ME6207C33M5G
ME6207C33M5G
    MICRONE(南京微盟)
    SOT23-5
    输出类型:固定 输出极性:正 最大输入电压:6.5V 输出电压:3.3V 输出电流(最大值):800mA 电源纹波抑制比(PSRR):65dB@(1kHz)
ME6207C33M5G 数据手册
ME6207 High Output Current LDO Regulator , High PSRR , Low Dropout, ME6207 Series General Description Features The ME6207 Series is a positive voltage regulator with a low dropout voltage,high output voltage accuracy,and low crrent consumption developed based on CMOS technology. A built-in low on-resistance transistor provides a low dropout voltage and large output current, a built-in overcurrent protector prevents the load current from exceeding the current capacitance of the output transistor. An ON/OFF circuit ensures a long battery life. Compared with the voltage regulators using the conventional CMOS process, a larger variety of capacitors are available, including small ceramic capacitors. Typical Application            Maximum Output Current: 800 mA (VIN≥VOUT(T)+1.0V) Dropout Voltage: 100mV@ IOUT =300mA,VOUT =5.0V Operating Voltage Range: 2V~6.5V Highly Accuracy: ±1% Low Current Consumption: During Operation: 82uA(TYP.) During Shutdown:0.1uA(TYP.) High Ripple Rejection: 65dB@1KHz (ME6207C50) Line Regulation: 0.05%(TYP.) Package Power supply for DVD and CD-ROM drives Power supply for personal communication device Power supply for battery-powered devices Power supply for note PCs   3-pin SOT89-3 5-pin SOT89-5,SOT23-5,TO252-5 Typical Application Circuit V04 www.microne.com.cn Page 1 of 15 ME6207 Selection Guide V04 product series product description ME6207A50PG VOUT =5.0V;no enable function;Package:SOT89-3 ME6207C18M5G VOUT =1.8V; have enable function;Package:SOT23-5 ME6207C33M5G VOUT =3.3V; have enable function;Package:SOT23-5 ME6207C50K5G VOUT =5.0V; have enable function;Package:TO252-5 ME6207C50M5G VOUT =5.0V; have enable function;Package:SOT23-5 ME6207C50P5G VOUT =5.0V; have enable function;Package:SOT89-5 www.microne.com.cn Page 2 of 15 ME6207 Pin Configuration SOT-89-5 SOT23-5 SOT89-3 TO252-5 Pin Assignment ME6207AXX Pin Number Pin Name Functions 1 VSS Ground 2 VIN Input Voltage 3 VOUT Output Voltage SOT89-3 ME6207CXX Pin Number Pin Name Functions 5 CE ON / OFF Control 2 3 VSS Ground 3 4 1 NC No Connect 4 1 2 VIN Input Voltage 5 5 4 VOUT Output Voltage SOT89-5 SOT23-5 TO252-5 1 3 2 V04 www.microne.com.cn Page 3 of 15 ME6207 Block Diagram Absolute Maximum Ratings Parameter Symbol Ratings Units Input Voltage VIN 7.0 V Output Current IOUT 800 mA Output Voltage VOUT Vss-0.3~VIN +0.3 V CE Pin Voltage VCE Vss-0.3~VIN +0.3 V 1000 mW 1000 mW 250 mW 500 mW SOT-89-5 Power Dissipation TO252-5 SOT-23-5 PD SOT-89-3 Operating Temperature Range TOPR -40~+85 ℃ Storage Temperature Range TSTG -40~+125 ℃ V04 www.microne.com.cn Page 4 of 15 ME6207 Electrical Characteristics (VIN= VOUT (T) +1.0V,VCE = VIN,CIN=CL=10uF,Ta=25OC ,unless otherwise noted) Parameter Output Voltage Symbol VOUT(E) (Note 2) Input voltage VIN Maximum Output IOUTMAX Current (Note 4) Load Regulation Line Regulation Dropout Voltage Current consumption during operation Current consumption during shutdown Conditions IOUT=100mA Min. X 0.99 VOUT (T) (Note 1) Max. Units X 1.01 V 2.0 - 6.5 V VIN≥ VOUT (T) +1.0V - 800 - mA ∆VOUT 1mA≤IOUT≤300mA - 10 100 mV ∆VOUT IOUT =100mA - 0.05 0.3 %/V 1.8V≤VOUT (T)≤2.0V - 200 260 3.0V≤VOUT (T)≤5.5V - 100 180 - 82 160 μA - 0.1 1.0 μA 1.5 - - V - - 0.3 V ∆VIN • VOUT VDIF (Note 3) ISS1 ISS2 - Typ. VOUT (T) +0.5V ≤VIN≤6.5V IOUT =300mA mV CE pin = ON, no load CE pin = OFF, no load CE “High” Voltage VCEH Start up,RL=1.0KΩ CE “Low” Voltage VCEL Shut down, RL=1.0KΩ CE “High” Current ICEH VIN=6.5V,VCE=6.5V -0.1 - 0.1 μA CE “Low” Current ICEL VIN=6.5V,VCE=0V -0.1 - 0.1 μA - 70 - VIN=6V , △Vrip=0.5Vrms, Ripple Rejection Rate |RR| IOUT=100mA, f=1kHz Short-circuit current Ishort 1.8V≤VOUT (T)≤2.0V dB 3.0V≤VOUT (T)≤5.5V CE pin = ON, VOUT = 0 V - 65 - - 350 - mA Note : 1. VOUT (T) :Specified Output Voltage 2.VOUT (E) :Effective Output Voltage ( le. The output voltage when “VOUT (T)+1.0V”is provided at the Vin pin while maintaining a certain Iout value.) 3.VDIF:VIN1 –VOUT (E)’ VIN1 :The input voltage when VOUT(E)’ appears as input voltage is gradually decreased. VOUT (E)’=A voltage equal to 98% of the output voltage whenever an amply stabilized Iout {VOUT (T)+1.0V} is input. 4. IOUTMAX:Due to restrictions on the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation of the package when the output current is large.This specification is guaranteed by design. V04 www.microne.com.cn Page 5 of 15 ME6207 Operation 1. Basic operation Figure 1 shows the block diagram of the ME6207 Series. The error amplifier compares the reference voltage (Vref) with Vfb, which is the output voltage resistance-divided by feedback resistors Rs and Rf. It supplies the output transistor with the gate voltage necessary to ensure a certain output voltage free of any fluctuations of input voltage and temperature. Figure 1 2. Output transistor The ME6207 Series uses a low on-resistance P-channel MOS FET as the output transistor.Be sure that VOUT does not exceed VIN + 0.3 V to prevent the voltage regulator from being damaged due to inverse current flowing from VOUT pin through a parasitic diode to VIN pin. 3. Shutdown pin (CE pin) This pin starts and stops the regulator. When the CE pin is set to the shutdown level, the operation of all internal circuits stops, and the built-in P-channel MOS FET output transistor between the VIN pin and VOUT pin is turned off to substantially reduce the current consumption. The VOUT pin becomes the VSS level due to the internally divided resistance of several hundreds kΩ between the VOUT pin and VSS pin. Since the CE pin is neither pulled down nor pulled up internally, do not use it in the floating state. In addition, note that the current consumption increases if a voltage of 0.3 V to VIN − 0.3 V is applied to the CE pin. Table 1 CE Pin Internal Circuits VOUT Pin Voltage Current Consumption “H” Power on Operating Set value ISS1 “L” Power off Stopped Vss level ISS2 V04 www.microne.com.cn Page 6 of 15 ME6207 Precautions 1. Wiring patterns for the VIN, VOUT and GND pins should be designed so that the impedance is low.When mounting an output capacitor between the VOUT and VSS pins (CL) and a capacitor for stabilizing the input between VIN and VSS pins (CIN), the distance from the capacitors to these pins should be as short as possible. 2.Note that the output voltage may increase when a series regulator is used at low load current (1.0 mA or less). 3.Generally a series regulator may cause oscillation, depending on the selection of external parts. The following conditions are recommended for this IC. However, be sure to perform sufficient evaluation under the actual usage conditions for selection, including evaluation of temperature characteristics. Input capacitor (CIN): 4.7 µF or more Output capacitor (CL): 4.7 µF or more Equivalent series resistance (ESR): 0.5 Ω or less 4. The voltage regulator may oscillate when the impedance of the power supply is high and the input capacitor is small or an input capacitor is not connected. 5.The application conditions for the input voltage, output voltage, and load current should not exceed the package power dissipation. 6. Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. 7. SII claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. V04 www.microne.com.cn Page 7 of 15 ME6207 Type Characteristics (1) Input VoltageVS.Output Voltage(Ta = 25 °C) ME6207C50P5G VOUT-VIN 5.1 VOUT(V) 5.0 4.9 300mA 4.8 100mA A 10mA 4.7 4.6 1mA 4.5 4.5 5.0 5.5 6.0 6.5 7.0 VIN(V) (2) Output Current VS.Droput Voltage(VIN= VOUT (T) +1.0V,Ta = 25 °C) ME6207C50P5G VDROP-IOUT 350 300 VDROP(V) 250 200 150 100 50 0 100 200 300 400 500 600 700 800 IOUT(mA) (3) Input Voltage VS. Current Consumption(Ta = 25 °C) ME6207C50P5G I SS1-VIN 250 ISS1(uA) 200 150 100 50 0 1 2 3 4 5 6 7 VIN(V) V04 www.microne.com.cn Page 8 of 15 ME6207 (4) Input VoltageVS.Output Voltage(Ta = 25 °C) ME6207C33M5G Output Voltage(V) Vin VS. Vout 3.6 3.4 3.2 1mA 3 2.8 10mA 2.6 100mA 2.4 300mA 2.2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 7 7.5 Input Voltage(V) (5) Output Current VS.Droput Voltage(VIN= VOUT (T) +1.0V,Ta = 25 °C) ME6207C33M5G Vdrop VS Iout 350 DROP Voitage(mV) 300 250 200 150 100 50 0 0 100 200 300 400 500 600 700 800 Output Voltage(V) (6) Output Current VS. Current Consumption(VIN= VOUT (T) +1.0V,Ta = 25 °C) ME6207C33M5G Vin VS Iss Current Consumption(uA) 140 120 100 80 60 40 20 0 0 1 2 3 4 5 6 7 Input Voltage(V) V04 www.microne.com.cn Page 9 of 15 ME6207 (7) Output Current VS. Output Voltage(VIN= VOUT (T) +1.0V,Ta = 25 °C) ME6207C33M5G Vout VS.Iout 3.35 Output Voltage(V) 3.3 3.25 3.2 3.15 3.1 3.05 3 0 V04 100 200 300 400 500 Output Current(mA) www.microne.com.cn 600 700 800 Page 10 of 15 ME6207 Package Information: ● SOT89-5 Millimeters Inches DIM Min Max Min Max A 4.4 4.6 0.173 0.181 a 0.5 0.62 0.02 0.024 B 1.63 1.83 0.064 0.072 b 0.44 0.54 0.017 0.021 C Type:0.059 D 2.4 2.6 0.094 0.102 E 1.4 1.6 0.054 0.063 F 0.35 0.43 0.013 0.017 L 3.95 4.25 0.155 0.167 r V04 Type:1.5 Type:80 www.microne.com.cn Type:80 Page 11 of 15 ME6207 ● SOT23-5 Millimeters Inches DIM Min Max Min Max A 0.9 1.45 0.0354 0.0570 A1 0 0.15 0 0.0059 A2 0.9 1.3 0.0354 0.0511 B 0.2 0.5 0.0078 0.0196 C 0.09 0.26 0.0035 0.0102 D 2.7 3.10 0.1062 0.1220 E 2.2 3.2 0.0866 0.1181 E1 1.30 1.80 0.0511 0.0708 e 0.95REF 0.0374REF e1 1.90REF 0.0748REF L 0.10 0.60 0.0039 0.0236 a0 00 300 00 300 V04 www.microne.com.cn Page 12 of 15 ME6207 ● SOT89-3 Millimeters Inches DIM Min Max Min Max A 1.4 1.6 0.0551 0.0630 A1 1.4 1.6 0.0551 0.0630 a 0.36 0.48 0.0142 0.0189 b 0.41 0.53 0.0161 0.0209 c 0.36 0.48 0.0142 0.0189 d 1.4 1.75 0.0551 0.0689 B 0.38 0.43 0.015 0.0169 C 1.4 1.6 0.0551 0.0630 D 4.4 4.6 0.1732 0.181 E - 4.25 - 0.1673 e 2.4 2.6 0.0945 0.1023 L1 0.4 - 0.0157 - L2 0.8 - 0.0315 - V04 www.microne.com.cn Page 13 of 15 ME6207 ● TO252-5 V04 www.microne.com.cn Page 14 of 15 ME6207      V04 The information described herein is subject to change without notice. Nanjing Micro One Electronics Inc is not responsible for any problems caused by circuits or diagrams described herein whose related industrial properties, patents, or other rights belong to third parties. The application circuit examples explain typical applications of the products, and do not guarantee the success of any specific mass-production design. Use of the information described herein for other purposes and/or reproduction or copying without the express permission of Nanjing Micro One Electronics Inc is strictly prohibited. The products described herein cannot be used as part of any device or equipment affecting the human body, such as exercise equipment, medical equipment, security systems, gas equipment, or any apparatus installed in airplanes and other vehicles, without prior written permission of Nanjing Micro One Electronics Inc. Although Nanjing Micro One Electronics Inc exerts the greatest possible effort to ensure high quality and reliability, the failure or malfunction of semiconductor products may occur. The user of these products should therefore give thorough consideration to safety design, including redundancy, fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community damage that may ensue. www.microne.com.cn Page 15 of 15
