LL4148
LL4148
    TK(通科)
    SOD80
    开关二极管(小信号) 单路 100V 150mA SOD80
LL4148 数据手册
东莞市通科电子有限公司 LL4148 DongGuan Tongke Electronic Co.,LTD FAST SWITCHING DIODE Features ! Fast Switching Speed ! Glass Package Version for High Reliability ! High Conductance ! Available in Both Through-Hole and Surface Mount Versions  A B C LL4148 Mechanical Data ! ! ! ! ! ! Case: MiniMELF Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: MiniMELF 0.05 grams MiniMELF Dim MIn Max A 3.30 3.50 B 1.40 1.50 C 0.26 0.32 All Dimensions in mm Marking: Cathode Band Only Lead Free: For RoHS / Lead Free Version, Maximum Ratings @TA=25°C unless otherwise specified Characteristic Symbol Value Unit VRM 100 V VRRM VRWM VR 75 V VR(RMS) 53 V Forward Continuous Current (Note 1) IFM 300 mA Rectified Current (Average), Half Wave Rectification with Resistive Load and f  50MHz (Note 1) IO 150 mA IFSM 1.0 2.0 A Pd 500 1.68 mW mW/°C RJA 300 K/W Tj, TSTG -65 to +175 °C Non-Repetitive Peak Reverse Voltage Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage RMS Reverse Voltage Non-Repetitive Peak Forward Surge Current @ t = 1.0s @ t = 1.0µs Power Dissipation (Note 1) Derate Above 25°C Thermal Resistance, Junction to Ambient Air (Note 1) Operating and Storage Temperature Range LL4148 1 of 3 www.tongke888.com 400-6922-883 东莞市通科电子有限公司 LL4148 DongGuan Tongke Electronic Co.,LTD Electrical Characteristics Characteristic FAST SWITCHING DIODE @TA=25°C unless otherwise specified Symbol Min Max Unit Test Condition Maximum Forward Voltage VFM — 1.0 V IF = 10mA Maximum Peak Reverse Current IRM — 5.0 50 30 25 µA µA µA nA VR = 75V VR = 70V, Tj = 150°C VR = 20V, Tj = 150°C VR = 20V Capacitance Cj — 4.0 pF VR = 0, f = 1.0MHz Reverse Recovery Time trr — 4.0 ns IF = 10mA to IR = 1.0mA VR = 6.0V, RL = 100 Note: 1. Diode on Ceramic Substrate 10mm x 8mm x 0.7mm. / LL4148 2 of 3 www.tongke888.com 400-6922-883 东莞市通科电子有限公司 LL4148 DongGuan Tongke Electronic Co.,LTD FAST SWITCHING DIODE Typical Characteristics Curves Fig.1- Power Derating Curve PD Power Dissipation (mW) IF Instantaneous Forward current (mA) Fig.2- Typical Forward Characteristics Ambient Temperature (°C) Instantaneous Forward Voltage (V) Fig.3- Typical junction capacitance CD Diode Capacitance (pF) IR Instantaneous Reverse current (nA) Fig.4- Typical Reverse Characteristics Reverse Voltage (V) / LL4148 Instantaneous Reverse Voltage (V) 3 of 3 www.tongke888.com 400-6922-883
LL4148
物料型号为LL4148,是一款快速开关二极管。
器件简介包括快速开关速度、高导通性、玻璃封装版本以提高可靠性,并且提供通孔和表面贴装版本。
引脚分配为MiniMELF封装,带有标记的阴极带。
参数特性包括非重复峰值反向电压100V、正向连续电流300mA、功率耗散500mW等。
功能详解涉及其电气特性,如最大正向电压、最大反向峰值电流、电容和反向恢复时间。
应用信息未在文档中明确说明,但通常此类二极管用于高速开关和整流应用。
封装信息为MiniMELF,尺寸为A 3.30-3.50mm、B 1.40-1.50mm、C 0.26-0.32mm。
LL4148 价格&库存
很抱歉,暂时无法提供与“LL4148”相匹配的价格&库存,您可以联系我们找货
