TD8203
TD8203
    TECHCODE(泰德)
    SOT23-6
    1.5MHz 白色LED升压转换器
TD8203 数据手册
        Techcode® DATASHEET TD8203 White LED Step-up Converter General Description  Features    The TD8203 is a current‐mode and fixed frequency boost  converter with an integrated N‐FET to drive white LEDs.  The  series  connection  allows  the  LED  current  to  be  identical for  uniform  brightness.  Its  low  on‐resistance  of  NFET and  low  feedback  voltage  reduce  power  loss  and  achieve high efficiency. Fast switching frequency(1.5MHz  typical) allows using small‐size inductor and both of input  and output  capacitors.  An  over  voltage  protection  function,which  monitors  the  output  voltage  via  OVP  pin,  stops switching  of  the  IC  if  the  OVP  voltage  exceeds  the  over voltage  threshold.  An  internal  soft‐start  circuit  eliminates the inrush current during start‐up.  The  TD8203  also  integrates  under‐voltage  lockout,  overtemperature protection, and current limit circuits to  protect the  IC  in  abnormal  conditions.  The  TD8203  is  available in a TSOT‐23‐6A  z z z z z z z z z z z z z Applications  z z z z   Wide Input Voltage from 2.7V to 6V  Fixed 1.5MHz Switching Frequency  Reference Voltage : 0.2V  PWM Brightness Control with Wide Frequency  Range of 100Hz to 100kHz  Build‐In Power MOSFET : 0.2W Open‐LED Protection  Under‐Voltage Lockout Protection  Over‐Temperature Protection
TD8203 价格&库存
很抱歉,暂时无法提供与“TD8203”相匹配的价格&库存,您可以联系我们找货
