EGH1HM4R7D11OT
EGH1HM4R7D11OT
    AISHI(艾华集团)
    插件,D5xL11mm
    直插铝电解电容 插件,D5xL11mm 4.7µF ±20% Ф5.00 x 11.00mm 50V 35mA 5000Hrs@105℃
EGH1HM4R7D11OT 数据手册
湖南艾华集团股份有限公司 HUNAN AIHUA GROUP CO., LTD Tel: (0737)6184466 Fax : (0737)6180493 Http://www.aihuaglobal.com SPECIFICATION Description: Aluminum Electrolytic Capacitors AISHI P/N: Part of GH Series SERIES: GH ITEM: Customer P/N: No.: CRS-JD-1711132 APPROVED BY Please Return One Copy with Your Approval 承认后请寄回一份 PREPARED BY CHECKED BY APPROVED BY Starts Released File Description Approval Sheet-GH Component No./rev CRS-2010-GH/ 01 变更记录 版本 CRS-JD-1711132 更改原因 新建 更改内容 新建 生效日期 2017-11-11 Customer 深圳市仁天芯科技有限公司 GH SERIES 2017-11-11 DATE FIG-1 TABLE-1 Aishi Part No. Capacitance (μF) Tolerance on Rated Capacitance (%) Rated Voltage (Vdc) 1 EGH1HM4R7D11OT 4.7 ±20 50 63 -40~+105 0.14 2 EGH1HM100D11OT 10 ±20 50 63 -40~+105 0.14 No. Customer Part No. Leakage tanδ Operating Surge Current Voltage Temp. Range (120Hz) (Max) (μA)(2min.) (℃) (Vdc) Dimensions (mm) Max Ripple Endurance Current (mArms) at 105℃ at105℃100kHz (Hours) 3 35 5000 5 5 50 5000 5 ΦD L Appearance Drawing No. α d F 11 2 0.5 2.0 FIG-1 11 2 0.5 2.0 FIG-1 Starts Released File Description Approval Sheet-GH Component CRS-2010-GH/ 01 No./rev 1 概述 SCOPE 本承认书规定了 GH 系列径向引线引出铝电解电容器的技术规范,本技术规范条文解释权归 本公司所有。 This specification covers “GH series” miniature single-ended aluminum electrolytic capacitors, Aishi reserves the right of final interpretation for this technical specification. 2 参考标准 APPLICABLE SPECIFICATION 本承认书参考 JIS-C-5101-1 和 JIS-C-5101-4 制定。 This approval sheet consulted the institute of JIS-C-5101-1 and JIS-C-5101-4. 3 工作温度范围 OPERATING TEMPERATURE RANGE 工作温度范围是电容器在施加额定工作电压条件下,可以长期可靠工作的环境温度范围。 -40℃~+105℃(6.3V.DC~100V.DC) Operating temperature range is the range of ambient temperature at which the capacitor can be operated continuously at rated voltage. -40℃~+105℃(6.3V.DC~100V.DC) 4 测试环境 CONDITION OF TEST 如果没有其他规定,标准的测试、检验环境条件如下所示: 环境温度:15℃~35℃ 相对湿度:45%~75% 大气压力:86kPa~106kPa 如果对测试结果有异议,可以在以下条件测试: 环境温度:20℃±1℃ 相对湿度:60%~67% 大气压力:86kPa~106kPa Unless otherwise specified, the standard range of atmospheric conditions for making measurements and tests are as follows Ambient temperature :15℃ to 35℃ Relative humidity :45% to 75% Air pressure :86kPa to 106kPa If there may be doubt on the results, measurements shall be made within the following limits Ambient temperature :20±1℃ Relative humidity :60% to 67% Air pressure :86kPa to 106kPa Name File No. GH Approval Sheet-GH Version 01 STANDARD MANUAL Page 1 Starts Released File Description Approval Sheet-GH Component CRS-2010-GH/ 01 No./rev 5 产品特性 PRODUCT CHARACTERISTICS 5.1 电气特性 ELECTRICAL CHARACTERISTICS 序号 项目 测试方法 性能 No. Item Test method Performance 5.1.1 额定工作电压 电压:直流电压值+交流电压峰值≤额定电压 Rated voltage . Voltage:DC. Voltage + peak ripple voltage ≤ 6.3V.DC~100V.DC Rated voltage 5.1.2 电容量 Capacitance 测试频率:120Hz(±20%) 容量偏差:-20%~+20% 测试电路:串联等效 Capacitance tolerance: 测试电压:0.5Vrms 以下+1.5~ 2.0VDC -20%~+20% Measuring frequency: 120Hz±20% Measuring circuit: Series equivalent circuit Measuring voltage: 0.5Vrms or less +1.5 to 2.0 VDC 5.1.3 测试条件与 5.1.2 电容量测试相同 DF 不大于规定值 Testing conditions are the same as 5.1.2 for DF: Not more than the specified capacitance value. 漏电流 在电容器两端施加额定工作电压,并串联 1000 Leakage current ±100Ω电阻,在施加电压 2 分钟后,测量漏电 6.3V~100V: I≤0.01CV 或 3μA, 取较大值(2 分钟后) 损失角正切值 Dissipation factor 5.1.4 流。 测试电路如下图: The rated voltage shall be applied across the capacitor and its protective resistor shall be 1000 ± 100 Ω . The leakage current shall then be measured after an electrification period of 2 min.. Measurement circuit 6.3V~100V: I≤0.01CV or 3μA Whichever is greater(after 2 min) I:漏电流(μA) C:容量(μF) V:额定工作电压(V) I:Leakage current(μA) C:Capacitance(μF) V:Rated voltage (V) Rs: Protective resistor(1000±100Ω) DC ammeter DC voltmeter S1: Switch S2: Protective switch for an ammeter Name File No. GH Approval Sheet-GH Version 01 STANDARD MANUAL Page 2 Starts Released 5.1.5 温度特性 Temperature characteristic 5.1.6 File Description Approval Sheet-GH 阶段 1 2 3 4 温度 20±2℃ +0 -25, -40 -3 ℃ 20±2℃ +3 105 -0 ℃ Component CRS-2010-GH/ 01 阶段 2: 时间 阻抗值与阶段 1 阻抗值相比,不大 -2h 15min. 2h 于表 2 要求。 阶段 4: 容量变化应在初值的±20%范围内 耐浪涌电压 阶段 1:测量容量和阻抗(|z| 20℃ 120Hz± 20%) 阶段 2:电容器恒温贮存 2 小时,在热平衡状态 测阻抗(|z|-25,-40℃ 120Hz±20%) 阶段 4:电容器恒温贮存 2 小时,在热平衡状态 测电容量 Step 1:Capacitance and impedance shall be measured. (|z| 20℃ 120Hz±20%) Step 2:After the capacitor being stored for 2 hours, impedance shall be measured at thermal stability. (|z|-25,-40℃ 120Hz±20%) Step 4:After the capacitor being stored for 105℃2 hours, capacitance shall be measured. The measurement shall be made at thermal stability 施加表 1 所列浪涌电压,充电 30±5 秒,放电 Surge test 5.5±0.5 分钟作为一个周期,共进行 1000 次。 测试温度:15℃-35℃ 然后在标准大气条件下放置达到热稳定,测试各 参数 Application of DC surge Voltage stated at table-1, 1000 times of charging for 30 ± 5 sec., discharging with a period of No./rev 5.5±0.5 min.. Test temperature: 15℃-35℃ Step 2: Impedance value ratio to the value at step 1 shall be not more than the value given in table-2 Step 4: Variation of capacitance Within ±20% of the initial value. 容量变化:在初始值的±20%以内。 损耗角正切值不大于规定值的 200%。 漏电流:达到 5.1.4 要求 Capacitance change: Within±20% of the initial value Dissipation factor: Not more than 200% of the specified value. Leakage current: To satisfy No.5.1.4 And the capacitor shall be stored under standard atmospheric conditions to obtain thermal stability, after which measurements shall be made. Test circuit + K R DC Power Cx R _ Note: This requirement is applicable only to instantaneous over voltage which may be applied to terminals of capacitor, therefore, not applicable to such over voltages as often applied. Name File No. GH Approval Sheet-GH Version 01 STANDARD MANUAL Page 3 Starts Released File Description Approval Sheet-GH 5.2 机械特性 MECHANICAL Component CRS-2010-GH/ 01 No./rev PERFORMANCE 序号 项目 测试方法 特性 No. Item Test method Performance 5.2.1 端子强度 端子抗拉强度: Terminal 沿电容器端子引线方向施加拉力(如下表),10±1 秒。 或短路,无可见机械损伤 引线直径Φ 0.45 0.5 0.6 0.8 1.0 When the capacitor is measured, 拉力 N 5 10 20 there shall be no intermittent 端子抗弯强度: contacts, or open or 在电容器引线施加固定重力(如下表),然后,将电容 short-circuiting. 体弯折 90°后回到原位,再向相反方向弯折 90°后回 There shall be no visible 到原位。 mechanical damage. 上述过程在 5 秒内完成。 strength 测量电容器应无接触不良、开路 0.5 0.6 0.8 1.0 引线直径Φ 0.45 2.5 5 10 拉力 N Tensile strength of terminal: A static load (stated in the table above) shall be applied to the terminal in the axial direction and acting in a direction away from the body for 10±1 sec.. Bending strength of terminal: Hang the specified dead weight (stated in the table above), then bend the body through 90°, return to the original position. Next bend it in opposite direction through 90° with the same speed, again return to the original position. Complete this operation in about 5 sec. 5.2.2 振动试验 Resistance to vibration 5.2.3 可焊性 Solderability Name File No. 依据 JIS C 5101-1 4.17 试验。 在 3 个互相垂直的方向分别施加 2 小时振动,共 6 小 时 频率:10-55Hz 振幅:1.5mm. 振速:1 分钟内振速 10~55~10Hz To comply with JIS C 5101-1 4.17 Direction and duration of vibration: 3 orthogonal directions mutually each for 2h , Total 6h. Vibration frequency range :10-55Hz Peak to peak amplitude: 1.5mm Sweep rate :10to55to10Hz in about 1 min. 测量电容器应无接触不良开路或 短路,无可见机械损伤。 When the capacitor is measured there shall be no intermittent contacts, or open or short circuiting There shall be no visible mechanical damage. 依据 JISC 5101-1 4.15 进行试验 焊锡温度:235±5℃ 浸入时间:2±0.5 秒 To comply with JISC 5101-1 4.15 Temperature of solder: 235±5℃ Dipping time: 2±0.5sec. This specification shall be met after the capacitors are stored under standard atmospheric conditions for 6 months. 浸入焊锡的引线表面积约 90%以 上应附着新锡 At least 90% of circumferential surface of the dipping portion of terminal shall be covered with new solder. GH Approval Sheet-GH Version 01 STANDARD MANUAL Page 4 Starts Released File Description Approval Sheet-GH 5.3 耐久性测试 ENDURANCE 序号 No. 5.3.1 5.3.2 项目 Item 耐焊接热 Resistance to soldering heat 稳态湿热 Resistance to damp heat (steady state) 5.3.3 高温负荷试验 Load life test No./rev PERFORMANCE 测试方法 Test method 特性 Performance 容量变化:在初始值±10%范围内 焊槽法: 损失角正切值:不大于规定值 焊锡温度:260±5℃ 漏电流:满足 5.1.4 要求 浸入时间:10±1 秒 外观:无异状 电路板 :1.6mm Variation of capacitance: Solder bath method Within ±10% of the initial value Solder bath temperature : 260±5℃ Dissipation factor: Immersion time : 10±1sec. Not more than the specified value Printed wiring board: 1.6mm Leakage current: To satisfy No.5.1.4 Appearance: No remarkable abnormality. 容量变化:在初始值±10%范围内 依据 JIS C 5101-1 4.22 进行试验 损失角正切值:不大于规定值 试验温度:40±2℃ 漏电流:满足 5.1.4 要求 试验时间:240±8h 外观:无异状 相对湿度:90~95% 试验后,电容器在标准大气条件下 1~2 小时, Variation of capacitance: Within ±10% of the initial value. 然后测试参数 Dissipation factor: To comply with JIS C 5101-1 4.22 Not more than the specified value Test temperature : 40±2℃ Leakage current: To satisfy No.5.1.4 Test time : 240±8h Appearance: Relative humidity: 90~95% After completion of test, the capacitor shall be No remarkable abnormality. subjected to standard atmospheric conditions for 1 to 2 hours, after which measurements shall be made. 1. 试验温度:105±2℃,施加额定电压和额定 纹波电流 Application of the rated voltage and the rated ripple current, Test temperature:105±2℃ 2. 试验时间:参照 TABLE 1 寿命要求 Testing time: refer to TABLE 1 life requirements Name File No. Component CRS-2010-GH/ 01 GH 容量变化:在初始值±20%范围内 损耗角正切值:不超过规定值的 200% 漏电流:不大于规定值 外观:无异状 Variation of capacitance: Within ±20% of the initial value. Dissipation factor: Not more than 200% of the specified value Leakage current: Not more than the specified value Appearance: No remarkable abnormality. Approval Sheet-GH Version 01 STANDARD MANUAL Page 5 Starts Released 5.3.4 高温贮存试验 Shelf life test File Description Approval Sheet-GH Component CRS-2010-GH/ 01 +48 在 105±2℃环境下无负荷贮存 1000 -0 h,至 少恢复 16 小时后。 The capacitors are stored without voltage load at +48 105±2℃ for 1000 -0 h and then resumed 16 hours. 5.3.5 防爆试验 Safety vent 以下试验只适用于铝壳直径≥Φ8 产品。 The following tests only apply to those products with vent products at diameter≥Φ8 with vent. 在电容器两极施加反向直流电压,其中通过的 电流为 1 A,在测试时防爆装置应能在 30 分 钟内动作。 D.C.Application test The capacitor shall be subjected to a reverse D.C. voltage. No./rev 容 量 变 化 : 初 始 值 ± 20% 范 围 内 (6.3V,10V: ≤±30%)。 损耗角正切值:不超过规定值的 200% 漏电流:不超过规定值的 200% 外观:无异状 Variation of capacitance: Within ±20% of the value before test. (6.3V,10V: ≤±30%) Dissipation factor: Not more than 200% of the specified value Leakage current: Not more than 200% of the specified value Appearance: No remarkable abnormality. 上述过程中应无引线、铝箔等散射, 无火花产生。 The safety vent is actuated under the test conditions, thereby preventing terminals, metal pieces, etc, of the capacitor from scattering due to burst, the case from separating from the seal packing, or the capacitor from producing flame. The current flowing through the capacitor shall be 1A. If the vent does work with the voltage applied for 30 minutes, the test is considered to be passed. ※ 表 2(TABLE 2) 额定工作电压 阻抗比 Max. Impedance Ratio 6.3 10 16 |z|-25℃/|z|20℃ 5 4 3 |z|-40℃/|z|20℃ 12 10 8 Rated voltage (v) Name File No. GH 25 35 50 63 100 2 5 4 3 Approval Sheet-GH Version 01 STANDARD MANUAL Page 6 Starts Released File Description Approval Sheet-GH Component CRS-2010-GH/ 01 No./rev 6 标记 MARKING 6.1 在电容器体上应注明如下内容: (1)生产厂商商标 GH 105℃ YyWw□PET (Yy 表示年份,Ww 表示制造周期, (2)型号-额定温度 (3)周期代码-我司代码-套管材质 □表示我司代码,我司代码:“Z、Y、J、S……” PET 表示套管材质) --V--μF (4)电压容量 (5)负极标志 6.1The following items shall be marked indelibly on the capacitor. (1)Manufacture’s name or trade mark. (2)Model - rated temperature GH 105℃ (3)Cycle code- AIHUA code -sleeve material YyWw□PET (Yy denotes last two digit of years and Ww denotes the week in which the capacitor is manufactured, □denotes the code of AIHUA,AIHUA code:“ Z、Y、J、S……” PET denotes the sleeve material ) --V--μF (4)Voltage Capacity (5)Polarity of the terminals 6.2 标记颜色 Marking color 套管颜色:棕色 标记颜色:白 Sleeve color:Brown Marking color:White 7 纹波电流频率因子 RIPPLE CURRENT FREQUENCY COEFFICIENT Freq. (Hz) Cap(uF) Cap.<100 100≤Cap.<220 220≤Cap.<1000 1000≤Cap. Name File No. 120 1k 10k 100k 0.40 0.50 0.70 0.85 0.68 0.76 0.85 0.95 0.78 0.87 0.90 0.98 1.00 1.00 1.00 1.00 GH Approval Sheet-GH Version 01 STANDARD MANUAL Page 7 Starts Released File Description Approval Sheet-GH Component CRS-2010-GH/ 01 No./rev 8 物料编码 PART NO SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Sleeve Terminal Size Capacitance Capacitance tolerance Voltage code⑧ code⑦ code⑥ code⑤ code④ code③ Series code② Category code① Type Code WV(V) 1th 4 6.3 10 16 25 35 40 50 63 80 100 160 180 200 220 250 315 350 380 400 420 450 500 Electrolytic Capacitor E ②Series code Series name Code 2 th 3 th G H GH ⑥Size code ΦD Code 10th 4 5 6.3 8 10 11 12 12.5 13 14 16 18 19 20 22 25 30 35 40 51 63.5 76 89 C D E F G H J W K X L M Z N O P Q R Y S T U V Name File No. ④ Capacitance Tolerance code ③Voltage code Category code ① L 5 7 11 12 16 20 25 30 35 40 46 50 60 80 100 115 120 130 140 160 200 Code 11th 12th 0 0 1 1 1 2 2 3 3 4 4 5 6 8 A B C D E G K 5 7 1 2 6 0 5 0 5 0 6 0 0 0 0 5 0 0 0 0 0 Code 4th 5th 0 0 1 1 1 1 1 1 1 1 1 2 2 2 2 2 2 2 2 2 2 2 2 G J A C E V G H J B K C L D N E F V P G T W H Tol. Code (%) 6th -10~+10 K -20~+20 M -10~+30 Q -10~+50 T -10~+20 V -0~+20 A -5~+20 C -10~-20 B -5~+5 D -0~+10 E -5~-20 F -15~+5 N ⑤Capacitance code Cap (µF) 0.10 0.22 0.33 0.47 0.68 1 2.2 3.3 4.7 6.8 10 22 33 47 68 100 220 330 470 680 1000 2200 3300 4700 6800 10000 22000 33000 68000 ⑦Terminal Code Specification Bulk packing 编带 Taping F=5mm (4Ф~8Ф) Taping F=2.5mm (4Ф~5Ф) Taped Straight-pack GH Code Size 13th 14th 15th 8th 9th R R R R R 0 2 3 4 6 1 2 3 4 6 1 2 3 4 6 1 2 3 4 6 1 2 3 6 1 2 3 4 6 1 R R R R 0 2 3 7 8 0 2 3 7 8 0 2 3 7 8 0 2 3 8 0 2 3 7 8 0 2 3 7 8 0 0 0 0 0 1 1 1 1 1 2 2 2 2 2 3 3 3 3 O - - P 5 0 X 2 5 ⑧Sleeve Code 5 0 Sleeve 3 5 2 5 2 0 B 1 5 Lead Cut L=3.5mm C 3 5 Lead Cut L=11.0mm C B 0 Lead Forming&cut L=4.5mm F 4 5 Kink&cut L=4.5mm J 4 5 Approval Sheet-GH Version 01 STANDARD Code 7th MANUAL Page PVC Code 16th C PET T 8 Starts Released File Description Approval Sheet-GH Component CRS-2010-GH/ 01 No./rev 9 加工型式 Lead Forming Type 9.1 编带 Taping ●Straight lead PIN Code : X ΦD=4~5 PIN Code : B ΦD=4~8 Name File No. GH Approval Sheet-GH Version 01 STANDARD MANUAL Page 9 Starts Released File Description Approval Sheet-GH Component CRS-2010-GH/ 01 No./rev PIN Code : B ΦD=10 DIMENSIONS(mm) CASE SIZE Items Symbol Pin Code 4x5 4x7 X Lead wire diameter 5x5 5x7 B X B 5x11 X 6.3x5 B 6.3x7 6.3x11 B B B 8x5 8x7 8x11 8x12 8x16 8x20 10x13 10x16 10x20 B B B Φd 0.45 0.45 0.5 0.45 0.5 0.5 Pitch of body P 12.7 12.7 12.7 12.7 12.7 12.7 12.7 Feed hole pitch P0 12.7 12.7 12.7 12.7 12.7 12.7 Hole center to lead distance P1 5.1 5.1 Feed hole center to body center distance P2 6.35 5.1 5.6 5.1 5.35 5.1 5.35 6.35 6.35 6.35 0.45/0.5 0.5/0.6 Tolerance 0.6 ±0.05 12.7 12.7 ±1.0 12.7 12.7 12.7 ±0.2 5.1 4.6 4.6 3.85 ±0.7 6.35 6.35 6.35 6.35 6.35 ±1.0 2.5 2.5 2.5 3.5 3.5 5.0 ±0.5 Lead to lead distance F Height of body from tape center H 18.5 18.5 18.5 18.5 18.5 18.5 18.5 18.5 18.5 ±0.75 Base tape width W 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 ±0.5 Adhesive tape width W0 11.0 11.0 11.0 11.0 11.0 11.0 11.0 11.0 11.0 min Hole position W1 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 +0.75 -0.5 Hole down tape position W2 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 max Name File No. 2.5 1.5 2.5 2.0 2.5 GH 2.0 Approval Sheet-GH Version 01 STANDARD MANUAL Page 10 Starts Released File Description Approval Sheet-GH Component CRS-2010-GH/ 01 No./rev ●Forming type PIN Code : P ΦD=4~8 DIMENSIONS(mm) CASE SIZE Items Symbol 8x5 8x7 8x11.5 8x12 8x16 8x20 P P Tolerance 4x5 4x7 5x5 5x7 5x11 6.3x5 P P P P P P P Φd 0.45 0.45 0.45 0.5 0.45 0.5 0.5 Pitch of body P 12.7 12.7 12.7 12.7 12.7 12.7 12.7 12.7 12.7 ±1.0 Feed hole pitch P0 12.7 12.7 12.7 12.7 12.7 12.7 12.7 12.7 12.7 ±0.2 Hole center to lead distance P1 3.85 3.85 3.85 3.85 3.85 3.85 3.85 3.85 3.85 ±0.7 Feed hole center to body center distance P2 6.35 6.35 6.35 6.35 6.35 6.35 6.35 6.35 6.35 ±1.0 Lead to lead distance F 1.5 2.0 2.0 2.0 2.5 2.5 2.5 3.5 3.5 ±0.5 Lead to lead distance F1 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 +0.8 -0.2 Height of body from tape center H 18.5 18.5 18.5 18.5 18.5 18.5 18.5 18.5 18.5 ±0.75 Lead wire clinch height H0 16.0 16.0 16.0 16.0 16.0 16.0 16.0 16.0 16.0 ±0.5 Base tape width W 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 ±0.5 Adhesive tape width W0 11.0 11.0 11.0 11.0 11.0 11.0 11.0 11.0 11.0 min Pin Code Lead wire diameter 6.3x7 6.3x11 0.45/0.5 0.5/0.6 ±0.05 Hole position W1 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 +0.75 -0.5 Hole down tape position W2 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 max Name File No. GH Approval Sheet-GH Version 01 STANDARD MANUAL Page 11 Starts Released File Description Approval Sheet-GH Component CRS-2010-GH/ 01 No./rev 9.2 端子切脚或成型 Lead Cut& Lead Forming ● LEAD CUT PIN CODE:C ● RANGE:Φ4~Φ8 φD RANGE:Φ4~Φ18 LEAD FORMING AND CUT PIN COED:F φD F±0.5 F±0.5 L±0.5 2.5MAX L±0.5 ● ΦD F L ΦD F L 4 1.5 3.0~12.0 4 5.0 3.5,4.5,5.0,7.0 5 2.0 3.0~12.0 5 5.0 3.5,4.5,5.0,7.0 6.3 2.5 3.0~12.0 6.3 5.0 3.5,4.5,5.0,7.0 8 3.5 3.0~12.0 8 5.0 3.5,4.5,5.0,7.0 10 5.0 3.0~12.0 - - - 12.5 5.0 3.0~12.0 - - - 16 7.5 3.0~12.0 - - - 18 7.5 3.0~12.0 - - - Kink & cutting PIN CODE:J RANGE:Φ10~Φ18 F±0.5 φD L±0.5 1.3±0.3 ΦD F L 10 5.0 4.0,4.5,5.0 12.5 5.0 4.0,4.5,5.0 16 7.5 4.0,4.5,5.0 18 7.5 4.0,4.5,5.0 Name File No. GH Approval Sheet-GH Version 01 STANDARD MANUAL Page 12 Starts Released File Description Approval Sheet-GH Component CRS-2010-GH/ 01 No./rev 10 包装 Packing 包装标签内容 Packing Label Marked (the following items shall be marked on the label) (Inside box or bag) 1)系列 series 2)料号 P/N 3)容量 Rated capacitance 4)电压 Rated Voltage 5)数量 quantity 6)尺寸 size 批号的填写 LOT Number : 1 2 3 4 5 6 7 8 年份 月份 序号 year month number 编带产品按下图包装 Taped Packing. 散包装按下图包装方式 Bulk Packing Name File No. GH Approval Sheet-GH Version 01 STANDARD MANUAL Page 13 Starts Released File Description Approval Sheet-GH Component CRS-2010-GH/ 01 No./rev 11 其它说明 OTHER REMARKS 11.1 铝电解电容器使用注意事项 IMPORTANT INFORMATION ON THE APPLICATION OF ALUMINUM ELECTROLYTIC CAPACITORS (1)直流铝电解电容器应按正确的极性使用 DC aluminum electrolytic capacitors are normally polarized 当直流铝电解电容器按反极性接入电路时,电容器会导致电子线路短路,由此产生的电流会引致电容器 损坏。若电路中有可能在负引线施加正电压,请选无极性产品。 When reverse voltage is applied on DC aluminum electrolytic capacitor ,the circuit will be short out and the capacitor will be damaged due to abnormal current flows through the capacitor. Please use non- polar types of capacitors when the positive voltage is applied on the cathode terminal. (2)在额定工作电压以下使用 Use capacitor within rated voltage 当电容器上所施加电压高于额定工作电压时,电容器的漏电流将上升,其电气特性将在短时内劣化直至损 坏。请注意电压峰值勿超出额定工作电压。 When capacitor is used at higher voltage than the rated voltage, leakage current may increase and characteristics may be drastically deteriorated and damaged in a short period. Please take extra caution that the peak voltage should not exceed the rated voltage. (3)作快速充放电使用 Sudden charge and discharge 当常规电容器被用作快速充电用途,其使用寿命可能会因为容量下降,温度急剧上升等而缩减。 When aluminum electrolytic capacitors for general purpose-use are employed in rapid charge and discharge application, its life expectancy may be shortened resulted from capacitance decrease, heat rise, etc. (4)电容器储存 Storage of the capacitor 请保管在室温 5~35℃,湿度 75%以下的环境。 We recommend the following conditions for storage: Ambient temperature : 5~35℃ ,Ambient humidity:75%RH; a) 产品储存期限: ≤12 个月; Storage life: ≤ 12 months; b) 产品储存期限12 个月时,需充电后再使用; If storage life 12 months,the products need to be charged again before using; c) 存放时间超过 3 年的电解电容器应报废处理; If Storage time three years, the products need to be discarded; d) 库存有效期以产品套管上印刷的时间开始计算; Expiry Date: calculating from the date marked on the sleeve; e) 请尽量以包装状态保管; Please keep capacitors in the original package; f) 请避免在以下环境下保管: Avoid storing the capacitors under such circumstances: ※ 溅水、高温高湿及结露的环境。 With water and oil or damp &dewing location. ※ 溅油、或者充满气体油成分的环境。 With gas and oil. Name File No. GH Approval Sheet-GH Version 01 STANDARD MANUAL Page 14 Starts Released ※ File Description Approval Sheet-GH Component CRS-2010-GH/ 01 No./rev 充满酸性有毒气体(硫化氢,亚硫酸,亚硝酸,氯,溴,溴化甲烷等)的环境。 With toxic gases such as hydrogen sulfide, sulfurous acid, nitrous acid, chlorine, bromine and methane. ※ 直射阳光、臭氧、紫外线及放射线照射的环境。 With direct sunlight, Ozone, ultraviolet rays or radiation. (5)施加纹波电流应小于额定值 Use capacitor within rated ripple current 施加纹波电流超过额定值后,会导致电容器体过热,容量下降,寿命缩短。电容器上标注了额定电压,请 将和直流电压叠加的纹波电压的峰值控制在额定工作电压以下。 If excessive ripple current is applied on the capacitor, excessive heat will be generated inside, the capacitance will be reduced and capacitor’s life shall be shortened. Rated voltage has been marked on the capacitor; therefore, the peak value of the ripple voltage should be less than the rated voltage. (6)使用环境温度 Ambient temperature 铝电解电容器的使用寿命会受到环境温度的影响。据科学统计,使用环境温度下降 10℃其使用寿命增加 1 倍。 Life of aluminum electrolytic capacitor is affected by the ambient temperature. It is generally known that the life doubles for each 10℃ decrease in temperature. (7)引出线强度 Tensile strength of lead wire 当拉力施加到电容器引出线,该拉力将作用于电容器内部,这可能导致电容器内部短路,开路或漏电流上 升。在电容器焊装到电路板,请勿强烈摇动电容器。 When a strong force is applied to the lead wires or terminals, stress is put on the internal connections, which may result in short circuit, open circuit or leakage current increase. Therefore it is not advisable to bend or handle a capacitor after it has been soldered to the PC board. (8)焊接过程耐热性 Heat resistance at the soldering process 铝电解电容器装至电路板进行浸焊或波峰焊时,其塑料套管可能因焊接时间过长、温度过高而发生破裂或 二次收缩。 During soldering process, secondary shrinkage or sleeve crack may occur when soldering temperature is too high or soldering time is too long. (9)电路板的安装孔孔距及安装位置 Hole pitch and position of PC board 电路板安装孔的设计应与产品说明书的引线脚距相一致,如果将电容器强行插入孔距不配套的电路板,那 么会有应力作用于引出线,这可能导致短路或漏电流上升。 When designig a PC board , its hole pitch should be designed to coincide with the lead pitch (lead spacing) of the capacitor specified in the catalog or specifications.When a capacitor is forcibly inserted into an unmatched hole pitch, a force will put on the leads and which could result in a short circuit or increased leakage current. (10)关于焊接以后的清洗 Cleaning after soldering ① 电容器不能用卤化有机物系列的清洗剂进行清洗。如果必须进行清洗,请使用能够保证电容器质量的清 洗剂。 The aluminum electrolytic capacitors should be free of halogenated solvents during board cleaning after soldering. Use solvent proof capacitors when halogenated solvents are used. Name File No. GH Approval Sheet-GH Version 01 STANDARD MANUAL Page 15 Starts Released File Description Approval Sheet-GH Component CRS-2010-GH/ 01 No./rev ② 对于能够保证电容器质量的清洗剂,清洗后请不要在清洗溶液或者密封容器中保管。清洗后的电容器请 和电路板一起在热风下干燥 10 分钟以上,热风的温度不可高于电容器规定上限温度。 After cleaned with the solvent which can guarantee the quality of capacitors, the capacitors should not be kept in solvent environments of non-ventilated places. Let the capacitors after cleaning dry with hot blast fully above 10mins and the temperature of hot blast should not be over than specified upper limit of that of capacitors. (11)关于固定剂以及镀层(涂层剂)Adhesives、fixative and coating materials(coating agent) ① 请不要使用含有卤化有机物系列的固定剂及镀层(涂层剂)。 Do not use halogenated adhesives and coating materials to fix aluminum electrolytic capacitors. ② 请不要让固定剂及镀层(涂层剂)将电容器封口部位(端子一侧)全部封住。 Do not cover up all the sealing area of capacitors with adhesives、fixative or coating materials (coating agent), make coverage only partial. 11.2 符合 RoHS RoHS compliance 符合欧盟 RoHS 的最新标准,若客户有特殊要求,按照双方签订的相关协议为准。 Completely in accordance with the latest standard of RoHS or relevant agreements reached by both parts if customer has special requirements. Name File No. GH Approval Sheet-GH Version 01 STANDARD MANUAL Page 16
EGH1HM4R7D11OT 价格&库存
很抱歉,暂时无法提供与“EGH1HM4R7D11OT”相匹配的价格&库存,您可以联系我们找货
