RC0402FR-0716RL
RC0402FR-0716RL
    YAGEO(国巨)
    贴片电阻 0402 16Ω ±1% 1/16W ±100ppm/℃
RC0402FR-0716RL 数据手册
DATA SHEET GENERAL PURPOSE CHIP RESISTORS RC_L series ±0.1%, ±0.5%, ±1%, ±5% Sizes 0075/0100/0201/0402/0603/0805/ 1206/1210/1218/2010/2512 Product specification – December 12, 2018 V.10 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SCOPE This specification describes RC series chip resistors with lead free terminations made by thick film process. RC_L SERIES 2 11 0075 to 2512 ORDERING INFORMATION - GLOBAL PART NUMBER Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER RC XXXX X X X XX XXXX L APPLICATIONS  All general purpose application (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0075/0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 FEATURES  Halogen Free Epoxy  RoHS compliant  Products with lead free terminations meet RoHS requirements  Pb-glass contained in electrodes, resistors element and glass are exempted by RoHS  Reducing environmentally hazardous wastes  High component and equipment reliability  Saving of PCB space  None forbidden-materials used in products/production (2) TOLERANCE B = ± 0.1% D = ± 0.5% F = ± 1.0% J = ± 5.0% (for jumper ordering, use code of J) (3) TAPING REEL & POWER R = Paper taping reel K = Embossed taping reel S = ESD safe reel (0075/0100 only) (4) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec. (5) TAPING REEL 07 = 7 inch dia. Reel 10=10 inch dia. Reel 13 =13 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power 7N = 7 inch dia. Reel, ESD safe reel (0075/0100 only) 3W = 13 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point Example: 97R6 = 97.6Ω 9K76 = 9760Ω 1M = 1,000,000Ω (7) DEFAULT CODE Letter L is the system default code for ordering only.(Note) ORDERING EXAMPLE The ordering code for a RC0402 0.0625W chip resistor value 100KΩwith ±5% tolerance, supplied in 7-inch tape reel of 10,000 units per reel is: RC0402JR-07100KL. NOTE 1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process". 2. On customized label, "LFP" or specific symbol can be printed. www.yageo.com Dec. 12, 2018 V.10 Product specification Chip Resistor Surface Mount RC_L SERIES 3 11 0075 to 2512 MARKING RC0075 / RC0100 / RC0201 / RC0402 No Marking Fig. 1 RC0603 0 1%, 0.5%,E24 exception values 10/11/13/15/20/75 of E24 series Fig. 2 240 = 24 × 100 = 24 88 1%, 0.5%, E96 refer to EIA-96 marking method, including values 10/11/13/15/20/75 of E24 series Fig. 3 88A = 806 × 100 = 806 Ω 03 5%, E24 series : 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 4 Value = 10 KΩ RC0805 / RC1206 / RC1210 / RC2010 / RC2512 00 1%, 0.5%, E24/E96 series : 4 digits First three digits for significant figure and 4th digit for numbe r of zeros Fig. 5 Value = 10 KΩ 03 5%, E24 series : 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 6 Value = 10 KΩ RC1218 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 7 Value = 10 KΩ 00 Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros Fig. 8 Value = 10 KΩ For further marking information, please see special data sheet "Chip resistors marking". www.yageo.com Dec. 12, 2018 V.10 Product specification Chip Resistor Surface Mount SERIES RC_L 4 11 0075 to 2512 TAPING CODE & POWER Type Power, W (P70) Coding 07 0075 0100 0201 0402 0603 0805 1/50 1/32 1/20 1/16 1/10 1/8 7W 1/8 1/5 1/4 Type Power, W (P70) Coding 07 1206 1210 1218 2010 2512 1/4 1/2 1 3/4 1 CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environmental influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Ni-barrier) are added, as shown in Fig.9. 7W 1/2 2 Outlines For dimensions, please refer to Table 1 9 Fig. 9 Chip resistor outlines DIMENSION Table 1 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) RC0075 0.30±0.01 0.15±0.01 0.13±0.01 0.08±0.03 0.08±0.03 RC0100 0.40±0.02 0.20±0.02 0.13±0.02 0.10±0.03 0.10±0.03 RC0201 0.60±0.03 0.30±0.03 0.23±0.03 0.10±0.05 0.15±0.05 RC0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 RC0603 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 RC0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 RC1206 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC1210 3.10±0.10 2.60±0.15 0.55±0.10 0.45±0.15 0.50±0.20 RC1218 3.10±0.10 4.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC2010 5.00±0.10 2.50±0.15 0.55±0.10 0.45±0.15 0.50±0.20 RC2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.50±0.20 www.yageo.com Dec. 12, 2018 V.10 Product specification Chip Resistor Surface Mount RC_L SERIES 5 11 0075 to 2512 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS POWER OPERATING TEMPERATURER ANGE Fig. 4 Chip resistor outlines-55℃ to 125℃ RC0075 1/50 W MAXIMUM WORKING VOLTAGE 10V MAXIMUM DIELECTRIC OVERLOAD WITHSTANDING VOLTAGE VOLTAGE 25V 25V RESISTANCE RANGE TEMPERATURE COEFFICIENT JUMPER CRITERIA Rated Current 5% (E24) 10Ω≦R
RC0402FR-0716RL
物料型号:RC_L系列,包括不同的尺寸和公差,如±0.1%, ±0.5%, ±1%, ±5%。
器件简介:RC_L系列是使用厚膜工艺制造的无铅端子的普通用途芯片电阻器。
引脚分配:文档中没有明确指出具体的引脚分配,但提到了电阻器是在高级陶瓷基板上构建的,两端有内部金属电极与厚膜电阻元件接触。
参数特性: - 工作温度范围:不同尺寸的电阻器有不同的工作温度范围,例如RC0402至RC2512的范围是-55℃至+155℃,而RC0075至RC0201的范围是-55℃至+125℃。 - 最大直流或交流(RMS)工作电压与额定功率相对应。 - 电阻温度系数:根据规格书有所不同,例如对于1Ω至10Ω的电阻,5%的E24系列为±200ppm/℃。
功能详解:文档提供了详细的电气特性表,包括最大工作电压、功率承受、电阻温度系数等。
应用信息:适用于所有普通用途的应用场景。
封装信息:提供了多种尺寸的封装信息,如0075、0100、0201、0402、0603、0805、1206、1210、1218、2010、2512等,并且每种尺寸都有详细的尺寸数据。
RC0402FR-0716RL 价格&库存
很抱歉,暂时无法提供与“RC0402FR-0716RL”相匹配的价格&库存,您可以联系我们找货
RC0402FR-0716RL
  • 100+0.00415
  • 500+0.00398
  • 1000+0.00371
  • 5000+0.00336
  • 10000+0.00315
库存:9400
RC0402FR-0716RL
    RC0402FR-0716RL
    • 1+0.883371+0.11468
    • 10+0.1851910+0.02404
    • 25+0.1336825+0.01736
    • 50+0.1055850+0.01371
    • 100+0.08536100+0.01108
    • 250+0.06514250+0.00846
    • 500+0.05386500+0.00700
    • 1000+0.045071000+0.00585
    • 5000+0.031265000+0.00406
    库存:95
    RC0402FR-0716RL
      • 1+0.09080
      • 100+0.05560
      • 1000+0.03560
      • 5000+0.02280
      • 10000+0.01630
      库存:5725
      RC0402FR-0716RL
        RC0402FR-0716RL
        • 10000+0.0273010000+0.00355
        • 20000+0.0241620000+0.00314
        • 30000+0.0226530000+0.00294
        • 50000+0.0210050000+0.00273
        • 70000+0.0200770000+0.00261
        • 100000+0.01917100000+0.00249
        库存:95
