Techcode®
DATASHEET
Single Buck Voltage Mode PWM Controller
General Description
Features
The TD1720 is a voltage mode, fixed 300kHz switching
frequency, synchronous buck converter. The TD1720 allows
wide input voltage that is either a single 5~12V or two supply
voltage(s) for various applications. A power‐on‐reset (POR)
circuit monitors the VCC supply voltage to prevent wrong
logic controls. A builtin soft‐start circuit prevents the output
voltages from overshoot as well as limits the input current.
An internal 0.8V temperature‐compensated reference
voltage with high accuracy is designed to meet the
requirement of low output voltage applications. The TD1720
provides excellent output voltage regulations against load
current
variation.
The controller’s over‐current protection monitors the output
current by using the voltage drop across the RDS(ON) of
low‐side MOSFET, eliminating the need for a current sensing
resistor that features high efficiency and low cost. In addition,
the TD1720 also integrates excellent protection functions:
The over‐voltage protection (OVP) , under‐ voltage protection
(UVP). OVP circuit which monitors the FB voltage to prevent
the PWM output from overvoltage,and UVP circuit which
monitors the FB voltage to prevent the PWM output from
under‐voltage or short‐circuit.The TD1720 is available in
SOP‐8P and TDFN3x3‐10 packages.
z
z
z
z
z
z
z
z
z
z
z
z
z
z
z
Wide 5V to 12V Supply Voltage
Power‐On‐Reset Monitoring on VCC
Excellent Output Voltage Regulations 0.8V Internal
Reference ±1% Over‐Temperature Range
Integrated Soft‐Start
Voltage Mode PWM Operation with External
Compensation
Up to 90% Duty Ratio for Fast Transient Response
Constant Switching Frequency 300kHz ±10%
Drive Dual Low Cost N‐MOSFETs with Adaptive
Dead‐Time Control
50% Under‐Voltage Protection
125% Over‐Voltage Protection
Adjustable Over‐Current Protection Threshold Using the
RDS(ON) of Low‐Side MOSFET
Shutdown Control by COMP
Power Good Monitoring (TDFN‐10 3mmx3mm Package
Only)
SOP‐8P and TDFN3x3‐10 Packages
Lead Free and Green Devices Available (RoHS Compliant)
Applications
z
z
z
z
z
z
TD1720
Graphic Cards
DSL, Switch HUB
Wireless Lan
Notebook Computer
Mother Board
LCD Monitor/TV
December, 20, 2011 Techcode Semiconductor Limited www.techcodesemi.com
1
Techcode®
DATASHEET
TD1720
Pin Assignments
PIN
NO.
SOP‐8P
TDFN3x3‐10
NAME
1
1
BOOT
2
3
2
4
UGATE
GND
4
5
LGATE
5
6
7
6
7
8
FUNCTION
This pin provides the bootstrap voltage to the high‐side gate driver for
driving the N‐channel MOSFET. An external capacitor from PHASE to
BOOT, an internal diode, generates the bootstrap voltage for the high‐side
d
High‐side
Gate
Driver
Output. This pin is the gate driver for high‐side
Signal and Power ground. Connecting this pin to system ground.
Low‐side Gate Driver Output and Over‐Current Setting Input. This pin is the
gate driver for low‐side MOSFET. It also used to set the maximum inductor
current. Refer to the section in “Function Description” for detail.
VCC
Power Supply Input. Connect a nominal 5V to 12V power supply voltage to
this pin. A power‐on‐reset function monitors the input
voltage at this pin. It is recommended that a decoupling
capacitor (1 to 10 F) is connected to GND for noise decoupling.
FB
Feedback Input of Converter. The converter senses feedback voltage via FB
and regulates the FB voltage at 0.8V. Connecting FB with a resistor‐divider
from the output sets the output voltage of the converter.
COMP
This is a multiplexed pin. During soft‐start and normal converter operation,
this pin represents the output of the error amplifier. It is used to
compensate the regulation control loop in combination with the FB pin.
Pulling COMP low (VDISABLE = 0.4V max.) will shut down the controller. When
the pull‐down device is released, the COMP pin will start to rise. When the
COMP pin rises above the VDISABLE trip point, the TD1720 will begin a new
initialization and soft‐start cycle.
2
Techcode®
DATASHEET
TD1720
8
3
PHASE
This pin is the return path for the high‐side gate driver. Connecting this pin
to the high‐side MOSFET source and connect a capacitor to BOOT for the
bootstrap voltage. This pin is also used to monitor the voltage drop
across the low‐side MOSFET for over‐current protection.
9(Exposed
Pad)
11(Exposed
Pad)
GND
Thermal Pad. Connect this pad to the system ground plan for good
thermal conductivity.
9
POK
POK is an open drain output used to indicate the status of the output
voltage. Connect the POK pin to 5 to 12V through a pull‐high resistor.
10
NC
No Connect
Ordering Information
TD1720 □
Circuit Type Packing:
Blank:Tube
R:Type and Reel
Package
M:SOP8-PP
Q:TDFN
3
Techcode®
DATASHEET
TD1720
Functional Block Diagram
Functional Block Diagram of TD1720
4
Techcode®
DATASHEET
TD1720
Absolute Maximum Ratings
Parameter
Symbol
VVCC
VBOOT
VUGATE
VLGATE
VPHASE
TJ
TSTG
Rating
VCC Supply Voltage (VCC to GND)
BOOT Supply Voltage (BOOT to PHASE)
BOOT Supply Voltage (BOOT to GND)
UGATE Voltage (UGATE to PHASE)
LGATE Voltage (LGATE to GND)
PHASE Voltage (PHASE to GND)
FB and COMP to GND
POK to GND
Maximum Junction Temperature
Storage Temperature
Maximum Lead Soldering Temperature, 10 Seconds
> 20ns
20ns
20ns
很抱歉,暂时无法提供与“TD1720”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.15940
- 20+1.06640
- 100+0.97340
- 500+0.88040
- 1000+0.83700
- 2000+0.80600
