BOSCH GO (3.6V)
BOSCH GO (3.6V)
    BOSCH(博世)
    电动螺丝刀、起子机 BOSCH GO 3.6V
BOSCH GO (3.6V) 数据手册
OBJ_BUCH-3206-001.book Page 1 Monday, June 12, 2017 2:41 PM GO Professional Robert Bosch Power Tools GmbH 70538 Stuttgart GERMANY www.bosch-pt.com 1 609 92A 3WU (2017.06) T / 208 en fr pt cn tw th id Original instructions Notice originale Manual original 正本使用说明书 原始使用說明書 หนังสือคูม ่ ือการใช้งาน ฉบับต้นแบบ Petunjuk-Petunjuk untuk Penggunaan Orisinal vi Bản gốc hướng dẫn sử dụng ar ςТЎϩХʉ ЌТϾϦφЍʉ ʌμВТЎϺυ fa ΖЎϩʉ ˒μВЖЙʉʓ ИͳϞφЁʑ OBJ_BUCH-3206-001.book Page 2 Monday, June 12, 2017 2| English . . . . . . . . . . . . . . . . . Page 7 Français . . . . . . . . . . . . . . . . Page 26 Português . . . . . . . . . . . . Página 46 中文 . . . . . . . . . . . . . . . . . . . . . .页 66 中文 . . . . . . . . . . . . . . . . . . . . . .頁 81 ภาษาไทย . . . . . . . . . . . . . . . หน้า 96 Bahasa Indonesia . . . . Halaman 116 Tiếng Việt. . . . . . . . . . . . . . Trang 137 ................ 183 .............. 205 ...................... 1 609 92A 3WU | (12.6.17) Bosch Power Tools I OBJ_DOKU-60680-001.fm Page 3 Monday, June 12, 2017 4 |3 1 2 3 4 5 6 7 8 1 609 92A 3WU | (12.6.17) Bosch Power Tools OBJ_BUCH-3206-001.book Page 4 Monday, June 12, 2017 4| A 1 609 92A 3WU | (12.6.17) Bosch Power Tools OBJ_BUCH-3206-001.book Page 5 Monday, June 12, 2017 |5 B 1 609 92A 3WU | (12.6.17) Bosch Power Tools OBJ_BUCH-3206-001.book Page 6 Monday, June 12, 2017 6| C 9 10 1 609 92A 3WU | (12.6.17) Bosch Power Tools OBJ_BUCH-3206-001.book Page 7 Monday, June 12, 2017 English | 7 English Safety Notes General Power Tool Safety Warnings WARNING Read all safety warnings and all instructions. Failure to follow the warnings and instructions may result in electric shock, fire and/or serious injury. Save all warnings and instructions for future reference. The term “power tool” in the warnings refers to your mains-operated (corded) power tool or battery-operated (cordless) power tool. Work area safety  Keep work area clean and well lit. Cluttered or dark areas invite accidents.  Do not operate power tools in explosive atmospheres, such as in the presence of flammable liquids, gases or dust. Power tools create sparks which may ignite the dust or fumes.  Keep children and bystanders away while operating a power tool. Distractions can cause you to lose control. Electrical safety  Power tool plugs must match the outlet. Never modify the plug in any way. Do not use any adapter plugs with earthed (grounded) power tools. Unmodified plugs and matching outlets will reduce risk of electric shock. 1 609 92A 3WU | (12.6.17) Bosch Power Tools OBJ_BUCH-3206-001.book Page 8 Monday, June 12, 2017 8 | English  Avoid body contact with earthed or grounded surfaces, such as pipes, radiators, ranges and refrigerators. There is an increased risk of electric shock if your body is earthed or grounded.  Do not expose power tools to rain or wet conditions. Water entering a power tool will increase the risk of electric shock.  Do not abuse the cord. Never use the cord for carrying, pulling or unplugging the power tool. Keep cord away from heat, oil, sharp edges and moving parts. Damaged or entangled cords increase the risk of electric shock.  When operating a power tool outdoors, use an extension cord suitable for outdoor use. Use of a cord suitable for outdoor use reduces the risk of electric shock.  If operating a power tool in a damp location is unavoidable, use a residual current device (RCD) protected supply. Use of an RCD reduces the risk of electric shock. Personal safety  Stay alert, watch what you are doing and use common sense when operating a power tool. Do not use a power tool while you are tired or under the influence of drugs, alcohol or medication. A moment of inattention while operating power tools may result in serious personal injury.  Use personal protective equipment. Always wear eye protection. Protective equipment such as 1 609 92A 3WU | (12.6.17) Bosch Power Tools OBJ_BUCH-3206-001.book Page 9 Monday, June 12, 2017 English | 9 dust mask, non-skid safety shoes, hard hat, or hearing protection used for appropriate conditions will reduce personal injuries.  Prevent unintentional starting. Ensure the switch is in the off-position before connecting to power source and/or battery pack, picking up or carrying the tool. Carrying power tools with your finger on the switch or energising power tools that have the switch on invites accidents.  Remove any adjusting key or wrench before turning the power tool on. A wrench or a key left attached to a rotating part of the power tool may result in personal injury.  Do not overreach. Keep proper footing and balance at all times. This enables better control of the power tool in unexpected situations.  Dress properly. Do not wear loose clothing or jewellery. Keep your hair, clothing and gloves away from moving parts. Loose clothes, jewellery or long hair can be caught in moving parts.  If devices are provided for the connection of dust extraction and collection facilities, ensure these are connected and properly used. Use of dust collection can reduce dust-related hazards. Power tool use and care  Do not force the power tool. Use the correct power tool for your application. The correct power tool will do the job better and safer at the rate for which it was designed. 1 609 92A 3WU | (12.6.17) Bosch Power Tools OBJ_BUCH-3206-001.book Page 10 Monday, June 12, 2017 10 | English  Do not use the power tool if the switch does not turn it on and off. Any power tool that cannot be controlled with the switch is dangerous and must be repaired.  Disconnect the plug from the power source and/or the battery pack from the power tool before making any adjustments, changing accessories, or storing power tools. Such preventive safety measures reduce the risk of starting the power tool accidentally.  Store idle power tools out of the reach of children and do not allow persons unfamiliar with the power tool or these instructions to operate the power tool. Power tools are dangerous in the hands of untrained users.  Maintain power tools. Check for misalignment or binding of moving parts, breakage of parts and any other condition that may affect the power tool’s operation. If damaged, have the power tool repaired before use. Many accidents are caused by poorly maintained power tools.  Keep cutting tools sharp and clean. Properly maintained cutting tools with sharp cutting edges are less likely to bind and are easier to control.  Use the power tool, accessories and tool bits etc. in accordance with these instructions, taking into account the working conditions and the work to be performed. Use of the power tool for operations different from those intended could result in a hazardous situation. 1 609 92A 3WU | (12.6.17) Bosch Power Tools OBJ_BUCH-3206-001.book Page 11 Monday, June 12, 2017 English | 11 Battery tool use and care  Recharge only with the charger specified by the manufacturer. A charger that is suitable for one type of battery pack may create a risk of fire when used with another battery pack.  Use power tools only with specifically designated battery packs. Use of any other battery packs may create a risk of injury and fire.  When battery pack is not in use, keep it away from other metal objects, like paper clips, coins, keys, nails, screws or other small metal objects, that can make a connection from one terminal to another. Shorting the battery terminals together may cause burns or a fire.  Under abusive conditions, liquid may be ejected from the battery; avoid contact. If contact accidentally occurs, flush with water. If liquid contacts eyes, additionally seek medical help. Liquid ejected from the battery may cause irritation or burns. Service  Have your power tool serviced by a qualified repair person using only identical replacement parts. This will ensure that the safety of the power tool is maintained. Safety Warnings for Screwdrivers  Hold power tool by insulated gripping surfaces, when performing an operation where the fastener may contact hidden wiring. 1 609 92A 3WU | (12.6.17) Bosch Power Tools OBJ_BUCH-3206-001.book Page 12 Monday, June 12, 2017 12 | English Fasteners contacting a “live” wire may make exposed metal parts of the power tool “live” and could give the operator an electric shock.  Hold the machine with a firm grip. High reaction torque can briefly occur while driving in and loosening screws.  Secure the workpiece. A workpiece clamped with clamping devices or in a vice is held more secure than by hand.  Always wait until the machine has come to a complete stop before placing it down. The tool insert can jam and lead to loss of control over the power tool.  Before any work on the machine (e. g., maintenance, tool change, etc.) as well as during transport and storage, set the rotational direction switch to the centre position. Unintentional actuation of the On/Off switch can lead to injuries. Protect the power tool against heat, e. g., against continuous intense sunlight, fire, water, and moisture. Danger of explosion.  In case of damage and improper use of the battery, vapours may be emitted. Ventilate the area and seek medical help in case of complaints. The vapours can irritate the respiratory system. 1 609 92A 3WU | (12.6.17) Bosch Power Tools OBJ_BUCH-3206-001.book Page 13 Monday, June 12, 2017 English | 13 Safety Warnings for Battery Chargers This charger is not in- tended for use by children and persons with physical, sensory or mental limitations or a lack of experience or knowledge. This charger can be used by children aged 8 and above and by persons who have physical, sensory or mental limitations or a lack of experience or knowledge if a person responsible for their safety supervises them or has instructed them in the safe operation of the charger and they understand the associated dangers. Otherwise, there is a danger of operating errors and injuries. 1 609 92A 3WU | (12.6.17) Bosch Power Tools OBJ_BUCH-3206-001.book Page 14 Monday, June 12, 2017 14 | English Supervise children. This will ensure that children do not play with the charger. Cleaning and user maintenance of the battery charger shall not be made by children without supervision. Keep the battery charger away from rain or moisture. Penetration of water in the battery charger increases the risk of an electric shock.  Only charge Bosch lithium-ion batteries or lithium-ion batteries installed in Bosch products. The battery voltage must match the battery charging voltage of the charger. Otherwise there is danger of fire and explosion.  Keep the battery charger clean. Contamination can lead to danger of an electric shock.  Before each use, check the battery charger, cable and plug. If damage is detected, do not use the battery charger. Never open the battery charger yourself. Have repairs performed only by a qualified technician and only using original spare parts. Damaged battery chargers, cables and plugs increase the risk of an electric shock. 1 609 92A 3WU | (12.6.17) Bosch Power Tools OBJ_BUCH-3206-001.book Page 15 Monday, June 12, 2017 English | 15 Product Description and Specifications Read all safety warnings and all instructions. Failure to follow the warnings and instructions may result in electric shock, fire and/or serious injury. Intended Use The machine is intended for driving in and loosening screws. Product Features The numbering of the product features refers to the illustration of the machine on the graphics page. 1 Screwdriver bit* 2 Tool holder 3 Rotational direction switch 4 Battery charge-control indicator 5 Torque preselection ring 6 Micro USB socket 7 Cover, micro USB port 8 Handle (insulated gripping surface) 9 USB cable* 10 Battery charger* *Accessories shown or described are not part of the standard delivery scope of the product. A complete overview of accessories can be found in our accessories program. 1 609 92A 3WU | (12.6.17) Bosch Power Tools OBJ_BUCH-3206-001.book Page 16 Monday, June 12, 2017 16 | English Technical Data Cordless Screwdriver GO Article number 3 601 JH2 0.. V= 3.6 Rated voltage min-1 0–360 No-load speed Max. torque for hard/soft screwdriving application according to ISO 5393 Nm 5/2.5 mm 5 Max. screw dia. Weight according to EPTA-Procedure 01:2014 kg 0.28 Permitted ambient temperature during charging °C 0...+45 Permitted ambient temperature during operation* and storage °C –20...+50 Battery Li-Ion Ah 1.5 Capacity Wh 6 Energy Number of battery cells 1 h 1.5 Charging time Charging cable connection Micro-USB Recommended chargers V/mA 5/1000 Protection class /II * limited performance at temperatures
BOSCH GO (3.6V) 价格&库存
很抱歉,暂时无法提供与“BOSCH GO (3.6V)”相匹配的价格&库存,您可以联系我们找货
