TLC315VS1000M35*50_VS
    SAMYOUNG(韩国三莹)
    插件,D35xL50mm
    直插铝电解电容 插件,D35xL50mm 1mF ±20% Ф35.00 x 50.00mm 315V 5000Hrs@105℃
TLC315VS1000M35*50_VS 数据手册
LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS TLC(LXG) Series •1 0 5 ℃ 5 , 0 0 0 H r s a s s u r e d . •Non-solvent proof. •Long Life. •For SMPS, Inverter. •RoHS compliant. •Halogen-free capacitors are also available. TLC TLA (LXG) High Reliability Long Life SPECIFICATIONS ltem Characteristics Rated Voltage Range Operating Temperature Range 10 ~ 100 VDC 200 ~ 500 VDC -40 ~ +105℃ -25 ~ +105℃ Capacitance Tolerance ±20%(M) Leakage Current I=0.02CV or 3mA, whichever is smaller. Where, I: Leakage current (㎂) C: Nominal capacitance (㎌) V: Rated voltage (VDC) (at 20℃, 5 minutes) ※ Dissipation Factor(Tan δ) Temperature Characteristics (Max.Impedance ratio) Rated Voltage(VDC) Tanδ(Max.) (at 20℃, 120Hz) 10 0.60 16 0.45 25 0.30 35 0.25 50 0.20 Rated Voltage(VDC) Z(-25℃)/Z(20℃) 10~16 25 35 50~63 80~100 4 3 3 2 2 Z(-40℃)/Z(20℃) 15 10 8 6 5 63~400 420~500 0.15 0.20 (at 20℃,120Hz) 200~400 420~500 8 4 - (at 120Hz) Load Life The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 5,000 hours at 105℃. Capacitance change ≦ ±25% of the initial value Tanδ ≦ 250% of the initial specified value Leakage current ≦ The initial specified value Shelf Life The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them at 105℃ for 1,000 hours without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Capacitance change ≦ ±20% of the initial value Tanδ ≦ 150% of the initial specified value Leakage current ≦ The initial specified value Others Satisfied characteristics KS C IEC 60384-4 ※ For capacitors with CV products 100,000 higher Tanδvalue may apply. When the capacitance exceeds 1,000㎌ , 0.01 shall be added every 1,000㎌ increase. DIMENSIONS OF TLC(LXG) Series RATED RIPPLE CURRENT When capacitors are operated in any other conditions at 120Hz the maximum ripple current must be multiplied by the figure shown in the table. ØD=Ø22~Ø35 VN/VS type PC board pin-out Frequency multiplying factor Freq.(Hz) VDC 1 0 ~ 5 0 V DC 60 0.95 120 1.00 300 1.03 1k 1.05 10k~ 1.08 6 3 ~ 1 0 0 V DC 0.92 1.00 1.07 1.13 1.19 2 0 0 ~ 2 5 0 V DC 3 5 0 ~ 5 0 0 V DC 0.81 0.77 1.00 1.00 1.17 1.16 1.32 1.30 1.45 1.41 228 Unit(mm) Marking : BROWN SLEEVE, SILVER INK The standard design has no bottom plate. LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF TLC(LXG) Series ㎌ VDC ØD 10 22 25.4 16 30 35 22 25 25.4 30 35 22×25 1.31 22×30 1.51 22×35 1.70 22×40 1.92 22×45 2.05 22×50 2.45 3,900 4,700 22×25 1.44 22×30 1.66 22×35 1.87 22×40 2.12 22×45 2.32 22×50 2.74 5,600 6,800 8,200 10,000 12,000 15,000 18,000 22×25 1.30 22×30 1.49 22×30 1.65 22×35 1.85 22×40 2.12 22×50 2.45 22,000 27,000 25.4×25 1.64 25.4×30 1.85 25.4×35 2.16 25.4×40 2.43 25.4×45 2.62 25.4×50 3.11 33,000 39,000 30×25 1.89 30×25 2.06 30×30 2.37 30×35 2.73 30×40 3.13 30×45 3.34 30×50 3.99 47,000 ㎌ VDC ØD 35×25 2.42 35×30 2.79 35×30 3.00 35×35 3.49 35×40 3.96 35×50 4.62 25.4×25 1.66 25.4×30 1.87 25.4×30 2.07 25.4×35 2.37 25.4×40 2.71 25.4×50 3.11 35 22 25.4 30×25 2.11 30×30 2.37 30×30 2.58 30×35 3.02 30×40 3.46 30×50 4.07 35×25 2.42 35×25 2.63 35×30 3.09 35×35 3.49 35×40 4.04 35×45 4.29 35×50 5.16 30 35 22 25.4 22×25 1.02 22×30 1.17 22×35 1.33 22×40 1.51 22×45 1.68 22×50 1.91 1,500 1,800 2,700 3,300 3,900 4,700 5,600 6,800 8,200 12,000 18,000 25.4×25 1.51 25.4×30 1.69 25.4×30 1.87 25.4×35 2.14 25.4×40 2.43 25.4×50 2.78 30×25 1.77 30×30 1.98 30×30 2.14 30×35 2.50 30×40 2.86 30×50 3.32 35×25 2.03 35×25 2.20 35×30 2.55 35×35 2.88 35×40 3.30 35×50 4.29 30×25 1.90 30×30 2.15 30×30 2.31 30×35 2.70 30×40 3.13 30×50 3.64 35 35×25 2.19 35×25 2.35 35×30 2.76 35×35 3.16 35×40 3.61 35×45 4.00 35×50 4.70 30 35 30×25 1.50 30×30 1.70 30×30 1.84 30×35 2.11 30×40 2.39 30×50 2.79 22 22×25 1.00 22×30 1.15 22×35 1.32 22×40 1.49 22×45 1.63 22×50 1.92 35×25 1.74 35×25 1.89 35×30 2.16 35×35 2.41 35×40 2.78 35×45 3.06 35×50 3.57 25.4 25.4×25 1.15 25.4×25 1.28 25.4×30 1.45 25.4×35 1.67 25.4×40 1.90 25.4×50 2.20 30 30×25 1.48 30×30 1.68 30×35 1.93 30×35 2.07 30×40 2.41 30×50 2.80 35 35×25 1.71 35×25 1.83 35×30 2.18 35×35 2.43 35×40 2.78 35×45 3.04 35×50 3.55 TLC(LXG) 10,000 25.4×25 1.41 25.4×30 1.58 25.4×30 1.70 25.4×35 1.98 25.4×40 2.24 25.4×50 2.57 25.4×25 1.17 25.4×30 1.32 25.4×30 1.47 25.4×35 1.70 25.4×40 1.89 25.4×45 2.05 25.4×50 2.38 30 63 1,200 22×25 1.10 22×25 1.21 22×30 1.42 22×35 1.58 22×40 1.78 22×45 1.96 22×50 2.26 25.4 50 1,000 2,200 22 Case Size ØD×L(mm) Rated Ripple Current(Arms/105℃, 120Hz) Series 229 LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF TLC(LXG) Series ㎌ VDC ØD 80 22 25.4 100 30 35 22 25.4 200 30 35 180 270 330 22×25 0.78 22×25 0.85 22×30 0.99 22×35 1.12 22×40 1.26 22×45 1.39 22×50 1.60 390 470 560 680 820 1,000 1,200 1,500 1,800 22×25 0.97 22×30 1.12 22×35 1.27 22×40 1.42 22×45 1.60 22×50 1.84 2,200 25.4×25 1.23 25.4×30 1.39 25.4×35 1.62 25.4×40 1.82 25.4×50 2.11 2,700 3,300 30×25 1.41 30×25 1.57 30×30 1.78 30×35 2.05 30×40 2.35 30×50 2.75 4,700 ㎌ VDC ØD 25.4×25 0.98 25.4×25 1.08 25.4×30 1.23 25.4×35 1.41 25.4×40 1.59 25.4×50 1.86 35×25 1.82 35×30 2.09 35×35 2.37 35×40 2.73 35×50 3.46 250 22 25.4 30×25 1.25 30×30 1.42 30×35 1.61 30×40 1.87 30×45 2.07 30×50 2.40 35 22 25.4 22×25 0.49 22×30 0.61 22×35 0.65 22×40 0.70 22×45 0.79 22×50 0.91 82 100 120 180 220 270 330 390 470 560 680 1,000 230 25.4×25 0.83 25.4×25 0.91 25.4×30 1.04 25.4×35 1.20 25.4×40 1.34 25.4×50 1.53 30×25 1.06 30×30 1.20 30×30 1.30 30×35 1.49 30×40 1.69 30×50 1.98 35×25 1.28 35×25 1.38 35×30 1.53 35×35 1.70 35×40 1.96 35×50 2.53 25.4×25 0.64 25.4×30 0.69 25.4×35 0.75 25.4×40 0.90 25.4×50 1.16 30 25.4×25 1.01 25.4×30 1.15 25.4×30 1.25 25.4×35 1.44 25.4×40 1.60 25.4×50 1.85 350 30 68 22×25 0.71 22×30 0.83 22×35 0.94 22×40 1.06 22×45 1.15 22×50 1.35 25.4 35×25 1.45 35×25 1.58 35×30 1.85 35×35 2.07 35×40 2.39 35×50 2.81 30×25 1.18 30×25 1.28 30×30 1.44 30×35 1.63 30×40 1.86 30×45 2.04 30×50 2.39 35 35×25 1.53 35×25 1.66 35×30 1.84 35×35 2.06 35×40 2.38 35×50 2.76 400 30 35 56 150 22 22×25 0.79 22×30 1.01 22×35 1.15 22×40 1.28 22×50 1.46 30×25 0.70 30×25 0.78 30×30 0.89 30×35 1.03 30×40 1.18 30×50 1.49 35×25 0.86 35×25 0.94 35×30 1.04 35×35 1.30 35×40 1.49 35×45 1.54 35×50 1.73 Case Size ØD×L (mm) Rated Ripple Current (Arms/105℃, 120Hz) 22 22×25 0.47 22×30 0.57 22×35 0.65 22×35 0.71 22×40 0.81 22×50 0.92 25.4 25.4×25 0.53 25.4×25 0.58 25.4×30 0.71 25.4×35 0.81 25.4×40 0.90 25.4×45 1.03 25.4×50 1.16 30 30×25 0.71 30×25 0.80 30×30 0.92 30×35 1.03 30×40 1.18 30×50 1.35 35 35×25 0.82 35×25 0.93 35×30 1.05 35×35 1.26 35×40 1.33 35×45 1.50 35×50 1.70 LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF TLC(LXG) Series ㎌ VDC ØD 420 22 25.4 450 30 35 47 56 68 82 100 120 150 180 220 270 330 390 470 22×30 0.58 22×30 0.65 22×35 0.73 22×40 0.83 22×45 0.95 22×50 1.07 25.4×30 0.66 25.4×30 0.73 25.4×35 0.83 25.4×40 0.95 25.4×40 1.07 25.4×50 1.21 30×30 0.83 30×30 0.95 30×35 1.07 30×40 1.21 30×45 1.38 30×50 1.60 22 22×25 0.47 22×30 0.53 22×35 0.59 22×35 0.66 22×40 0.75 22×45 0.84 22×50 0.95 35×30 1.08 35×30 1.22 35×35 1.41 35×40 1.60 35×45 1.80 35×50 1.92 25.4 25.4×30 0.59 25.4×30 0.66 25.4×35 0.73 25.4×35 0.83 25.4×40 0.95 25.4×45 1.07 25.4×50 1.21 500 30 30×30 0.74 30×30 0.83 30×35 0.95 30×35 1.07 30×40 1.21 30×45 1.38 30×50 1.60 35 35×30 0.84 35×30 0.96 35×30 1.08 35×35 1.22 35×40 1.41 35×45 1.61 35×50 1.80 22 25.4 30 22×35 0.37 22×35 25.4×30 30×30 0.45 0.44 0.41 22×40 25.4×35 30×30 0.52 0.51 0.54 22×45 25.4×35 30×35 0.58 0.62 0.62 25.4×40 30×35 0.64 0.63 25.4×45 30×40 0.71 0.71 30×45 0.76 30×50 0.89 30×60 1.05 35 35×30 0.72 35×30 0.80 35×40 0.90 35×45 1.01 35×50 1.44 35×60 1.55 Case Size ØD×L(mm) Rated Ripple Current(Arms/105℃, 120Hz) TLC(LXG) Series 231
TLC315VS1000M35*50_VS 价格&库存
很抱歉,暂时无法提供与“TLC315VS1000M35*50_VS”相匹配的价格&库存,您可以联系我们找货
