ME2100A33PG
ME2100A33PG
    MICRONE(南京微盟)
    SOT89-3
    VIN=6.5V Vo=3.3V Io=300mA Pd=500mW
ME2100A33PG 数据手册
ME2100 Series Ver 07 ME2100 Series Step-up DC-DC Converter ME2100 Series is a PFM Step-up DC/DC converter IC with low supply current by CMOS process. High frequency noise that occurs during switching is reduced by using advanced circuit designed, output voltage is programmable in 0.1V steps between 2.0~7.0V and maximum frequency is 100KHz(Typ.). A low ripple, high efficiency step-up DC/DC converter can be constructed of ME2100Xxx with only three external components. Also available is a CE(chip enable) function that reduce power dissipation During shut-down mode. ME2100Xxx is suitable for use with battery-powered instruments with low noise and low supply current. Features • Low input current:6µA(Type); • Low ripple and low noise; • Operating voltage range:0.9V~6.5V; • Output voltage range:2.0V~7.0V(step 0.1V); • Output voltage accuracy:±2.5%; • Output Current:if Vin=3.0V and Vout=3.3V,then Iout=300mA; • Low start voltage:≤0.9V(at Iout=1mA); • Maximum oscillator frequency: 100KHz(Typ.); • High Efficiency:85%(Type); • PACKAGE : SOT23-3 , SOT23-5 , SOT89-3 , SOT89-5 Selection Guide ME 21 00 A xx Applications X Power source for battery-powered equipment; • Power source for wireless mouse, wireless keyboard, toys, cameras, camcorders, VCRs, PDAs, and hand-held communication equipment; • Power source for appliances which require higher cell voltage than that of batteries used in the appliances。 • Package P–SOT89 M–SOT23 Feature Code 27–2.7V 30–3.0V 33–3.3 50–5.0V …... Version or Function Product Type Product Series Microne TYPE ME2100Axx ME2100Bxx ME2100Cxx ME2100Dxx ME2100F POSTFIX PACKAGE M3 P M3 P M5 P5 M5 P5 SOT23-3 SOT89-3 SOT23-3 SOT89-3 SOT23-5 SOT89-5 SOT23-5 SOT89-5 M5 SOT23-5 Nanjing Micro One Electronic Inc. SWITCHING TRANSISTOR Build_in Transistor Extemal Transistor Build_in Transistor Extemal Transistor Extemal Transistor Tel: 86-25-84731186 CE FUNCTION FEATURES No Lx No Ext Yes Lx+CE Yes Ext+CE No FB www. microne. com. cn 1(13) ME2100 Series Ver 07 Pin Configuration Pin Assignment ME2100Axx PIN Number SOT23-3 SOT89-3 1 1 3 2 2 3 PIN NAME Vss Vout Lx FUNCTION Ground Output voltage monitor, IC internal power supply Switch ME2100Bxx PIN Number SOT23-3 SOT89-3 1 1 3 2 2 3 ME2100Cxx PIN Number SOT23-5 SOT89-5 4 5 2 2 5 4 1 3 3 1 ME2100Dxx PIN Number SOT23-5 SOT89-5 4 5 2 2 5 4 1 3 3 1 PIN PIN NAME Vss Vout Ext Ground Output voltage monitor, IC internal power supply External switch transistor drive NAME Vss Vout Lx CE NC PIN FUNCTION FUNCTION Ground Output voltage monitor, IC internal power supply Switch Chip enable NC NAME Vss Vout Ext CE NC FUNCTION Ground Output voltage monitor, IC internal power supply External switch transistor drive Chip enable NC ME2100F PIN Number SOT23-5 1 2 3 4 5 Nanjing Micro One Electronic Inc. PIN NAME FB Vdd NC Vss EXT Tel: 86-25-84731186 FUNCTION Feedback internal power supply NC Ground External switch transistor drive www. microne. com. cn 2(13) ME2100 Series Ver 07 Block Diagram Absolute Maximum Ratings PARAMETER VIN Input Voltage Lx Pin voltage EXT Pin voltage CE Pin voltage Lx Pin current EXT Pin current Vdd input voltage Continuous Total SOT23 Power Dissipation SOT89 Operating Ambient Temperature Storage Temperature Soldering temperature and time Nanjing Micro One Electronic Inc. SYMBAL VIN VLX VEXT VCE ILX IEXT Vdd RATINGS 6.5 6.5 -0.3~Vout+0.3 -0.3~Vout+0.3 600 ±30 6.5 UNITS V V V V mA mA V Pd 300 mW Pd 500 mW TOpr Tstg Tsolder -25~+85 -40~+125 260℃, 10s ℃ ℃ Tel: 86-25-84731186 www. microne. com. cn 3(13) ME2100 Series Ver 07 Electrical Characteristics Measuring conditions:Unless otherwise specified , VIN=Vout*0.6,VSS=0V,IOUT=10mA,Topt=25℃。 ME2100A33/C33 Vout=3.3V,Fosc=100kHz SYMB-OL PARAMETER VOUT Output Voltage VIN Vstart Maximum Input Voltage Oscillation Start-up Voltage Vhold Oscillation Hold Voltage IDD1 Supply Current 1 CONDITIONS MIN TYP MAX UNITS 3.218 3.300 3.382 V 6.5 V 0.9 V IOUT=1mA, VIN:0→2V IOUT=1mA, VIN:2→0V No external 0.8 component 0.27 V 35 µA Vout=Vout*0.95, IDD2 Supply Current 2 Vout=Vout+0.5V 5 µA VLX=0.4V, Vout=Vout*0.95 180 mA Maxdty Lx Switching Current Lx Leakage Current Oscillation Frequency Duty Ratio EFFI Efficiency ILX ILXleak Fosc ME2100A50/C50 PARAMETER VOUT Output Voltage Vstart 0.5 µA Vout=set Vout*0.95 100 kHz on(VLX“L”)side 78 % 85 % Vout=5.0V,Fosc=100kHz SYMB-OL VIN Vout=VLX=6V Maximum Input Voltage Oscillation Start-up Voltage Vhold Oscillation Hold Voltage IDD1 Supply Current 1 CONDITIONS MIN TYP MAX UNITS 4.875 5.000 5.125 V 6.5 V 0.9 V IOUT=1mA, VIN:0→2V IOUT=1mA, VIN:2→0V No external component 0.8 0.32 V 60 µA Vout=Vout*0.95, IDD2 Supply Current 2 Vout=Vout+0.5V 6 µA VLX=0.4V, Vout=Vout*0.95 210 mA Maxdty Lx Switching Current Lx Leakage Current Oscillation Frequency Duty Ratio EFFI Efficiency ILX ILXleak Fosc Nanjing Micro One Electronic Inc. Vout=VLX=6V 0.5 µA Vout=set Vout*0.95 100 kHz on(VLX“L”)side 78 % 85 % Tel: 86-25-84731186 www. microne. com. cn 4(13) ME2100 Series Ver 07 ME2100B33/D33 Vout=3.3V,Fosc=100kHz SYMB-OL PARAMETER VOUT Output Voltage VIN Vstart Maximum Input Voltage Oscillation Start-up Voltage Vhold Oscillation Hold Voltage IDD1 Supply Current 1 CONDITIONS MIN TYP MAX UNITS 3.218 3.300 3.382 V 6.5 V 0.9 V IOUT=1mA, VIN:0→2V IOUT=1mA, VIN:2→0V No external 0.8 component 0.27 V 28 µA Vout=Vout*0.95, IDD2 Supply Current 2 Vout=Vout+0.5V 6 µA VLX=0.4V, Vout=Vout*0.95 280 mA Maxdty Lx Switching Current Lx Leakage Current Oscillation Frequency Duty Ratio EFFI Efficiency ILX ILXleak Fosc ME2100B50/D50 PARAMETER VOUT Output Voltage Maximum Input Voltage Oscillation Start-up Voltage Vstart 0.5 µA Vout=set Vout*0.95 100 kHz on(VLX“L”)side 78 % 85 % Vout=5.0V,Fosc=100kHz SYMB-OL VIN Vout=VLX=6V Vhold Oscillation Hold Voltage IDD1 Supply Current 1 CONDITIONS MIN TYP MAX UNITS 4.875 5.000 5.125 V 6.5 V 0.9 V IOUT=1mA, VIN:0→2V IOUT=1mA, VIN:2→0V No external component 0.8 0.32 V 50 µA Vout=Vout*0.95, IDD2 Supply Current 2 Vout=Vout+0.5V 5.8 µA VLX=0.4V, Vout=Vout*0.95 300 mA Maxdty Lx Switching Current Lx Leakage Current Oscillation Frequency Duty Ratio EFFI Efficiency ILX ILXleak Fosc Nanjing Micro One Electronic Inc. Vout=VLX=6V 0.5 µA Vout=set Vout*0.95 100 kHz on(VLX“L”)side 78 % 85 % Tel: 86-25-84731186 www. microne. com. cn 5(13) ME2100 Series Ver 07 ME2100F Vout=3.0V,Fosc=100kHz SYMB-OL PARAMETER VOUT VFB VIN Vstart CONDITIONS MIN TYP MAX UNITS Output Voltage 2.925 3.000 3.075 V Feedback Voltage 1.219 1.25 1.281 V 6.5 V 0.9 V Maximum Input Voltage Oscillation Start-up Voltage IOUT=1mA, VIN:0→2V IOUT=1mA, VIN:2→0V No external Vhold Oscillation Hold Voltage IDD1 Supply Current 1 component Supply Current 2 Lx Switching Current Vout=Vout*0.95 Vout=Vout+0.5V VLX=0.4V, Vout=Vout*0.95 Lx Leakage Current Vout=VLX=6V IDD2 ILX ILXleak Maxdty Oscillation Frequency Duty Ratio EFFI Efficiency Fosc 0.8 0.27 V 31 µA 5 µA 280 mA 0.5 µA Vout=set Vout*0.95 100 kHz on(VLX“L”)side 78 % 86 % Note:1、Diode use Schottky diode such as IN5817 or IN5819 (forward voltage drop:0.2V) 2、Inductor:47μH(r
ME2100A33PG 价格&库存
很抱歉,暂时无法提供与“ME2100A33PG”相匹配的价格&库存,您可以联系我们找货
