ME2803A18M3G
ME2803A18M3G
    MICRONE(南京微盟)
    SOT23-3
    VIN=8V Pd=300mW
ME2803A18M3G 数据手册
ME2803 Voltage Detectors , ME2803 Series General Description Features ME2803 Series are highly precise, low power  Highly accuracy: ±1% (-VDET=2.2V 以上) consumption voltage detectors, manufactured using  Low power consumption: TYP 0.7uA (VIN=3.5V, -VDET=2.0V)  Detect CMOS technologies. Detect voltage is extremely accurate with minimal temperature drift. CMOS output configurations are available. voltage range : 1.0V~6.5V increments  Operating voltage range:0.7V~7V  Detect voltage temperature characteristics: TYP±100ppm/℃  Typical Application  Microprocessor reset circuitry  Memory battery back-up circuits  Power-on reset circuits  Power failure detection Output configuration: CMOS Package ● 3-pin SOT23-3、SOT89-3、TO-92 Typical Application Circuit V03 in www.microne.com.cn Page 1 of 12 0.1V ME2803 Selection Guide ME 2803X X X X X G Environment mark Package: M3-SOT23-3 T-TO-92 P-SOT89-3 Output Voltage Function Product Type Product Series Microne product series product description ME2803A10M3G VOUT =1.0V;Rising edge detection;Package:SOT23-3 ME2803A A33M3G VOUT =3.3V;Rising edge detection;Package:SOT23-3 NOTE: 1. At present ,there are seventeen kinds of voltage value: 1.0V、1.1V、1.4V、1.6V、1.8V、2.2V、2.5V、2.7V、2.8V、3.0V、3.3V、3.4V、3.5V。 2. If you need other voltage and package, please contact our sales staff. V03 www.microne.com.cn Page 2 of 12 ME2803 Pin Configuration TO-92 SOT-23-3 SOT-89-3 Pin Assignment ME2803XX Pin Number SOT-23-3 SOT-89-3 TO-92 2 1 3 3 1 2 3 1 2 Pin Name Functions GND VOUT VIN Ground Output Voltage Input Voltage Block Diagram Absolute Maximum Ratings PARAMETER SYMBAL RATINGS UNITS VIN Input Voltage VIN 8 V Output Current IOUT 50 mA VOUT GND-0.3~VIN+0.3 V Output Voltage CMOS Continuous Total Power Dissipation SOT-23-3 SOT-89-3 300 Pd TO-92 500 mW 500 Operating Ambient Temperature TOpr -40~+85 ℃ Storage Temperature Tstg -40~+125 ℃ Soldering temperature and time Tsolder 260℃, 10s MM 400 V HBM 4000 V ESD V03 www.microne.com.cn Page 3 of 12 ME2803 Electrical Characteristics (-VDET(S)=1.0V to 6.5V±1% ,Ta=25OC ,unless otherwise noted) Parameter Symbol Detect Voltage -VDET Hysteresis Range VHYS Supply Current ISS Conditions Min. Typ Max. -VDET(S)≦1.5V -VDET(S) ×0.98 -VDET(S) -VDET(S) ×1.02 -VDET(S)>1.5V -VDET(S) ×0.99 -VDET(S) -VDET(S) ×1.01 - 0.03 0.06 0.1 VIN=2V (1.0V-1.5V) - 0.7 1 VIN =3.5V (1.6V-2.0V) - 0.7 1 1.2 2 1.1 2 1.0 2 VIN=4.5V (2.1V-3.9V) VIN =6V (4.0V-5.6V) - VIN=7V (5.7V-6.5V) Iout N-ch Units V V uA VDS=0.5V VIN =0.7V 0.01 0.14 -- mA Iout P-ch VDS=0.5V VIN =7V 1.7 3.4 -- mA Operating voltage VIN - 0.7 - 7 V Responding time tpLH 60 us Temperature characteristics   VDET Ta  VDET ±350 ppm/℃ Output Current Ta =-40℃ ~ 85℃ - ±100 Note: 1、-VDET(S) :Specified Detection Voltage value 2、-VDET :Actual Detection Voltage value 3、Release Voltage:+VDET=-VDET+VHYS V03 www.microne.com.cn Page 4 of 12 ME2803 Functional Description: 1、 When input voltage (VIN) rises above detect voltage (–VDET), output voltage (VOUT) will be equal to VIN. 2、 When input voltage (VIN) falls below detect voltage (–VDET), output voltage (VOUT) will be equal to the ground voltage (GND) level. 3、 When input voltage (VIN) falls to a level below that of the minimum operating voltage (VMIN), output will become unstable. In this condition, VIN will equal the pulled-up output (should output be pulled-up.) 4、 When input voltage (VIN) rises above the ground voltage (GND) level, output will be unstable at levels below the minimum operating voltage (VMIN). Between the VMIN and detect release voltage +VDET) levels, the ground voltage (GND) level will be maintained. 5、 When input voltage (VIN) rises above detect release voltage (+VDET), output voltage (VOUT) will be equal to VIN. 6、 The difference between +VDET and –VDET represents the hysteresis range. Timing Chart: ME2803XX: Directions for use: 1、 Please use this IC within the stated maximum ratings. Operation beyond these limits may cause degrading or permanent damage to the device. 2、When a resistor is connected between the VIN pin and the input with CMOS output configurations, oscillation may occur as a result of voltage drops at RIN if load current(IOUT) exists.(refer to the Oscillation Description(1) below) 3、When a resistor is connected between the VIN pin and the input with CMOS output configurations, oscillation may occur as a result of through current at the time of voltage release even if load current(IOUT) does not exist. (refer to the Oscillation Description(2) below) 4、With a resistor connected between the VIN and the input, detect and release voltage will rise as a result of the IC’s supply current flowing through the VIN pin. 5、In order to stabilize the IC’s operations, please ensure that VIN pin’s input frequency’s rise and fall times are more than several u Sec/V. V03 www.microne.com.cn Page 5 of 12 ME2803 Oscillation Description: 1、 Output current oscillation with the CMOS output configuration When the voltage applied at IN rises, release operations commence and the detector’s output voltage increase. Load current (IOUT) will flow at RL. Because a voltage drop (RIN*IOUT) is produces at the RIN resistor, located between the input (IN) and the VIN pin. The load current will flow via the IC’s pin. The voltage drop will also lead to a fall in the voltage level at the VIN pin. When the VIN pin voltage level falls below the detect voltage level, detect operations will commence. Fllowing detect operations, load current flow will cease and since voltage drop at R IN will disapper, the voltage level at the VIN pin will rise and release operations will begin over again. Oscillation may occur with this “release-detect-release” repetition. Further, this condition will also appear via means of a similar mechanism during detect operations. 2、 Oscillation as a result of through current Since the ME2803 series are CMOS IC’s, through current will flow when the IC’s internal circuit switching operates (during release and detect operations). Consequently, oscillation is liable to occur as a result of drops in voltage at the through current’s resistor (RIN) during release voltage operations.(refer to diagram 2) since hysteresis exists during detect operations, oscillation is unlikely to occur. V03 www.microne.com.cn Page 6 of 12 ME2803 Type Characteristics 1、SUPPLY CURRENT VS. AMBIENT TEMPERATURE VIN=2V,-VDET=1.1V VIN=3V,-VDET=2.2V Iss VS Temp I ss VS T E M P Iss (uA) Iss (uA) 1 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 -15 7 20 30 40 50 60 70 80 90 100 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 - 1 6 10 20 30 40 50 60 70 80 90 100 T E M P℃) ( Temp (℃) 2、SUPPLY CURRENT VS. INPUT VOLTAGE -VDET=1.1V (T=25℃) -VDET=2.2V (T=25℃) Iss VS VIN I s s VS VI N 1.6 1.2 Iss (uA) 1.4 Iss (uA) 1.2 1 0.8 0.6 0.4 1 0.8 0.6 0.4 0.2 0.2 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 VIN (V) V03 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 VI N ( V) www.microne.com.cn Page 7 of 12 5.5 6 ME2803 3、DETECT,RELEASE VOLTAGE VS. AMBIENT TEMPERATURE -VDET=1.1V -VDET=2.2V VDET VS TEMP 1.25 2.35 1.2 2.3 VDET (V) VDET (V) VDET VS TEMP 1.15 1.1 1.05 -VDET +VDET 2.25 2.2 2.15 1 +VDET -VDET 2.1 -15 7 20 30 40 50 60 70 80 90 100 110 120 -16 10 20 30 40 TEMP (℃) VDS=0.5V 7 0.8 6 T=100℃ Iout (mA) Iout (mA) 80 90 100 110 120 Iout (N) VS VIN 1 T=-15℃ 70 -VDET=2.2V Iout(N) VS VIN 0.4 60 TEMP (℃) 4、 N-ch OUTPUT CURRENT VS. INPUT VOLTAGE VDS=0.5V -VDET=1.1V 0.6 50 T=25℃ 0.2 T=-15℃ 5 T=23℃ 4 T=85℃ 3 2 1 0 0 0.2 0.4 0.6 0.8 1 0.2 0.5 0.7 VIN (V) 1 1.2 1.7 2.2 VIN (V) 5、P-ch OUTPUT CURRENT VS. INPUT VOLTAGE VDS=0.5V -VDET=1.1V VDS=0.5V -VDET=2.2V I o u t ( P ) VS VI N I o u t ( P ) VS VI N 1.5 3.5 (mA) (mA) 3 2.5 Iout 3.5 Iout 2 1 0.5 T = 1 0℃0 T = 2℃ 5 T = - 1℃5 3 2.5 2 1.5 1 T = 8℃ 5 0.5 T = 2℃ 3 T = - 1℃5 4 4.5 0 0 1.2 1.5 2 2.5 3 3.5 5 2.5 2.8 3.2 3.5 VI N ( V) VI N ( V) V03 2.3 www.microne.com.cn Page 8 of 12 5 ME2803 Packaging Information ● SOT23-3 DIM Millimeters Inches Min Max Min Max A 2.7 3.1 0.1063 0.122 B 1.7 2.1 0.0669 0.0827 b 0.35 0.5 0.0138 0.0197 C 1.0 1.2 0.0394 0.0472 c 0.1 0.25 0.0039 0.0098 d 0.2 - 0.0079 - E 2.6 3.0 0.1023 0.1181 e 1.5 1.8 0.059 0.0708 V03 www.microne.com.cn Page 9 of 12 ME2803 ● SOT89-3 DIM Millimeters Inches Min Max Min Max A 1.4 1.6 0.0551 0.0630 A1 1.4 1.6 0.0551 0.0630 a 0.36 0.48 0.0142 0.0189 b 0.41 0.53 0.0161 0.0209 c 0.36 0.48 0.0142 0.0189 d 1.4 1.75 0.0551 0.0689 B 0.38 0.43 0.015 0.0169 C 1.4 1.6 0.0551 0.0630 D 4.4 4.6 0.1732 0.181 E - 4.25 - 0.1673 e 2.4 2.6 0.0945 0.1023 L1 0.4 - 0.0157 - L2 0.8 - 0.0315 - V03 www.microne.com.cn Page 10 of 12 ME2803 ● TO-92 DIM V03 Millimeters Inches Min Max Min Max A 3.4 3.8 0.13386 0.1496 B 0.3 0.5 0.0118 0.0197 C 4.4 4.8 0.1732 0.189 D 4.4 4.8 0.1732 0.189 E 0.9 1.5 0.0354 0.059 e 1.17 1.37 0.046 0.0539 e1 2.39 2.69 0.094 0.1059 L 12 16 0.4724 0.6299 www.microne.com.cn Page 11 of 12 ME2803      The information described herein is subject to change without notice. Nanjing Micro One Electronics Inc is not responsible for any problems caused by circuits or diagrams described herein whose related industrial properties, patents, or other rights belong to third parties. The application circuit examples explain typical applications of the products, and do not guarantee the success of any specific mass-production design. Use of the information described herein for other purposes and/or reproduction or copying without the express permission of Nanjing Micro One Electronics Inc is strictly prohibited. The products described herein cannot be used as part of any device or equipment affecting the human body, such as exercise equipment, medical equipment, security systems, gas equipment, or any apparatus installed in airplanes and other vehicles, without prior written permission of Nanjing Micro One Electronics Inc. Although Nanjing Micro One Electronics Inc exerts the greatest possible effort to ensure high quality and reliability, the failure or malfunction of semiconductor products may occur. The user of these products should therefore give thorough consideration to safety design, including redundancy, fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community damage that may ensue. V03 www.microne.com.cn Page 12 of 12
ME2803A18M3G 价格&库存
很抱歉,暂时无法提供与“ME2803A18M3G”相匹配的价格&库存,您可以联系我们找货
