TLA450VS220M30*30_VS
    SAMYOUNG(韩国三莹)
    插件,D30xL30mm
    直插铝电解电容 插件,D30xL30mm 220µF ±20% Ф30.00 x 30.00mm 450V 3000Hrs@105℃
TLA450VS220M30*30_VS 数据手册
LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS TLA Series •105℃ 3,000Hrs assured. •Non-solvent proof. •Long Life. •For SMPS, Inverter. •RoHS compliant. •Halogen-free capacitors are also available. TDA TLA Long Life SPECIFICATIONS Item Characteristics Rated Voltage Range Operating Temperature Range 1 6 0 ~ 5 0 0 VDC -25 ~ +105℃ Capacitance Tolerance ±20%(M) (at 20℃, 120Hz) I=0.02CV or 3m A, whichever is smaller. Where, I:Leakage Current(μA), C:Nominal capacitance(μ F), V:Rated voltage(VDC) (at 20℃, 5minutes) Leakage Current ※ Dissipation Factor(Tan δ) Rated voltage(VDC) 160~500 Tan δ(Max.) 0.20 (at 20℃, 120Hz) Temperature Characteristics (Max. Impedance ratio) Rated voltage(VDC) 160~400 420~500 4 8 Z(-25℃)/Z(20℃) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 3,000 hours at 105℃. Capacitance change ≦ ±20% of the initial value Tan δ ≦ 200% of the initial specified value Leakage current ≦ The initial specified value Load Life The following specifications shall be satisfied when the capacitors are restored to 20℃ after the exposing them at 105℃ for 1,000 hours without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Capacitance change ≦ ±20% of the initial value Tan δ ≦ 200% of the initial specified value ≦ The initial specified value Leakage current Shelf Life Others Satisfied characteristics KS C IEC 60384-4 ※For capacitors with CV products ≻100,000 higher Tanδvalue may apply. When the capacitance exceeds 1,000μF, 0.01 shall be added every 1,000μF increase. DIMENSIONS OF TLA Series RATED RIPPLE CURRENT When capacitor are operated in any other condition at 120Hz, the maximum ripple current must be multiplied by the figure shown in the table. ØD=Ø22~Ø35 Unit(mm) VN/VS type PC board pin-out Frequency multiplying factor 300 1k 10k~ 160~250VDC 0.81 1.00 1.17 1.32 1.45 350~500VDC 0.77 1.00 1.16 1.30 1.41 Marking : BROWN SLEEVE, SILVER INK The standard design has no bottom plate. Series 120 TLA Freq.(Hz) 60 VDC 217 LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF TLA Series VDC ØD μF 160 22 25.4 200 30 35 22 25.4 250 30 35 220 22×25 1.10 22×30 1.25 22×30 1.35 22×40 1.50 22×45 1.67 22×45 1.78 22×25 1.20 22×25 1.26 22×30 1.33 22×35 1.60 22×40 1.82 22×45 2.04 22×50 2.25 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 25.4×25 1.30 25.4×25 1.33 25.4×30 1.60 25.4×30 1.82 25.4×35 2.04 25.4×40 2.25 25.4×45 2.49 25.4×60 2.97 30×25 1.60 30×25 1.82 30×30 2.04 30×30 2.25 30×35 2.49 30×40 2.84 30×45 3.32 30×60 3.86 VDC ØD μF 35×25 2.04 35×25 2.25 35×30 2.49 35×30 2.84 35×35 3.00 35×45 3.50 25.4×25 1.25 25.4×25 1.35 25.4×30 1.50 25.4×30 1.60 25.4×35 1.78 25.4×45 2.04 25.4×50 2.30 25.4×60 2.66 100 120 150 180 220 270 330 390 470 560 680 218 35×25 1.78 35×25 2.04 35×30 2.30 35×35 2.65 35×40 3.08 35×45 3.48 35×50 3.78 22 25.4 22×25 0.55 22×25 0.69 22×30 0.75 22×35 0.82 22×40 0.92 22×45 1.05 22×50 1.16 25.4×25 0.75 25.4×30 0.83 25.4×30 0.92 25.4×35 1.04 25.4×40 1.18 25.4×45 1.29 25.4×50 1.51 25.4×60 1.66 30 25.4×25 0.95 25.4×25 1.18 25.4×35 1.30 25.4×35 1.49 25.4×35 1.65 25.4×40 1.80 25.4×50 2.00 25.4×60 2.20 30×25 1.30 30×25 1.49 30×30 1.65 30×30 1.80 30×35 2.00 30×40 2.30 30×50 2.47 30×60 2.85 35 35×25 1.65 35×25 1.80 35×30 2.00 35×35 2.30 35×40 2.47 35×45 2.60 35×50 3.00 35×60 3.42 Case Size ØD×L(mm) Rated Ripple Current(Arms/105℃, 120Hz) 400 350 30 35 68 82 30×25 1.50 30×25 1.60 30×30 1.78 30×30 2.04 30×35 2.30 30×40 2.65 30×50 3.08 30×60 3.49 25.4 22×25 0.78 22×30 1.00 22×30 1.18 22×35 1.30 22×40 1.49 22×45 1.65 22×50 1.67 180 270 22 30×25 0.82 30×25 0.90 30×30 1.02 30×30 1.17 30×35 1.34 30×40 1.51 30×45 1.65 30×50 1.85 30×60 2.15 35×25 1.04 35×25 1.20 35×30 1.22 35×35 1.47 35×35 1.69 35×40 1.90 35×50 1.99 22 22×25 0.55 22×25 0.64 22×30 0.70 22×35 0.75 22×40 0.88 22×45 0.98 22×50 1.10 25.4 25.4×25 0.70 25.4×25 0.75 25.4×30 0.88 25.4×35 0.98 25.4×40 1.10 25.4×45 1.22 25.4×50 1.44 25.4×60 1.51 30 30×25 0.80 30×25 0.88 30×30 0.98 30×30 1.10 30×35 1.22 30×40 1.44 30×45 1.60 30×50 1.90 30×60 2.10 35 35×25 0.98 35×25 1.0 35×30 1.22 35×30 1.44 35×35 1.60 35×40 1.90 35×45 2.12 35×60 2.27 LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF TLA Series VDC ØD μF 450 420 22 25.4 30 35 56 22×25 0.50 22×25 0.64 22×30 0.70 22×35 0.75 22×40 0.88 22×45 0.95 22×50 1.10 68 82 100 120 150 180 220 270 330 25.4×25 0.58 25.4×25 0.70 25.4×30 0.75 25.4×35 0.88 25.4×35 0.95 25.4×45 1.10 25.4×50 1.22 25.4×60 1.41 390 470 VDC ØD μF 56 68 82 100 120 150 180 220 270 330 30×25 0.73 30×25 0.88 30×30 0.95 30×35 1.10 30×40 1.22 30×45 1.45 30×50 1.55 30×60 1.79 35×25 0.94 35×25 1.10 35×30 1.22 35×35 1.45 35×40 1.55 35×45 1.90 35 22 25.4 22×25 0.40 22×30 0.53 22×30 0.64 22×35 0.69 22×40 0.80 22×45 0.88 22×50 1.00 25.4×25 0.50 25.4×25 0.64 25.4×30 0.69 25.4×30 0.80 25.4×35 0.88 25.4×40 1.00 25.4×45 1.12 25.4×50 1.18 Case Size ØD×L(mm) Rated Ripple Current(Arms/105℃, 120Hz) 30 30×25 0.64 30×25 0.80 30×30 0.88 30×30 1.00 30×35 1.12 30×40 1.28 30×50 1.45 30×60 1.51 35 35×25 0.73 35×25 0.75 35×30 1.12 35×35 1.28 35×40 1.45 35×40 1.55 35×50 1.85 500 22 25.4 30 22×35 0.46 22×40 0.45 22×45 0.56 25.4×30 0.46 25.4×35 0.53 25.4×35 0.58 25.4×40 0.65 25.4×45 0.75 30×30 0.48 30×30 0.55 30×35 0.58 30×35 0.66 30×40 0.76 30×45 0.80 30×50 0.90 30×60 1.10 35×30 0.78 35×35 0.81 35×40 0.93 35×45 1.11 35×50 1.28 35×60 1.50 TLA Series 219
物料型号:TLA Series
器件简介:TLA系列是大型铝电解电容器,具有105℃下3000小时的保证寿命,非溶剂型,长寿命,适用于SMPS(开关电源)、逆变器,符合RoHS标准,也提供无卤素电容器。
引脚分配:文档中提到了PC板引脚分配,例如VN/VS型电容器的引脚长度分别为5.8+1(VN)和4.0±0.5(VS)。
参数特性: - 额定电压范围:160~500V - 工作温度范围:-25~+105°C - 电容公差:±20%(M) - 漏电流:在20°C, 120Hz时,1μA或0.02CV,取较小者 - 损耗角正切(Tan):最大0.20(在20°C, 120Hz) - 温度特性:在-25°C和20°C之间的最大阻抗比(Z(-25°C)/Z(20°C))分别为4和8(在120Hz)
功能详解:文档中提到了电容器在105°C下3000小时后的负载寿命和在105°C下1000小时的无电压货架寿命,以及在这些条件下的电容变化、损耗角正切和漏电流的规格。
应用信息:适用于开关电源(SMPS)和逆变器。
封装信息:提供了不同额定电压和尺寸的电容器的尺寸和额定纹波电流信息。
TLA450VS220M30*30_VS 价格&库存
很抱歉,暂时无法提供与“TLA450VS220M30*30_VS”相匹配的价格&库存,您可以联系我们找货
