TDA160VS3300M35*60_VS
    SAMYOUNG(韩国三莹)
    插件,D35xL60mm
    直插铝电解电容 插件,D35xL60mm 3.3mF ±20% Ф35.00 x 60.00mm 160V 2000Hrs@105℃
TDA160VS3300M35*60_VS 数据手册
LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS •1 0 5 ℃ 2 , 0 0 0 H r s a s s u r e d . TDA Series •Non-solvent proof. •For SMPS, Inverter. •RoHS compliant. •Halogen-free capacitors are also available. KMH TDA Downsized SPECIFICATIONS ltem Characteristics Rated Voltage Range Operating Temperature Range 16 ~ 100 VDC 160 ~ 500 VDC -40 ~ +105℃ -25 ~ +105℃ Capacitance Tolerance (at 20℃, at 120Hz) ±20% (M) I=0.02CV(㎂) or 3mA, whichever is smaller. Where, I:Max. leakage current(㎂) C:Nominal capacitance(㎌) V:Rated voltage(VDC) Leakage Current ※ Dissipation Factor(Tan δ) Rated Voltage(VDC) 16 25~35 50~63 100 Tanδ(Max.) 0.40 0.35 0.25 0.20 (at 20℃, 5 minutes) 160~400 420~500 0.15 0.20 (at 20℃, 120Hz) Rated Voltage(VDC) Z(-25℃)/Z(20℃) Z(-40℃)/Z(20℃) Temperature Characteristics (Max.Impedance ratio) 16 4 15 25 3 10 35 3 8 50~63 2 6 100 2 5 160~400 420~500 4 8 (at 120HZ) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours at 105℃. Load Life Capacitance change Tanδ Leakage Current ≦ ±20% of the initial value ≦ 200% of the initial specified value ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after the exposing them at 105℃ for 1,000 hours without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Shelf Life Capacitance change Tanδ Leakage Current ≦ ±20% of the initial value ≦ 200% of the initial specified value ≦ The initial specified value Satisfied characteristics KS C IEC 60384-4 Others ※ For capacitors with CV products › 100,000 Higher Tanδvalue may apply. ※ When the capacitors exceed 1,000㎌, 0.01 shall be added every 1,000㎌ increase. DIMENSIONS OF TDA Series RATED RIPPLE CURRENT When capacitors are operated in any other condition at 120HZ, the maximum ripple current must be multiplied by the figure shown in the table. ØD=Ø22~Ø35 VN/VS type PC board pin-out Frequency multiplying factor Freq.(Hz) 1 6 ~ 5 0 VDC 6 3 ~ 1 0 0 V DC 1 6 0 ~ 2 5 0 VDC 3 1 5 ~ 5 0 0 VDC VDC 200 60 0.95 0.92 0.81 0.77 120 1.00 1.00 1.00 1.00 300 1.03 1.07 1.17 1.16 1k 1.05 1.13 1.32 1.30 10k~ 1.08 1.19 1.45 1.41 Unit(mm) Marking : BROWN SLEEVE, SILVER INK The standard design has no bottom plate. LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF TDA Series ㎌ VDC ØD 16 22 25.4 25 30 35 22 25.4 35 30 35 22×25 1.40 22×30 1.57 22×30 1.72 22×35 1.95 22×40 2.20 22×50 2.55 3,300 3,900 4,700 5,600 6,800 8,200 10,000 12,000 15,000 18,000 22×25 1.57 22×30 1.73 22×30 1.97 22×35 2.22 22×40 2.55 22×45 2.87 22,000 27,000 33,000 39,000 47,000 ㎌ VDC ØD 25.4×25 1.97 25.4×30 2.24 25.4×35 2.58 25.4×40 30×30 2.92 2.88 25.4×45 30×35 3.32 3.29 25.4×50 30×40 35×30 3.78 3.77 3.45 30×45 35×35 4.30 4.26 30×50 35×40 4.81 4.79 35×50 5.43 22×25 1.50 22×25 1.63 22×30 1.86 22×35 2.11 22×40 2.39 22×45 2.69 25.4×25 1.87 25.4×30 2.12 25.4×35 2.42 25.4×40 2.74 25.4×45 3.15 25.4×50 3.54 50 22 25.4 30×25 2.15 30×25 2.39 30×30 2.70 30×35 3.13 30×40 3.54 30×45 4.04 35×25 2.74 35×30 3.27 35×30 3.50 35×35 3.97 35×45 4.73 35×50 5.39 30 35 22 25.4 30 35 22×25 1.19 22×25 1.33 22×30 1.51 22×35 1.73 22×40 1.97 22×50 2.29 1,500 2,200 2,700 3.300 3,900 4,700 5,600 6,800 10,000 30×25 2.15 30×30 2.35 30×35 2.76 30×40 3.30 30×45 3.60 30×50 4.04 35×25 2.48 35×25 2.70 35×30 3.25 35×35 3.56 35×40 4.03 35×45 4.56 25.4×25 1.52 25.4×30 1.74 25.4×35 1.99 25.4×40 2.27 25.4×45 2.54 25.4×50 2.86 30×25 1.99 30×25 2.19 30×30 2.53 30×35 35×30 2.90 2.75 30×40 35×30 3.23 3.23 30×45 35×35 3.72 3.67 35×40 4.37 35×50 4.92 30×25 1.91 30×30 2.24 30×35 2.56 30×40 2.86 30×45 3.22 30×50 3.66 35×25 2.56 35×30 2.79 35×35 3.19 35×40 3.64 35×45 3.90 35×50 4.40 25.4 25.4×25 1.33 25.4×30 1.51 25.4×35 1.71 25.4×40 1.98 25.4×45 2.23 25.4×50 2.53 30 30×25 1.68 30×30 1.95 30×35 2.26 30×40 2.57 30×45 2.88 30×50 3.28 35 35×25 2.17 35×30 2.50 35×35 2.86 35×40 3.27 35×45 3.67 35×50 3.80 Series 12,000 25.4×25 1.80 25.4×30 1.96 25.4×35 2.23 25.4×40 2.53 25.4×45 2.87 25.4×50 3.24 35 TDA 8,200 25.4×25 1.70 25.4×30 1.85 25.4×35 2.18 25.4×35 2.39 25.4×40 2.70 25.4×50 3.30 22 22×25 1.06 22×30 1.32 22×35 1.50 22×40 1.69 22×45 1.94 1,000 1,200 30 100 820 22×25 1.33 22×30 1.50 22×30 1.69 22×35 1.93 22×40 2.16 22×45 2.43 22×50 2.75 25.4 63 560 1,800 22 Case Size ØD×L(mm) Rated Ripple Current(Arms/105℃, 120Hz) 201 LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF TDA Series ㎌ VDC ØD 160 22 25.4 200 30 35 22 25.4 250 30 35 22 25.4 30 35 100 120 150 180 220 270 330 390 470 560 680 820 1,000 22×25 1.20 22×30 1.30 22×30 1.36 22×35 1.46 22×40 1.66 22×45 1.99 22×50 2.18 1,200 1,500 1,800 2,200 ㎌ VDC ØD 22×20 0.53 22×20 0.62 22×25 25.4×20 0.70 0.66 22×25 25.4×20 0.87 0.80 22×30 25.4×20 1.20 1.10 22×30 25.4×25 30×20 1.28 1.29 1.19 25.4×25 30×20 35×20 22×35 1.41 1.39 1.31 1.35 25.4×30 30×25 35×20 22×45 1.56 1.51 1.54 1.41 25.4×30 30×25 35×20 22×45 1.73 1.65 1.68 1.69 25.4×30 30×30 35×25 1.95 2.00 1.91 25.4×40 30×30 35×25 2.14 2.15 2.17 25.4×45 30×35 35×30 2.39 2.37 2.41 25.4×60 30×40 35×35 2.87 2.74 2.79 30×45 35×35 3.14 3.11 30×60 35×45 3.76 3.66 25.4×20 0.64 25.4×20 0.70 25.4×20 0.83 25.4×25 1.21 25.4×25 1.27 25.4×30 1.41 25.4×35 1.53 25.4×35 1.69 25.4×45 1.99 25.4×50 2.21 25.4×60 2.57 315 22 25.4 30×20 1.20 30×25 1.25 30×25 1.50 30×30 1.57 30×30 1.74 30×35 2.00 30×40 2.23 30×45 2.53 30×50 3.01 30×60 3.47 22×25 0.78 22×30 0.96 22×30 1.11 22×35 1.20 22×40 1.45 35×20 22×45 1.30 1.53 35×25 22×50 1.52 1.77 35×25 1.72 35×30 2.04 35×35 2.30 35×35 2.57 35×40 2.99 35×45 3.38 35×60 3.60 350 30 35 22 25.4 35 68 100 120 150 180 220 270 330 390 470 560 680 820 202 22×25 0.64 22×30 0.68 22×30 0.75 22×35 0.82 22×40 0.91 22×45 0.94 25.4×25 0.76 25.4×30 0.83 25.4×30 0.88 25.4×35 0.96 25.4×45 1.13 25.4×50 1.28 30×25 0.85 30×30 1.00 30×35 1.12 30×40 1.28 30×45 1.44 30×50 1.63 22×25 0.56 22×25 0.67 22×30 0.73 22×35 0.83 22×40 0.89 22×45 0.98 35×25 22×50 1.06 1.12 35×30 1.30 35×35 1.42 35×40 1.64 35×45 1.87 35×50 2.07 25.4×25 0.73 25.4×30 0.83 25.4×30 0.89 25.4×35 0.98 25.4×40 1.10 25.4×45 1.24 25.4×60 1.47 25.4×60 1.70 30×20 0.93 30×20 1.10 30×25 1.26 30×25 1.44 30×30 1.57 30×30 1.73 30×35 1.94 30×40 2.10 30×50 2.31 30×60 2.50 35×20 1.17 35×25 1.49 35×25 1.57 35×25 1.72 35×30 1.97 35×35 1.98 35×40 2.30 35×45 2.43 35×50 2.80 400 30 47 82 25.4×20 0.48 25.4×20 0.59 25.4×20 0.75 25.4×25 0.95 25.4×25 1.10 25.4×30 1.20 25.4×35 1.49 25.4×35 1.50 25.4×40 1.74 25.4×50 1.84 25.4×60 2.20 30×25 0.83 30×25 0.91 30×30 0.98 30×30 1.08 30×40 1.24 30×40 1.40 30×45 1.67 30×50 1.87 30×60 2.18 35×25 0.96 35×25 1.12 35×30 1.29 35×35 1.47 35×35 1.65 35×40 1.86 35×50 2.18 35×60 2.53 22 25.4 22×20 0.22 22×25 0.51 22×25 0.55 22×30 0.67 22×35 0.76 22×40 0.82 22×45 0.88 22×50 1.01 25.4×20 0.46 25.4×20 0.53 25.4×25 0.67 25.4×30 0.76 25.4×30 0.80 25.4×35 0.88 25.4×40 0.99 25.4×45 1.12 25.4×50 1.27 25.4×60 1.51 30 30×20 0.60 30×25 0.76 30×25 0.82 30×30 0.89 30×30 0.98 30×35 1.12 30×40 1.28 30×45 1.49 30×50 1.63 30×60 1.88 35 35×20 0.70 35×20 0.80 35×25 0.90 35×25 1.02 35×30 1.16 35×35 1.35 35×35 1.47 35×40 1.62 35×50 1.88 35×60 2.19 Case Size ØD×L(mm) Rated Ripple Current(Arms/105℃, 120Hz) LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF TDA Series ㎌ VDC ØD 420 22 25.4 450 30 35 56 68 82 100 120 150 180 220 270 330 390 470 560 22×25 0.50 22×25 0.51 22×30 0.58 22×35 0.72 22×45 0.79 22×50 0.89 25.4×25 0.63 25.4×30 0.69 25.4×30 0.73 25.4×35 0.74 25.4×40 0.89 25.4×45 1.01 30×25 0.75 30×25 0.75 30×30 0.88 30×35 1.00 30×45 1.19 30×50 1.36 35×25 0.81 35×25 0.87 35×30 1.05 35×35 1.19 35×40 1.39 35×45 1.57 35×50 1.73 22 22×25 0.40 22×30 0.50 22×30 0.55 22×35 0.62 22×40 0.70 22×45 0.77 25.4 25.4×25 0.50 24.5×25 0.54 25.4×30 0.62 25.4×35 0.71 25.4×40 0.75 25.4×45 0.84 25.4×50 0.98 25.4×60 1.17 500 30 30×25 0.64 30×30 0.72 30×30 0.74 30×35 0.87 30×40 0.98 30×45 1.15 30×50 1.38 30×60 1.60 35 35×25 0.73 35×25 0.75 35×30 0.88 35×30 1.00 35×35 1.17 35×40 1.38 35×45 1.56 35×50 1.72 35×60 1.98 22 25.4 30 22×35 25.4×30 30×30 0.48 0.46 0.46 22×40 25.4×35 30×30 0.55 0.53 0.53 22×45 25.4×35 30×35 0.58 0.58 0.56 25.4×40 30×35 0.66 0.65 25.4×45 30×40 0.76 0.75 30×45 0.80 30×50 0.90 30×60 1.10 35 35×30 0.78 35×35 0.81 35×40 0.93 35×45 1.11 35×50 1.28 35×60 1.50 Case Size ØD×L(mm) Rated Ripple Current(Arms/105℃, 120Hz) TDA Series 203
TDA160VS3300M35*60_VS 价格&库存
很抱歉,暂时无法提供与“TDA160VS3300M35*60_VS”相匹配的价格&库存,您可以联系我们找货
