Operation Junction Temperature Range --------------------------------------------------------------------------------------------- −40°C to 125°C  Operation Ambient Temperature Range ---------------------------------------------------------------------------------------------- −40°C to 85°C Electrical Characteristics (VIN = VOUT + 1V, CIN = COUT = 1µF, TA = 25° C, unless otherwise specified) Parameter Symbol Test Conditions Min Typ. Max Units Output Voltage Accuracy ΔVOUT IOUT =1mA −2 -- +2 % Output Loading Current ILO AD VEN =VIN , V IN >2.5V Current Limit IL IM RLOAD = 1Ω Quiescent Current IQ VEN ≥1.2V, IOUT =0mA 100 130 Dropout Voltage VDROP IOUT =200mA, V OUT >2.8V 130 200 IOUT =300mA, V OUT >2.8V 220 300 Line Regulation ΔVLINE Load Regulation ΔILOAD 1mA 25mΩ on the Where TJ(MAX) is the maximum operation junction 6219 output ensures stability. The 6219 still works well temperature 125°C, TA is the ambient temperature and with output capacitor of other types due to the wide stable the θJA is the junction to ambient thermal resistance. For ESR range. Output capacitor of larger capacitance can recommended operating conditions specification of 6219, reduce noise and improve load transient response, where TJ(MAX) is the maximum junction temperature of stability, and PSRR. The output capacitor should be the die (125°C) and TA is the maximum ambient located not more than 0.5 inch from the VOUT pin of the temperature. The junction to ambient thermal resistance 6219 and returned to a clean analog ground. (θJA is layout dependent) for SOT23-5 package is Start-up Function Enable Function 195°C/W. PD(MAX) = ( 125°C − 25°C ) / 195 = 500mW The 6219 features an LDO regulator enable/disable The maximum power dissipation depends on operating function. To assure the LDO regulator will switch on, the ambient temperature for fixed TJ(MAX) and thermal EN turn on control level must be greater than 1.4 volts. resistance θJA. The LDO regulator will go into the shutdown mode when the voltage on the EN pin falls below 0.4 volts. For to protecting the system, the 6219 have a quick-discharge function. If the enable function is not needed in a specific application, it may be tied to VIN to keep the LDO regulator in a continuously on state. Page 5 of 8 HX6219 Packaging Information SOT23-5 Page 6 of 8 HX6219 Page 7 of 8 HX6219 SOT23-3 Page 8 of 8
HX6219B332MR 价格&库存
很抱歉,暂时无法提供与“HX6219B332MR”相匹配的价格&库存,您可以联系我们找货
HX6219B332MR
  • 50+0.12000
  • 500+0.10800
  • 5000+0.10000
  • 10000+0.09600
  • 30000+0.09200
  • 50000+0.08960
