Photocoupler
LTV-817-IN series
1. DESCRIPTION
1.1 Features
Current transfer ratio (Test condition : IF = 5mA, VCE = 5V, Ta=25oC)
LTV-817-IN (CTR = 30 to 400%)
LTV-817-A-IN (CTR = 80 to 160%)
LTV-817-B-IN (CTR = 130 to 260%)
LTV-817-C-IN (CTR = 200 to 400%)
High input-output isolation voltage ( Viso = 5,000Vrms )
Response time ( tr : TYP. 4µs at VCE = 2V, IC = 2mA, RL = 100Ω )
Dual-in-line package :
LTV-817-IN : 1-channel type
Safety approval
UL 1577
VDE DIN EN60747-5-5 (VDE 0884-5)
CSA CA5A
CQC GB4943.1-2011/ GB8898-2011 (meet Altitude up to 5000m)
Nordic Safety ( FIMKO/NEMKO/SEMKO/DEMKO)
RoHS Compliance
All materials be used in device are followed EU RoHS directive (No.2002/95/EC).
1.2 Applications
Hybrid substrates that require high density mounting.
Programmable controllers
1/10
Part No. : LTV-817-IN series
BNC-OD-FC002/A4
Photocoupler
LTV-817-IN series
2. PACKAGE DIMENSIONS
2.1
LTV-817-IN
ID code *5
Notes :
1. Year date code.
2. 2-digit work week.
3. Factory identification mark shall be marked
(Y: Thailand, W: China-CZ, X : China-TJ)
4. Rank shall be or shall not be marked.
5. ID code: —、N、no mark、IN or any indicator character.
* Dimensions are in Millimeters and (Inches).
2/10
BNC-OD-FC002/A4
Photocoupler
LTV-817-IN series
3. RATING AND CHARACTERISTICS
3.1 Absolute Maximum Ratings at Ta=25°C
Parameter
Input
Symbol
Rating
Unit
Forward Current
IF
30
mA
Reverse Voltage
VR
5
V
Power Dissipation
P
49
mW
Collector - Emitter Voltage
VCEO
35
V
Emitter - Collector Voltage
VECO
6
V
Collector Current
IC
30
mA
Collector Power Dissipation
PC
150
mW
Total Power Dissipation
Ptot
150
mW
Isolation Voltage
Viso
5000
Vrms
Operating Temperature
Topr
-55 ~ +110
o
C
C
C
Output
1.
2.
1.
AC For 1 Minute,
Storage Temperature
Tstg
-55 ~ +125
o
Soldering Temperature
Tsol
260
o
R.H. = 40 ~ 60%
Isolation voltage shall be measured using the following method.
(1) Short between anode and cathode on the primary side and between collector and emitter on the
secondary side.
(2) The isolation voltage tester with zero-cross circuit shall be used.
(3) The waveform of applied voltage shall be a sine wave.
2.
For 10 Seconds
3/10
BNC-OD-FC002/A4
Photocoupler
LTV-817-IN series
3.2
ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C
Parameter
Input
Symbol
Min.
Typ.
Max.
Unit
Forward Voltage
VF
1.2
1.7
V
IF=20mA
Reverse Current
IR
µA
VR=4V
Terminal Capacitance
Ct
30
250
pF
V=0, f=1KHz
Collector Dark Current
ICEO
250
nA
VCE=20V, IF=0
BVCEO
35
V
IC=0.1mA, IF=0
BVECO
6
V
IE=10µA, IF=0
IC
1.5
mA
CTR
30
400
VCE(sat)
0.1
0.4
V
Collector-Emitter
Output
Test Condition
Breakdown Voltage
Emitter-Collector
Breakdown Voltage
Collector Current
1.
Current Transfer Ratio
Collector-Emitter
Saturation Voltage
Isolation Resistance
VCE=5V
IF=20mA
IC=1mA
TRANSFER
CHARACTERISTICS
IF=5mA
Riso
5×105
Ω
DC500V,
40 ~ 60% R.H.
Floating Capacitance
Cf
0.6
1
pF
V=0, f=1MHz
Response Time (Rise)
tr
4
µs
VCE=2V,
IC=2mA
Response Time (Fall)
1.
CTR =
IC
IF
tf
3
µs
RL=100Ω,
× 100%
4/10
BNC-OD-FC002/A4
Photocoupler
LTV-817-IN series
4. RANK TABLE OF CURRENT TRANSFER RATIO CTR
CTR Rank
Min
Max
L
30
100
A
80
160
B
130
260
C
200
400
L or A or B or C or D
30
400
Condition
IF=5mA, VCE=5V, Ta=25oC
5/10
BNC-OD-FC002/A4
Photocoupler
LTV-817-IN series
5. CHARACTERISTICS CURVES
Fig.1 Forword Current
vs. Ambient Temperatute
Fig.2 Collector Power Dissiption
vs. Ambient Temperature
Collector Power dissipation Pc (mW)
60
Forward current I F (mA)
50
40
30
50
75
100
125
200
150
100
50
o
7mA
75
100
125
500
O
Ta=25 C
o
4
3
2
Ta=75 C
50 C
o
200
o
25 C
0C
-25 C
o
100
o
50
5
1
2
15
10
0.5
1.5
2.0
2.5
3.0
Forward voltage VF (V)
Forward current IF (mA)
Fig.5 Current Transfer Ratio vs.
Forward Current
Fig.6 Collector Current vs.
Collector-emitter Voltage
200
30
V CE =5V
Ta=25 C
180
I F =30mA
o
160
Collector current Ic (mA)
Current transfer ratio CTR (%)
50
Fig.4 Forward Current vs. Forward
Voltage
1mA
3mA
5mA
Ic=0.5mA
Collecotr-emitter saturation voltage
VCE (sat) (V)
5
25
Ambient temperature Ta ( C)
Fig.3 Collector-emitter Saturation
Voltage vs. Forward Current
6
o
140
120
100
80
60
40
o
Ta=25 C
20mA
25
Pc(MAX.)
10mA
10
5mA
5
2
5
10
50
2
3
4
5
6
7
8
9
Collector-emitter voltage VCE (V)
6/10
BNC-OD-FC002/A4
Photocoupler
LTV-817-IN series
Fig.7 Relative Current Transfer Ratio
0.16
I F =5mA
VCE =5V
Collector-emitter saturation voltage
VCE (sat) (V)
Relative current transfer ratio (%)
150
Fig.8 Collector-emitter Saturation Voltage
100
50
50
75
100
I F=20mA
Ic=1mA
0.14
0.12
0.10
0.08
0.06
0.04
0.02
125
50
75
100
125
Fig.10 Response Time vs. Load
Resistance
-5
500
VCE =20V
-6
10
Response time ( s)
Collector dark current I CEO (A)
25
Fig.9 Collector Dark Current vs.
Ambient Temperature
10
o
o
-7
10
-8
10
-9
10
-10
10
200
100
VCE =2V
Ic=2mA
Ta=25 C
o
50
tr
td
tf
5
ts
2
1
0.5
-11
10
-25
50
75
o
Fig.11 Frequency Response
100
125
0.2
0.05
0.1 0.2
0.5
1
2
5
10
Load resistance R L(k )
Test Circuit for Response Time
7/10
BNC-OD-FC002/A4
Photocoupler
LTV-817-IN series
6. TEMPERATURE PROFILE OF SOLDERING
6.1 IR Reflow soldering (JEDEC-STD-020C compliant)
One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three
times.
Profile item
Conditions
Preheat
- Temperature Min (TSmin)
150˚C
- Temperature Max (TSmax)
200˚C
- Time (min to max) (ts)
90±30 sec
Soldering zone
- Temperature (TL)
217˚C
- Time (tL)
60 sec
Peak Temperature (TP)
260˚C
Ramp-up rate
3˚C / sec max.
Ramp-down rate
3~6˚C / sec
20 sec
Temperature ( C)
Ramp-up
TP 260 C
TL 217 C
Tsmax 200 C
Ramp-down
60 sec
tL (Soldering)
Tsmin
150 C
25 C
60 ~ 120 sec
ts (Preheat)
35~70 sec
8/10
Time (sec)
BNC-OD-FC002/A4
Photocoupler
LTV-817-IN series
6.2 Wave soldering (JEDEC22A111 compliant)
One time soldering is recommended within the condition of temperature.
Temperature: 260+0/-5˚C
Time: 10 sec.
Preheat temperature:25 to 140˚C
Preheat time: 30 to 80 sec.
6.3 Hand soldering by soldering iron
Allow single lead soldering in every single process. One time soldering is recommended.
Temperature: 380+0/-5˚C
Time: 3 sec max.
9/10
BNC-OD-FC002/A4
Photocoupler
LTV-817-IN series
7. RRECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD)
Unit: mm
8. Notes
LiteOn is continually improving the quality, reliability, function or design and LiteOn reserves the right to make changes
without further notices.
The products shown in this publication are designed for the general use in electronic applications such as office automation
equipment, communications devices, audio/visual equipment, electrical application and instrumentation.
For equipment/devices where high reliability or safety is required, such as space applications, nuclear power control
equipment, medical equipment, etc, please contact our sales representatives.
When requiring a device for any ”specific” application, please contact our sales in advice.
If there are any questions about the contents of this publication, please contact us at your convenience.
The contents described herein are subject to change without prior notice.
Immerge unit’s body in solder paste is not recommended.
10/10
BNC-OD-FC002/A4
很抱歉,暂时无法提供与“LTV-817-B-IN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.18883
- 20+0.17217
- 100+0.15551
- 500+0.13885
- 1000+0.13107
- 2000+0.12552
- 国内价格
- 10+0.37800
- 100+0.29430
- 300+0.25240
- 1000+0.22097
- 5000+0.19592
- 10000+0.18339
- 国内价格
- 100+0.18272
- 500+0.17899
