昱灿电子 www.szyucan.com
SY8201
High Efficiency Fast Response, 1A, 27V Input
Synchronous Step Down Regulator
Preliminary Specification
General Description
Features
SY8201 develops high efficiency synchronous stepdown DC-DC converter capable of delivering 1A .
SY8201 operates over a wide input voltage range from
4.5V to 27V and integrate main switch and
synchronous switch with very low RDS(ON) to minimize
the conduction loss.
• Low RDS(ON) for internal switches
(top/bottom):350/150 mΩ
• 4.5-27V input voltage range
• Instant PWM architecture to achieve fast transient
responses Internal softstart limits the inrush current
• 2% 0.6V reference
• RoHS Compliant and Halogen Free
• Compact package: SOT23-6
SY8201 adopts the instant PWM architecture to
achieve fast transient responses for high step down
applications and high efficiency at light loads. In
addition, it operates at pseudo-constant frequency of
500 kHz under heavy load conditions to minimize the
size of inductor and capacitor.
Ordering Information
SY8201□(□□)□
Temperature Code
Package Code
Optional Spec Code
Temperature Range: -40°C to 85°C
Ordering Number
SY8201ABC
Package type
SOT23-6
Applications
Set Top Box
Portable TV
Access Point Router
DSL Modem
LCD TV
Note
Typical Applications
Efficiency vs. Load Current
94
Efficiency (%)
1
92
90
88
86
84
12VIN,5.0VOUT
2
82
16VIN,5.0VOUT
80
24VIN,5.0VOUT
78
0.4
0.6
0.8
1
Load Current (A)
Figure 1. Schematic Diagram
SY8201 Rev.2
Figure 2. Efficiency vs Load Current
1
SY8201
Pinout (top view)
(SOT23-6)
Top Mark: ENxyz, (Device code: EN, x=year code, y=week code, z= lot number code)
Pin Name
Pin Number
BS
1
GND
2
FB
3
EN
IN
LX
4
5
6
Pin Description
Boot-Strap Pin. Supply high side gate driver. Decouple this pin to LX pin with
0.1uF ceramic cap.
Ground pin
Output Feedback Pin. Connect this pin to the center point of the output resistor
divider (as shown in Figure 1) to program the outpu
Vout=0.6*(1+R1/R2)
Enable control. Pull high to turn on. Do not float.
Input pin. Decouple this pin to GND pin with at least 1uF ceramic cap
Inductor pin. Connect this pin to the switching node of inductor
Absolute Maximum Ratings (Note 1)
Supply Input Voltage ----------------------------------------------------------------------------------------- 30V
LX, EN Voltage------------------------------------------------------------------------------------------------ VIN + 0.3V
FB, BS-LX Voltage--------------------------------------------------------------------------------------------- 4V
Power Dissipation, PD @ TA = 25°C SOT23-6, ----------------------------------------------------------- 0.6W
Package Thermal Resistance (Note 2)
θ JA ---------------------------------------------------------------------------------------------------- 250°C/W
θ JC ---------------------------------------------------------------------------------------------------- 130°C/W
Junction Temperature Range -------------------------------------------------------------------------------- 150°C
Lead Temperature (Soldering, 10 sec.) -------------------------------------------------------------------- 260°C
Storage Temperature Range --------------------------------------------------------------------------------- -65°C to 150°C
Dynamic LX voltage in 50ns duration ---------------------------------------------------------------------IN+3V to GND-4V
Recommended Operating Conditions (Note 3)
Supply Input Voltage ----------------------------------------------------------------------------------------- 4.5V to 27V
Junction Temperature Range -------------------------------------------------------------------------------- -40°C to 125°C
Ambient Temperature Range -------------------------------------------------------------------------------- -40°C to 85°C
SY8201 Rev.2
2
SY8201
Electrical Characteristics
(VIN = 12V, VOUT = 1.2V, L = 2.2uH, COUT = 10uF, TA = 25°C, IOUT = 1A unless otherwise specified)
Parameter
Input Voltage Range
Quiescent Current
Shutdown Current
Feedback Reference
Voltage
FB Input Current
Top FET RON
Bottom FET RON
Bottom FET Valley
Current Limit
EN Rising Threshold
EN Falling Threshold
Input UVLO Threshold
UVLO Hysteresis
On Time
Min ON Time
Min Off Time
Thermal Shutdown
Temperature
Thermal Shutdown
Hysteresis
Symbol
VIN
IQ
ISHDN
Test Conditions
IOUT=0, VFB=VREF×105%
EN=0
0.588
VREF
IFB
RDS(ON)1
RDS(ON)2
Min
4.5
VFB=VIN
Typ
400
5
0.6
-50
Max
27
10
0.612
50
0.35
0.15
ILIM
1.5
VENH
VENL
VUVLO
VHYS
TON
1.5
TSD
THYS
nA
Ω
Ω
A
0.4
200
50
100
150
V
V
V
V
ns
ns
ns
°C
15
°C
0.4
4.5
VIN = 12V ,VOUT=1.2V, IOUT = 1A
Unit
V
µA
µA
Note 1: Stresses listed as the above “Absolute Maximum Ratings” may cause permanent damage to the device.
These are for stress ratings. Functional operation of the device at these or any other conditions beyond those
indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating
conditions for extended periods may remain possibility to affect device reliability.
Note 2: θ JA is measured in the natural convection at TA = 25°C on a low effective single layer thermal
conductivity test board of JEDEC 51-3 thermal measurement standard. Pin 2 of SOT23-6 packages is the case
position for θ JC measurement. Test condition: Device mounted on 2” x 2” FR-4 substrate PCB, 2oz copper, with
minimum recommended pad on top layer and thermal vias to bottom layer ground plane.
Note 3: The device is not guaranteed to function outside its operating conditions.
SY8201 Rev.2
3
SY8201
SOT23-6 Package Outline & PCB layout
1.90
1.50 - 1.70
1.00
2.70 - 3.00
2.40
2.80 - 3.10
0.95
0.60
0.30 - 0.50
0.1 - 0.15
0.01 - 0.1
Top View
0.25 REF
Recommended Pad Layout
1.0 - 1.3
0.95 TYP
0.3 - 0.6
Notes:
SY8201 Rev.2
1.90 TYP
All dimension in MM
All dimension do not include mold flash & metal burr
4
SY8201
Taping & Reel Specification
1. SOT23-6 taping orientation
3.9/4.1
7.7/8.3
1.45/1.55
Feeding direction
2. Carrier Tape & Reel specification for packages
Reel
Width
Reel
Size
Package
types
Tape width
(mm)
Pocket
pitch(mm)
Reel size
(Inch)
Reel
width(mm)
Trailer
length(mm)
Leader length
(mm)
Qty per
reel
SOT23-6
8
4
7"
8.4
280
160
3000
3. Others: NA
SY8201 Rev.2
5
很抱歉,暂时无法提供与“SY8201ABC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.63080
- 50+1.27829
- 150+1.12720
- 500+0.93863
- 3000+0.85472
- 6000+0.80439
- 国内价格
- 50+0.80174
- 500+0.78930
- 国内价格
- 5+1.47980
- 50+1.15993
- 600+0.85172
- 1200+0.83894
- 国内价格
- 1+1.59500
- 100+1.22100
- 750+1.01750
- 1500+0.92510
- 3000+0.85800
- 国内价格
- 1+1.35300
- 10+1.18180
- 100+1.01050
- 1000+0.85640
