NFK160VB47M10*16_3.5CC
    SAMYOUNG(韩国三莹)
    插件,D10xL16mm
    直插铝电解电容 插件,D10xL16mm 47µF ±20% Ф10.00 x 16.00mm 160V 5000Hrs@105℃
NFK160VB47M10*16_3.5CC 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS NFK Series •105℃ 5,000Hrs assured. •Non-solvent proof. •High Ripple, Long Life. •For SMPS, IP-Board, Adaptor. •RoHS compliant. •Halogen-free capacitors are also available. NFC NFK High Ripple SPECIFICATIONS ltem Characteristics Rated Voltage Range 160 ~ 400 VDC Operating Temperature Range 420 ~ 500 VDC -40 ~+105℃ -25 ~ +105℃ Capacitance Tolerance ±20%(M) Time c・v Leakage Current After 1 minute (at 20℃, 120Hz) After 5 minutes ≦ 1000 I=0.1CV+40 I=0.03CV+15 > 1000 I=0.04CV+100 I=0.02CV+25 Where, I:Max. Leakage current(㎂) C:Nominal capacitance (㎌) V:Rated voltage (VDC) (at 20℃) Dissipation Factor(Tan δ) Temperature Characteristics (Max. Impedance ratio) Rated Voltage(VDC) 160~250 350~500 Tanδ(Max.) 0.20 0.24 (at 20℃, 120Hz) Rated Voltage(VDC) 160~250 350~400 420~500 Z(–25℃)/Z(+20℃) 3 5 6 Z(–40℃)/Z(+20℃) 6 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 5,000 hours at 105℃. Load Life Capacitance change Tan δ Leakage current Shelf Life The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Capacitance change Tan δ Leakage current Others DIMENSIONS OF NFK Series ≦ ±20% of the initial value ≦ 200% of the initial specified value ≦ The initial specified value ≦ ±20% of the initial value ≦ 200% of the initial specified value ≦ 500% of the initial specified value Satisfied characteristics KS C IEC 60384-4 Unit(mm) Marking : DARK BROWN SLEEVE, SILVER INK ØD 20 18 16 12.5 10 8 Ød 0.8 0.8 0.8 0.6 0.6 0.6 F 7.5 7.5 7.5 5.0 5.0 3.5 ØD′ ØD+0.5 max. L′ L+1.5max. L+2.0 max. ※Ø10 x 12L, L′ ≦ L+1.5 150 22 0.8 10.0 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF NFK Series 160 VDC ltems ㎌ ØD×L(mm) 200 Rated Ripple Current (mArms/105℃,120Hz) 22 25 10×12 10×12.5 10×20 12.5×20 12.5×20 12.5×25 12.5×30 16×25 16×31.5 18×31.5 27 33 47 68 100 150 220 330 240 240 250 340 400 436 550 736 912 1,200 ØD×L(mm) Rated Ripple Current (mArms/105℃,120Hz) 10×12 10×12.5 8×20 162 162 160 10×20 12.5×20 250 340 12.5×25 436 12.5×30 16×25 18×31.5 550 736 985 350 250 VDC ltems ㎌ 6.8 10 15 22 33 47 68 82 100 150 180 220 ØD×L(mm) Rated Ripple Current (mArms/105℃,120Hz) 10×12 10×12.5 8×15 86 86 95 10×12.5 105 10×12 10×12.5 10×16 128 128 165 12.5×20 250 12.5×20 12.5×25 10×40 12.5×30 12.5×35 10×50 16×25 18×25 12.5×50 18×31.5 18×31.5 320 375 465 463 515 585 591 721 860 813 925 ØD×L(mm) Rated Ripple Current (mArms/105℃,120Hz) 8×20 10×16 10×20 10×20 120 125 125 130 12.5×20 12.5×20 12.5×25 225 249 260 12.5×30 380 12.5×40 16×25 18×25 516 510 620 18×31.5 743 18×35.5 942 18×40 400 V DC ltems ㎌ 4.7 6.8 10 22 27 33 47 68 82 100 120 150 180 220 Rated Ripple Current (mArms/105℃,120Hz) 90 105 98 98 125 150 140 200 250 295 305 352 375 436 475 472 700 795 912 1,020 1,080 1,200 ØD×L(mm) Rated Ripple Current (mArms/105℃,120Hz) 10×20 12.5×20 135 215 16×20 340 16×25 368 18×20 375 18×25 500 18×31.5 18×35.5 18×40 18×45 660 750 830 950 Series 15 8×15 8×20 10×12 10×12.5 10×16 10×20 12.5×16 10×25 12.5×20 12.5×25 16×20 10×45 12.5×35 16×25 12.5×40 18×25 18×31.5 18×35.5 18×40 18×40 20×40 22×45 420 NFK 8.2 ØD×L(mm) 1,048 151 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF NFK Series 450 V DC 500 ØD×L(mm) Rated Ripple Current (mArms/105℃,120Hz) 4.7 6.8 8.2 10 8×20 10×16 10×16 10×20 79 100 122 135 15 10×25 185 22 27 10×33 12.5×25 12.5×30 16×20 10×45 10×50 12.5×40 16×25 215 260 335 340 353 400 405 368 ltems ㎌ 33 39 47 60 68 82 100 120 150 180 18×25 500 12.5×50 670 18×31.5 650 12.5×60 16×45 18×35.5 16×50 18×40 18×45 20×40 22×50 750 750 750 800 800 920 930 1,100 Rated Ripple Current (mArms/105℃,120Hz) ØD×L(mm) 12.5×30 10×50 220 305 12.5×45 365 12.5×50 425 18×31.5 468 12.5×60 16×45 18×35.5 16×50 18×35.5 18×40 18×45 515 585 585 653 640 653 750 20×40 800 18×50 22×45 850 900 22×50 980 RATED RIPPLE CURRENT MULTIPLIERS Frequency Multipliers 152 Freq.(Hz) 120 1k 10k 50k 100k Factor 1.00 1.25 1.50 1.75 2.00
NFK160VB47M10*16_3.5CC 价格&库存
很抱歉,暂时无法提供与“NFK160VB47M10*16_3.5CC”相匹配的价格&库存,您可以联系我们找货
