RC0402FR-074K3L
RC0402FR-074K3L
    YAGEO(国巨)
    贴片电阻 0402 4.3KΩ ±1% 1/16W ±100ppm/℃
RC0402FR-074K3L 数据手册
DATA SHEET GENERAL PURPOSE CHIP RESISTORS RC0402 5%, 1% Product specification – Jan 05, 2011 V.6 Supersedes Date of Mar. 06, 2003 RoHS compliant & Halogen Free Product specification Chip Resistor Surface Mount RC SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes RC0402 series chip resistors with lead-free terminations made by thick film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. YAGEO BRAND ordering code GLOBAL PART NUMBER APPLICATIONS All general purpose application FEATURES Halogen Free Epoxy RoHS compliant - - RC0402 ( PREFERRED ) X R - XX XXXX L (1) (2) (3) (4) (5) (6) (1) TOLERANCE F = ±1% J = ±5% (for Jumper ordering, use code of J) (2) PACKAGING TYPE R = Paper / PE taping reel Products with lead free terminations meet RoHS requirements (3) TEMPERATURE COEFFICIENT OF RESISTANCE Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS (4) TAPING REEL – = Base on spec 07 = 7 inch dia. Reel 7D = 7 inch dia. Reel, 2 x Standard Quantity 10 = 10 inch dia. Reel 13 = 13 inch dia. Reel Reducing environmentally hazardous wastes High component and equipment reliability Saving of PCB space 2 9 0402 SERIES (5) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. None forbidden-materials used in products/production Detailed resistance rules show in table of “Resistance rule of global part number”. (6) DEFAULT CODE Letter L is system default code for ordering only (Note) Resistance rule of global part number Resistance code rule Example D1 D1 = Dummy 0R 0R = Jumper XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω ORDERING EXAMPLE The ordering code of a RC0402 chip resistor, value 56 X with ±1% tolerance, supplied in 7-inch tape of 20,000 units per reel is: RC0402FR-7D56RL. NOTE 1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol can be printed www.yageo.com Jan 05, 2011 V.6 Product specification Chip Resistor Surface Mount RC SERIES 3 9 0402 PHYCOMP BRAND ordering codes Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp brand products. GLOBAL PART NUMBER ( PREFERRED ) For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2. 12NC CODE 2322 XXX XXXXX L (1) (2) (3) Last digit of 12NC Resistance decade (3) (4) PAPER / PE TAPE ON REEL (units) Last digit 0.01 to 0.0976 X 0.1 to 0.976 X 0 705 87xxx 1 to 9.76 X 8 --- 706 8xxxx 10 to 97.6 X 9 --- 705 91007 100 to 976 X 1 1 to 9.76 KX 2 10 to 97.6 KX 3 100 to 976 KX 4 1 to 9.76 MX 5 10 to 97.6 MX 6 TYPE/ START 0402 IN (1) TOL. RESISTANCE (%) RANGE 10,000 RC31 2322 ±5% 1 to 22 MΩ 705 70xxx --- RC32 2322 ±1% 1 to 10 MΩ 706 7xxxx - 0Ω 705 91001 Jumper 2322 (2) 20,000/not preferred 50,000 (1) The resistors have a 12-digit ordering code starting with 2322. (2) The subsequent 4 or 5 digits indicate the resistor tolerance and packaging. (3) The remaining 4 or 3 digits represent the resistance value with the last digit indicating the multiplier as shown in the table of “Last digit of 12NC”. 0.02 X = 0200 or 200 0.3 X = 3007 or 307 ORDERING EXAMPLE 1X = 1008 or 108 The ordering code of a RC32 resistor, value 56 X with ±1% tolerance, supplied in tape of 10,000 units per reel is: 232270675609L or RC0402FR-0756RL. 33 KX = 3303 or 333 10 MX = 1006 or 106 (4) Letter L is system default code for order only (Note) Example: 7 NOTE 1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol can be printed www.yageo.com Jan 05, 2011 V.6 Product specification Chip Resistor Surface Mount RC SERIES 4 9 0402 MARKING RC0402 No marking ynsc007 Fig. 1 For further marking information, please see special data sheet “Chip resistors marking” CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environment influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Nibarrier) are added. See fig.2 OUTLINES For dimension see Table 1 overcoat Primary glass layer resistive layer (Jumper chip is a conductor) inner electrode H termination(Ni/matte tin) ceramic substrate I2 overcoat I1 W YNSC056 DIMENSIONS Table 1 TYPE L RC0402 L (mm) 1.00 ±0.05 W (mm) 0.50 ±0.05 H (mm) 0.35 ±0.05 I1 (mm) 0.20 ±0.10 I2 (mm) 0.25 ±0.10 Fig. 2 Chip resistor outlines www.yageo.com Jan 05, 2011 V.6 Product specification Chip Resistor Surface Mount RC SERIES 5 9 0402 ELECTRICAL CHARACTERISTICS FOOTPRINT AND SOLDERING PROFILES Table 2 RC0402 1/16 W CHARACTERISTICS Operating Temperature Range –55 °C to +155 °C Maximum Working Voltage 50 V Maximum Overload Voltage 100 V Dielectric Withstanding Voltage 100 V For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”. 5% (E24) 1 Ω to 22 MΩ Resistance Range 1% (E24/E96) 1 Ω to 10 MΩ Zero Ohm Jumper < 0.05 Ω Temperature Coefficient 1 Ω ≤ R ≤ 10 Ω ±200 ppm/°C 10 Ω < R ≤ 10 MΩ ±100 ppm/°C 10 MΩ < R ≤ 22 MΩ ±200 ppm/°C Rated Current 1.0 A Maximum Current 2.0 A Jumper Criteria PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PRODUCT TYPE PACKING STYLE RC0402 Paper / PE Taping Reel (R) REEL DIMENSION QUANTITY PER REEL 7" (178 mm) 10,000/20,000 units 10" (254 mm) 20,000 units 13" (330 mm) 50,000 units NOTE 1. For paper/PE tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing” 2. For size of 0402, standard quantity is 10,000 units per reel FUNCTIONAL DESCRIPTION POWER RATING RC0402 rated power at 70°C is 1/16 W RATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less handbook, halfpage P (%Prated ) MLB206_2 100 50 0 55 0 50 70 100 155 o Tamb ( C) Where V=Continuous rated DC or AC (rms) working voltage (V) Fig. 3 Maximum dissipation (P) in percentage of rated power as a function of the operating ambient temperature (Tamb) P=Rated power (W) R=Resistance value (X) www.yageo.com Jan 05, 2011 V.6 Product specification Chip Resistor Surface Mount RC SERIES 6 9 0402 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Temperature Coefficient of Resistance (T.C.R.) IEC 60115-1 4.8 At +25/–55 °C and +25/+125 °C Refer to table 2 Formula: R2–R1 T.C.R= ------------------------- ×106 (ppm/°C) R1(t2–t1) Where t1=+25 °C or specified room temperature t2=–55 °C or +125 °C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Life/Endurance IEC 60115-1 4.25.1 At 70±5 °C for 1,000 hours, RCWV applied for 1.5 hours on, 0.5 hour off, still air required ±(1.0%+0.05 Ω) for 1% tol. ±(3.0%+0.05 Ω) for 5% tol.
RC0402FR-074K3L 价格&库存
很抱歉,暂时无法提供与“RC0402FR-074K3L”相匹配的价格&库存,您可以联系我们找货
RC0402FR-074K3L
    库存:9200
    RC0402FR-074K3L
    • 50+0.00280
    • 500+0.00253
    • 5000+0.00218
    • 30000+0.00210
    • 90000+0.00201
    RC0402FR-074K3L
      库存:8000
      RC0402FR-074K3L
        • 10000+0.00250
        库存:80000
        RC0402FR-074K3L
          • 100+0.00360
          • 1000+0.00280
          • 3000+0.00230
          • 10000+0.00210
          • 50000+0.00190
          库存:9900
          RC0402FR-074K3L
            库存:12520
