MEM2309SG
MEM2309SG
    MICRONE(南京微盟)
    SOP-8
    P沟道,-30V,-6A,80mΩ@-4.5V
MEM2309SG 数据手册
MEM2309 P-Channel MOSFET MEM2309S Description: Feature:  MEM2309SG Series P-channel enhancement RDS(ON) =53mΩ@ VGS=-10V,ID=-6A mode field-effect transistor ,produced with high RDS(ON) =68mΩ@ VGS=-4.5V,ID=-4A cell density DMOS trench technology, which is especially used to minimize -30V/-6A  on-state High Density Cell Design For Ultra Low On-Resistance resistance.  This device particularly suits low voltage Surface mount package:SOP8 applications, and low power dissipation. Pin Configuration: Typical Application:    Power management Load switch Battery protection Absolute Maximum Ratings: Parameter Symbol Ratings Unit Drain-Source Voltage VDSS -30V V Gate-Source Voltage VGSS V TOpr ±20 -6 -3.2 -30 2 0.8 150 ℃ Tstg -65/150 ℃ Drain Current TA=25℃ TA=70℃ Pulsed Drain Current1,2 TA=25℃ Total Power Dissipation TA=70℃ Operating Temperature Range Storage Temperature Range V6.0 www.microne.com.cn ID IDM Pd A A W 1 MEM2309 Thermal Characteristics: Parameter 3 Thermal Resistance, Junction-to-Ambient Symbol Ratings Unit RθJA 50 ℃/W Electrical Characteristics: MEM2309SG Parameter Drain-Source Breakdown Voltage Gate Threshold Voltage Gate-Body Leakage Zero Gate Voltage Drain Current Static Drain-Source On-Resistance Forward Transconductance Drain-Source Diode Forward Current Source-drain (diode forward) voltage Input Capacitance Output Capacitance Reverse Transfer Capacitance Turn-On Delay Time Rise Time Turn-Off Delay Time Fall-Time Total Gate Charge Gate-Source Charge Gate-Drain Charge Symbol Test Condition Static Characteristics VGS=0V, V(BR)DSS ID=-250uA VDS= VGS, VGS(th) ID=-250uA VDS=0V,VGS=20V IGSS VDS=0V,VGS=-20V IDSS VDS=-24V VGS=0V Min Type Max Unit -30 -34 -1.1 -1.3 -2 V 5 -5 -6 30 -30 -300 nA nA nA V RDS(ON)1 VGS=-10V,ID=-6A 33 53 65 mΩ RDS(ON)2 VGS=-4.5V,ID=-4A 50 68 80 mΩ gFS VDS = –5 V, ID = –5.3 A 10 IS VSD VGS=0V,IS=-1A Dynamic Characteristics Ciss VDS = -15V, Coss VGS = 0 V, f = 1 MHz Crss Switching Characteristics td(on) VDD = -15 V, tr ID=-1 A, VGEN = -10 V, td(off) Rg = 6 Ω tf Qg Qgs Qgd VDS = -15 V, VGS = -10 V, ID = -4A -0.8 S -2.1 A -1.2 V 530 140 70 8 15 15 10 10 pF 15 25 25 15 15 ns 2.2 2.0 nc 1、Repetitive rating, pulse width limited by junction temperature. 2、Pulse test; pulse width ≤300 us, duty cycle ≤2%. 3、Surface Mounted on FR4 Board, t ≤ 10 sec. V6.0 www.microne.com.cn 2 MEM2309 Typical Performance Characteristics: V6.0 www.microne.com.cn 3 MEM2309 V6.0 www.microne.com.cn 4 MEM2309 Package Information: V6.0 www.microne.com.cn 5 MEM2309 · The information described herein is subject to change without notice. · Nanjing Micro One Electronics Inc is not responsible for any problems caused by circuits or diagrams described herein whose related industrial properties, patents, or other rights belong to third parties. The application circuit examples explain typical applications of the products, and do not guarantee the success of any specific mass-production design. · Use of the information described herein for other purposes and/or reproduction or copying without the express permission of Nanjing Micro One Electronics Inc is strictly prohibited. · The products described herein cannot be used as part of any device or equipment affecting the human body, such as exercise equipment, medical equipment, security systems, gas equipment, or any apparatus installed in airplanes and other vehicles, without prior written permission of Nanjing Micro One Electronics Inc. · Although Nanjing Micro One Electronics Inc exerts the greatest possible effort to ensure high quality and reliability, the failure or malfunction of semiconductor products may occur. The user of these products should therefore give thorough consideration to safety design, including redundancy, fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community damage that may ensue. V6.0 www.microne.com.cn 6
MEM2309SG
物料型号为 MEM2309S,是一款 P-Channel MOSFET,使用高密度 DMOS 沟槽技术制造,特别适用于最小化导通电阻。
以下是 PDF 文档中提供的主要信息概述:
器件简介: - 型号:MEM2309S - 类型:P-Channel MOSFET - 技术:高密度 DMOS 沟槽技术 - 应用:低电压、低功耗应用
引脚分配: - 表面贴装封装:SOP8
参数特性: - 漏极-源极电压:-30V - 栅极-源极电压:+20V - 漏极电流:-6A(25°C),-3.2A(70°C) - 脉冲漏极电流:-30A - 总功耗:2W(25°C),0W(70°C) - 工作温度范围:-65°C 至 150°C - 存储温度范围:-65°C 至 150°C - 热阻:50°C/W
功能详解: - 典型应用:电源管理、负载开关、电池保护 - 导通电阻:在 Vgs=-10V, Id=-6A 时为 53 mΩ;在 Vgs=-4.5V, Id=-4A 时为 68 mΩ - 栅极阈值电压:-1.1V 至 -2.0V - 栅极-体漏电流:5nA 至 30nA(正向),-5nA 至 -30nA(反向) - 零栅极电压漏极电流:-6nA 至 -300nA - 栅极电荷:Qg=10nC 至 15nC,Qgs=2.2nC,Qgd=2.0nC - 输入电容:Ciss=530pF,Coss=140pF,Crss=70pF
应用信息: - 适用于电源管理、负载开关和电池保护等应用。
封装信息: - 封装类型:SOP8 - 封装尺寸:1.55mm x 4.975mm(引脚间距 0.4325mm)
文档还包含了电气特性、热特性、典型性能特性、最大安全工作区和瞬态热响应曲线等详细信息。
如需更详细的技术数据和图表,请参阅完整的 PDF 文档。
MEM2309SG 价格&库存
很抱歉,暂时无法提供与“MEM2309SG”相匹配的价格&库存,您可以联系我们找货
