MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
KZH
Low impedance, 105℃
KZM P5-24
Series
Longer life
KZH
・Newly innovative electrolyte is employed to minimize impedance
・Endurance with ripple current: 5,000 to 6,000 hours at 105℃
・Non solvent resistant type
・RoHS2 Compliant
Lower Z
KZE P5-29
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +105℃
6.3 to 35Vdc
±20% (M)
I=0.01CV or 3µA, whichever is greater.
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V
tanδ(Max.)
0.22 0.19 0.16 0.14 0.12
When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase.
Z (-25℃) / Z (+20℃)
2max.
Z (-40℃) / Z (+20℃)
3max.
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20℃, 120Hz)
(at 20℃ after 2 minutes)
(at 20℃, 120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage)for the specified period of time at 105℃.
Time
φ5 &φ6.3 : 5,000hoursφ8 to φ16 : 6,000hours
Capacitance change
≦±25% of the initial value (6.3, 10Vdc :≦±30%)
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
Endurance
Shelf Life
φd
Sleeve (PET : Brown)
F±0.5
Code : E
φD'
●Terminal
F±0.5
◆DIMENSIONS [mm]
L'
Vent
(Exceptφ5 &φ6.3)
15min
4min
(φ5 to φ10)
(φ12.5 to φ16)
φD
φd
F
φD'
L'
5
0.5
2.0
6.3
0.5
2.5
10 12.5
8
0.6 0.6 0.6
3.5 5.0 5.0
φD+0.5max.
L+1.5max.
16
0.8
7.5
Gas escape end seal
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E KZH AAA E AA AAA M AAA N
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 47µF:470, 100µF:101, 1,000µF:102)
Lead forming·taping code
Terminal code
Voltage code (ex. 6.3V:6R3, 35V:350)
Series code
Category
Please refer to "Product code guide (radial lead type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
5-27
CAT. No. E1001R
Low impedance, 105℃
KZHSeries
◆STANDARD RATINGS
WV
(Vdc)
Cap
(µF)
Case size
φD×L(mm)
20℃
6.3
10
16
220
470
820
1,200
1,200
1,500
1,800
2,200
2,700
3,900
4,700
5,600
6,800
6,800
8,200
150
330
680
1,000
1,000
1,500
1,500
1,800
2,200
3,300
3,900
4,700
4,700
5,600
6,800
100
220
470
680
680
1,000
1,000
1,500
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
5×11
6.3×11
8×11.5
8×15
10×12.5
8×20
10×16
10×20
10×25
12.5×20
12.5×25
12.5×30
12.5×35
16×20
16×25
5×11
6.3×11
8×11.5
8×15
10×12.5
8×20
10×16
10×20
10×25
12.5×20
12.5×25
12.5×30
16×20
12.5×35
16×25
5×11
6.3×11
8×11.5
8×15
10×12.5
8×20
10×16
10×20
0.24
0.11
0.062
0.048
0.045
0.033
0.032
0.020
0.018
0.017
0.015
0.013
0.012
0.015
0.013
0.24
0.11
0.062
0.048
0.045
0.033
0.032
0.020
0.018
0.017
0.015
0.013
0.015
0.012
0.013
0.24
0.11
0.062
0.048
0.045
0.033
0.032
0.020
0.80
0.35
0.19
0.15
0.14
0.11
0.10
0.060
0.054
0.043
0.038
0.033
0.031
0.038
0.035
0.80
0.35
0.19
0.15
0.14
0.11
0.10
0.060
0.054
0.043
0.038
0.033
0.038
0.031
0.035
0.80
0.35
0.19
0.15
0.14
0.11
0.10
0.060
330
500
900
1,210
1,240
1,410
1,650
1,960
2,250
2,480
2,900
3,450
3,570
3,250
3,630
330
500
900
1,210
1,240
1,410
1,650
1,960
2,250
2,480
2,900
3,450
3,250
3,570
3,630
330
500
900
1,210
1,240
1,410
1,650
1,960
WV
(Vdc)
Part No.
Cap
(µF)
Case size
φD×L(mm)
20℃
EKZH6R3E□□221ME11D
EKZH6R3E□□471MF11D
EKZH6R3E□□821MHB5D
EKZH6R3E□□122MH15D
EKZH6R3E□□122MJC5S
EKZH6R3E□□152MH20D
EKZH6R3E□□182MJ16S
EKZH6R3E□□222MJ20S
EKZH6R3E□□272MJ25S
EKZH6R3E□□392MK20S
EKZH6R3E□□472MK25S
EKZH6R3E□□562MK30S
EKZH6R3E□□682MK35S
EKZH6R3E□□682ML20S
EKZH6R3E□□822ML25S
EKZH100E□□151ME11D
EKZH100E□□331MF11D
EKZH100E□□681MHB5D
EKZH100E□□102MH15D
EKZH100E□□102MJC5S
EKZH100E□□152MH20D
EKZH100E□□152MJ16S
EKZH100E□□182MJ20S
EKZH100E□□222MJ25S
EKZH100E□□332MK20S
EKZH100E□□392MK25S
EKZH100E□□472MK30S
EKZH100E□□472ML20S
EKZH100E□□562MK35S
EKZH100E□□682ML25S
EKZH160E□□101ME11D
EKZH160E□□221MF11D
EKZH160E□□471MHB5D
EKZH160E□□681MH15D
EKZH160E□□681MJC5S
EKZH160E□□102MH20D
EKZH160E□□102MJ16S
EKZH160E□□152MJ20S
16
25
35
1,800
2,200
2,700
3,300
3,300
3,900
4,700
68
150
330
390
470
560
680
820
1,000
1,500
1,800
2,200
2,200
2,700
3,300
47
100
220
270
330
390
470
560
680
1,000
1,200
1,500
1,500
1,800
2,200
10×25
12.5×20
12.5×25
12.5×30
16×20
12.5×35
16×25
5×11
6.3×11
8×11.5
8×15
10×12.5
8×20
10×16
10×20
10×25
12.5×20
12.5×25
12.5×30
16×20
12.5×35
16×25
5×11
6.3×11
8×11.5
8×15
10×12.5
8×20
10×16
10×20
10×25
12.5×20
12.5×25
12.5×30
16×20
12.5×35
16×25
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.018
0.017
0.015
0.013
0.015
0.012
0.013
0.24
0.11
0.062
0.048
0.045
0.033
0.032
0.020
0.018
0.017
0.015
0.013
0.015
0.012
0.013
0.24
0.11
0.062
0.048
0.045
0.033
0.032
0.020
0.018
0.017
0.015
0.013
0.015
0.012
0.013
0.054
0.043
0.038
0.033
0.038
0.031
0.035
0.80
0.35
0.19
0.15
0.14
0.11
0.10
0.060
0.054
0.043
0.038
0.033
0.038
0.031
0.035
0.80
0.35
0.19
0.15
0.14
0.11
0.10
0.060
0.054
0.043
0.038
0.033
0.038
0.031
0.035
2,250
2,480
2,900
3,450
3,250
3,570
3,630
330
500
900
1,210
1,240
1,410
1,650
1,960
2,250
2,480
2,900
3,450
3,250
3,570
3,630
330
500
900
1,210
1,240
1,410
1,650
1,960
2,250
2,480
2,900
3,450
3,250
3,570
3,630
Part No.
EKZH160E□□182MJ25S
EKZH160E□□222MK20S
EKZH160E□□272MK25S
EKZH160E□□332MK30S
EKZH160E□□332ML20S
EKZH160E□□392MK35S
EKZH160E□□472ML25S
EKZH250E□□680ME11D
EKZH250E□□151MF11D
EKZH250E□□331MHB5D
EKZH250E□□391MH15D
EKZH250E□□471MJC5S
EKZH250E□□561MH20D
EKZH250E□□681MJ16S
EKZH250E□□821MJ20S
EKZH250E□□102MJ25S
EKZH250E□□152MK20S
EKZH250E□□182MK25S
EKZH250E□□222MK30S
EKZH250E□□222ML20S
EKZH250E□□272MK35S
EKZH250E□□332ML25S
EKZH350E□□470ME11D
EKZH350E□□101MF11D
EKZH350E□□221MHB5D
EKZH350E□□271MH15D
EKZH350E□□331MJC5S
EKZH350E□□391MH20D
EKZH350E□□471MJ16S
EKZH350E□□561MJ20S
EKZH350E□□681MJ25S
EKZH350E□□102MK20S
EKZH350E□□122MK25S
EKZH350E□□152MK30S
EKZH350E□□152ML20S
EKZH350E□□182MK35S
EKZH350E□□222ML25S
□□ : Enter the appropriate lead forming or taping code.
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Frequency(Hz)
Capacitance(µF)
0.47
220
680
2,200
4,700
to
to
to
to
to
150
560
1,800
3,900
8,200
120
0.40
0.50
0.60
0.75
0.85
1k
0.75
0.85
0.87
0.90
0.95
10k
0.90
0.94
0.95
0.95
0.98
100k
1.00
1.00
1.00
1.00
1.00
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
5-28
CAT. No. E1001R
