SHT30-DIS-B
SHT30-DIS-B
    SENSIRION(盛思锐)
    DFN-8-EP(2.5x2.5)
    温湿度传感器 DFN-8 2.15~5.5V 1.7µA
SHT30-DIS-B 数据手册
Preliminary Data Sheet SHT3x-DIS Humidity and Temperature Sensor  Fully calibrated, linearized, and temperature compensated digital output  Wide supply voltage range, from 2.4 to 5.5 V  I2C Interface with communication speeds up to 1 MHz and two user selectable addresses  Typical accuracy of  2%RH and  0.3°C  Very fast start-up and measurement time  Tiny 8-Pin DFN package Product Summary SHT3x-DIS is the next generation of Sensirion’s temperature and humidity sensors. It builds on a new CMOSens® sensor chip that is at the heart of Sensirion’s new humidity and temperature platform. The SHT3x-DIS has increased intelligence, reliability and improved accuracy specifications compared to its predecessor. Its functionality includes enhanced signal processing, two distinctive and user selectable I2C addresses and communication speeds of up to 1 MHz. The DFN package has a footprint of 2.5 x 2.5 mm while keeping a height of 0.9 mm. This allows for integration of the SHT3x-DIS into a great variety of applications. Additionally, the wide supply voltage range of 2.4 to 5.5 V guarantees compatibility with diverse assembly situations. All in all, the SHT3x-DIS incorporates 15 years of knowledge of Sensirion, the leader in the humidity sensor industry. Benefits of Sensirion’s CMOSens® Technology  High reliability and long-term stability  Industry-proven technology with a track record of more than 15 years  Designed for mass production  High process capability  Low signal noise nRESET RH Sensor T Sensor ADC ADC VDD Power on Reset VSS Calibration Memory Content 1 Sensor Performance.............................................2 2 Specifications .......................................................4 3 Pin Assignment ....................................................6 4 Operation and Communication .............................7 5 Packaging...........................................................13 6 Shipping Package ..............................................15 7 Quality ................................................................16 8 Ordering Information...........................................16 9 Further Information .............................................16 www.sensirion.com Data processing & Linearization Digital Interface ADDR SDA SCL RESET Alert Logic Alert Figure 1 Functional block diagram of the SHT3x-DIS. The sensor signals for humidity and temperature are factory calibrated, linearized and compensated for temperature and supply voltage dependencies. November 2014 - 0.9 1/17 Preliminary Data Sheet SHT3x-DIS 1 Sensor Performance 1.1 Humidity Sensor Performance Parameter SHT30 Accuracy tolerance1 SHT31 Accuracy tolerance1 Repeatability2 Resolution Hysteresis Specified range3 Response time5 Long-term drift Conditions Value Units Typ. Max. Typ. Max. 3 Figure 2 2 Figure 4 0.13 0.05 0.8 0 to 100 86 2 s 80%RH). After returning into the normal temperature and humidity range the sensor will slowly come back to calibration state by itself. Prolonged exposure to extreme conditions may accelerate ageing. To ensure stable operation of the humidity sensor, the conditions described in the document “SHTxx Assembly of SMD Packages”, section “Storage and Handling Instructions” regarding exposure to volatile organic compounds have to be met. Please note as well that this does apply not only to transportation and manufacturing, but also to operation of the SHT3x-DIS. 8 Temperature response times strongly depends on the design-in of the sensor in the final application. Minimal response time can be achieved when the thermalized sensor at T1 is placed on a well conducting surface with temperature T2. www.sensirion.com November 2014 - 0.9 3/17 Preliminary Data Sheet SHT3x-DIS 2 2.1 Specifications Electrical Specifications Parameter Supply voltage Power-up/down level Supply current Heater power Symbol Condition VDD VPOR IDD PHeater Min. Typ. Max. 2.4 2.22 3.3 2.35 5.5 2.4 Not measuring 0.2 Measuring 800 Average 2 Heater running Units Comments V V Average current when sensor is not performing a measurement. Average current consumption while A sensor is measuring at lowest repeatability, Average current consumption (operation A with one measurement per second at lowest repeatability) Depending on the mW supply voltage A 5 25 Table 3 Electrical specifications, Specification are at 25°C and typical VDD 2.2 Timing Specification for the Sensor System Parameter Symbol Conditions Power-up time tPU Soft reset time tSR Typ. Max. After hard reset, VDD ≥ VPOR 0.3 0.5 After soft reset. 0.3 0.5 tMEAS,l 2.5 3 tMEAS,m 4.5 5 tMEAS,h 12.5 13.5 Duration of reset pulse Measurement duration Min. 350 Units Comments Time between VDD reaching ms VPOR and sensor entering idle state Time between ACK of soft ms reset command and sensor entering idle state ns See section 3.6 Duration for a humidity and temperature measurement ms when the repeatability is set to low Duration for a humidity and temperature measurement ms when the repeatability is set to medium Duration for a humidity and temperature measurement ms when the repeatability is set to high Table 4 System Timing Specification, Specification are at 25°C and typical VDD www.sensirion.com November 2014 - 0.9 4/17 Preliminary Data Sheet SHT3x-DIS 2.3 Absolut Minimum and Maximum Ratings Stress levels beyond those listed in Table 5 may cause permanent damage to the device or affect the reliability of the sensor. These are stress ratings only and functional operation of the device at these conditions cannot be guaranteed. Parameter Supply voltage VDD Max Voltage on pins (pin 1 (SDA); pin 2 (ADDR); pin 3 (ALERT); pin 4(SCL); pin 6(nRESET)) Input current on any pin Operating temperature range Storage temperature range ESD HBM (human body model) ESD MM (machine model) ESD CDM (charge device model) Rating Units -0.5 to 6 -0.5 to VDD+0.5 V V ±100 -40 to 125 -40 to 150 4 200 750 mA °C °C kV V V Table 5 Absolut minimum and maximum ratings; values are target specs and not confirmed by measurements yet www.sensirion.com November 2014 - 0.9 5/17 Preliminary Data Sheet SHT3x-DIS 3 Pin Assignment The SHT3x-DIS comes in a tiny 8-pin DFN package – see Table 6. Name Comments 1 SDA 2 ADDR 3 ALERT 4 5 SCL VDD 6 nRESET 7 R 8 VSS Serial data; input / output Address pin; input; connect to either VDD or VSS, do not leave floating Indicates alarm condition; output; must be left floating if unused Serial clock; input / output Supply voltage; input Reset pin active low; Input; if not used it is recommended to connect to VDD No electrical function; recommended to connected to VSS Ground 1 8 2 7 3 6 4 5 Power Pins (VDD, VSS) Serial Clock and Serial Data (SCL, SDA) SCL is used to synchronize the communication between microcontroller and the sensor. The clock frequency can be freely chosen between 0 to 1000 kHz. Commands with clock stretching according to I2C Standard9 are supported. The SDA pin is used to transfer data to and from the sensor. For safe communication, the timing specifications defined in the I2C manual9 must be met. Both SCL and SDA lines are open-drain I/Os with diodes to VDD and VSS. They should be connected to external pull-up resistors (please refer to Figure 7). A device on the I2C bus must only drive a line to ground. The external pull-up resistors (e.g. Rp=10 kΩ) are required to pull the www.sensirion.com VDD(5) ALERT(3) SCL(4) ADDR(2) SDA(1) die VSS(8) pad 3.3 The electrical specifications of the SHT3x-DIS are shown in Table 3. The power supply pins must be decoupled with a 100 nF capacitor that shall be placed as close to the sensor as possible – see Figure 7 for a typical application circuit. 3.2 nRESET(6) RP RP R(7) Figure 7 Typical application circuit. Please note that the positioning of the pins does not reflect the position on the real sensor. This is shown in Table 6. Table 6 SHT3x-DIS pin assignment (Transparent top view). Dashed lines are only visible if viewed from below. The die pad is internally connected to VSS. 3.1 VDD 100nF Pin signal high. For dimensioning resistor sizes please take bus capacity and communication frequency into account (see for example Section 7.1 of NXPs I2C Manual for more details9). It should be noted that pull-up resistors may be included in I/O circuits of microcontrollers. It is recommended to wire the sensor according to the application circuit as shown in Figure 7. Die Pad (center pad) The die pad or center pad is visible from below and located in the center of the package. It is electrically connected to VSS. Hence electrical considerations do not impose constraints on the wiring of the die pad. However, due to mechanical reasons it is recommended to solder the center pad to the PCB. For more information on design-in, please refer to the document “SHTxx Design Guide”. 3.4 ADDR Pin Through the appropriate wiring of the ADDR pin the I2C address can be selected. Please note that the I2C address is represented through the 7 MSBs of the I2C read or write header. The LSB switches between read or write header. The wiring for the default address is shown in Table 7 and Figure 7. The ADDR pin must not be left floating. Please note that only the 7 MSBs of the I2C Read/Write Header constitute the I2C Address. SHT3x-DIS I2C Address in Hex. representation I2C address A 0x44 (default) I2C address B 0x45 Condition ADDR (pin 2) connected to VSS ADDR (pin 2) connected to VDD Table 7 I2C device address November 2014 - 0.9 6/17 Preliminary Data Sheet SHT3x-DIS 3.5 ALERT Pin The alert pin may be used to connect to the interrupt pin of a microcontroller. The output of the pin depends on the value of the RH/T reading relative to programmable limits. Its function is explained in a separate application note. If not used, this pin must be left floating. 3.6 nRESET Pin The nReset pin may be used to generate a reset of the sensor. A minimum pulse duration of 350 ns is required to reliably trigger a reset of the sensor. Its function is explained in more detail in section 4. If not used it is recommended to connect to VDD. 4 Operation and Communication The SHT3x-DIS supports I2C fast mode (and frequencies up to 1000 kHz). Clock stretching can be enabled and disabled through the appropriate user command. For detailed information on the I2C protocol, refer to NXP I2C-bus specification9. All SHT3x-DIS commands and data are mapped to a 16bit address space. Additionally, data and commands are protected with a CRC checksum. This increases communication reliability. The 16 bits commands to the sensor already include a 3 bit CRC checksum. Data send from and received by the sensor is always succeeded by an 8 bit CRC. In write direction it is mandatory to transmit the checksum, since the SHT3x-DIS only accepts data if it is followed by the correct checksum. In read direction it is up to the master to decide if it wants to read and process the checksum. 4.1 Power-Up and Communication Start The sensor starts powering-up after reaching the powerup threshold voltage VPOR specified in Table 3. After reaching this threshold voltage the sensor needs the time tPU to enter idle state. Once the idle state is entered it is ready to receive commands from the master (microcontroller). address plus 0 as the write bit) and a 16-bit measurement command. The proper reception of each byte is indicated by the sensor. It pulls the SDA pin low (ACK bit) after the falling edge of the 8th SCL clock to indicate the reception. A complete measurement cycle is depicted in Table 8. With the acknowledgement of the measurement command, the SHT3x-DIS starts measuring humidity and temperature. 4.3 Measurement Commands for Single Shot Data Acquisition Mode In this mode one issued measurement command triggers the acquisition of one data pair. Each data pair consists of one 16 bit temperature and one 16 bit humidity value (in this order). During transmission the data pair is always followed by a CRC checksum, see section 4.4. In single shot mode different measurement commands can be selected. The 16 bit commands are shown in Table 8. They differ with respect to repeatability (low, medium and high) and clock stretching (enabled or disabled). The repeatability setting influences the measurement duration and the current consumption of the sensor. This is explained in section 2.2. During measurement the sensor generally does not respond to any I2C activity, i.e. I2C read and write headers are not acknowledged (NACK). However, when a command with clock stretching has been issued, the sensor responds to a read header with an ACK and subsequently pulls down the SCL line. The SCL line is pulled down until the measurement is complete. As soon as the measurement is complete, the sensor releases the SCL line and sends the measurement results. Each transmission sequence begins with a START condition (S) and ends with a STOP condition (P) as described in the I2C-bus specification. The stop condition is optional. Whenever the sensor is powered up, but not performing a measurement or communicating, it automatically enters sleep state for energy saving. This sleep state cannot be controlled by the user. 4.2 Starting a Measurement A measurement communication sequence consists of a START condition, the I2C write header (7-bit I2C device 9 http://www.nxp.com/documents/user_manual/UM10204.pdf www.sensirion.com November 2014 - 0.9 7/17 Preliminary Data Sheet SHT3x-DIS Condition Repeatability Clock stretching Hex. code MSB LSB High 06 Medium enabled 0x2C 0D Low 10 High 00 Medium disabled 0x24 0B Low 16 e.g. 0x2C06: high repeatability measurement with clock stretching enabled In case the user needs humidity and temperature data but does not want to process CRC data, it is recommended to read the first two bytes of data with the CRC byte (without processing the CRC data) and abort the read transfer after reading the second two data bytes with a NACK. 4.5 Measurement Commands for Periodic Data Acquisition Mode In this mode one issued measurement command yields a stream of data pairs. Each data pair consists of one 16 bit temperature and one 16 bit humidity value (in this order). In periodic mode different measurement commands can be selected. The corresponding 16 bit commands are shown in Table 9. They differ with respect to repeatability (low, medium and high) and data acquisition frequency (0.5, 1, 2, 4 & 10 measurements per second, mps). Clock stretching cannot be selected in this mode. The data acquisition frequency and the repeatability setting influences the measurement duration and the current consumption of the sensor. This is explained in section 2.2 of this datasheet. Condition Repeatability After the sensor has completed the measurement, the master can read the measurement results (pair of RH& T) by sending a START condition followed by an I2C read header. The sensor will acknowledge the reception of the read header and send two bytes of data (temperature) followed by one byte CRC checksum and another two bytes of data (relative humidity) followed by one byte CRC checksum. Each byte must be acknowledged by the microcontroller with an ACK condition for the sensor to continue sending data. If the sensor does not receive an ACK from the master after any byte of data, it will not continue sending data. The sensor will send the temperature value first and then the relative humidity value. After receiving the checksum for the humidity value a NACK and stop condition should be send (see Table 10). 1 S 2 3 4 5 6 I2C Address I2C write header 7 8 9 W 1 2 3 4 5 6 7 Command MSB 8 9 10 11 12 13 14 15 16 17 18 Command LSB ACK Readout of Measurement Results for Single Shot Mode ACK 4.4 mps High 32 Medium 0.5 0x20 24 Low 2F High 30 Medium 1 0x21 26 Low 2D High 36 Medium 2 0x22 20 Low 2B High 34 Medium 4 0x23 22 Low 29 High 37 Medium 10 0x27 21 Low 2A e.g. 0x2F31: 10 high repeatability mps - measurement per second ACK Table 8 Measurement commands in single shot mode (Clear blocks are controlled by the microcontroller, grey blocks by the sensor.) Hex. code MSB LSB 16-bit command Table 9 Measurement commands for periodic data acquisition mode (Clear blocks are controlled by the microcontroller, grey blocks by the sensor.) The I2C master can abort the read transfer with a NACK condition after any data byte if it is not interested in subsequent data, e.g. the CRC byte or the second measurement result, in order to save time. www.sensirion.com November 2014 - 0.9 8/17 Preliminary Data Sheet SHT3x-DIS 4.6 Readout of Measurement Results for Periodic Mode Transmission of the measurement data can be initiated through the command shown in Table 10. If no measurement data is present the I2C read header is responded with a NACK instead of an ACK (Bit 9 in Table 10) and the communication stops. Command Hex code Fetch Data 0x E0 00 4.8 Reset A system reset of the SHT3x-DIS can be generated externally by issuing a command (soft reset) or by sending a pulse to the dedicated reset pin (nReset pin). Additionally, a system reset is generated internally during power-up or when brownout conditions are met. During the reset procedure the sensor will not process commands. In order to achieve a full reset of the sensor without removing the power supply, it is recommended to use the nRESET pin of the SHT3x-DIS. Soft Reset Table 10 Data fetch command (Clear blocks are controlled by the microcontroller, grey blocks by the sensor.) 4.7 ART Command The unique ART (accelerated response time) feature can be activated by issuing the command in Table 12. The art command is structurally similar to any other command in Table 9. Hence section 4.5 & 4.6 apply for starting a measurement and reading out data. The ART feature can also be evaluated using the Evaluation Kit EK-H5 from Sensirion. Command Hex Code Periodic Measurement with ART 0x30A2 4 5 6 I2C Address 7 8 9 W I2C write header 1 2 3 4 5 6 7 Command MSB 8 9 It is worth noting that the sensor reloads calibration data prior to every measurement by default. Command Hex Code Soft Reset 0x30A2 Table 12 Soft reset command (Clear blocks are controlled by the microcontroller, grey blocks by the sensor.) 10 11 12 13 14 15 16 17 18 Command LSB ACK 3 ACK S 2 ACK 1 The SHT3x-DIS provides a soft reset mechanism that forces the system into a well-defined state without removing the power supply. When the system is in idle state the soft reset command can be sent to the SHT3xDIS. This triggers the sensor to reset its system controller and reloads calibration data from the memory. In order to start the soft reset procedure the command as shown in Table 12 should be sent. 16-bit command Table 11 Command for a periodic data acquisition with the ART feature (Clear blocks are controlled by the microcontroller, grey blocks by the sensor.) Reset through the nReset Pin Pulling the nReset pin low (see Table 6) generates a reset similar to a hard reset (switching the power supply to the VDD Pin off and then on again. The pins 1 (SDA), 4(SCL) and 2(ADDR) have a lower voltage than VDD. Otherwise the sensor will be powered over the ESD diodes. The reset pin is internally connected to VDD through a pull-up and hence active low. The nReset pin has to be pulled low for at least 350 ns to generate a reset. General Call Additionally a reset of the sensor can also be generated using the “general call” mode according to I2C-bus specification9. This generates a reset which is functionally identical to using the nReset pin. It is important to understand that a reset generated in this way is not device specific. All devices on the same I2C bus that support the general call mode will perform a reset. Additionally, for this command to work it is required www.sensirion.com November 2014 - 0.9 9/17 Preliminary Data Sheet SHT3x-DIS that the sensor is able to process I2C commands. The appropriate command consists of two bytes and is shown in Table 13. Command Code Address byte Second byte Reset command using the general call address 0x00 0x06 3 4 5 6 7 8 S General Call Address 9 General Call 1st byte 1 2 3 4 5 6 7 8 Command Hex Code Clear status register 0x 30 41 9 ACK 2 All flags (Bit 15, 11, 10, 4) in the status register can be cleared (reinitialized to their default value) by sending the command shown in Table 16. 0x0006 ACK 1 Clear Status Register Reset Command General Call 2nd byte Table 13 Reset through the general call address (Clear blocks are controlled by the microcontroller, grey blocks by the sensor.). Table 16 Command to clear the status register (Clear blocks are controlled by the microcontroller, grey blocks by the sensor.) Bit 4.9 Heater The heater can be switched on and off by command, see table below. The status is listed in the status register. After a reset the heater is disabled (default condition). Command Heater Enable Heater Disabled 14 13 Hex Code MSB LSB 0x306 15 D 6 12 11 10 Table 14 Heater command (Clear blocks are controlled by the microcontroller, grey blocks by the sensor.) 9:5 4 4.10 Status Register The status register contains information on the operational status of the heater, the alert mode and on the execution status of the last command and the last write sequence. The command to read out the status register is shown in Table 15 whereas a description of the content can be found in Table 17. Command Hex code Read Out of status register 0xF32D 3:2 1 0 Field description Alert pending status '0': no pending alerts '1': at least one pending alert Write '1' to clear all alert flags Reserved Heater status ‘0’ : Heater OFF ‘1’ : Heater ON Reserved RH tracking alert ‘0’ : no alert ‘1’ . alert T tracking alert ‘0’ : no alert ‘1’ . alert Reserved System reset detected '0': no reset detected since last ‘clear all alert flags write’ '1': reset detected (hard reset, soft reset command or supply fail) Reserved Command status '0': last command executed successfully '1': last command not processed. It was either invalid, failed the integrated command checksum Write data checksum status '0': checksum of last write transfer was correct '1': checksum of last write transfer failed Reset value ‘0’ ‘0’ ‘0’ ‘0’ ‘0 ‘0’ ‘00000’ ‘0’ ‘00’ ‘0’ ‘0’ Table 17 Description of the status register Table 15 Command to read out the status register (Clear blocks are controlled by the microcontroller, grey blocks by the sensor.) www.sensirion.com November 2014 - 0.9 10/17 Preliminary Data Sheet SHT3x-DIS 4.11 Checksum Calculation The 8-bit CRC checksum transmitted after each data word is generated by a CRC algorithm. Its properties are displayed in Table 18. The CRC covers the contents of the two previously transmitted data bytes. To calculate the checksum only these two previously transmitted data bytes are used. Property Value Name Width Protected data Polynomial Initialization Reflect input Reflect output Final XOR Examples CRC-8 8 bit read and/or write data 0x31 (x8 + x5 + x4 + 1) 0xFF False False 0x00 CRC (0xBEEF) = 0x92 Table 18 I2C CRC properties. 4.12 Conversion of Signal Output Measurement data is always transferred as 16-bit values (unsigned integer). These values are already linearized and compensated for temperature and supply voltage effects. Converting those raw values into a physical scale can be achieved using the following formulas. Relative humidity conversion formula (result in %RH): RH  100  S RH 2 16  1 Temperature conversion formula (result in °C & °F): ST 2 1 S T F    49  347  16 T 2 1 T C    45  175  16 SRH and ST denote the raw sensor output for humidity and temperature, respectively. The formulas only work correct when SRH and ST are used in decimal representation. www.sensirion.com November 2014 - 0.9 11/17 Preliminary Data Sheet SHT3x-DIS 4.13 Communication Timing Parameter Symbol SCL clock frequency Hold time (repeated) START condition LOW period of the SCL clock HIGH period of the SCL clock SDA hold time SDA set-up time SCL/SDA rise time SCL/SDA fall time SDA valid time Set-up time for a repeated START condition Set-up time for STOP condition Capacitive load on bus line Low level input voltage High level input voltage Low level output voltage fSCL Conditions Min. Typ. 0 tHD;STA After this period, the first clock pulse is generated Max. Units 1000 kHz 0.24 µs tLOW 0.65 µs tHIGH 0.26 µs tHD;DAT tSU;DAT tR tF tVD;DAT 250 100 ns ns ns ns µs tSU;STA 0.6 µs tSU;STO 0.6 µs CB VIL VIH VOL 300 300 0.9 400 0.3xVDD 1xVDD 0.66 -0.5 0.7xVDD 3 mA sink current Comments pF V V V Table 19 Communication timing specifications for I2C fm (fast mode), Specification are at 25°C and typical VDD . The numbers above are values according to the I2C Specification (UM10204, Rev. 5, October 9 13, 2012) 1/fSCL tHIGH tR tLOW tF 70% SCL tSU;DAT 30% tHD;DAT DATA IN 70% SDA 30% tVD;DAT tF DATA OUT tR 70% SDA 30% Figure 8 Timing diagram for digital input/output pads. SDA directions are seen from the sensor. Bold SDA lines are controlled by the sensor, plain SDA lines are controlled by the micro-controller. Note that SDA valid read time is triggered by falling edge of preceding toggle. www.sensirion.com November 2014 - 0.9 12/17 Preliminary Data Sheet SHT3x-DIS 5 Packaging SHT3x-DIS sensors are provided in a DFN package. DFN stands for dual flat no leads. The humidity sensor opening is centered on the top side of the package. The sensor chip is made of silicon and is mounted to a lead frame. The latter is made of Cu plated with Ni/Pd/Au. Chip and lead frame are overmolded by an epoxy-based mold compound leaving the central die pad and I/O pins exposed for mechanical and electrical connection. Please note that the side walls of the sensor are diced and therefore these diced lead frame surfaces are not covered with the respective plating. 5.1 etc). The last three digits (BCD) represent an alphanumeric tracking code. That code can be decoded by Sensirion only and allows for tracking on batch level through production, calibration and testing – and will be provided upon justified request. If viewed from below pin 1 is indicated by triangular shaped cut in the otherwise rectangular die pad. The dimension of the triangular cut are shown in Figure 10 through the labels T1 & T2. SHT 3 x Traceability All SHT3x-DIS sensors are laser marked for easy identification and traceability. The marking on the sensor top side consists of a pin-1 indicator and two lines of text. The top line consist of the pin-1 indicator which is located in the top left corner and the product name. The small letter x stands for the accuracy class. The bottom line consists of 6 letters. The first two digits XY (=DI) describe the output mode. The third letter (A) represents the manufacturing year (4 = 2014, 5 = 2015, www.sensirion.com XYABCD Figure 9 Top View of the SHT3x-DIS illustrating the laser marking. November 2014 - 0.9 13/17 Preliminary Data Sheet SHT3x-DIS 5.2 Package Outline T1 x T2 b E E2 e S D A L D2 Figure 10 Dimensional drawing of SHT3x-DIS sensor package Parameter Package height Leadframe height Pad width Package width Center pad length Package length Center pad width Pad pitch Pad length Symbol Min Nom. A A3 0.8 0.9 0.2 1 b D D2 E E2 e L S 0.2 2.4 1 2.4 1.7 0.25 2.5 1.1 2.5 1.8 0.5 0.35 0.3 2.6 1.2 2.6 1.9 0.3 Max Units Comments 0.4 1.5 mm mm mm mm mm mm mm mm mm mm Max cavity Center pad marking T1xT2 0.3x45° mm Not shown in the drawing Only as guidance. This value includes all tolerances, including displacement tolerances. Typically the opening will be smaller. indicates the position of pin 1 Table 20 Package outline 5.3 Land Pattern Figure 11 shows the land pattern. The land pattern is understood to be the metal layer on the PCB, onto which the DFN pads are soldered. The solder mask is understood to be the insulating layer on top of the PCB covering the copper traces. It is recommended to design the solder mask as a NonSolder Mask Defined (NSMD) type. For NSMD pads, the solder mask opening should provide a 60 μm to 75 μm design clearance between any copper pad and solder mask. As the pad pitch is only 0.5 mm we recommend to have one solder mask opening for all 4 I/O pads on one side. www.sensirion.com For solder paste printing it is recommended to use a laser-cut, stainless steel stencil with electro-polished trapezoidal walls and with 0.1 or 0.125 mm stencil thickness. The length of the stencil apertures for the I/O pads should be the same as the PCB pads. However, the position of the stencil apertures should have an offset of 0.1 mm away from the center of the package. The die pad aperture should cover about 70 – 90 % of the die pad area –thus it should have a size of about 0.9 mm x 1.6 mm. For information on the soldering process and further recommendation on the assembly process please consult the Application Note HT_AN_SHTxx_Assembly_of_SMD_Packages , which can be found on the Sensirion webpage. November 2014 - 0.9 14/17 Preliminary Data Sheet SHT3x-DIS land pattern stencil aperture sensor outline 0.25 1.6 0.5 0.4 0.45 0.5 0.375 1.7 0.5 0.375 0.5 0.25 0.5 0.5 0.3x45° 0.3 0.2 0.55 1 0.55 0.75 0.55 0.9 0.8 Figure 11 Recommended metal land pattern and stencil apertures for the SHT3x-DIS. The dashed lines represent the outer dimension of the DFN package. The PCB pads and stencil apertures are indicated through the shaded areas. 6 Shipping Package Ø1.5 +.1 /-0.0 4.00 2.00 ±.05 SEE Note 2 Ø1.00 MIN 1.75 ±.1 4.00 SEE Note 1 0.30 ±.05 A 5.50 ±.05 SEE NOTE 2 R 0.2 MAX. B0 B 12.0 +0.3/-0.1 A R 0.25 TYP. K0 A0 SECTION A - A A0 = 2.75 B0 = 2.75 K0 = 1.20 TOLERANCES - UNLESS NOTED 1PL ±.2 2PL ±.10 NOTES: 1. 10 SPROCKET HOLE PITCH CUMULATIVE TOLERANCE ±0.2 2. POCKET POSITION RELATIVE TO SPROCKET HOLE MEASURED AS TRUE POSITION OF POCKET, NOT POCKET HOLE 3. A0 AND B0 ARE CALCULATED ON A PLANE AT A DISTANCE "R" ABOVE THE BOTTOM OF THE POCKET DETAIL B Figure 12 Technical drawing of the packaging tape with sensor orientation in tape. Header tape is to the right and trailer tape to the left on this drawing. Dimensions are given in millimeters. www.sensirion.com November 2014 - 0.9 15/17 Preliminary Data Sheet SHT3x-DIS 7 8 Quality Qualification of the SHT3x-DIS is performed based on the AEC Q 100 qualification test method. 7.1 This sensor cannot be ordered so far. Samples are available upon request. Please contact Sensirion. 9 Material Contents The device is fully RoHS and WEEE compliant, e.g. free of Pb, Cd, and Hg. Ordering Information Further Information For more in-depth information on the SHT3x-DIS and its application please consult the following documents: Document Name Description Source SHT3x Shipping Package Information on Tape, Reel and shipping bags (technical drawing and dimensions) Available upon request Available for download at the Sensirion humidity sensors download center: SHTxx Assembly of SMD Packages Assembly Guide (Soldering Instruction,) SHTxx Design Guide Design guidelines for designing SHTxx humidity sensors into applications SHTxx Handling Instructions Available for download at the Sensirion Guidelines for proper handling of SHTxx humidity humidity sensors download center: sensors (Reconditioning Procedure) www.sensirion.com/humidity-download Sensirion Humidity Sensor Specification Statement Definition of sensor specifications. www.sensirion.com/humidity-download Available for download at the Sensirion humidity sensors download center: www.sensirion.com/humidity-download Available for download at the Sensirion humidity sensors download center: www.sensirion.com/humidity-download Table 21 Documents containing further information relevant for theSHT3x-DIS. Revision History Date Version 0.9 www.sensirion.com Page(s) Changes Initial release November 2014 - 0.9 16/17 Preliminary Data Sheet SHT3x-DIS Headquarters and Subsidiaries SENSIRION AG Laubisruetistr. 50 CH-8712 Staefa ZH Switzerland Sensirion Inc., USA phone: +1 805 409 4900 info_us@sensirion.com www.sensirion.com Sensirion Korea Co. Ltd. phone: +82 31 337 7700 3 info@sensirion.co.kr www.sensirion.co.kr phone: +41 44 306 40 00 fax: +41 44 306 40 30 info@sensirion.com http://www.sensirion.com Sensirion Japan Co. Ltd. phone: +81 3 3444 4940 info@sensirion.co.jp www.sensirion.co.jp Sensirion China Co. Ltd. phone: +86 755 8252 1501 info@sensirion.com.cn www.sensirion.com.cn Sensirion AG (Germany) phone: +41 44 927 11 66 info@sensirion.com www.sensirion.com To find your local representative, please visit http://www.sensirion.com/contact www.sensirion.com November 2014 - 0.9 17/17
SHT30-DIS-B 价格&库存
很抱歉,暂时无法提供与“SHT30-DIS-B”相匹配的价格&库存,您可以联系我们找货
