SY6280AAC
SY6280AAC
    SILERGY(矽力杰)
    SOT23-5
    电源开关/负载开关 2.4V~5.5V SOT23-5 600mW 2A 80mΩ -40℃~+125℃
SY6280AAC 数据手册
Application Note: AN_SY6280 Low Loss Power Distribution Switch TARGET DESIGN SPECIFICATION Preliminary Spec General Description Features The SY6280 develops ultra-low Rds(on) switch with programmable current limiting to protect the power source from over current and short circuit conditions. It integrates the over temperature protection and discharges the output capacitor during the shutdown. In case the output is pulled higher than the input voltage under the shutdown, the SY6280 can block the current flowing from the output to the input. • • • • • • • • Distribution voltages: 2.4V to 5.5V Programmable current limit Enable polarity: active high Over temperature shutdown and automatic retry Reverse blocking (no body diode) At shutdown, OUT can be forced higher than IN Automatic output discharge at shutdown Compact SOT23 packages minimize the board space. Ordering Information SY6280□(□□)□ Applications Temperature Code Package Code Optional Spec Code Temperature Range: -40°C to 85°C Ordering Number Package type SY6280AAC SOT23-5 • USB 3G Datacard • USB Dongle • MiniPCI Accessories Note ---- Typical Applications Figure 1. Schematic Diagram AN_SY6280 Rev. 0.1 Silergy Corp. Confidential- Prepared for Customer Use Only 1 AN_SY6280 Pinout (top view) OUT 1 GND 2 ISET 3 5 IN 4 EN (SOT23-5) Top mark: COxyz (Device code: CO, x=year code, y=week code, z= lot number code) Pin Name IN GND OUT EN ISET Pin number 5 2 1 4 3 Pin Description Input pin Ground pin Output pin ON/OFF control. Pull high to enable IC. Do not float. Current limit programming pin. Connect a resistor Rset from this pin to GND to program the current limit: Ilim (A)=6800/Rset (ohm) Absolute Maximum Ratings (Note 1) All pins-------------------------- ----------------------------------------------------------------------------------- 6V Power Dissipation, PD @ TA = 25°C SOT23-5, --------------------------------------------------------------- 0.6W Package Thermal Resistance (Note 2) θ JA ------------------------------------------------------------------------------------------------------- 200°C/W θ JC ------------------------------------------------------------------------------------------------------- 130°C/W Junction Temperature Range ------------------------------------------------------------------------------------ 150°C Lead Temperature (Soldering, 10 sec.) ------------------------------------------------------------------------ 260°C Storage Temperature Range ------------------------------------------------------------------------------------- -65°C to 150°C ESD Susceptibility (Note 2) HBM (Human Body Mode) ------------------------------------------------------------------------------------- 2kV MM (Machine Mode) -------------------------------------------------------------------------------------------- 200V Recommended Operating Conditions (Note 3) IN--------------------------------------------------------------------------------------------------------------------- 2.4V to 5.5V All other pins ------------------------------------------------------------------------------------------------------- 0-5.5V Junction Temperature Range ------------------------------------------------------------------------------------ -40°C to 125°C Ambient Temperature Range ------------------------------------------------------------------------------------ -40°C to 85°C AN_SY6280 Rev. 0.1 Silergy Corp. Confidential- Prepared for Customer Use Only 2 AN_SY6280 Electrical Characteristics (VIN = 5V, CL=1uF, per channel, TA = 25°C unless otherwise specified) Parameter Input Voltage Range Shutdown Input Current Quiescent Supply Current FET RON EN Rising Threshold EN Falling Threshold EN Leakage IN UVLO Threshold IN UVLO Hysteresis Over Current Limit Turn-ON Time Turn-OFF Time OUT Shutdown Discharge Resistance Thermal Shutdown Temperature Thermal Shutdown Hysteresis Symbol VIN ISHDN IQ RDS(ON)1 VEN(H) VEN(L) IEN VIN,UVLO VIN,HYS ILIM ILIM(min) ILIM(max) TON TOFF RDIS TSD Test Conditions Min 2.4 Open load, IC Disabled. Open load, IC Enabled. Typ 0.1 25 80 Max 5.5 1 2 0.8 1 2.3 VEN=5.5V RSET=6.8kΩ RL=10Ω RL=10Ω, CL=1uF 0.75 0.1 1 0.4 2 120 10 150 130 20 1.25 Unit V µA µA mΩ V V µA V V A A A us us Ω ℃ ℃ Note 1: Stresses listed as the above “Absolute Maximum Ratings” may cause permanent damage to the device. These are for stress ratings. Functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may remain possibility to affect device reliability. Note 2: θ JA is measured in the natural convection at TA = 25°C on a low effective single layer thermal conductivity test board of JEDEC 51-3 thermal measurement standard. Pin 2 of SOT23-5 packages is the case position for θ JC measurement. Note 3: The device is not guaranteed to function outside its operating conditions AN_SY6280 Rev. 0.1 Silergy Corp. Confidential- Prepared for Customer Use Only 3 AN_SY6280 Typical Operating Characteristics Supply Current VS Input Voltage 50 45 40 35 30 25 20 2 3 4 5 6 Vin (V) UVLO at Falling VIN (2V/div) VOUT (2V/div) RL=10Ω CIN=10uF/10V, 100uF/electrolytic COUT=10uF/10V Time (400us/div) EN OFF VEN (5V/div) VOUT (2V/div) RL=10Ω CIN=10uF/10V, 100uF/electrolytic COUT=10uF/10V Time (100us/div) AN_SY6280 Rev. 0.1 Silergy Corp. Confidential- Prepared for Customer Use Only 4 AN_SY6280 Operation The SY6280 is a current limited P-channel MOSFET power switch designed for high-side load-switching applications. There is no parasitic body diode between drain and source of the MOSFET, so the SY6280 prevents current flow from out to input when out being externally forced to a higher voltage than vin when chip is disabled. Over-current protection When the over-current condition is sensed, the gate of the pass switch is modulated to achieve constant output current. Under output short circuit conditions, the normal current limit folded back 50%. If the over current condition presists for a long enough time, the junction temperature may exceed 130C, and overtemperature protection will shut down the part. Once the chip temperature drops to 110C, the part will restart. Supply Filter Capacitor In order to prevent the input voltage drooping during hot-plug events, a 10uF ceramic capacitor form VIN to GND is strongly recommended. However, higher capacitor values could reduce the voltage droop on the input further. Furthermore, an output short will cause ringing on the input without the input capacitor. It could destroy the internal circuitry when the input transient exceed 6V which is the absolute maximum supply voltage even for a short duration. Current Limiting Setting Current limiting is programmable to protect the power source from over current and short circuit conditions. Connect a resistor RSET from this ISET pin to GND to program the current limit: Ilim (A)=6800 / Rset (ohm). PCB Layout Guide For best performance of the SY6280 , the following guidelines must be strictly followed:  Keep all VBUS traces as short and wide as possible and use at least 2 ounce copper for all VBUS traces.  Place a ground plane under all circuitry to lower both resistance and inductance and improve DC and transient performance.  inductance) between the port and the capacitor and improve transient performance.  Input and output capacitors should be placed closed to the IC and connected to ground plane to reduce noise coupling.  Locate the ceramic bypass capacitors as close as possible to the VIN pins and VOUT pins of SY6280. Locate the output capacitor as close to the connectors as possible to lower impedance(mainly PCB Layout Guide(SOT23-5) AN_SY6280 Rev. 0.1 Silergy Corp. Confidential- Prepared for Customer Use Only 5 AN_SY6280 SOT23-5 Package outline & PCB layout design 0.55 1.50 - 1.70 0.80 2.70 - 3.00 2.40 2.80 - 3.10 0.95 TYP 0.30 - 0.50 0.01 - 0.1 0.1 - 0.15 0.25 REF Recommended Pad Layout 1.0 - 1.3 0.95 TYP 0.3 - 0.6 1.90 TYP Notes: All dimensions are in millimeters. All dimensions don’t include mold flash & metal burr. AN_SY6280 Rev. 0.1 Silergy Corp. Confidential- Prepared for Customer Use Only 6
SY6280AAC 价格&库存
很抱歉,暂时无法提供与“SY6280AAC”相匹配的价格&库存,您可以联系我们找货
SY6280AAC
  • 5+0.45900
  • 20+0.41850
  • 100+0.37800
  • 500+0.33750
  • 1000+0.31860
  • 2000+0.30510
库存:8450
SY6280AAC
  • 3000+0.31130
库存:102739
SY6280AAC
    • 1+0.64240
    • 200+0.41470
    • 1500+0.36080
    • 3000+0.31900
    库存:150109
    SY6280AAC
    • 1+0.69820
    • 10+0.60980
    • 100+0.52140
    • 1000+0.44190
    库存:30055
