CF14JT22K0
CF14JT22K0
    SEI
    AXIAL_D2.3X6MM_TM
    碳膜电阻 AXIAL_D2.3X6MM_TM 22KΩ ±5% 0~-500ppm/℃
CF14JT22K0 数据手册
CF/CFM Series Stackpole Electronics, Inc. Carbon Film Resistor • Features: Resistive Product Solutions General purpose resistor ideal for commercial/industrial applications Flame retardant coatings standard Flameproof version available as CFF Panasert available on selected sizes; contact factory Auto sequencing/insertion compatible CFM (mini) ideal choice when size constraints apply Cut and formed product is available on select sizes; contact factory Standard lead wire for CF/CFM is copper plated steel, with 100% tin over plate 100% tin plate on copper wire is available as type CFQ/CFQM RoHS compliant, lead-free and halogen-free • • • • • • • • • Electrical Specifications Type/Code Power Rating (Watts) @ 70ºC Maximum Working (1) Voltage Maximum Overload Voltage Dielectric Withstanding Voltage CF18 0.125W 250V 500V 350V CF14 0.25W 350V 600V 350V CF12 0.5W 350V 700V 600V 10Ω to 9.99KΩ = 0 ~ -400ppm/ºC CF1 1W 500V 1,000V 600V 10KΩ to 99KΩ = 0 ~ -500ppm/ºC 100KΩ to 999KΩ = 0 ~ -850ppm/ºC CF2 2W 500V 1,000V 600V CFM14 0.25W 250V 500V 350V CFM12 0.5W 350V 600V 350V CFM1 1W 600V 1,000V 600V Resistance Temperature Coefficient per Ohmic Range Ohmic Range (Ω) and Tolerance 2% 5% 10 - 1M
CF14JT22K0 价格&库存
很抱歉,暂时无法提供与“CF14JT22K0”相匹配的价格&库存,您可以联系我们找货
CF14JT22K0
  • 1+0.885191+0.11467
  • 10+0.2378310+0.03081
  • 25+0.2009325+0.02603
  • 50+0.1747050+0.02263
  • 100+0.15347100+0.01988
  • 250+0.12948250+0.01678
  • 500+0.11448500+0.01483
  • 1000+0.101691000+0.01318
库存:68431
