3296W-1-102
3296W-1-102
    BOCHEN(博晨)
    POTENTIONMETER_9.5X4.85MM_TM
    精密微调电阻 POTENTIONMETER_9.5X4.85MM_TM 1KΩ ±10% 1/2W ±250ppm/℃
3296W-1-102 数据手册
产品品牌博晨(BOCHEN) 3296W 型玻璃釉预调电位器 技术承认书 拟 制: 审 核: 批 准: 3296W 型玻璃釉预调电位器技术承认书 电气特性 Electrical Characteristcs 标称阻值范围(Range of normal resistance):10Ω—2MΩ 阻值允许偏差(Resistance tolerance):±10% 终端电阻(Termial resistance):≤5%R 或 5Ω 接触电阻变化(Contact resistance variation):CRV≤5%或 5Ω 耐电压(Winthstand Voltage):640Vac 绝缘电阻(Insulation resistance):Ri≥1G(100Vdc) 有效电行程(Effective electrical travel):>总机械行程的 70%(>70% of total mechanical travel) 极限动触点电流(Limit current of moving comtact):100mA 环境特性 Environment Characteristics 额定功率(Rated Power)(315V max):0.5W 70℃,0W 125℃ 温度范围(Temperature range):-55℃——+125℃ 温度系数(TCR):±250ppm/℃ 温度变化(Temperature variation):-55℃,30min,+125℃,30min 循环 5 次ΔR≤5%R, Δ(Uab/Uac)≤± 5% 振动(Vibration):10-500Hz,0.75mm,6h 电气间断(electrical interruption):≤100/us ΔR≤5%R,Δ(Uab/Uac)≤±7.5% 2 碰撞(Collision):390m/S ,4000 次 ΔR≤5%R 气候顺序(Climate category):IEC68-2-2 等(meet IEC68-2-2 etc)ΔR≤10%R,R1≥100MΩ 70℃电气耐久性(Electrical endurance at 70℃):0.5W,1000h ΔR≤10%R CRV≤3%R 或 5 Ω 恒定湿热(Steady damp-heat):IEC68-2-3,Ca,96h ΔR≤10%R,R1≥100MΩ 物理特性 Physical Characteristics 总机械行程(Total Mechanical Travel):30±2 圈(30±2 turns) 起动力矩(Staring Torque):≤30mN.m 标准包装(Standard Packaging):50 只/管(50pcs.per tube) 标志(Mark):阻值允许偏差(10%不标注)、阻值代码、产品型号 Resistance tolerance (when no identification,it is of ± 10%)resistance code type
3296W-1-102 价格&库存
很抱歉,暂时无法提供与“3296W-1-102”相匹配的价格&库存,您可以联系我们找货
3296W-1-102
  • 5+0.75180
  • 20+0.68880
  • 100+0.62580
  • 500+0.56280
  • 1000+0.53340
  • 2000+0.51240
库存:461
3296W-1-102
  • 5+1.28420
  • 50+0.87320
  • 150+0.77140
  • 500+0.64500
  • 2500+0.58860
库存:2770
3296W-1-102
    • 1+0.38310
    库存:2421
    3296W-1-102
      • 50+0.36300
      库存:1627
      3296W-1-102
        • 5+1.29428
        • 50+0.88085
        • 150+0.77868
        • 500+0.65124
        • 2500+0.59444
        • 5000+0.56042
        库存:16554
