MHA-BP25VB100M8*11.5_5.0TP
    SAMYOUNG(韩国三莹)
    插件,D8xL11.5mm
    直插铝电解电容 插件,D8xL11.5mm 100µF ±20% Ф8.00 x 11.50mm 25V 2000Hrs@85℃
MHA-BP25VB100M8*11.5_5.0TP 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS MHA Series •85℃ 2,000Hrs assured. •Non-solvent proof. •For Digital Household Appliance. •RoHS compliant. •Halogen-free capacitors are also available. MHA SHL Downsized SPECIFICATIONS Item Characteristics Rated Voltage Range 6.3 Opertating Temperature Range ~ 160 100 VDC -40 ~ +85℃ 500 VDC -25 ~ +85℃ Capacitance Tolerance ±20% (M) (at 20℃, 120Hz) After 1 minute CV≦1,000 CV›1,000 0.1CV+40 0.04CV+100 After 1 minute:I=0.03CV(μA) or 4μA, whichever is greater. Leakage Current ~ After 2 minutes:I=0.01CV(μA) or 3μA, whichever is greater. After 5 minutes CV≦1,000 CV›1,000 0.03CV+15 0.02CV+25 Where, I:Max. Leakage current(μA), C:Nominal capacitance(μ F), V:Rated voltage(VDC) Dissipation Factor (Tanδ) Rated Voltage(VDC) 6.3 10 16 25 35 50 63 100 160~250 350~500 Tanδ(Max.) 0.34 0.24 0.20 0.16 0.14 0.12 0.10 0.09 0.20 0.24 When the capacitance exceeds 1,000㎌, 0.02 shall be added every 1,000㎌ increase. Temperature Characteristics (Max. Impedance ratio) (at 20℃) Rated Voltage(V DC ) 6.3 10 16 25 35 50 Z(-25℃)/Z(20℃) Z(-40℃)/Z(20℃) 5 12 4 10 3 8 2 5 2 4 2 3 (at 20℃, 120Hz) 63~100 160 200~250 350~500 3 4 4 - 8 - 16 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours at 85℃. Load Life Capacitance change ≦ ±20% of the initial value Tanδ ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 85℃ without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Shelf Life Capacitance change ≦ ±20% of the initial value Tan δ ≦ 200% of the initial specified value Leakage current ≦ The initial specified value (where, 200% for ≧ WV 160 VDC) Others Satisfied characteristics KS C IEC 60384-4 DIMENSIONS OF MHA Series Unit(mm) Marking : BLACK SLEEVE, WHITE INK ØD 5 6.3 8 10 12.5 16 18 Ød 0.5 0.5 0.6 0.6 0.6 0.8 0.8 F 2.0 2.5 3.5 5.0 5.0 7.5 7.5 ØD′ ØD+0.5 max. L′ L+1.5 max. L+2.0 max. ≤ D +0.5 and L≤ L +1.0 ※Ø8 X 9L,ØD′ 98 22 0.8 10.0 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF MHA Series μF VDC 6.3 10 16 25 35 50 63 100 160 200 250 350 400 450 5×11 20 6.3×11 23 5×11 29 6.3×11 33 5×11 20 6.3×11 23 5×11 34 6.3×11 39 5×11 24 6.3×11 27 6.3×11 28 6.3×11 29 6.3×11 24 6.3×11 41 6.3×11 43 6.3×11 44 6.3×11 51 8×11.5 59 8×11 70 10×12.5 10×12.5 65 73 1 5×11 22 5×11 24 5×11 24 2.2 5×11 34 5×11 35 5×11 37 3.3 5×11 41 5×11 43 5×11 44 6.3×11 46 6.3×11 47 6.3×11 48 6.3×11 48 8×11.5 56 6.3×11 56 6.3×11 57 6.3×11 58 8×11.5 66 8×11.5 68 4.7 5×11 35 5×11 48 5×11 53 5×11 55 6.8 5×11 46 5×11 59 5×11 63 5×11 64 5×11 39 5×11 49 5×11 53 5×11 71 5×11 76 5×11 76 5×11 52 5×11 68 5×11 73 5×11 80 5×11 113 6.3×11 130 5×11 100 5×11 106 5×11 129 8×9 98 6.3×11 177 8×9 110 6.3×11 159 8×11.5 187 10×16 224 6.3×11 190 8×11 223 8×15 246 10×16 277 10 22 33 5×11 41 5×11 70 5×11 80 5×11 83 47 5×11 59 5×11 88 5×11 120 5×11 126 68 5×11 90 5×11 110 5×11 130 5×11 151 100 5×11 135 5×11 150 5×11 170 5×11 184 8×9 115 220 5×11 211 5×11 229 8×9 150 5×11 256 6.3×11 290 6.3×11 322 330 470 680 1,000 3,300 6,800 10,000 15,000 16×20 140 12.5×20 294 16×20 297 16×25 204 16×20 395 16×20 407 16×25 368 18×25 233 16×25 522 16×20 490 16×25 500 10×16 416 12.5×20 496 16×20 550 16×31.5 674 10×16 615 12.5×20 742 16×25 906 10×16 706 10×20 823 12.5×25 18×31.5 18×31.5 1,304 1,281 987 10×20 918 10×20 1,039 8×11.5 269 6.3×11 231 8×11.5 306 8×11.5 321 6.3×11 318 8×11.5 405 10×12.5 506 6.3×11 360 8×11.5 453 8×11 494 8×15 547 6.3×11 384 8×11.5 499 8×11 540 8×15 597 10×12.5 682 8×11.5 546 8×11 584 8×15 655 10×16 826 10×16 909 12.5×16 12.5×25 1,190 1,512 16×20 1,299 22×30 1,421 16×31.5 1,587 22×40 1,680 16×20 543 16×31.5 18×31.5 1,029 1,040 12.5×16 12.5×16 111 101 16×20 216 10×12.5 12.5×16 12.5×20 377 441 311 6.3×11 213 10×16 78 10×25 229 12.5×16 12.5×20 275 262 12.5×16 12.5×20 315 340 10×16 123 10×16 83 10×16 68 22×35 1,074 16×31.5 18×31.5 544 269 18×31.5 18×35.5 698 620 22×45 1,150 22×35 1,333 22×35 1,459 8×11 679 10×20 12.5×25 16×20 18×31.5 10×12.5 10×16 1,715 1,007 1,724 8×15 1,163 1,932 840 751 10×16 10×16 10×20 12.5×20 12.5×30 16×31.5 18×31.5 2,320 1,059 1,651 2,654 1,129 1,933 1,340 10×20 10×25 10×30 12.5×30 16×25 18×31.5 3,118 1,350 2,159 1,657 2,314 1,804 12.5×20 12.5×20 16×20 16×25 16×35.5 2,200 1,822 2,464 1,929 3,061 12.5×20 12.5×30 16×25 16×31.5 2,690 2,235 2,992 2,545 16×20 16×25 16 ×31.5 3,420 2,571 2,742 Case Size ØD×L(mm) 16×31.5 18×31.5 Rated Ripple Current(mArms/85℃, 120Hz) 3,453 3,707 8×11.5 610 Series 4,700 8×11.5 503 5×11 138 8×9 98 5×11 168 6.3×11 191 10×16 226 10×12.5 95 6.3×11 34 8×11.5 8×11.5 34 40 8×11 8×11 46 43 10×12.5 10×12.5 54 50 MHA 2,200 5×11 262 6.3×11 297 6.3×11 355 8×9 241 8×11 6.3×11 6.3×11 69 8×11.5 79 67 82 10×12.5 8×11.5 8×11.5 80 92 78 8x11 6.3×11 78 10×12.5 8×11.5 97 8×11.5 106 96 10×12.5 82 113 10×12.5 10×12.5 10×16 12.5×16 205 136 152 182 500 RATED RIPPLE CURRENT MULTIPLIERS Frequency Multipliers Freq.(Hz) Cap.(㎌) 1~6.8 10~68 100~1,000 2,200~15,000 60 120 300 1k 10k~ 0.65 0.75 0.80 0.85 1.00 1.00 1.00 1.00 1.35 1.25 1.15 1.03 1.75 1.50 1.30 1.05 2.30 1.75 1.40 1.08 99
MHA-BP25VB100M8*11.5_5.0TP 价格&库存
很抱歉,暂时无法提供与“MHA-BP25VB100M8*11.5_5.0TP”相匹配的价格&库存,您可以联系我们找货
