NFK200VB100M12.5*30_LO 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
NFK Series
•105℃ 5,000Hrs assured.
•Non-solvent proof.
•High Ripple, Long Life.
•For SMPS, IP-Board, Adaptor.
•RoHS compliant.
•Halogen-free capacitors are also available.
NFC
NFK
High Ripple
SPECIFICATIONS
ltem
Characteristics
Rated Voltage Range
160 ~ 400 VDC
Operating Temperature Range
420 ~ 500 VDC
-40 ~+105℃
-25 ~ +105℃
Capacitance Tolerance
±20%(M)
Time
c・v
Leakage Current
After 1 minute
(at 20℃, 120Hz)
After 5 minutes
≦ 1000
I=0.1CV+40
I=0.03CV+15
> 1000
I=0.04CV+100
I=0.02CV+25
Where, I:Max. Leakage current(㎂) C:Nominal capacitance (㎌) V:Rated voltage (VDC) (at 20℃)
Dissipation Factor(Tan δ)
Temperature Characteristics
(Max. Impedance ratio)
Rated Voltage(VDC)
160~250
350~500
Tanδ(Max.)
0.20
0.24
(at 20℃, 120Hz)
Rated Voltage(VDC)
160~250
350~400
420~500
Z(–25℃)/Z(+20℃)
3
5
6
Z(–40℃)/Z(+20℃)
6
6
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the
rated voltage with the rated ripple current is applied (the peak voltage shall not exceed the
rated voltage) for 5,000 hours at 105℃.
Load Life
Capacitance change
Tan δ
Leakage current
Shelf Life
exposing them for 1,000 hours at 105℃ without voltage applied. The rated voltage shall be
applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48
hours before the measurements.
Capacitance change
Tan δ
Leakage current
Others
DIMENSIONS OF NFK Series
≦ ±20% of the initial value
≦ 200% of the initial specified value
≦ The initial specified value
≦ 500% of the initial specified value
Satisfied characteristics KS C IEC 60384-4
Unit(mm)
Marking : DARK BROWN SLEEVE, SILVER INK
ØD
16
12.5
10
8
Ød
0.8
0.8
0.8
0.6
0.6
0.6
F
7.5
7.5
7.5
5.0
5.0
3.5
ØD′
ØD+0.5 max.
L′ L+1.5max.
L+2.0 max.
※Ø10 x 12L, L′
≦ L+1.5
150
22
0.8
10.0
RATINGS OF NFK Series
160
VDC
ltems
ØD×L(mm)
200
Rated Ripple Current
(mArms/105℃,120Hz)
22
25
10×12
10×12.5
10×20
12.5×20
12.5×20
12.5×25
12.5×30
16×25
16×31.5
18×31.5
27
33
47
68
100
150
220
330
240
240
250
340
400
436
550
736
912
1,200
ØD×L(mm)
(mArms/105℃,120Hz)
10×12
10×12.5
8×20
162
162
160
10×20
12.5×20
250
340
12.5×25
436
12.5×30
16×25
18×31.5
550
736
985
350
250
VDC
ltems
6.8
10
15
22
33
47
68
82
100
150
180
220
ØD×L(mm)
(mArms/105℃,120Hz)
10×12
10×12.5
8×15
86
86
95
10×12.5
105
10×12
10×12.5
10×16
128
128
165
12.5×20
250
12.5×20
12.5×25
10×40
12.5×30
12.5×35
10×50
16×25
18×25
12.5×50
18×31.5
18×31.5
320
375
465
463
515
585
591
721
860
813
925
ØD×L(mm)
(mArms/105℃,120Hz)
8×20
10×16
10×20
10×20
120
125
125
130
12.5×20
12.5×20
12.5×25
225
249
260
12.5×30
380
12.5×40
16×25
18×25
516
510
620
18×31.5
743
18×35.5
942
18×40
400
V DC
ltems
4.7
6.8
10
22
27
33
47
68
82
100
120
150
180
220
(mArms/105℃,120Hz)
90
105
98
98
125
150
140
200
250
295
305
352
375
436
475
472
700
795
912
1,020
1,080
1,200
ØD×L(mm)
(mArms/105℃,120Hz)
10×20
12.5×20
135
215
16×20
340
16×25
368
18×20
375
18×25
500
18×31.5
18×35.5
18×40
18×45
660
750
830
950
Series
15
8×15
8×20
10×12
10×12.5
10×16
10×20
12.5×16
10×25
12.5×20
12.5×25
16×20
10×45
12.5×35
16×25
12.5×40
18×25
18×31.5
18×35.5
18×40
18×40
20×40
22×45
420
NFK
8.2
ØD×L(mm)
1,048
151
450
V DC
500
ØD×L(mm)
(mArms/105℃,120Hz)
4.7
6.8
8.2
10
8×20
10×16
10×16
10×20
79
100
122
135
15
10×25
185
22
27
10×33
12.5×25
12.5×30
16×20
10×45
10×50
12.5×40
16×25
215
260
335
340
353
400
405
368
ltems
33
39
47
60
68
82
100
120
150
180
18×25
500
12.5×50
670
18×31.5
650
12.5×60
16×45
18×35.5
16×50
18×40
18×45
20×40
22×50
750
750
750
800
800
920
930
1,100
(mArms/105℃,120Hz)
ØD×L(mm)
12.5×30
10×50
220
305
12.5×45
365
12.5×50
425
18×31.5
468
12.5×60
16×45
18×35.5
16×50
18×35.5
18×40
18×45
515
585
585
653
640
653
750
20×40
800
18×50
22×45
850
900
22×50
980
RATED RIPPLE CURRENT MULTIPLIERS
Frequency Multipliers
152
Freq.(Hz)
120
1k
10k
50k
100k
Factor
1.00
1.25
1.50
1.75
2.00
NFK200VB100M12.5*30_LO 价格&库存
很抱歉,暂时无法提供与“NFK200VB100M12.5*30_LO”相匹配的价格&库存,您可以联系我们找货
