NHA100VB330M12.5*25_LO
    SAMYOUNG(韩国三莹)
    插件,D12.5xL25mm
    直插铝电解电容 插件,D12.5xL25mm 330µF ±20% Ф12.50 x 25.00mm 100V 2000Hrs@105℃
NHA100VB330M12.5*25_LO 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS NHA Series Solventproof • 1 0 5℃ 1 , 0 0 0 ~ 2 , 0 0 0 H r s a s s u r e d . WV≦100VDC •For Digital Household Appliance. •RoHS compliant. •Halogen-free capacitors are also available. NHA KMG Downsized SPECIFICATIONS Item Characteristics Rated Voltage Range 6.3 Operating Temperature Range ~ 160 100 VDC -55 ~ +105℃ Capacitance Tolerance 400 VDC 450 ~ (at 20℃, 120Hz) After 1 minute CV≦1,000 CV›1,000 0.1CV+40 0.04CV+100 After 2 minutes:I=0.01CV(μA) or 3μA, whichever is greater. After 5 minutes CV≦1,000 CV›1,000 0.03CV+15 0.02CV+25 Where, I:Max. Leakage current(μA), C:Nominal capacitance(μ F), V:Rated voltage(VDC) Dissipation Factor (Tanδ) (at 20℃) Rated Voltage(VDC) 6.3 10 16 25 35 50 63 100 160~250 350~500 Tanδ(Max.) 0.34 0.24 0.20 0.16 0.14 0.12 0.10 0.09 0.20 0.24 When the capacitance exceeds 1,000㎌, 0.02 shall be added every 1,000㎌ increase. Temperature Characteristics (Max . Impedance ratio) 500 VDC -25 ~ +105℃ ±20% (M) After 1 minute:I=0.03CV(μA) or 4μA, whichever is greater. Leakage Current ~ -40 ~ +105℃ Rated Voltage(V DC ) 6.3 10 16 25 35 50 Z(-25℃)/Z(20℃) Z(-40℃)/Z(20℃) 5 12 4 10 3 8 2 5 2 4 2 3 (at 20℃, 120Hz) 63~100 160 200~400 450~500 3 4 3 5 6 6 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours at 105℃.(where, 1,000 hours ≤ Ø8) Load Life Shelf Life Capacitance change ≦ ±20% of the initial value Tanδ ≦ 200% of the initial specified value Leakage current ≦ The initial specified value (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied.(where, 500 hours ≤ Ø8) The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Capacitance change ≦ ±20% of the initial value Tan δ ≦ 200% of the initial specified value Leakage current ≦ The initial specified value (where, 200% for ≧ WV 160 VDC) Others Satisfied characteristics KS C IEC 60384-4 DIMENSIONS OF NHA Series Unit(mm) Marking : BROWN SLEEVE, WHITE INK ØD 18 10 12.5 16 8 6.3 5 Ød 0.5 0.5 0.6 0.6 0.6 0.8 0.8 F 2.0 2.5 3.5 5.0 5.0 7.5 7.5 ØD′ ØD+0.5 max. L′ L+1.5 max. L+2.0 max. 100 22 0.8 10.0 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF NHA Series μF VDC 6.3 10 16 50 63 100 1 5×11 13 5×11 15 5×11 16 2.2 5×11 18 5×11 19 5×11 21 3.3 5×11 30 5×11 33 5×11 34 6.3×11 35 35 5×11 35 5×11 53 5×11 60 6.3×11 146 68 5×11 69 5×11 83 5×11 92 5×11 113 5×11 122 6.3×11 138 6.3×11 156 8×11.5 207 4,700 6,800 15,000 5 x 11 141 6.3× 11 159 5×11 6.3×11 5×11 6.3×11 153 238 170 213 6.3× 11 6.3×11 6.3×11 293 6.3×11 216 8×11.5 239 265 340 8×11.5 6.3×11 6.3×11 8×11.5 406 258 8×15 286 366 447 8×11.5 8×11.5 8×11.5 10×16 413 365 620 405 8×15 455 8×11.5 10×16 8×15 10×16 443 756 542 680 10×16 10×20 12.5×16 12.5×20 772 1,188 886 1,019 10×20 12.5×20 12.5×20 16×20 1,032 1,535 1,205 1,275 12.5×20 12.5×25 16×20 16×25 1,280 1,865 1,492 1,610 12.5×25 16×20 16 ×25 18×31.5 1,554 2,374 1,699 1,929 16×25 16×31.5 18×31.5 18×35.5 1,897 2,649 2,082 2,365 16×31.5 2,297 5×11 125 6.3×11 168 8×11.5 294 8×11 360 8×15 398 10×20 202 6.3×11 27 12.5 ×16 12.5×20 206 218 10×12.5 12.5×16 12.5×20 252 265 239 16×20 300 6.3×11 28 8×11.5 29 6.3×11 38 8×11.5 38 16×20 246 16×25 322 8×11.5 216 16×25 16×35.5 10×16 12.5×25 16×20 8×11.5 360 10 ×12.5 366 405 321 447 229 251 10×12.5 10×16 12.5×20 16×25 16×31.5 18×35.5 22×45 656 474 684 719 572 780 395 18×31.5 18×35.5 848 866 10×16 529 10×20 633 16×20 810 10×20 690 12.5×20 886 16×25 1,072 22×35 1,130 12.5×16 12.5×20 12.5×25 973 1,160 777 16×31.5 1,364 22×45 1,463 12.5×16 12.5×25 16×25 1,287 1,565 940 16×20 16×31.5 18×35.5 1,724 1,938 1,394 16×31.5 18 ×31.5 2,190 1,808 18×31.5 2,262 18×40 2,642 18×35.5 1,987 10×16 547 6.3×11 28 8×11.5 30 8×11 39 6.3×11 6.3×11 10×12.5 36 37 41 8×11.5 6.3×11 46 6.3×11 44 8×11.5 10 ×12.5 43 8×11.5 45 48 45 8×11.5 8×11.5 10×12.5 10×12.5 59 54 56 58 10×16 8×11.5 10×12.5 10×16 79 62 67 73 10 ×12.5 10×16 12.5×16 10×25 157 102 117 138 10 ×16 12.5×16 12.5×25 16×20 210 145 169 189 6.3×11 24 16×25 280 500 6.3×11 22 8×11.5 8×11.5 22 25 8×11 30 10×12.5 10×12.5 29 35 10×12.5 10×12.5 38 36 10×16 10×16 54 50 10×16 12.5×16 70 66 12.5×20 16×20 125 123 12.5×30 16×25 189 165 16×25 222 18×25 188 16×31.5 18×31.5 376 338 18×35.5 453 22×30 414 22×35 880 22×40 1,156 NHA 10,000 6.3×11 14 8×11.5 52 8×11.5 60 10×12.5 101 10×16 143 6.3×11 133 3,300 6.3×11 19 5×11 49 5×11 59 6.3×11 100 8×11.5 144 8×11.5 171 8×15 189 5×11 101 2,200 6.3×11 18 5×11 48 5×11 59 5×11 87 6.3×11 122 5×11 80 1,000 5×11 15 6.3×11 17 5×11 44 5×11 54 5×11 79 5×11 97 5×11 77 680 5×11 13 6.3×11 15 5×11 33 5×11 40 5×11 67 5×11 80 5×11 66 470 5×11 12 6.3×11 14 5×11 17 6.3×11 20 5×11 31 5×11 37 5×11 56 5×11 75 5×11 61 330 450 6.3×11 41 47 220 400 5×11 40 5×11 52 5×11 100 350 5×11 39 33 5×11 90 250 5×11 37 5×11 48 5×11 56 100 200 5×11 27 6.8 22 160 5×11 25 4.7 10 25 Case Size ØD×L(mm) Rated Ripple Current(mArms/105℃, 120Hz) Series RATED RIPPLE CURRENT MULTIPLIERS Frequency Multipliers Freq.(Hz) Cap.(㎌) 1~6.8 10~68 100~1,000 2,200~15,000 60 120 300 1k 10k~ 0.65 0.75 0.80 0.85 1.00 1.00 1.00 1.00 1.35 1.25 1.15 1.03 1.75 1.50 1.30 1.05 2.30 1.75 1.40 1.08 SMT Products are available upon request. Please check with us about individual characteristics. 101
NHA100VB330M12.5*25_LO 价格&库存
很抱歉,暂时无法提供与“NHA100VB330M12.5*25_LO”相匹配的价格&库存,您可以联系我们找货
