MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
LXZ
Series
Low impedance, Downsized, 105℃
LXZ
Lower Z
・Adoption of innovative electrolyte and new technologies
Downsized
・Very low impedance at high frequency
LXY P180
・Endurance with ripple current: 2,000 to 8,000 hours at 105℃
Lower Z
・Solvent resistant type (see PRECAUTIONS AND GUIDELINES)
・RoHS Compliant
LXV P182
・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information.
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-55 to +105℃
6.3 to 63Vdc
(at 20℃, 120Hz)
±20% (M)
I=0.01CV or 3µA, whichever is greater.
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃ after 2 minutes)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V 63V
tanδ(Max.)
0.22 0.19 0.16 0.14 0.12 0.10 0.08
When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase.
(at 20℃, 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for the specified period of time at 105℃.
Time
φ5 & 6.3 : 2,000hours φ8 : 3,000hours φ10 : 5,000hoursφ12.5 : 7,000hours φ16 & 18 : 8,000hours
Capacitance change
≦±20% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
Dissipation Factor
(tanδ)
Endurance
Shelf Life
◆DIMENSIONS [mm]
φd
F±0.5
Code : E
Sleeve (PET : Dark blue)
F±0.5
●Terminal
φD
φD'
φd
F
φD'
L'
15min.
4min.
(φ5 to φ10)
(φ12.5 to φ18)
L'
5
0.5
2.0
6.3
0.5
2.5
10 12.5
8
0.6 0.6 0.6
3.5 5.0 5.0
φD+0.5max.
L+1.5max.
16
0.8
7.5
18
0.8
7.5
Gas escape end seal
Vent
(Exceptφ5 & φ6.3)
◆PART NUMBERING SYSTEM
1
2
3
4
E LXZ
5
6
7
8
E
9
10
11
12
13
14
M
15
16
17
18
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 150µF:151, 2,200µF:222)
Lead forming·taping code
Terminal code
Voltage code (ex. 6.3V:6R3, 25V:250, 50V:500)
Series code
Category
Please refer to "Product code guide (radial lead type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
177
Downloaded from Arrow.com.
CAT. No. E1001Q
LXZSeries
◆STANDARD RATINGS
WV
(Vdc)
Cap
(µF)
Case size
φD×L(mm)
20℃
150
330
470
680
820
1,000
1,200
1,200
1,500
2,200
2,700
3,300
3,900
6.3
4,700
5,600
5,600
6,800
6,800
6,800
8,200
10,000
10,000
12,000
12,000
15,000
18,000
100
220
330
470
680
680
1,000
1,000
1,200
1,500
1,800
2,200
3,300
10
3,900
3,900
4,700
5,600
5,600
5,600
6,800
6,800
8,200
8,200
10,000
10,000
12,000
47
100
220
330
470
470
560
680
16
1,000
1,200
1,500
1,500
2,200
2,700
2,700
5×11.5
6.3×11.5
6.3×15
8×12
10×12.5
8×15
8×20
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
12.5×35
16×20
12.5×40
16×25
18×20
16×30
16×35
18×25
16×40
18×30
18×35
18×40
5×11.5
6.3×11.5
6.3×15
8×12
8×15
10×12.5
8×20
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
12.5×35
12.5×40
16×25
18×20
16×30
18×25
16×35
18×30
16×40
18×35
18×40
5×11.5
6.3×11.5
6.3×15
8×12
8×15
10×12.5
8×20
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.50
0.25
0.18
0.12
0.090
0.090
0.080
0.068
0.052
0.045
0.037
0.038
0.030
0.025
0.022
0.029
0.017
0.022
0.028
0.019
0.017
0.020
0.015
0.018
0.016
0.015
0.50
0.25
0.18
0.12
0.090
0.090
0.080
0.068
0.052
0.045
0.037
0.038
0.030
0.025
0.029
0.022
0.017
0.022
0.028
0.019
0.020
0.017
0.018
0.015
0.016
0.015
0.50
0.25
0.18
0.12
0.090
0.090
0.080
0.068
0.052
0.045
0.037
0.038
0.030
0.025
0.029
1.0
0.50
0.36
0.24
0.18
0.18
0.16
0.136
0.104
0.090
0.074
0.076
0.060
0.050
0.044
0.058
0.034
0.044
0.056
0.038
0.034
0.040
0.030
0.036
0.032
0.030
1.0
0.50
0.36
0.24
0.18
0.18
0.16
0.136
0.104
0.090
0.074
0.076
0.060
0.050
0.058
0.044
0.034
0.044
0.056
0.038
0.040
0.034
0.036
0.030
0.032
0.030
1.0
0.50
0.36
0.24
0.18
0.18
0.16
0.136
0.104
0.090
0.074
0.076
0.060
0.050
0.058
175
290
400
555
760
730
810
1,050
1,220
1,440
1,690
1,660
1,950
2,310
2,510
2,210
2,870
2,560
2,490
3,010
3,150
2,740
3,710
3,330
3,680
3,800
175
290
400
555
730
760
810
1,050
1,220
1,440
1,690
1,660
1,950
2,310
2,210
2,510
2,870
2,560
2,490
3,010
2,740
3,150
3,330
3,710
3,680
3,800
175
290
400
555
730
760
810
1,050
1,220
1,440
1,690
1,660
1,950
2,310
2,210
WV
(Vdc)
Part No.
Cap
(µF)
Case size
φD×L(mm)
20℃
ELXZ6R3E□□151MEB5D
ELXZ6R3E□□331MFB5D
ELXZ6R3E□□471MF15D
ELXZ6R3E□□681MH12D
ELXZ6R3E□□821MJC5S
ELXZ6R3E□□102MH15D
ELXZ6R3E□□122MH20D
ELXZ6R3E□□122MJ16S
ELXZ6R3E□□152MJ20S
ELXZ6R3E□□222MJ25S
ELXZ6R3E□□272MJ30S
ELXZ6R3E□□332MK20S
ELXZ6R3E□□392MK25S
ELXZ6R3E□□472MK30S
ELXZ6R3E□□562MK35S
ELXZ6R3E□□562ML20S
ELXZ6R3E□□682MK40S
ELXZ6R3E□□682ML25S
ELXZ6R3E□□682MM20S
ELXZ6R3E□□822ML30S
ELXZ6R3E□□103ML35S
ELXZ6R3E□□103MM25S
ELXZ6R3E□□123ML40S
ELXZ6R3E□□123MM30S
ELXZ6R3E□□153MM35S
ELXZ6R3E□□183MM40S
ELXZ100E□□101MEB5D
ELXZ100E□□221MFB5D
ELXZ100E□□331MF15D
ELXZ100E□□471MH12D
ELXZ100E□□681MH15D
ELXZ100E□□681MJC5S
ELXZ100E□□102MH20D
ELXZ100E□□102MJ16S
ELXZ100E□□122MJ20S
ELXZ100E□□152MJ25S
ELXZ100E□□182MJ30S
ELXZ100E□□222MK20S
ELXZ100E□□332MK25S
ELXZ100E□□392MK30S
ELXZ100E□□392ML20S
ELXZ100E□□472MK35S
ELXZ100E□□562MK40S
ELXZ100E□□562ML25S
ELXZ100E□□562MM20S
ELXZ100E□□682ML30S
ELXZ100E□□682MM25S
ELXZ100E□□822ML35S
ELXZ100E□□822MM30S
ELXZ100E□□103ML40S
ELXZ100E□□103MM35S
ELXZ100E□□123MM40S
ELXZ160E□□470MEB5D
ELXZ160E□□101MFB5D
ELXZ160E□□221MF15D
ELXZ160E□□331MH12D
ELXZ160E□□471MH15D
ELXZ160E□□471MJC5S
ELXZ160E□□561MH20D
ELXZ160E□□681MJ16S
ELXZ160E□□102MJ20S
ELXZ160E□□122MJ25S
ELXZ160E□□152MJ30S
ELXZ160E□□152MK20S
ELXZ160E□□222MK25S
ELXZ160E□□272MK30S
ELXZ160E□□272ML20S
16
25
35
50
3,300
3,900
3,900
3,900
4,700
4,700
5,600
5,600
6,800
8,200
10,000
47
100
150
220
330
330
390
470
680
820
1,000
1,000
1,500
1,800
1,800
2,200
2,200
2,700
2,700
3,300
3,300
3,900
3,900
4,700
4,700
5,600
33
56
100
150
220
220
270
330
470
560
680
680
1,000
1,200
1,200
1,500
1,800
1,800
1,800
2,200
2,200
2,700
2,700
3,300
3,300
3,900
22
47
68
100
12.5×35
12.5×40
16×25
18×20
16×30
18×25
16×35
18×30
16×40
18×35
18×40
5×11.5
6.3×11.5
6.3×15
8×12
8×15
10×12.5
8×20
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
12.5×35
18×20
12.5×40
16×25
16×30
18×25
16×35
18×30
16×40
18×35
18×40
5×11.5
6.3×11.5
6.3×15
8×12
8×15
10×12.5
8×20
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
12.5×35
12.5×40
16×25
18×20
16×30
18×25
16×35
18×30
16×40
18×35
18×40
5×11.5
6.3×11.5
6.3×15
8×12
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.022
0.017
0.022
0.028
0.019
0.020
0.017
0.018
0.015
0.016
0.015
0.50
0.25
0.18
0.12
0.090
0.090
0.080
0.068
0.052
0.045
0.037
0.038
0.030
0.025
0.029
0.022
0.028
0.017
0.022
0.019
0.020
0.017
0.018
0.015
0.016
0.015
0.50
0.25
0.18
0.12
0.090
0.090
0.080
0.068
0.052
0.045
0.037
0.038
0.030
0.025
0.029
0.022
0.017
0.022
0.028
0.019
0.020
0.017
0.018
0.015
0.016
0.015
0.90
0.45
0.31
0.22
0.044
0.034
0.044
0.056
0.038
0.040
0.034
0.036
0.030
0.032
0.030
1.0
0.50
0.36
0.24
0.18
0.18
0.16
0.136
0.104
0.090
0.074
0.076
0.060
0.050
0.058
0.044
0.056
0.034
0.044
0.038
0.040
0.034
0.036
0.030
0.032
0.030
1.0
0.50
0.36
0.24
0.18
0.18
0.16
0.136
0.104
0.090
0.074
0.076
0.060
0.050
0.058
0.044
0.034
0.044
0.056
0.038
0.040
0.034
0.036
0.030
0.032
0.030
1.8
0.90
0.62
0.44
2,510
2,870
2,560
2,490
3,010
2,740
3,150
3,330
3,710
3,680
3,800
175
290
400
555
730
760
810
1,050
1,220
1,440
1,690
1,660
1,950
2,310
2,210
2,510
2,490
2,870
2,560
3,010
2,740
3,150
3,330
3,710
3,680
3,800
175
290
400
555
730
760
810
1,050
1,220
1,440
1,690
1,660
1,950
2,310
2,210
2,510
2,870
2,560
2,490
3,010
2,740
3,150
3,330
3,710
3,680
3,800
155
260
360
485
Part No.
ELXZ160E□□332MK35S
ELXZ160E□□392MK40S
ELXZ160E□□392ML25S
ELXZ160E□□392MM20S
ELXZ160E□□472ML30S
ELXZ160E□□472MM25S
ELXZ160E□□562ML35S
ELXZ160E□□562MM30S
ELXZ160E□□682ML40S
ELXZ160E□□822MM35S
ELXZ160E□□103MM40S
ELXZ250E□□470MEB5D
ELXZ250E□□101MFB5D
ELXZ250E□□151MF15D
ELXZ250E□□221MH12D
ELXZ250E□□331MH15D
ELXZ250E□□331MJC5S
ELXZ250E□□391MH20D
ELXZ250E□□471MJ16S
ELXZ250E□□681MJ20S
ELXZ250E□□821MJ25S
ELXZ250E□□102MJ30S
ELXZ250E□□102MK20S
ELXZ250E□□152MK25S
ELXZ250E□□182MK30S
ELXZ250E□□182ML20S
ELXZ250E□□222MK35S
ELXZ250E□□222MM20S
ELXZ250E□□272MK40S
ELXZ250E□□272ML25S
ELXZ250E□□332ML30S
ELXZ250E□□332MM25S
ELXZ250E□□392ML35S
ELXZ250E□□392MM30S
ELXZ250E□□472ML40S
ELXZ250E□□472MM35S
ELXZ250E□□562MM40S
ELXZ350E□□330MEB5D
ELXZ350E□□560MFB5D
ELXZ350E□□101MF15D
ELXZ350E□□151MH12D
ELXZ350E□□221MH15D
ELXZ350E□□221MJC5S
ELXZ350E□□271MH20D
ELXZ350E□□331MJ16S
ELXZ350E□□471MJ20S
ELXZ350E□□561MJ25S
ELXZ350E□□681MJ30S
ELXZ350E□□681MK20S
ELXZ350E□□102MK25S
ELXZ350E□□122MK30S
ELXZ350E□□122ML20S
ELXZ350E□□152MK35S
ELXZ350E□□182MK40S
ELXZ350E□□182ML25S
ELXZ350E□□182MM20S
ELXZ350E□□222ML30S
ELXZ350E□□222MM25S
ELXZ350E□□272ML35S
ELXZ350E□□272MM30S
ELXZ350E□□332ML40S
ELXZ350E□□332MM35S
ELXZ350E□□392MM40S
ELXZ500E□□220MEB5D
ELXZ500E□□470MFB5D
ELXZ500E□□680MF15D
ELXZ500E□□101MH12D
□□ : Enter the appropriate lead forming or taping code.
178
CAT. No. E1001Q
LXZSeries
◆STANDARD RATINGS
WV
(Vdc)
Cap
(µF)
Case size
φD×L(mm)
20℃
50
63
120
120
180
180
220
330
390
390
560
680
680
820
820
1,000
1,000
1,200
1,200
1,500
1,800
1,800
2,200
2,700
12
22
8×15
10×12.5
8×20
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
12.5×35
18×20
12.5×40
16×25
16×30
18×25
16×35
16×40
18×30
18×35
18×40
5×11.5
6.3×11.5
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.16
0.16
0.12
0.13
0.088
0.073
0.054
0.059
0.044
0.039
0.048
0.033
0.042
0.029
0.034
0.028
0.029
0.025
0.021
0.025
0.023
0.020
1.9
1.0
0.32
0.32
0.24
0.26
0.18
0.15
0.11
0.12
0.088
0.078
0.096
0.066
0.084
0.058
0.068
0.056
0.058
0.050
0.042
0.050
0.046
0.040
4.0
2.0
635
620
730
850
1,050
1,250
1,500
1,480
1,840
2,220
1,840
2,290
1,980
2,500
2,240
2,700
2,610
2,800
3,200
3,000
3,100
3,400
145
240
WV
(Vdc)
Part No.
Cap
(µF)
Case size
φD×L(mm)
20℃
ELXZ500E□□121MH15D
ELXZ500E□□121MJC5S
ELXZ500E□□181MH20D
ELXZ500E□□181MJ16S
ELXZ500E□□221MJ20S
ELXZ500E□□331MJ25S
ELXZ500E□□391MJ30S
ELXZ500E□□391MK20S
ELXZ500E□□561MK25S
ELXZ500E□□681MK30S
ELXZ500E□□681ML20S
ELXZ500E□□821MK35S
ELXZ500E□□821MM20S
ELXZ500E□□102MK40S
ELXZ500E□□102ML25S
ELXZ500E□□122ML30S
ELXZ500E□□122MM25S
ELXZ500E□□152ML35S
ELXZ500E□□182ML40S
ELXZ500E□□182MM30S
ELXZ500E□□222MM35S
ELXZ500E□□272MM40S
ELXZ630E□□120MEB5D
ELXZ630E□□220MFB5D
63
39
68
100
100
120
150
180
220
330
330
390
470
470
680
680
680
820
820
820
1,000
1,200
1,200
1,500
1,800
6.3×15
8×12
8×15
10×12.5
10×16
8×20
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
12.5×35
16×25
18×20
12.5×40
16×30
18×25
16×35
16×40
18×30
18×35
18×40
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.61
0.34
0.27
0.255
0.19
0.21
0.145
0.13
0.090
0.085
0.070
0.055
0.059
0.047
0.050
0.055
0.042
0.043
0.043
0.036
0.030
0.032
0.030
0.025
1.4
0.75
0.65
0.51
0.38
0.52
0.29
0.26
0.18
0.17
0.14
0.11
0.12
0.094
0.10
0.11
0.084
0.086
0.086
0.072
0.060
0.064
0.060
0.050
330
405
535
540
600
690
890
1,050
1,300
1,290
1,720
2,090
1,770
2,270
2,160
2,290
2,560
2,670
2,590
2,770
2,850
2,950
3,100
3,210
Part No.
ELXZ630E□□390MF15D
ELXZ630E□□680MH12D
ELXZ630E□□101MH15D
ELXZ630E□□101MJC5S
ELXZ630E□□121MJ16S
ELXZ630E□□151MH20D
ELXZ630E□□181MJ20S
ELXZ630E□□221MJ25S
ELXZ630E□□331MJ30S
ELXZ630E□□331MK20S
ELXZ630E□□391MK25S
ELXZ630E□□471MK30S
ELXZ630E□□471ML20S
ELXZ630E□□681MK35S
ELXZ630E□□681ML25S
ELXZ630E□□681MM20S
ELXZ630E□□821MK40S
ELXZ630E□□821ML30S
ELXZ630E□□821MM25S
ELXZ630E□□102ML35S
ELXZ630E□□122ML40S
ELXZ630E□□122MM30S
ELXZ630E□□152MM35S
ELXZ630E□□182MM40S
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Frequency(Hz)
Capacitance(µF)
12
220
680
2,200
4,700
to
to
to
to
to
180
560
1,800
3,900
18,000
120
0.40
0.50
0.60
0.75
0.85
1k
0.75
0.85
0.87
0.90
0.95
10k
0.90
0.94
0.95
0.95
0.98
100k
1.00
1.00
1.00
1.00
1.00
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
179
CAT. No. E1001Q
