HX2301(2.8A)
HX2301(2.8A)
    HX(恒佳兴)
    SOT-23
    P沟道 VDS=20V VGS=±12V ID=2.8A P=1W SOT23
HX2301(2.8A) 数据手册
SOT-23Plastic-Encapsulate Transistors HX2301 MOSFET(P-Channel) FEATURES TrenchFET Power MOSFET MARKING: A1SHB MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Value Units VDS Symbol Drain-Source voltage Parameter -20 V VGS Gate-Source voltage ±12 V ID Drain current -2.8 A PD Power Dissipation 1 W Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55-150 ℃ ELECTRICAL CHARACTERISTICS (Tamb=25℃unless otherwise specified) Parameter Symbol Test conditions MIN Drain-Source Breakdown Voltage V(BR)DSS VGS=0V,ID=-250uA -20 Gate-Threshold Voltage -0.4 Vth(GS) VDS= VGS, ID=-250 uA Gate-body Leakage IGSS VDS=0V, VGS=±12V Zero Gate Voltage Drain Current IDSS VDS=-20V, VGS=0V Drain-Source On-Resistance rDS(ON) Forward Trans conductance gfs TYP MAX UNIT V -0.7 -1.2 V ±100 nA -1 uA VGS=-4.5V, ID=-2.8A 55 85 mΩ VGS=-2.5V, ID=-2A 60 110 mΩ VDS=-5V, ID=-5A 5 S Dynamic Characteristics Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss 560 VDS=-10V, VGS=0V, f=1MHz pF 61 55 Switching Capacitance Turn-on Delay Time td(on) Turn-on Rise Time tr Turn-off Delay Time td(off) Turn-off Fall Time tf Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd VDD=-10V, ID=- 2.8A , VGS=-4.5V RGEN=-60ohm R L=10ohm VDS=-10V, ID=-3A, VGS=-4.5V, 11 nS 6.6 nS 113 nS 46 nS 6.1 nC 1.7 nC 1.3 nC Drain-Source Diode Characteristics Diode Forward Voltage VSD Diode Forward Current Is VGS=0V, ID=-1.3A -1.2 V -1.3 A 1
HX2301(2.8A) 价格&库存
很抱歉,暂时无法提供与“HX2301(2.8A)”相匹配的价格&库存,您可以联系我们找货
