DL80VS4700M25.4*50_VS
    SAMYOUNG(韩国三莹)
    插件,D25.4xL50mm
    直插铝电解电容 插件,D25.4xL50mm 4.7mF ±20% Ф25.40 x 50.00mm 80V 2000Hrs@85℃
DL80VS4700M25.4*50_VS 数据手册
LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS •85℃ 2,000Hrs assured. DL Series •Non-solvent proof. •For AMP, AVR. •General Audio grade. •RoHS compliant.. •Halogen-free capacitors are also available. SPECIFICATIONS ltem Characteristics Rated Voltage Range 50 ~ 100 VDC Operating Temperature Range -40~+85℃ ±20%(M) Capacitance Tolerance (at 20℃, 120Hz) I=0.01CV or 2mA, whichever is smaller. Where, I: Leakage current (㎂) C: Nominal capacitance (㎌) V: Rated voltage (VDC) Leakage Current Dissipation Factor(Tan δ) (at 20℃, 5 minutes) Refer to the below table. (at 20℃, 120Hz) Z(-25℃)/Z(20℃) Z(-40℃)/Z(20℃) Temperature Characteristics (Max. Impedance ratio) 4 15 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied for 2,000 hours at 85℃. Load Life Capacitance change ≦ ±20% of the initial value. Tanδ ≦ 200% of the initial specified value. Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after the exposing them at 85℃ for 1,000 hours without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Capacitance change ≦ ±20% of the initial value. Tanδ ≦ 200% of the initial specified value. Leakage current ≦ The initial specified value. Shelf Life 5,000 times (at 70℃) After this test is completed, the capacitors shall be satisfied the following specifications Capacitance change ≦ ±20% of the initial value. Tanδ ≦ 150% of the initial specified value. Leakage current ≦ The initial specified value. where, Charge resistance : 2.2Ω Charge conditions: rated volt. 1(A) Discharge resistance: 100Ω Charge and discharge time:30 sec(each) Charge & Discharge Others Satisfied characteristics KS C IEC 60384-4 RATINGS OF DL Series ㎌ V DC 50 63 80 0.20 0.20 1.81 1.86 25.4×40 30×30 0.20 0.25 1.96 1.75 4,700 25.4×40 30×30 0.25 0.25 2.09 2.09 25.4×50 30×40 35×35 30×50 35×40 0.25 0.25 0.25 0.35 0.35 2.65 2.67 2.67 2.63 2.61 25.4×50 30×40 35×30 30×50 35×40 0.25 0.25 0.30 0.30 0.30 2.21 2.22 2.03 2.58 2.57 30×50 35×40 30×60 35×50 40×40 35×60 40×50 40×60 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 2.90 2.88 3.32 3.34 3.35 3.85 3.92 5.00 30×60 35×50 40×40 35×60 40×50 35×60 40×50 0.35 0.35 0.35 0.35 0.35 0.40 0.40 2.77 2.77 2.77 3.23 3.22 3.31 3.30 40×60 0.40 3.86 6,800 8,200 10,000 12,000 15,000 22,000 Rated Ripple Current (Arms/85℃, 120Hz) Tanδ(Max.) Case Size ØD×L(mm) 25.4×50 30×40 35×35 25.4×60 30×50 35×40 30×60 35×50 40×40 35×60 40×50 0.20 0.20 0.25 0.25 0.25 0.30 0.30 0.30 0.30 0.30 0.30 1.07 1.08 1.86 2.33 2.35 2.73 2.72 2.72 2.72 3.16 3.15 40×60 0.35 3.37 50×50 0.40 3.50 30×60 35×50 40×40 35×60 40×50 0.20 0.20 0.25 0.25 0.25 2.32 2.32 2.28 2.62 2.61 40×60 0.25 3.29 Series 25.4×30 30×25 DL 3,300 100 DIMENSIONS : Refer to page 242. 241
DL80VS4700M25.4*50_VS 价格&库存
很抱歉,暂时无法提供与“DL80VS4700M25.4*50_VS”相匹配的价格&库存,您可以联系我们找货
