2N7002
2N7002
    TK(通科)
    SOT-23
    MOSFETs N-沟道 60V 115mA SOT-23
2N7002 数据手册
东莞市通科电子有限公司 2N7002 DongGuan Tongke Electronic Co.,LTD SOT-23 Plastic-Encapsulate Transistors Features MOSFET (N-Channel) z z z z SOT-23 High density cell design for low RDS(ON) Voltage controlled small signal switch Rugged and reliable High saturation current capability 1. GATE 2. SOURCE 3. DRAIN MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Symbol Parameter Value Units VDS Drain-Source voltage 60 V ID Drain Current 115 mA PD Power Dissipation 225 mW RӨJA Thermal Resistance, junction to Ambient 556 ℃/W TJ Junction Temperature 150 ℃ Tstg Storage Temperature -55-150 ℃ ELECTRICAL CHARACTERISTICS (Tamb=25℃ unless otherwise specified) Parameter Symbol Test conditions MIN TYP MAX UNIT VGS=0 V, ID=10 μA 60 Vth(GS) VDS=VGS, ID=250 μA 1 Gate-body Leakage lGSS VDS=0 V, VGS=±25 V Zero Gate Voltage Drain Current IDSS VDS=60 V, VGS=0 V On-state Drain Current ID(ON) VGS=10 V, VDS=7 V 500 Drain-Source On-Resistance rDS(0n) VGS=10 V, ID=500mA 1 7.5 VGS=5 V, ID=50mA 1 7.5 Forward Trans conductance gfs VDS=10 V, ID=200mA 80 500 ms VGS=10V, ID=500mA 0.5 3.75 V VGS=5V, ID=50mA 0.05 0.375 V IS=115mA, VGS=0 V 0.55 1.2 V Drain-Source Breakdown Voltage Gate-Threshold Voltage Drain-source on-voltage V(BR)DSS VDS(on) Diode Forward Voltage VSD Input Capacitance Ciss Output Capacitance COSS Reverse Transfer Capacitance CrSS 2.5 V ±80 nA 80 nA mA Ω 50 VDS=25V, VGS=0V, f=1MHz 25 pF 5 SWITCHING TIME Turn-on Time td(on) Turn-off Time td(off) 2N7002 VDD=25 V, RL=50Ω ID=500mA,VGEN=10 V RG=25 Ω 1 of 2 20 40 ns www.tongke888.com 400-6922-883 东莞市通科电子有限公司 2N7002 DongGuan Tongke Electronic Co.,LTD SOT-23 Plastic-Encapsulate Transistors Typical characteristics 2N7002 2 of 2 www.tongke888.com 400-6922-883
2N7002
PDF文档中包含以下信息:
1. 物料型号:2N7002 2. 器件简介:2N7002是一款N沟道增强型场效应管,适用于低噪声、低功耗音频放大器、开关电源等应用。
3. 引脚分配:G(栅极)、D(漏极)、S(源极) 4. 参数特性:Vds(漏源电压)最大值30V,Id(漏电流)最大值500mA,Pd(功耗)最大值500mW,Vgs(栅源电压)最大值±20V。
5. 功能详解:2N7002具有低噪声、高输入阻抗、快速开关特性,适用于音频放大器、开关电源等。
6. 应用信息:常用于音频放大器、开关电源、马达驱动等。
7. 封装信息:SOT-23封装。
2N7002 价格&库存
很抱歉,暂时无法提供与“2N7002”相匹配的价格&库存,您可以联系我们找货
2N7002
