LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS
KMR
Series
Downsized snap-ins, 105℃
KMR
・Downsized 5mm in height from current snap-ins KMQ series
・Max. 50% up ripple current than same case size of KMQ series
・Endurance with ripple current : 2,000 hours at 105℃
・Rated voltage range : 160 to 450Vdc, Capacitance range : 100 to 3,300µF
・For inverter control, switching power supplies
・Non solvent resistant type
・RoHS2 Compliant
Downsized
KMQ
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-25 to +105℃
160 to 450Vdc
±20% (M)
I≦3 CV
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
Rated voltage (Vdc)
160 to 250V
315 to 400V
420 & 450V
tanδ(Max.)
0.15
0.15
0.20
Rated voltage (Vdc)
160 to 250V
315 to 400V
420 & 450V
Z(-25℃)/Z(+20℃)
4
8
8
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20℃, 120Hz)
(at 20℃ after 5 minutes)
(at 20℃, 120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for 2,000 hours at 105℃.
Capacitance change
≦±20% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
≦±15% of the initial value
D.F. (tanδ)
≦150% of the initial specified value
Leakage current
Endurance
Shelf Life
◆DIMENSIONS [mm]
Sleeve (PET : Brown)
●Terminal
PC board pin-out
(View from Solder side)
Negative mark
φD+1max.
10
2-φ2
4.0±0.5
L±2.5
Vent
Code : LI (φ35)
Negative mark
PC board pin-out
4.2±0.5
Code : VS (φ22 to φ35) : Standard
2-1.2×6
φD+1max.
●Terminal
Vent
5±0.5
L±2.5
4.5±1
14.2±1
The standard design has no plastic disc.
◆PART NUMBERING SYSTEM
1
2
3
4
E KMR
5
6
7
8
9
10
VS N
11
12
13
14
M
15
16
17
18
S
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 100µF:101, 2,700µF:272)
Dummy terminal code
Terminal code (VS, LI)
Voltage code (ex. 160V:161, 315V:3B1, 450V:451)
Series code
Category
Please refer to "Product code guide (snap-in type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001S
KMRSeries
◆STANDARD RATINGS
WV
(Vdc)
160
180
200
Cap
(µF)
560
680
820
820
1,000
1,000
1,000
1,200
1,200
1,200
1,500
1,500
1,500
1,500
1,800
1,800
1,800
1,800
2,200
2,200
2,700
2,700
3,300
470
560
680
680
820
820
1,000
1,000
1,000
1,200
1,200
1,200
1,200
1,500
1,500
1,500
1,800
1,800
2,200
2,200
2,200
2,200
2,700
560
560
680
680
820
820
820
1,000
1,000
1,000
1,200
1,200
1,200
1,500
1,500
1,500
1,800
1,800
2,200
2,200
2,700
Case size Rated ripple current
φD×L(mm) (Arms/105℃,120Hz)
22 ×25
22 × 30
22× 35
25.4 ×25
22 ×40
25.4×30
30 × 25
22× 45
22 ×50
25.4×35
25.4× 40
25.4× 45
30 ×30
35 ×25
25.4× 50
30 × 35
30 ×40
35 ×30
30 ×45
35 × 35
30× 50
35 ×40
35 ×45
22 ×25
22 ×30
22 × 35
25.4 ×25
22 ×40
25.4× 30
22 × 45
25.4 ×35
30 ×25
22× 50
25.4×40
30 ×30
35 ×25
25.4× 45
25.4×50
30×35
30 ×40
35 ×30
30× 45
30×50
35 ×35
35 ×40
35× 45
22 ×30
25.4 ×25
22× 35
25.4 ×30
22 × 40
25.4×35
30 ×25
22 ×50
25.4 ×40
30 ×30
25.4×45
30× 35
35×25
25.4 ×50
30 ×40
35× 30
30×45
35 ×35
30 × 50
35 × 40
35 × 45
1.58
1.83
2.06
1.89
2.33
2.15
1.90
2.61
2.69
2.45
2.82
2.88
2.39
2.17
3.22
2.73
2.82
2.47
3.23
2.79
3.66
3.23
3.68
1.45
1.66
1.87
1.72
2.11
1.94
2.38
2.24
1.90
2.69
2.52
2.14
1.94
2.88
2.94
2.49
2.82
2.47
3.23
3.31
2.79
2.92
3.33
1.66
1.56
1.87
1.77
2.11
2.03
1.72
2.45
2.30
1.95
2.58
2.23
1.94
2.94
2.58
2.25
2.92
2.53
3.31
2.92
3.33
Part No.
EKMR161VSN561MP25S
EKMR161VSN681MP30S
EKMR161VSN821MP35S
EKMR161VSN821MQ25S
EKMR161VSN102MP40S
EKMR161VSN102MQ30S
EKMR161VSN102MR25S
EKMR161VSN122MP45S
EKMR161VSN122MP50S
EKMR161VSN122MQ35S
EKMR161VSN152MQ40S
EKMR161VSN152MQ45S
EKMR161VSN152MR30S
EKMR161VSN152MA25S
EKMR161VSN182MQ50S
EKMR161VSN182MR35S
EKMR161VSN182MR40S
EKMR161VSN182MA30S
EKMR161VSN222MR45S
EKMR161VSN222MA35S
EKMR161VSN272MR50S
EKMR161VSN272MA40S
EKMR161VSN332MA45S
EKMR181VSN471MP25S
EKMR181VSN561MP30S
EKMR181VSN681MP35S
EKMR181VSN681MQ25S
EKMR181VSN821MP40S
EKMR181VSN821MQ30S
EKMR181VSN102MP45S
EKMR181VSN102MQ35S
EKMR181VSN102MR25S
EKMR181VSN122MP50S
EKMR181VSN122MQ40S
EKMR181VSN122MR30S
EKMR181VSN122MA25S
EKMR181VSN152MQ45S
EKMR181VSN152MQ50S
EKMR181VSN152MR35S
EKMR181VSN182MR40S
EKMR181VSN182MA30S
EKMR181VSN222MR45S
EKMR181VSN222MR50S
EKMR181VSN222MA35S
EKMR181VSN222MA40S
EKMR181VSN272MA45S
EKMR201VSN561MP30S
EKMR201VSN561MQ25S
EKMR201VSN681MP35S
EKMR201VSN681MQ30S
EKMR201VSN821MP40S
EKMR201VSN821MQ35S
EKMR201VSN821MR25S
EKMR201VSN102MP50S
EKMR201VSN102MQ40S
EKMR201VSN102MR30S
EKMR201VSN122MQ45S
EKMR201VSN122MR35S
EKMR201VSN122MA25S
EKMR201VSN152MQ50S
EKMR201VSN152MR40S
EKMR201VSN152MA30S
EKMR201VSN182MR45S
EKMR201VSN182MA35S
EKMR201VSN222MR50S
EKMR201VSN222MA40S
EKMR201VSN272MA45S
WV
(Vdc)
250
315
350
Cap
(µF)
330
390
470
560
560
560
680
680
820
820
820
820
1,000
1,000
1,200
1,200
1,200
1,500
1,500
1,800
2,200
180
220
270
270
330
330
390
390
390
470
470
470
470
560
560
680
680
680
820
820
1,000
1,000
1,200
1,200
150
220
220
270
270
330
330
330
330
390
390
390
390
470
560
560
560
560
680
680
820
22 × 25
22 × 30
22 × 35
22 × 40
25.4 × 30
30 × 25
22 × 45
25.4 × 35
25.4 × 40
25.4 × 45
30 × 30
35 × 25
25.4 × 50
30 × 35
30 × 40
30 × 45
35 × 35
30 × 50
35 × 40
35 × 45
35 × 50
22 × 25
22 × 30
22 × 35
25.4 × 25
22 × 40
25.4 × 30
22 × 45
25.4 × 35
30 × 25
22 × 50
25.4 × 40
30 × 30
35 × 25
25.4× 45
30 × 35
25.4 × 50
30 × 40
35 × 30
30 × 45
35 × 35
30 × 50
35 × 40
35 × 45
35 × 50
22 × 25
22 × 30
25.4× 25
22 × 35
25.4 × 30
22 × 40
22 × 45
25.4 × 35
30 × 25
22 × 50
25.4 × 40
30 × 30
35 × 25
25.4 × 45
25.4 × 50
30 × 35
30 × 40
35 × 30
30 × 45
35 × 35
30 × 50
1.21
1.38
1.56
1.74
1.61
1.42
1.97
1.85
2.08
2.13
1.77
1.60
2.40
2.03
2.31
2.38
2.06
2.73
2.41
2.72
3.10
0.91
1.06
1.20
1.15
1.37
1.30
1.52
1.48
1.39
1.72
1.67
1.57
1.52
1.86
1.78
2.10
2.03
1.90
2.31
2.13
2.61
2.46
2.78
2.86
0.84
1.06
1.04
1.20
1.18
1.37
1.40
1.36
1.28
1.56
1.52
1.43
1.38
1.71
1.90
1.78
1.84
1.72
2.10
1.94
2.36
Part No.
EKMR251VSN331MP25S
EKMR251VSN391MP30S
EKMR251VSN471MP35S
EKMR251VSN561MP40S
EKMR251VSN561MQ30S
EKMR251VSN561MR25S
EKMR251VSN681MP45S
EKMR251VSN681MQ35S
EKMR251VSN821MQ40S
EKMR251VSN821MQ45S
EKMR251VSN821MR30S
EKMR251VSN821MA25S
EKMR251VSN102MQ50S
EKMR251VSN102MR35S
EKMR251VSN122MR40S
EKMR251VSN122MR45S
EKMR251VSN122MA35S
EKMR251VSN152MR50S
EKMR251VSN152MA40S
EKMR251VSN182MA45S
EKMR251VSN222MA50S
EKMR3B1VSN181MP25S
EKMR3B1VSN221MP30S
EKMR3B1VSN271MP35S
EKMR3B1VSN271MQ25S
EKMR3B1VSN331MP40S
EKMR3B1VSN331MQ30S
EKMR3B1VSN391MP45S
EKMR3B1VSN391MQ35S
EKMR3B1VSN391MR25S
EKMR3B1VSN471MP50S
EKMR3B1VSN471MQ40S
EKMR3B1VSN471MR30S
EKMR3B1VSN471MA25S
EKMR3B1VSN561MQ45S
EKMR3B1VSN561MR35S
EKMR3B1VSN681MQ50S
EKMR3B1VSN681MR40S
EKMR3B1VSN681MA30S
EKMR3B1VSN821MR45S
EKMR3B1VSN821MA35S
EKMR3B1VSN102MR50S
EKMR3B1VSN102MA40S
EKMR3B1VSN122MA45S
EKMR3B1VSN122MA50S
EKMR351VSN151MP25S
EKMR351VSN221MP30S
EKMR351VSN221MQ25S
EKMR351VSN271MP35S
EKMR351VSN271MQ30S
EKMR351VSN331MP40S
EKMR351VSN331MP45S
EKMR351VSN331MQ35S
EKMR351VSN331MR25S
EKMR351VSN391MP50S
EKMR351VSN391MQ40S
EKMR351VSN391MR30S
EKMR351VSN391MA25S
EKMR351VSN471MQ45S
EKMR351VSN561MQ50S
EKMR351VSN561MR35S
EKMR351VSN561MR40S
EKMR351VSN561MA30S
EKMR351VSN681MR45S
EKMR351VSN681MA35S
EKMR351VSN821MR50S
CAT. No. E1001S
KMRSeries
◆STANDARD RATINGS
WV
(Vdc)
350
400
420
Cap
(µF)
820
1,000
1,200
120
180
180
220
220
270
270
270
270
330
330
330
330
390
390
470
470
470
560
560
680
680
820
820
1,000
120
150
150
180
180
220
220
220
220
270
Case size
φD×L(mm)
Rated ripple
current
(Arms/105℃, 120Hz)
Part No.
2.23
2.54
2.86
0.75
0.96
0.94
1.09
1.07
1.24
1.26
1.23
1.16
1.44
1.40
1.31
1.27
1.55
1.49
1.74
1.69
1.58
1.91
1.76
2.15
2.03
2.30
2.37
2.50
0.78
0.91
0.89
1.03
1.00
1.16
1.19
1.16
1.11
1.36
EKMR351VSN821MA40S
EKMR351VSN102MA45S
EKMR351VSN122MA50S
EKMR401VSN121MP25S
EKMR401VSN181MP30S
EKMR401VSN181MQ25S
EKMR401VSN221MP35S
EKMR401VSN221MQ30S
EKMR401VSN271MP40S
EKMR401VSN271MP45S
EKMR401VSN271MQ35S
EKMR401VSN271MR25S
EKMR401VSN331MP50S
EKMR401VSN331MQ40S
EKMR401VSN331MR30S
EKMR401VSN331MA25S
EKMR401VSN391MQ45S
EKMR401VSN391MR35S
EKMR401VSN471MQ50S
EKMR401VSN471MR40S
EKMR401VSN471MA30S
EKMR401VSN561MR45S
EKMR401VSN561MA35S
EKMR401VSN681MR50S
EKMR401VSN681MA40S
EKMR401VSN821MA45S
EKMR401VSN821MA50S
EKMR401VSN102MA50S
EKMR421VSN121MP25S
EKMR421VSN151MP30S
EKMR421VSN151MQ25S
EKMR421VSN181MP35S
EKMR421VSN181MQ30S
EKMR421VSN221MP40S
EKMR421VSN221MP45S
EKMR421VSN221MQ35S
EKMR421VSN221MR25S
EKMR421VSN271MP50S
35 ×40
35 × 45
35× 50
22× 25
22 ×30
25.4×25
22 × 35
25.4 ×30
22 ×40
22 × 45
25.4× 35
30 ×25
22 ×50
25.4× 40
30× 30
35 ×25
25.4×45
30 × 35
25.4× 50
30 ×40
35 ×30
30 × 45
35× 35
30 ×50
35 ×40
35 × 45
35 × 50
35 ×50
22 ×25
22 ×30
25.4× 25
22 ×35
25.4 ×30
22 ×40
22 ×45
25.4× 35
30×25
22 × 50
WV
(Vdc)
420
450
Cap
(µF)
270
270
270
330
330
390
390
390
470
470
560
560
680
820
100
120
150
150
180
180
220
220
220
270
270
270
270
270
330
330
330
390
470
470
470
560
560
680
Case size
φD×L(mm)
25.4 × 40
30 × 30
35 × 25
25.4 × 45
30 × 35
25.4 × 50
30 × 40
35 × 30
30 × 45
35 × 35
30 × 50
35 × 40
35 × 45
35 × 50
22 × 25
22 × 30
22 × 35
25.4 × 25
22 × 40
25.4 × 30
22 × 45
25.4 × 35
30 × 25
22 × 50
25.4 × 40
25.4 × 45
30 × 30
35 × 25
25.4 × 50
30 × 35
35 × 30
30 × 40
30 × 45
30 × 50
35 × 35
35 × 40
35 × 45
35 × 50
Rated ripple
current
(Arms/105℃, 120Hz)
Part No.
1.32
1.26
1.26
1.49
1.45
1.66
1.63
1.58
1.85
1.77
2.07
2.02
2.29
2.59
0.71
0.82
0.94
0.89
1.05
1.00
1.19
1.16
1.11
1.36
1.32
1.35
1.26
1.26
1.52
1.45
1.45
1.63
1.85
1.90
1.77
2.02
2.08
2.36
EKMR421VSN271MQ40S
EKMR421VSN271MR30S
EKMR421VSN271MA25S
EKMR421VSN331MQ45S
EKMR421VSN331MR35S
EKMR421VSN391MQ50S
EKMR421VSN391MR40S
EKMR421VSN391MA30S
EKMR421VSN471MR45S
EKMR421VSN471MA35S
EKMR421VSN561MR50S
EKMR421VSN561MA40S
EKMR421VSN681MA45S
EKMR421VSN821MA50S
EKMR451VSN101MP25S
EKMR451VSN121MP30S
EKMR451VSN151MP35S
EKMR451VSN151MQ25S
EKMR451VSN181MP40S
EKMR451VSN181MQ30S
EKMR451VSN221MP45S
EKMR451VSN221MQ35S
EKMR451VSN221MR25S
EKMR451VSN271MP50S
EKMR451VSN271MQ40S
EKMR451VSN271MQ45S
EKMR451VSN271MR30S
EKMR451VSN271MA25S
EKMR451VSN331MQ50S
EKMR451VSN331MR35S
EKMR451VSN331MA30S
EKMR451VSN391MR40S
EKMR451VSN471MR45S
EKMR451VSN471MR50S
EKMR451VSN471MA35S
EKMR451VSN561MA40S
EKMR451VSN561MA45S
EKMR451VSN681MA50S
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Frequency(Hz)
160 to 250Vdc
315 to 450Vdc
50
0.81
0.77
120
1.00
1.00
300
1.17
1.16
1k
1.32
1.30
10k
1.45
1.41
50k
1.50
1.43
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
CAT. No. E1001S
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
United Chemi-Con (UCC):
EKMR451VSN271MR30S
