RMCF0603FT10K0
RMCF0603FT10K0
    SEI
    贴片电阻 0603 10KΩ ±1% 1/10W ±100ppm/℃
RMCF0603FT10K0 数据手册
RMCF/RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Features: • • • • • • Resistive Product Solutions RMCF – standard power ratings RMCP – high power ratings Nickel barrier terminations standard Power derating from 100% at 70ºC to zero at +155ºC AEC-Q200 Compliant (except RMCP0201) RoHS compliant and halogen-free Electrical Specifications - RMCF Type / Code Power Rating (Watts) @ 70ºC Maximum Working Voltage (1) Maximum Overload Voltage Maximum Current (Amp) RMCF01005 0.03W 15V 30V 0.5 A RMCF0201 0.05W 25V 50V 0.5 A RMCF0402 0.063W 50V 100V 1A RMCF0603 0.1W 75V 150V 1A RMCF0805 0.125W 150V 300V 2A RMCF1206 0.25W 200V 400V 2A RMCF1210 0.33W (3) 200V 400V 3A RMCF2010 0.75W 200V 400V 3A RMCF2512 1W 200V 400V 3A Resistance Temperature Coefficient Ohmic Range (Ω) and Tolerance (2) -200/+600 ppm/ºC ± 250 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 500 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC 1 - 9.76 10 - 1M 1 - 9.76 10 - 10M 1% 5% 1 - 9.76 (4) 10 - 1M 1.02M - 10M 1.1M - 20M 0.1 - 0.499 0.5 - 0.976 1 - 9.76 1 - 20M 10 - 1M 1.02M - 10M 0.1 - 9.76 0.1 - 20M 10 - 1M 1.02M - 10M 0.1 - 9.76 0.1 - 20M 10 - 1M 1.02M - 10M 0.1 - 0.976 1 - 9.76 10 - 20M 10 - 10M 0.1 - 0.976 1 - 9.76 10 - 10M 10 - 10M 0.1 - 0.976 1 - 9.76 10 - 10M 10 - 10M - Notes: (1) Lesser of √P*R or maximum working voltage (2) Contact factory for extended ohmic values (3) Power rating is 0.5W for ohmic values 1KΩ and below (4) Contact factory for lower ohmic values Rev Date: 01/07/2019 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com RMCF/RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Electrical Specifications - RMCP Type / Code Power Rating (Watts) @ 70ºC Maximum Working (1) Voltage Maximum Overload Voltage Maximum Current RMCP0201 0.063W 25V 50V 1 Amp RMCP0402 0.125W 50V 100V 1.5 Amp RMCP0603 0.25W 75V 150V 2 Amp RMCP0805 0.33W 150V 300V 2.5 Amp RMCP1206 0.33W 200V 400V 3.5 Amp RMCP1210 0.5W 200V 400V 5 Amp RMCP2010 1W 200V 400V 6 Amp RMCP2512 2W 250V 500V 7 Amp Resistance Temperature Coefficient Ohmic Range (Ω) and Tolerance (2) 1%, 5% 1 - 9.76 10 - 1M 1 - 9.76 10 - 1M 1 - 9.76 10 - 1M 1 - 9.76 10 - 1M 1 - 9.76 10 - 1M 1 - 9.76 10 - 1M 1 - 9.76 10 - 1M 1 - 9.76 10 - 1M -200/+400 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC Notes: (1) Lesser of √P*R or maximum working voltage (2) Contact factory for extended ohmic values Mechanical Specifications Type / Code Average Unit Weight (mg) RMCF01005 0.07 RMCF0201 RMCP0201 RMCF0402 RMCP0402 RMCF0603 RMCP0603 RMCF0805 RMCP0805 RMCF1206 RMCP1206 RMCF1210 RMCP1210 RMCF2010 RMCP2010 RMCF2512 RMCP2512 0.16 0.57 0.62 1.88 2.04 5.00 4.37 8.86 8.95 15.55 15.96 23.56 24.24 40.02 39.45 L Body Length 0.016 ± 0.0008 0.40 ± 0.02 0.024 ± 0.0012 0.60 ± 0.03 0.039 ± 0.004 1.00 ± 0.10 0.061 ± 0.006 1.55 ± 0.15 0.079 ± 0.008 2.00 ± 0.20 0.126 ± 0.010 3.20 ± 0.25 0.126 ± 0.010 3.20 ± 0.25 0.197 ± 0.008 5.00 ± 0.20 0.248 ± 0.008 6.30 ± 0.20 Rev Date: 01/07/2019 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. W Body Width 0.008 ± 0.0008 0.20 ± 0.02 0.012 ± 0.0012 0.30 ± 0.03 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.006 0.80 ± 0.15 0.049 ± 0.004 1.25 ± 0.10 0.063 ± 0.006 1.60 ± 0.15 0.098 ± 0.010 2.50 ± 0.25 0.098 ± 0.008 2.50 ± 0.20 0.126 ± 0.010 3.20 ± 0.25 2 H Body Height 0.005 ± 0.0008 0.13 ± 0.02 0.009 ± 0.0012 0.23 ± 0.03 0.012 ± 0.002 0.30 ± 0.05 0.018 ± 0.004 0.45 ± 0.10 0.020 ± 0.006 0.50 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 a Top Termination 0.004 ± 0.0012 0.10 ± 0.03 0.006 ± 0.002 0.15 ± 0.05 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.014 ± 0.010 0.35 ± 0.25 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.012 0.50 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 b Bottom Termination 0.004 ± 0.0012 0.10 ± 0.03 0.006 ± 0.002 0.15 ± 0.05 0.010 ± 0.006 0.25 ± 0.15 0.012 ± 0.008 0.30 ± 0.20 0.014 ± 0.010 0.35 ± 0.25 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.012 0.50 ± 0.30 0.024 ± 0.014 0.60 ± 0.35 0.024 ± 0.014 0.60 ± 0.35 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RMCF/RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Performance Characteristics Test Test Specifications Test Conditions (JIS-C 5202) Short Time Overload ±(2%+0.1Ω) 2.5x rated voltage for 5 seconds Dielectric Withstanding Voltage No flashover or breakdown 100 VAC, 1 minute Resistance to Soldering Heat ±1% 260ºC±5ºC, for 10 seconds ±0.5 seconds (Solder Bath) Solderability 95% coverage, minimum 235ºC±5ºC, for 2 seconds ±0.5 seconds (Colophonium flux) Temperature Cycle ±(1%+0.05Ω) Jumper (
RMCF0603FT10K0 价格&库存
很抱歉,暂时无法提供与“RMCF0603FT10K0”相匹配的价格&库存,您可以联系我们找货
RMCF0603FT10K0
  • 50+0.02293
  • 200+0.02150
  • 600+0.02008
  • 2000+0.01865
  • 5000+0.01723
  • 10000+0.01623
RMCF0603FT10K0
  • 100+0.02744
  • 1000+0.02096
  • 5000+0.01739
  • 10000+0.01523
  • 50000+0.01340
  • 100000+0.01242
