NFC400VB47M16*25_4.0CC
    SAMYOUNG(韩国三莹)
    插件,D16xL25mm
    直插铝电解电容 插件,D16xL25mm 47µF ±20% Ф16.00 x 25.00mm 400V 364mA@120Hz 5000Hrs@105℃
NFC400VB47M16*25_4.0CC 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS NFC Series •105℃ 2,000~5,000Hrs assured. •Non-solvent proof. •High Ripple, Long Life. •For SMPS, IP-Board, Adaptor. •RoHS compliant. •Halogen-free capacitors are also available. NZE NFC Long Life SPECIFICATIONS ltem Characteristics Rated Voltage Range 160 ~ 400 VDC Operating Temperature Range 420~ 500 VDC -40 ~+ 105℃ -25 ~ +105℃ Capacitance Tolerance ±20%(M) Time c・v Leakage Current After 1 minute (at 20℃, 120Hz) After 5 minutes ≦ 1000 I=0.1CV+40 I=0.03CV+15 > 1000 I=0.04CV+100 I=0.02CV+25 Where, I:Max. Leakage current(㎂) C:Nominal capacitance (㎌) V:Rated voltage (VDC) (at 20℃) Dissipation Factor(Tan δ) Temperature Characteristics (Max. Impedance ratio) Rated Voltage(VDC) 160~250 350~500 Tanδ(Max.) 0.20 0.24 (at 20℃, 120Hz) Rated Voltage(VDC) 160~250 350~400 420~500 Z(–25℃)/Z(+20℃) 3 5 6 Z(–40℃)/Z(+20℃) 6 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 5,000 hours at 105℃. (where, 2,000 hours for Ø6.3) Load Life Shelf Life Capacitance change Tan δ Leakage current The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Capacitance change Tan δ Leakage current Satisfied characteristics KS C IEC 60384-4 Unit(mm) Marking : DARK BROWN SLEEVE, SILVER INK ØD 6.3 8 20 18 10 12.5 16 Ød 0.5 0.6 0.6 0.6 0.8 0.8 0.8 F 2.5 3.5 5.0 5.0 7.5 7.5 7.5 ØD′ ØD+0.5 max. L′ L+1.5 max. L+2.0 max. ※Ø8 x 50L, L′ ≦ L+2.0 22 0.8 10.0 147 Series DIMENSIONS OF NFC Series ≦ ±20% of the initial value ≦ 200% of the initial specified value ≦ 500% of the initial specified value NFC Others ≦ ±20% of the initial value ≦ 200% of the initial specified value ≦ The initial specified value MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF NFC Series 160 V DC ltems ㎌ ØD×L(mm) Rated Ripple Current (mArms/105℃,120Hz) 3.3 10 33 47 68 82 100 150 220 330 ltems ㎌ 6.8 10 22 33 47 68 100 150 220 330 Rated Ripple Current (mArms/105℃,120Hz) 6.3 ×11 8 ×11.5 8 ×20 10 ×20 12.5 ×20 12.5 ×20 12.5 ×25 8 ×50 16 ×20 16 ×25 16 ×25 18 ×31.5 36 75 135 192 262 312 409 320 462 548 701 906 350 ØD×L(mm) Rated Ripple Current (mArms/105℃,120Hz) 8×11.5 8×20 10×20 10×20 12.5×20 70 95 130 193 214 12.5×25 285 250 340 452 591 748 936 1,196 8×50 12.5×25 16×25 16×31.5 18×31.5 18×35.5 20×40 ØD×L(mm) Rated Ripple Current (mArms/105℃,120Hz) 8 ×15 8 ×20 10 ×20 65 90 126 12.5 ×20 207 8 ×50 16 ×20 245 284 16 ×25 364 16 ×31.5 18 ×31.5 18 ×40 22 ×45 472 591 760 970 400 V DC ltems ㎌ 1 3.3 6.8 8.2 148 ØD×L(mm) 250 V DC 10 22 27 33 47 68 82 100 120 150 180 220 135 192 236 312 380 409 360 548 701 876 1,110 8×20 10×20 10×20 12.5×20 10×20 12.5×25 8×50 16×25 16×25 16×31.5 18×31.5 22 200 420 ØD×L(mm) Rated Ripple Current (mArms/105℃,120Hz) 6.3×11 8×11.5 8×15 8×20 10×16 12.5×25 8×50 16×20 16×25 16×31.5 18×31.5 18×35.5 18×40 18×40 20×40 22×45 19 42 66 80 85 225 240 284 364 472 536 611 680 760 855 996 ØD×L(mm) Rated Ripple Current (mArms/105℃,120Hz) 18×31.5 18×31.5 18×35.5 18×40 18×45 500 560 720 740 753 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF NFC Series 450 V DC ltems ㎌ 500 ØD×L(mm) Rated Ripple Current (mArms/105℃,120Hz) 6.3×11 8×11.5 8×15 8×15 8×20 10×20 10×25 12.5×20 12 23 38 42 62 100 121 135 8×50 16×25 230 267 16×31.5 319 10×50 18×25 334 368 1 1.5 2.2 3.3 4.7 6.8 8.2 10 15 22 27 33 39 40 47 56 60 12.5×42.5 18×31.5 12.5×50 18×31.5 12.5×60 18×35.5 18×40 18×45 20×40 22×50 68 82 100 120 150 180 476 500 473 594 630 720 740 753 757 910 ØD×L(mm) Rated Ripple Current (mArms/105℃,120Hz) 10×20 100 12.5×20 12.5×25 12.5×30 10×50 18×25 16×31.5 12.5×50 12.5×50 18×31.5 135 182 210 253 308 319 358 360 393 12.5×60 12.5×60 440 455 18×35.5 489 18×40 594 18×45 20×40 22×45 22×50 620 618 702 827 RATED RIPPLE CURRENT MULTIPLIERS Frequency Multipliers Freq.(Hz) 120 1k 10k 50k 100k Factor 1.00 1.25 1.50 1.60 1.75 NFC Series 149
NFC400VB47M16*25_4.0CC 价格&库存
很抱歉,暂时无法提供与“NFC400VB47M16*25_4.0CC”相匹配的价格&库存,您可以联系我们找货
