ME2108
PFM Step-up DC/DC Converter, ME2108 Series
General Description
Features
ME2108 Series is a PFM Step-up DC/DC converter
IC with low supply current by CMOS process. High
frequency noise that occurs during switching is
reduced by using advanced circuit designed, output
voltage is programmable in 0.1V steps between
2.0~7.0V and maximum frequency is 180KHz(TYP.).
A low ripple, high efficiency step-up DC/DC converter
can be constructed of ME2108Xxx with only three
external components. Also available is a CE(chip
enable) function that reduce power dissipation
During shut-down mode. ME2108Xxx is suitable for
use with battery-powered instruments with low noise
and low supply current.
Typical Application
Low ripple and low noise
Operating voltage range:0.9V~6.5V
Output voltage range:2.0V~7.0V(step 0.1V)
Output voltage accuracy:±2.5%
Output Current:If VIN=3.0V and VOUT=5.0V,then
IOUT=400mA
Low start voltage:≤0.9V(at IOUT =1mA)
Maximum oscillator frequency:180KHz(TYP.)
High Efficiency:85%(TYP.)
Package
Power source for battery-powered equipment
3-pin: SOT23-3、SOT89-3、TO92
Power source for wireless mouse, wireless
keyboard, toys, cameras, camcorders, VCRs,
PDAs, and hand-held communication equipment
Power source for appliances which require higher
cell voltage than that of batteries used in the
appliances
5-pin: SOT23-5
V12.0
www.microne.com.cn
1/14
ME2108
Typical Applications
For use build in transistor
For use external transistor
For use chip enable
For use external transistor&chip enable
Components:
Inductor:33uH(Sumida )
Diode:IN5817、IN5819
Capacitor:47uF/16V(Tantalum Capacitor)
NMOS:MEM2302、AAT9460、XP151、XP161
V12.0
www.microne.com.cn
2/14
ME2108
Selection Guide
ME 21 08 X X X X X G
Environment mark
Package:
P-SOT89-3
M5-SOT23-5
Output Voltage
Function
Product Type
Product Series
Microne
Product series
Switch
Transistor
CE
Function
Featutes
Voltage
Package
ME2108A28PG
Build in
Transistor
No
Lx
2.8
SOT89-3
ME2108A30M3G
Build in
Transistor
No
Lx
3.0
SOT23-3
ME2108A33TG
Build in
Transistor
No
Lx
3.3
TO-92
ME2108B33M3G
External
Transistor
No
Ext
3.3
SOT23-3
ME2108C36M5G
Build in
Transistor
Yes
Lx
3.6
SOT23-5
ME2108D50M5G
External
Transistor
Yes
Ext
5.0
SOT23-5
ME2108F33M5G
External
Transistor
Yes
Ext
3.3
SOT23-5
NOTE:
V12.0
At present ,there are five kinds of voltage value:
2.7V、2.8V、3.0V、3.3V、3.6V、4.0V、5.0V、5.6V。
If you need other voltage and package, please contact our sales staff。
www.microne.com.cn
3/14
ME2108
Pin Configuration
ME2108AXX
PIN Number
Pin Name
Function
1
Vss
Ground
2
3
Vout
3
2
Lx
SOT23-3
SOT89-3
TO92
1
1
3
2
Output voltage monitor, IC internal power supply
Switch
ME2108BXX
PIN Number
Pin Name
Function
1
Vss
Ground
3
2
Vout
2
3
Ext
SOT23-3
SOT89-3
1
External switch transistor drive
ME2108CXX
PIN Number
Pin Name
Function
5
Vss
Ground
2
2
Vout
5
4
Lx
Switch
1
3
CE
Chip enable
3
1
NC
NC
SOT23-5
SOT89-5
4
ME2108DXX
PIN Number
SOT23-5
Pin Name
Function
4
Vss
Ground
2
Vout
5
Ext
1
CE
Chip enable
3
NC
NC
V12.0
www.microne.com.cn
4/14
ME2108
ME2108F
PIN Number
Pin Name
Function
1
FB
Feed Back
2
Vdd
3
NC
NC
4
Vss
Ground
5
EXT
SOT23-5
Block Diagram
Absolute Maximum Ratings
PARAMETER
SYMBAL
RATINGS
UNITS
VIN Input Voltage
VIN
6.5
V
Lx Pin voltage
VLX
6.5
V
EXT Pin voltage
VEXT
-0.3~Vout+0.3
V
CE Pin voltage
VCE
-0.3~Vout+0.3
V
Lx Pin current
ILX
600
mA
EXT Pin current
IEXT
±30
mA
Vdd input voltage
Vdd
6.5
V
SOT23
Pd
300
mW
SOT89
Pd
500
mW
TO92
Pd
500
mW
Operating Ambient Temperature
TOpr
-25~+85
Storage Temperature
Tstg
-40~+125
Soldering temperature and time
Tsolder
260℃, 10s
Continuous Total Power
Dissipation
V12.0
www.microne.com.cn
5/14
ME2108
Electrical Characteristics
Measuring conditions:Unless otherwise specified , VIN=Vout×0.6,VSS=0V,IOUT=10mA,Topt=25℃。
ME2108Axx/Cxx
SYMBOL
Fosc=180kHz
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNITS
Vout×
0.975
Vout
Vout×
1.025
V
0.9
V
VOUT
Output Voltage
Vstart
Oscillation Start-up
Voltage
IOUT=1mA,
VIN:0→2V
0.8
Vhold
Oscillation Hold
Voltage
IOUT=1mA,
VIN:2→0V
0.45
V
IDD1
Supply Current 1
No external component
Vout=Vout×0.95,
50
µA
IDD2
Supply Current 2
Vout=Vout+0.5V
9
µA
ILX
Lx Switching Current
VLX=0.4V,
Vout=Vout×0.95
360
mA
ILXleak
Lx Leakage Current
Vout=VLX=6V
Fosc
Oscillation Frequency
Vout=set Vout×0.95
180
kHz
Maxdty
Duty Ratio
on(VLX“L”)side
84
EFFI
Efficiency
85
ME2108Bxx/Dxx
0.5
µA
Fosc=180kHz
SYMBOL
PARAMETER
VOUT
Output Voltage
Vstart
Voltage
Vhold
MIN
TYP
MAX
UNITS
Vout×
0.975
Vout
Vout×
1.025
V
IOUT=1mA,
VIN:0→2V
0.8
0.9
V
Oscillation Hold
Voltage
IOUT=1mA,
VIN:2→0V
0.45
V
IDD1
Supply Current 1
Vout=Vout×0.95,
80
µA
IDD2
Supply Current 2
Vout=Vout+0.5V
12
µA
ILX
VLX=0.4V,
Vout=Vout×0.95
360
mA
ILXleak
Lx Leakage Current
Vout=VLX=6V
Fosc
Vout=set Vout×0.95
180
kHz
Maxdty
Duty Ratio
on(VLX“L”)side
84
EFFI
Efficiency
85
V12.0
CONDITIONS
0.5
www.microne.com.cn
µA
6/14
ME2108
ME2108F
VFB=3.3V , Fosc=180kHz
SYMBOL
PARAMETER
VFB
Output Feedback
Voltage
Vstart
Voltage
Vhold
CONDITIONS
MIN
TYP
MAX
UNITS
3.22
3.3
3.38
V
IOUT=1mA,
VIN:0→2V
0.8
0.9
V
Oscillation Hold
Voltage
IOUT=1mA,
VIN:2→0V
0.45
V
IDD1
Supply Current 1
Vout=Vout×0.95,
80
µA
IDD2
Supply Current 2
Vout=Vout+0.5V
10
µA
ILX
VLX=0.4V,
Vout=Vout×0.95
360
mA
ILXleak
Lx Leakage Current
Vout=VLX=6V
Fosc
Oscillation
Frequency
Vout=set Vout×0.95
180
kHz
Maxdty
Duty Ratio
on(VLX“L”)side
84
EFFI
Efficiency
85
0.5
µA
Note:1、Diode use Schottky diode such as IN5817 or IN5819 (forward voltage drop:0.2V)
2、Inductor:33μH(r
很抱歉,暂时无法提供与“ME2108C50M5G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.55440
- 200+0.35750
- 1500+0.31130
- 3000+0.27500
- 国内价格
- 10+0.42897
- 100+0.33393
- 600+0.33059
- 1200+0.32398
- 3000+0.31426
- 国内价格
- 5+0.46797
- 50+0.36429
- 150+0.31245
- 500+0.27357
- 国内价格
- 100+0.25481
- 1000+0.24239
