TDA200VS3900M35*70_VS 数据手册
LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS
•1 0 5 ℃ 2 , 0 0 0 H r s a s s u r e d .
TDA Series
•Non-solvent proof.
•For SMPS, Inverter.
•RoHS compliant.
•Halogen-free capacitors are also available.
KMH
TDA
Downsized
SPECIFICATIONS
ltem
Characteristics
Rated Voltage Range
Operating Temperature Range
16 ~ 100 VDC
160 ~ 500 VDC
-40 ~ +105℃
-25 ~ +105℃
Capacitance Tolerance
(at 20℃, at 120Hz)
±20% (M)
I=0.02CV(㎂) or 3mA, whichever is smaller.
Where, I:Max. leakage current(㎂) C:Nominal capacitance(㎌)
V:Rated voltage(VDC)
Leakage Current
※ Dissipation Factor(Tan δ)
Rated Voltage(VDC)
16
25~35
50~63
100
Tanδ(Max.)
0.40
0.35
0.25
0.20
(at 20℃, 5 minutes)
160~400 420~500
0.15
0.20
(at 20℃, 120Hz)
Rated Voltage(VDC)
Z(-25℃)/Z(20℃)
Z(-40℃)/Z(20℃)
Temperature Characteristics
(Max.Impedance ratio)
16
4
15
25
3
10
35
3
8
50~63
2
6
100
2
5
160~400 420~500
4
8
(at 120HZ)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the
rated voltage is applied for 2,000 hours at 105℃.
Load Life
Capacitance change
Tanδ
Leakage Current
≦ ±20% of the initial value
≦ 200% of the initial specified value
≦ The initial specified value
exposing them at 105℃ for 1,000 hours without voltage applied. The rated voltage shall be applied
to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours
before the measurements.
Shelf Life
Capacitance change
Tanδ
Leakage Current
Satisfied characteristics KS C IEC 60384-4
Others
※ For capacitors with CV products › 100,000 Higher Tanδvalue may apply.
※ When the capacitors exceed 1,000㎌, 0.01 shall be added every 1,000㎌ increase.
DIMENSIONS OF TDA Series
RATED RIPPLE CURRENT
When capacitors are operated in any other condition
at 120HZ, the maximum ripple current must be
multiplied by the figure shown in the table.
ØD=Ø22~Ø35
VN/VS type
PC board pin-out
Frequency multiplying factor
Freq.(Hz)
1 6 ~ 5 0 VDC
6 3 ~ 1 0 0 V DC
1 6 0 ~ 2 5 0 VDC
3 1 5 ~ 5 0 0 VDC
VDC
200
60
0.95
0.92
0.81
0.77
120
1.00
1.00
1.00
1.00
300
1.03
1.07
1.17
1.16
1k
1.05
1.13
1.32
1.30
10k~
1.08
1.19
1.45
1.41
Unit(mm)
Marking : BROWN SLEEVE, SILVER INK
The standard design has no bottom plate.
RATINGS OF TDA Series
VDC
ØD
16
22
25.4
25
30
35
22
25.4
35
30
35
22×25
1.40
22×30
1.57
22×30
1.72
22×35
1.95
22×40
2.20
22×50
2.55
3,300
3,900
4,700
5,600
6,800
8,200
10,000
12,000
15,000
18,000
22×25
1.57
22×30
1.73
22×30
1.97
22×35
2.22
22×40
2.55
22×45
2.87
22,000
27,000
33,000
39,000
47,000
VDC
ØD
25.4×25
1.97
25.4×30
2.24
25.4×35
2.58
25.4×40 30×30
2.92
2.88
25.4×45 30×35
3.32
3.29
25.4×50 30×40 35×30
3.78
3.77
3.45
30×45 35×35
4.30
4.26
30×50 35×40
4.81
4.79
35×50
5.43
22×25
1.50
22×25
1.63
22×30
1.86
22×35
2.11
22×40
2.39
22×45
2.69
25.4×25
1.87
25.4×30
2.12
25.4×35
2.42
25.4×40
2.74
25.4×45
3.15
25.4×50
3.54
50
22
25.4
30×25
2.15
30×25
2.39
30×30
2.70
30×35
3.13
30×40
3.54
30×45
4.04
35×25
2.74
35×30
3.27
35×30
3.50
35×35
3.97
35×45
4.73
35×50
5.39
30
35
22
25.4
30
35
22×25
1.19
22×25
1.33
22×30
1.51
22×35
1.73
22×40
1.97
22×50
2.29
1,500
2,200
2,700
3.300
3,900
4,700
5,600
6,800
10,000
30×25
2.15
30×30
2.35
30×35
2.76
30×40
3.30
30×45
3.60
30×50
4.04
35×25
2.48
35×25
2.70
35×30
3.25
35×35
3.56
35×40
4.03
35×45
4.56
25.4×25
1.52
25.4×30
1.74
25.4×35
1.99
25.4×40
2.27
25.4×45
2.54
25.4×50
2.86
30×25
1.99
30×25
2.19
30×30
2.53
30×35 35×30
2.90
2.75
30×40 35×30
3.23
3.23
30×45 35×35
3.72
3.67
35×40
4.37
35×50
4.92
30×25
1.91
30×30
2.24
30×35
2.56
30×40
2.86
30×45
3.22
30×50
3.66
35×25
2.56
35×30
2.79
35×35
3.19
35×40
3.64
35×45
3.90
35×50
4.40
25.4
25.4×25
1.33
25.4×30
1.51
25.4×35
1.71
25.4×40
1.98
25.4×45
2.23
25.4×50
2.53
30
30×25
1.68
30×30
1.95
30×35
2.26
30×40
2.57
30×45
2.88
30×50
3.28
35
35×25
2.17
35×30
2.50
35×35
2.86
35×40
3.27
35×45
3.67
35×50
3.80
Series
12,000
25.4×25
1.80
25.4×30
1.96
25.4×35
2.23
25.4×40
2.53
25.4×45
2.87
25.4×50
3.24
35
TDA
8,200
25.4×25
1.70
25.4×30
1.85
25.4×35
2.18
25.4×35
2.39
25.4×40
2.70
25.4×50
3.30
22
22×25
1.06
22×30
1.32
22×35
1.50
22×40
1.69
22×45
1.94
1,000
1,200
30
100
820
22×25
1.33
22×30
1.50
22×30
1.69
22×35
1.93
22×40
2.16
22×45
2.43
22×50
2.75
25.4
63
560
1,800
22
Case Size ØD×L(mm)
Rated Ripple Current(Arms/105℃, 120Hz)
201
VDC
ØD
160
22
25.4
200
30
35
22
25.4
250
30
35
22
25.4
30
35
100
120
150
180
220
270
330
390
470
560
680
820
1,000
22×25
1.20
22×30
1.30
22×30
1.36
22×35
1.46
22×40
1.66
22×45
1.99
22×50
2.18
1,200
1,500
1,800
2,200
VDC
ØD
22×20
0.53
22×20
0.62
22×25
25.4×20
0.70
0.66
22×25
25.4×20
0.87
0.80
22×30
25.4×20
1.20
1.10
22×30
25.4×25 30×20
1.28
1.29
1.19
25.4×25 30×20 35×20 22×35
1.41
1.39
1.31
1.35
25.4×30 30×25 35×20 22×45
1.56
1.51
1.54
1.41
1.73
1.65
1.68
1.69
25.4×30 30×30 35×25
1.95
2.00
1.91
25.4×40 30×30 35×25
2.14
2.15
2.17
25.4×45 30×35 35×30
2.39
2.37
2.41
25.4×60 30×40 35×35
2.87
2.74
2.79
30×45 35×35
3.14
3.11
30×60 35×45
3.76
3.66
25.4×20
0.64
25.4×20
0.70
25.4×20
0.83
25.4×25
1.21
25.4×25
1.27
25.4×30
1.41
25.4×35
1.53
25.4×35
1.69
25.4×45
1.99
25.4×50
2.21
25.4×60
2.57
315
22
25.4
30×20
1.20
30×25
1.25
30×25
1.50
30×30
1.57
30×30
1.74
30×35
2.00
30×40
2.23
30×45
2.53
30×50
3.01
30×60
3.47
22×25
0.78
22×30
0.96
22×30
1.11
22×35
1.20
22×40
1.45
35×20 22×45
1.30
1.53
35×25 22×50
1.52
1.77
35×25
1.72
35×30
2.04
35×35
2.30
35×35
2.57
35×40
2.99
35×45
3.38
35×60
3.60
350
30
35
22
25.4
35
68
100
120
150
180
220
270
330
390
470
560
680
820
202
22×25
0.64
22×30
0.68
22×30
0.75
22×35
0.82
22×40
0.91
22×45
0.94
25.4×25
0.76
25.4×30
0.83
25.4×30
0.88
25.4×35
0.96
25.4×45
1.13
25.4×50
1.28
30×25
0.85
30×30
1.00
30×35
1.12
30×40
1.28
30×45
1.44
30×50
1.63
22×25
0.56
22×25
0.67
22×30
0.73
22×35
0.83
22×40
0.89
22×45
0.98
35×25 22×50
1.06
1.12
35×30
1.30
35×35
1.42
35×40
1.64
35×45
1.87
35×50
2.07
25.4×25
0.73
25.4×30
0.83
25.4×30
0.89
25.4×35
0.98
25.4×40
1.10
25.4×45
1.24
25.4×60
1.47
25.4×60
1.70
30×20
0.93
30×20
1.10
30×25
1.26
30×25
1.44
30×30
1.57
30×30
1.73
30×35
1.94
30×40
2.10
30×50
2.31
30×60
2.50
35×20
1.17
35×25
1.49
35×25
1.57
35×25
1.72
35×30
1.97
35×35
1.98
35×40
2.30
35×45
2.43
35×50
2.80
400
30
47
82
25.4×20
0.48
25.4×20
0.59
25.4×20
0.75
25.4×25
0.95
25.4×25
1.10
25.4×30
1.20
25.4×35
1.49
25.4×35
1.50
25.4×40
1.74
25.4×50
1.84
25.4×60
2.20
30×25
0.83
30×25
0.91
30×30
0.98
30×30
1.08
30×40
1.24
30×40
1.40
30×45
1.67
30×50
1.87
30×60
2.18
35×25
0.96
35×25
1.12
35×30
1.29
35×35
1.47
35×35
1.65
35×40
1.86
35×50
2.18
35×60
2.53
22
25.4
22×20
0.22
22×25
0.51
22×25
0.55
22×30
0.67
22×35
0.76
22×40
0.82
22×45
0.88
22×50
1.01
25.4×20
0.46
25.4×20
0.53
25.4×25
0.67
25.4×30
0.76
25.4×30
0.80
25.4×35
0.88
25.4×40
0.99
25.4×45
1.12
25.4×50
1.27
25.4×60
1.51
30
30×20
0.60
30×25
0.76
30×25
0.82
30×30
0.89
30×30
0.98
30×35
1.12
30×40
1.28
30×45
1.49
30×50
1.63
30×60
1.88
35
35×20
0.70
35×20
0.80
35×25
0.90
35×25
1.02
35×30
1.16
35×35
1.35
35×35
1.47
35×40
1.62
35×50
1.88
35×60
2.19
Case Size ØD×L(mm)
VDC
ØD
420
22
25.4
450
30
35
56
68
82
100
120
150
180
220
270
330
390
470
560
22×25
0.50
22×25
0.51
22×30
0.58
22×35
0.72
22×45
0.79
22×50
0.89
25.4×25
0.63
25.4×30
0.69
25.4×30
0.73
25.4×35
0.74
25.4×40
0.89
25.4×45
1.01
30×25
0.75
30×25
0.75
30×30
0.88
30×35
1.00
30×45
1.19
30×50
1.36
35×25
0.81
35×25
0.87
35×30
1.05
35×35
1.19
35×40
1.39
35×45
1.57
35×50
1.73
22
22×25
0.40
22×30
0.50
22×30
0.55
22×35
0.62
22×40
0.70
22×45
0.77
25.4
25.4×25
0.50
24.5×25
0.54
25.4×30
0.62
25.4×35
0.71
25.4×40
0.75
25.4×45
0.84
25.4×50
0.98
25.4×60
1.17
500
30
30×25
0.64
30×30
0.72
30×30
0.74
30×35
0.87
30×40
0.98
30×45
1.15
30×50
1.38
30×60
1.60
35
35×25
0.73
35×25
0.75
35×30
0.88
35×30
1.00
35×35
1.17
35×40
1.38
35×45
1.56
35×50
1.72
35×60
1.98
22
25.4
30
22×35 25.4×30 30×30
0.48
0.46
0.46
22×40 25.4×35 30×30
0.55
0.53
0.53
22×45 25.4×35 30×35
0.58
0.58
0.56
25.4×40 30×35
0.66
0.65
25.4×45 30×40
0.76
0.75
30×45
0.80
30×50
0.90
30×60
1.10
35
35×30
0.78
35×35
0.81
35×40
0.93
35×45
1.11
35×50
1.28
35×60
1.50
Case Size ØD×L(mm)
TDA
Series
203
