MEL7136A/MEL7136B
Linear Adjustable Constant Current LED Driver MEL7136A/MEL7136B
General Description
Features
The MEL7136A is a constant current regulator
for driving LEDs with low quiescent current and low
dropout voltage. The current is adjustable from
10mA to1A with an external resistor.
The MEL7136B is only a controller , and must be
connected to an external NMOS. MEL7136B is an
external transistor, is suitable for applications
requiring a high output current . The output current
of ME7136B can be adjusted by external DC
control voltage or PWM control.
Only one external resistor is required to achieve
a constant current LED driver. Soft start , thermal
protection and low voltage protection are also
provided.
The driver pin EXT is provided for current and
voltage extension. Adding an external NMOS or
NPN transistor to this pin can extend current and
voltage range.
Selection Guide
Typical Application
The output current of ME7136B is adjustable
Sink current:10mA to1A adjustable with an external
resistor
Current and voltage range extendable by adding an
external NMOS or NPN transistor
Power supply voltage: 2.7-18V
Low drop out voltage: 50mV@1A
Low quiescent current: 80uA
Thermal Shutdown protection:165℃
Soft start
Low voltage protection: 2.5V
Package: MEL7136A: SOT89-5, ESOP8
MEL7136B: SOT23-5
Power Led driver and controller
Typical Application Circuit
V05
www.microne.com.cn
Page 1 of 14
MEL7136A/MEL7136B
MEL7136A
Low Voltage And Light Load (Under 1A)
Low Voltage And Heavy Load (Exceed 1A)
High Voltage Application
MEL7136B
Low Voltage Application
VDD
2.7V-18V
VDD
VDD
Zener
Diode
CIN
10uF
MEL7136B EXT
CIN
10uF
GND
V05
VDD
NMOS
MEL7136B EXT
CS
REXT
www.microne.com.cn
GND
NMOS
CS
REXT
Page 2 of 14
MEL7136A/MEL7136B
Adjustable Output Current Application
VDD
VDD
CIN
10uF
MEL7136B EXT
NMOS
R3=10K
GND
CS
R4=240K
REXT=1Ω
Dimming
VDC/PWM
REXT Resistor Value selection:
REXT(Ω )
ILED(mA)
10
10
1
100
0.286
350
0.1
1000
ILED
V
R
CS
EXT
Block Diagram
MEL7136A
V05
MEL7136B
www.microne.com.cn
Page 3 of 14
MEL7136A/MEL7136B
Pin Configuration
SOT23-5(only for MEL7136B)
SOT89-5
ESOP8
Pin Assignment
MEL7136A
Pin Number
Pin Name
Functions
1
CS
Output current detection
1
2
D(LED)
The negative input feet of LED
3
3
VDD
Power Input
5
4
GND
Ground
7
5
EXT
Driving external NMOS
NC
No connection
ESOP8
SOT89-5
2
4,6,8
MEL7136B
Pin Number
Pin Name
Functions
1
NC
NC
2
GND
Ground
3
VDD
Power Input
4
CS
5
EXT
SOT23-5
Absolute Maximum Ratings
Parameter
Symbol
Ratings
Units
Input Voltage
VDD
18
V
Voltage on LED,CS
VLED, VCS,
-0.3~VDD+0.3
V
Voltage on EXT
VEXT
6
V
Output Current
IOUT
1.5
A
Power Dissipation
V05
SOT89-5
PD
www.microne.com.cn
500
1300(PCB mounted)(*1)
mW
Page 4 of 14
MEL7136A/MEL7136B
2000
ESOP8
PD
SOT23-5
PD
300
Operating Temperature Range
TOPR
-40~+125
Storage Temperature Range
TSTG
-40~+150
2000(PCB mounted)(*1)
mW
(T=25℃)
260℃,4sec
Lead Temperature
ESD(ESD voltage for human body model )
VESD
2000
V
*1:The power dissipation figure shown in PCB mounted. Please refer to page8-9 for details.
Electrical Characteristics
MEL7136A/MEL7136B
(VDD= 3.6V, Ta=25OC, unless otherwise noted)
Parameter
Symbol
Conditions
Min.
Sink Current
I sink
VDD=3.6V
Input Voltage
VDD
I sink=1A
CS Voltage
VCS
Sink current accuracy
△ILED/ILED
Load Regulation
LDR
Line Regulation
LNR
Output dropout
voltage
V drop
Quiescent Current
ISS
I sink=1A
Units
10
1000
mA
2.7
18
V
mV
95
100
105
-5
-2.5
5
0.1
2
mA/V
0.4
2
mA/V
50
100
mV
80
100
uA
2.5
2.7
V
VLED= 3V
3.6V≤VDD≤18V
VDD=3.6V, VLED= 0.5V
VDD=3.6V
2.3
Low voltage hysteresis
Vhys
Maximal EXT Voltage
VEXT
Thermal Shutdown
protection
Tsd
V05
Max.
VLED=0.2V to 3V
VDD=3.6V
Low Voltage
Protection
Typ.
0.15
VDD=5.0V,VCS=0V
2.5
3.6
V
4.5
165
www.microne.com.cn
V
Page 5 of 14
MEL7136A/MEL7136B
Type Characteristics
(1) Quiescent Current VS. Input Voltage (No external component)
Quiescent Current(uA)
120
100
80
60
40
4
6
8
10
12
14
16
18
Input Voltage(V)
(2) Quiescent Current VS. Temperature(VDD=3.6V )
Quiescent Current VS.Temperature
100
80
60
40
-20
60
80
100
120
140
160
900
1000
Temperature(℃)
(3) Dropout Voltage VS. Output Current(VDD=3.6V )
Dropout Voltage VS. Output current
Dropout Voltage (mV)
60
50
40
30
200
300
400
500
600
700
800
Output current(mA)
V05
www.microne.com.cn
Page 6 of 14
MEL7136A/MEL7136B
Adjustment of the ME7136B output current
1 Output current adjustment by external DC control voltage
The Dimming pin can be driven by an external dc voltage (VDC), as shown, to adjust the output current to a value
below the nominal average value defined by REXT. VREF=0.1V.
VDD
MEL7136B
R3=10K
CS
R4=240K
REXT=1
Dimming
VDC : 0-2.5V
Figure 1. Dimming Control Using a DC Voltage
R4:R3=24:1
The average output current is given by:
ILED
V
REF
ILED 0
R3 (V
V
DC
REF
R4
REXT
(0≤VDC≤2.5V)
(2.5≤VDC≤VDD)
2 Output current adjustment by PWM control
A Pulse Width Modulated (PWM) signal with duty cycle PWM can be applied to the Dimming pin, as shown below, to
adjust the output current to a value below the nominal average value set by resistor REXT.VREF=0.1V.
V05
www.microne.com.cn
Page 7 of 14
MEL7136A/MEL7136B
VDD
MEL7136B
R3=10K
CS
R4=240K
REXT=1
Dimming
VH≥2.5V
PWM
F=100-1000HZ
Figure 2. Dimming Control Using a PWM Signal
R4:R3=24:1
ILED
V
REF
R3 (2.5 Duty V
REF
R4
REXT
(2.5≤VPWM≤VDD & 0≤Duty≤100%)
PWM dimming provides reduced brightness by modulating the LED’s forward current between 0% and 100%. The
LED brightness is controlled by adjusting the relative ratios of the on time to the off time. A 25% brightness level is
achieved by turning the LED on at full current for 25% of one cycle. To ensure this switching process between on and
off state is invisible by human eyes, the switching frequency must be greater than 100 Hz. Above 100 Hz, the human
eyes average the on and off times, seeing only an effective brightness that is proportional to the LED’s on-time duty
cycle. The advantage of PWM dimming is that the forward current is always constant, therefore the LED color does
not vary with brightness as it does with analog dimming. Pulsing the current provides precise brightness control while
preserving the color purity. The best dimming frequency of MEL7136B is 100Hz to 1kHz.
V05
www.microne.com.cn
Page 8 of 14
MEL7136A/MEL7136B
Power dissipation
● SOT89-5 power dissipation
The power dissipation data for the SOT89-5 is shown as below. The value of power dissipation varies with the mount
board conditions. Please use this data as the reference data taken in the following condions.
1. Measurement condition
Condition:
Mount on a board
Ambient:
Natural convection
Soldering:
Lead(pb) free
Board:
Dimensions 30*35mm (1050mm2 in one side)
Copper(Cu) traces occupy 50% of the board
Area in top and back faces
Material:
Glass Epoxy (FR-4)
Thickness: 1.6mm
Through-hole: 5*0.8 Diameter
2. Power dissipation vs. Ambient temperature
Board Mount (Tj max=125 ℃)
Evaluation Board( Unit:mm)
Ambient Temperature(℃)
Power Dissipation(mW)
25
1300
85
520
Thermal Resistance(℃/W)
76.92
Pd vs.Ta
1400
Power dissipation (mW)
1200
1000
800
600
400
200
35
45
55
65
75
85
95
105
115
125
Ambient temperature(℃)
V05
www.microne.com.cn
Page 9 of 14
MEL7136A/MEL7136B
● ESOP8 power dissipation
The power dissipation data for the ESOP8 is shown as below. The value of power dissipation varies with the mount
3. Measurement condition
Condition:
Mount on a board
Ambient:
Natural convection
Soldering:
Lead(pb) free
Board:
Material:
Glass Epoxy (FR-4)
Thickness: 1.6mm
Through-hole: 4*0.8 Diameter
4. Power dissipation vs. Ambient temperature
25
2000
85
700
66.67
Pd vs.Ta
Power dissipation(mW)
2400
2000
1600
1200
800
400
35
45
55
65
75
85
95
105
115
125
V05
www.microne.com.cn
Page 10 of 14
MEL7136A/MEL7136B
Packaging Information
● Packaging Type: SOT89-5
Millimeters
Inches
DIM
Min
Max
Min
Max
A
4.4
4.6
0.173
0.181
a
0.5
0.62
0.02
0.024
B
1.63
1.83
0.064
0.072
b
0.44
0.54
0.017
0.021
C
Type:0.059
D
2.4
2.6
0.094
0.102
E
1.4
1.6
0.054
0.063
F
0.35
0.43
0.013
0.017
L
3.95
4.25
0.155
0.167
r
V05
Type:1.5
Type:80
www.microne.com.cn
Type:80
Page 11 of 14
MEL7136A/MEL7136B
● Packaging Type: SOP8-PP
Dimension (mm)
Dimension (Inches)
Character
Min
Max
Min
Max
A
1.350
1.750
0.053
0.069
A1
0.1
0.3
0.004
0.012
B
b
V05
1.27(Typ.)
0.330
0.05(Typ.)
0.510
0.013
0.020
c
0.9(Typ.)
0.035(Typ.)
c1
1.0(Typ.)
0.039(Typ.)
D
5.8
6.2
0.228
0.244
D1
3.202
3.402
0.126
0.134
E
3.800
4.000
0.150
0.157
E1
2.313
2.513
0.091
0.099
F
4.7
5.1
0.185
0.201
L
0.675
0.725
0.027
0.029
G
0.32(Typ.)
0.013(Typ.)
R
0.15(Typ.)
0.006(Typ.)
1
7
8
www.microne.com.cn
7
8
Page 12 of 14
MEL7136A/MEL7136B
Package type:SOT23-5
Unit:mm(inch)
Millimeters
Inches
DIM
V05
Min
Max
Min
Max
A
0.9
1.45
0.0354
0.0570
A1
A2
0.9
1.3
0.0354
0.0511
B
0.2
0.5
0.0078
0.0196
C
0.09
0.26
0.0035
0.0102
D
2.7
3.10
0.1062
0.1220
E
2.2
3.2
0.0866
0.1181
E1
1.30
1.80
0.0511
0.0708
e
0.95REF
0.0374REF
e1
1.90REF
0.0748REF
L
0.10
0.60
0.0039
0.0236
a0
00
300
00
300
www.microne.com.cn
Page 13 of 14
MEL7136A/MEL7136B
V05
The information described herein is subject to change without notice.
Nanjing Micro One Electronics Inc is not responsible for any problems caused by circuits or diagrams
described herein whose related industrial properties, patents, or other rights belong to third parties.
The application circuit examples explain typical applications of the products, and do not guarantee the
success of any specific mass-production design.
Use of the information described herein for other purposes and/or reproduction or copying without the
express permission of Nanjing Micro One Electronics Inc is strictly prohibited.
The products described herein cannot be used as part of any device or equipment affecting the human
body, such as exercise equipment, medical equipment, security systems, gas equipment, or any
apparatus installed in airplanes and other vehicles, without prior written permission of Nanjing Micro
One Electronics Inc.
Although Nanjing Micro One Electronics Inc exerts the greatest possible effort to ensure high quality
and reliability, the failure or malfunction of semiconductor products may occur. The user of these
products should therefore give thorough consideration to safety design, including redundancy,
fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community
damage that may ensue.
www.microne.com.cn
Page 14 of 14
很抱歉,暂时无法提供与“MEL7136BM5G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.59290
- 200+0.40920
- 1500+0.37180
- 3000+0.34650
- 国内价格
- 5+0.54057
- 50+0.42385
- 600+0.41961
- 1200+0.41122
- 3000+0.39888
- 国内价格
- 5+0.59573
- 50+0.46710
- 150+0.40274
- 500+0.35446
