ME6210
500mA,Low Quiescent, Low Dropout LDO Linear Regulators
General Description
Features
ME6210 series are low quiescent, low-dropout
High output accuracy:± 2%
linear voltage regulators.ME6210 series are based
Input voltage:2V to 18 V
on the CMOS process and allow high voltage
Output voltage:1.5V ~ 5.0V
input .The allow operation voltage as high as 18V.
Ultra-low quiescent current (Typ. = 1.5 µ A)
ME6210 series have short circuit protection
Output Current:Iout = 500mA
(When Vin = 4V and Vout =3V)
function.
Low dropout voltage: 11mV@ Iout =10mA (Typ.
Vout = 3.0V)
Typical
Application
Power source for home electric/electronic
Input good stability:Typ. 0.03% / V
Short-circuit Current::Typ. 50mA
Ceramic capacitor can be used
Package
3-pin SOT89-3,SOT23-3,SOT23,TO92
appliances
Power source for battery-powered devices
Power source for personal communication
devices
V05
Typical Application Circuit
www.microne.com.cn
Page 1 of 12
ME6210
Selection Guide
ME 6210X X X X X G
Environment mark
Package:
P-SOT89-3
M3-SOT23-3
X-SOT23
T-TO92
Output Voltage
Function
Product Type
Product Series
Microne
product series
product description
ME6210A30PG
VOUT =3.0V; Package:SOT89-3
ME6210A28M3G
VOUT =2.8V; Package:SOT23-3
ME6210A33M3G
VOUT =3.3V; Package:SOT23-3
NOTE:
1. At present ,there are five kinds of voltage value: 2.5、2.8V、3.0V、3.3V、3.6V、4.0V、5.0V。
2. If you need other voltage and package, please contact our sales staff。
V05
www.microne.com.cn
Page 2 of 12
ME6210
Pin Configuration
Pin Assignment
ME6210Axx
Pin Number
M3
P
X
T
SOT23-3
SOT89-3
SOT23
TO-92
1
1
1
1
VSS
Ground
2
3
2
3
VOUT
Output
3
2
3
2
VIN
Input
Name
Function
Absolute Maximum Ratings
Parameter
Symbol
Description
Units
Input Voltage
VIN
18
V
Output Current
IOUT
700
mA
Output Voltage
VOUT
Vss-0.3 ~ Vout+0.3
V
SOT23-3
Pd
300
mW
SOT89-3
Pd
500
mW
SOT23
Pd
250
mW
TO-92
Pd
500
mW
Operating Ambient Temperature
TOpr
-25 ~ +85
Storage Temperature
Tstg
-40 ~ +125
Power Dissipation
Lead Temperature
V05
260℃,10sec
www.microne.com.cn
Page 3 of 12
ME6210
Block Diagram
Electrical Characteristics
ME6210A30
(VIN= VOUT+1.0V,CIN=COUT=10uF,Ta=25OC, unless otherwise noted)
Parameter
Output Voltage
Input Voltage
Maximum Output
Current
Load Regulation
Dropout Voltage
(Note 3)
Supply Current
Line Regulations
Temperature coefficient
Short-circuit
V05
Current
Symbol
Conditions
VOUT(E)
IOUT=40mA,
(Note 2)
VIN=Vout+1V
Min.
X 0.98
Typ.
VOUT (T)
(Note 1)
VIN
IOUT _max
∆VOUT
VIN=Vout+1V
VIN=Vout+1V,
1mA≤IOUT≤200mA
Max.
Units
X 1.02
V
18
V
500
mA
12
30
mV
VDIF1
IOUT =10mA
11
14
mV
VDIF2
IOUT =100mA
110
140
mV
VDIF3
IOUT =200mA
220
280
mV
ISS
VIN=Vout+1V
1.5
2.5
μ A
0.03
0.1
%/V
±60
±100
Ppm/℃
50
70
mA
∆VOUT
IOUT =10mA
∆VIN ×VOUT
Vout+1V ≤VIN≤18V
∆VOUT
VIN=Vout+1V ,IOUT =10mA
∆Ta ×VOUT
-40℃≤Ta≤125℃
Ishort
VIN=Vout+1V
www.microne.com.cn
Page 4 of 12
ME6210
ME6210A33
Parameter
Output Voltage
Input Voltage
Maximum Output
Current
Load Regulation
Dropout Voltage
(Note 3)
Supply Current
Line Regulations
Short-circuit
Current
Symbol
Conditions
VOUT(E)
IOUT=40mA,
(Note 2)
VIN=Vout+1V
Min.
X 0.98
Typ.
VOUT (T)
(Note 1)
VIN
IOUT _max
∆VOUT
VIN=Vout+1V
Max.
Units
X 1.02
V
18
V
500
VIN=Vout+1V,
1mA≤IOUT≤200mA
mA
12
30
mV
VDIF1
IOUT =10mA
10
13
mV
VDIF2
IOUT =100mA
100
130
mV
VDIF3
IOUT =200mA
200
260
mV
ISS
VIN=Vout+1V
1.6
2.5
μ A
∆VOUT
IOUT =10mA
∆VIN ×VOUT
Vout+1V ≤VIN≤18V
0.03
0.1
%/V
±60
±100
Ppm/℃
50
70
mA
Typ.
Max.
Units
X 1.02
V
18
V
∆VOUT
∆Ta ×VOUT
-40℃≤Ta≤125℃
Ishort
VIN=Vout+1V
ME6210A50
Parameter
Output Voltage
Input Voltage
Maximum Output
Current
Load Regulation
Dropout Voltage
(Note 3)
Supply Current
Line Regulations
Short-circuit
V05
Current
Symbol
Conditions
VOUT(E)
IOUT=40mA,
(Note 2)
VIN=Vout+1V
Min.
X 0.98
VOUT (T)
(Note 1)
VIN
IOUT _max
∆VOUT
VIN=Vout+1V
VIN=Vout+1V,
1mA≤IOUT≤200mA
500
mA
10
30
mV
VDIF1
IOUT =10mA
8
11
mV
VDIF2
IOUT =100mA
80
110
mV
VDIF3
IOUT =200mA
160
220
mV
ISS
VIN=Vout+1V
1.7
2.5
μ A
∆VOUT
IOUT =10mA
∆VIN ×VOUT
Vout+1V ≤VIN≤18V
0.03
0.1
%/V
∆VOUT
∆Ta ×VOUT
-40℃≤Ta≤125℃
±60
±100
Ppm/℃
Ishort
VIN=Vout+1V
50
70
mA
www.microne.com.cn
Page 5 of 12
ME6210
Note :
1. VOUT (T) :Specified Output Voltage
2.VOUT (E) :Effective Output Voltage ( ie. The output voltage when “VOUT (T)+1.0V”is provided at the Vin pin while
maintaining a certain Iout value.)
3.VDIF:VIN1 –VOUT (E)’
VIN1 :The input voltage when VOUT (E)’ appears as input voltage is gradually decreased.
VOUT (E)’=A voltage equal to 98% of the output voltage whenever an amply stabilized Iout and {VOUT (T)
+1.0V} is input.
Precautions
During the test, if AC/DC power supply and the ceramic chip capacitors collocation is used, there may be
serious voltage spike phenomenon instantaneously. When the power supply access to 15V, the voltage is
rushed to about 30V instantaneously. Because of exceeding the limit voltage of chip, the chip is damaged. If
you string a small resistance of 1 ohm in the input end during the test, the peak phenomenon can be
avoided.
In the test, there is serious burr phenomenon only when the AC/DC power is used with ceramic chip
capacitors. But electrolytic capacitors and tantalum capacitance won't appear above phenomenon. Please
be sure to pay attention to this point when you use AC/DC power.
In normal use, when any type of capacitor is used with battery or the supply of fire power, the above
phenomenon doesn’t occur.
V05
www.microne.com.cn
Page 6 of 12
ME6210
Type Characteristics
(1) Output Voltage VS. Output Current
( Ta = 25 °C,VIN=4V) ME6210A30
(2)Output Voltage VS. Input Voltage
(Ta = 25 °C,Iout=10mA) ME6210A30
Output Voltage VS.Input Voltage
3.4
3.2
3.1
3
2.9
2.8
2.7
2.6
Output Voltage(V)
Output Voltage(V)
Output Voltage VS.Output Current
200
300
400
3
2.6
2.2
1.8
1.4
1
0.6
500
Output Current(mA)
2
4
8
10
12
14
16
18
16
18
Input Voltage(V)
(3)Dropout Voltage VS. Output Current
( Ta = 25 °C) ME6210A30
(4)Supply Current VS. Input Voltage
Dropout Voltage VS.Output Current
Supply Current VS.Input Voltage
2.4
600
Supply Current(uA)
Dropout Voltage(mV)
6
500
400
300
200
100
2
1.6
1.2
0.8
0.4
200
300
400
500
Output Current(mA)
4
6
8
10
12
14
Input Voltage (V)
(5)Output Voltage VS. Temperature(VIN=4V ,Iout=10mA) ME6210A30
Output Voltage VS.Temperature
Output Voltage(V)
3.1
3.05
3
2.95
2.9
2.85
2.8
-40
-20
60
80
100
120
140
160
Temperature(℃)
V05
www.microne.com.cn
Page 7 of 12
ME6210
Packaging Information
● SOT89-3
DIM
Millimeters
Inches
Min
Max
Min
Max
A
1.4
1.6
0.0551
0.0630
A1
1.4
1.6
0.0551
0.0630
a
0.36
0.48
0.0142
0.0189
b
0.41
0.53
0.0161
0.0209
c
0.36
0.48
0.0142
0.0189
d
1.4
1.75
0.0551
0.0689
B
0.38
0.43
0.015
0.0169
C
1.4
1.6
0.0551
0.0630
D
4.4
4.6
0.1732
0.181
E
4.25
0.1673
e
2.4
2.6
0.0945
0.1023
L1
0.4
0.0157
L2
0.8
0.0315
V05
www.microne.com.cn
Page 8 of 12
ME6210
● SOT23-3
DIM
V05
Millimeters
Inches
Min
Max
Min
Max
A
2.7
3.1
0.1063
0.122
B
1.7
2.1
0.0669
0.0827
b
0.35
0.5
0.0138
0.0197
C
1.0
1.2
0.0394
0.0472
c
0.1
0.25
0.0039
0.0098
d
0.2
0.0079
E
2.6
3.0
0.1023
0.1181
e
1.5
1.8
0.059
0.0708
www.microne.com.cn
Page 9 of 12
ME6210
● SOT23
DIM
V05
Millimeters
Inches
Min
Max
Min
Max
A
2.7
3.1
0.1063
0.122
B
1.7
2.1
0.0669
0.0827
b
0.35
0.5
0.0138
0.0197
C
1.0
1.2
0.0394
0.0472
c
0.1
0.25
0.0039
0.0098
d
0.2
0.0079
E
2.1
2.64
0.0827
0.1039
e
1.2
1.4
0.0472
0.0551
www.microne.com.cn
Page 10 of 12
ME6210
● TO-92
DIM
A
A1
b
c
D
D1
E
e
e1
L
h
Φ
V05
Millimeters
Min
3.3
1.1
0.38
0.36
4.3
3.43
4.3
2.4
2.44
14.1
一
Inches
Max
3.7
1.4
0.55
0.51
4.7
一
4.7
2.7
2.64
14.5
0.38
1.6
www.microne.com.cn
Min
0.1299
0.0433
0.015
0.0142
0.1693
0.135
0.1693
0.0945
0.0961
0.5551
一
Max
0.1457
0.0551
0.0217
0.0201
0.185
一
0.185
0.1063
0.1039
0.5709
0.015
0.063
Page 11 of 12
ME6210
The information described herein is subject to change without notice.
Nanjing Micro One Electronics Inc is not responsible for any problems caused by circuits or diagrams
described herein whose related industrial properties, patents, or other rights belong to third parties.
The application circuit examples explain typical applications of the products, and do not guarantee the
success of any specific mass-production design.
Use of the information described herein for other purposes and/or reproduction or copying without the
express permission of Nanjing Micro One Electronics Inc is strictly prohibited.
The products described herein cannot be used as part of any device or equipment affecting the human
body, such as exercise equipment, medical equipment, security systems, gas equipment, or any
apparatus installed in airplanes and other vehicles, without prior written permission of Nanjing Micro
One Electronics Inc.
Although Nanjing Micro One Electronics Inc exerts the greatest possible effort to ensure high quality
and reliability, the failure or malfunction of semiconductor products may occur. The user of these
products should therefore give thorough consideration to safety design, including redundancy,
fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community
damage that may ensue.
V05
www.microne.com.cn
Page 12 of 12
很抱歉,暂时无法提供与“ME6210A50M3G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.19639
- 500+0.19018
- 国内价格
- 1+0.39490
- 200+0.25520
- 1500+0.22220
- 3000+0.19690
- 国内价格
- 10+0.36850
- 100+0.28836
- 300+0.24830
- 3000+0.21816
- 6000+0.19419
- 9000+0.18209
- 国内价格
- 5+0.33438
- 50+0.32936
- 600+0.22530
