ME301CPG
ME301CPG
    MICRONE(南京微盟)
    SOT89-3
    VIN=6.5V Vo=3V Pd=500mW
ME301CPG 数据手册
MEXX1C PFM Step-up DC/DC Converter, MEXX1C Series General Description Features MEXX1C Series is a PFM Step-up DC/DC converter IC with low supply current by CMOS process. High frequency noise that occurs during switching is reduced by using advanced circuit designed, output voltage is programmable in 0.1V steps between 2.0~7.0V and maximum frequency is 100KHz (TYP.). A low ripple, high efficiency step-up DC/DC converter can be constructed of MEXX1C with only three external components. Also available is a CE(chip enable) function that reduce power dissipation During shut-down mode. MEXX1C is suitable for use with battery-powered instruments with low noise and low supply current. Selection Guide l l l l l l l l l l Typical Application l Power source for battery-powered equipment l Power source for wireless mouse, wireless keyboard, toys, cameras, camcorders, VCRs, PDAs, and hand-held communication equipment Power source for appliances which require higher cell voltage than that of batteries used in the appliances l V5.0 Low input current:6µA(TYP.) Low ripple and low noise Operating voltage range:0.9V~6.5V Output voltage range:2.0V~7.0V(step 0.1V) Output voltage accuracy:±2.5%; Output Current: if VIN=3.0V and VOUT=3.3V,then IOUT=250mA Low start voltage:
ME301CPG 价格&库存
很抱歉,暂时无法提供与“ME301CPG”相匹配的价格&库存,您可以联系我们找货
