RC0603FR-0722R6L
RC0603FR-0722R6L
    YAGEO(国巨)
    贴片电阻 0603 22.6Ω ±1% 1/10W ±100ppm/℃
RC0603FR-0722R6L 数据手册
Product specification – Apr 24, 2009 V.4 Supersedes Date of Mar. 06, 2003 DATA SHEET GENERAL PURPOSE CHIP RESISTORS RC0603 5%, 1% RoHS compliant Product specification Chip Resistor Surface Mount RC SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes RC0603 series chip resistors with lead-free terminations made by thick film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. YAGEO BRAND ordering code GLOBAL PART NUMBER APPLICATIONS All general purpose application FEATURES RoHS compliant - - Products with lead free terminations meet RoHS requirements Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS Reducing environmentally hazardous wastes High component and equipment reliability Saving of PCB space 2 9 0603 (RoHS Compliant) SERIES RC0603 ( PREFERRED ) X R - XX XXXX L (1) (2) (3) (4) (5) (6) (1) TOLERANCE F = ±1% J = ±5% (for Jumper ordering, use code of J) (2) PACKAGING TYPE R = Paper / PE taping reel (3) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec (4) TAPING REEL 07 = 7 inch dia. Reel 10 = 10 inch dia. Reel 13 = 13 inch dia. Reel (5) RESISTANCE VALUE None forbidden-materials used in products/production There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Halogen Free Epoxy Detailed resistance rules show in table of “Resistance rule of global part number”. (6) OPTIONAL CODE L = optional symbol (Note) Resistance rule of global part number Resistance code rule Example 0R 0R = Jumper XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω ORDERING EXAMPLE The ordering code of a RC0603 chip resistor, value 56 X with ±1% tolerance, supplied in 7-inch tape reel is: RC0603FR-0756R(L). NOTE 1. All our RSMD products meet RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) www.yageo.com Apr 24, 2009 V.4 Product specification Chip Resistor Surface Mount RC SERIES 3 9 0603 (RoHS Compliant) PHYCOMP BRAND ordering codes Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp brand products. GLOBAL PART NUMBER ( PREFERRED ) For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2. 12NC CODE 2322 / 2350 XXX XXXXX L (1) TYPE/ START 0603 IN (1) (2) (3) Last digit of 12NC Resistance decade (3) (4) TOL. RESISTANCE (%) RANGE PAPER / PE TAPE ON REEL (units) (2) 5,000 10,000/not preferred 20,000 RC21 2322 ±5% 1 to 10 MΩ 702 60xxx 702 70xxx 702 81xxx RC22 2322 ±1% 1 to 10 MΩ 704 6xxxx 704 7xxxx 704 8xxxx HRC21 2350 ±5% 11 to 22 MΩ 522 10xxx - - Jumper 2322 - 0Ω 702 96001 702 97001 702 92002 Last digit 0.01 to 0.0976 X 0.1 to 0.976 X 0 1 to 9.76 X 8 10 to 97.6 X 9 100 to 976 X 1 1 to 9.76 KX 2 7 10 to 97.6 KX 3 (1) The resistors have a 12-digit ordering code starting with 2322 / 2350. 100 to 976 KX 4 (2) The subsequent 4 or 5 digits indicate the resistor tolerance and packaging. 1 to 9.76 MX 5 10 to 97.6 MX 6 (3) The remaining 4 or 3 digits represent the resistance value with the last digit indicating the multiplier as shown in the table of “Last digit of 12NC”. Example: (4) "L" is optional symbol (Note) . ORDERING EXAMPLE The ordering code of a RC22 resistor, value 56 X with ±1% tolerance, supplied in tape of 5,000 units per reel is: 232270465609(L) or RC0603FR-0756R(L). 0.02 X = 0200 or 200 0.3 X = 3007 or 307 1X = 1008 or 108 33 KX = 3303 or 333 10 MX = 1006 or 106 NOTE 1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) www.yageo.com Apr 24, 2009 V.4 Product specification Chip Resistor Surface Mount RC SERIES 4 9 0603 (RoHS Compliant) MARKING RC0603 E-24 series: 3 digits 03 First two digits for significant figure and 3rd digit for number of zeros YNSC001 Fig. 1 Value = 10 KΩ E-96 series: 3 digits for 0603 ±1% EIA-96 marking method 563 For 0603 ±1% E-24 series, one short bar under marking letter ynsc003 Fig. 2 Value = 12.4 KΩ Fig. 3 E-24 1% Value = 56 KΩ For further marking information, please see special data sheet “Chip resistors marking”. CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environment influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Nibarrier) are added. See fig.4 OUTLINES For dimension see Table 1 marking layer overcoat Primary glass layer resistive layer (Jumper chip is a conductor) inner electrode H termination(Ni/matte tin) ceramic substrate I2 overcoat I1 W DIMENSIONS YNSC065 Table 1 TYPE L RC0603 L (mm) 1.60 ±0.10 W (mm) 0.80 ±0.10 H (mm) 0.45 ±0.10 I1 (mm) 0.25 ±0.15 I2 (mm) 0.25 ±0.15 Fig. 4 Chip resistor outlines www.yageo.com Apr 24, 2009 V.4 Product specification Chip Resistor Surface Mount RC SERIES ELECTRICAL CHARACTERISTICS 5 9 0603 (RoHS Compliant) FOOTPRINT AND SOLDERING PROFILES Table 2 RC0603 1/10 W CHARACTERISTICS Operating Temperature Range –55 °C to +155 °C Maximum Working Voltage 50 V Maximum Overload Voltage 100 V Dielectric Withstanding Voltage 100 V For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”. 5% (E24) 1 Ω to 22 MΩ Resistance Range 1% (E24/E96) 1 Ω to 10 MΩ Zero Ohm Jumper < 0.05 Ω Temperature Coefficient 1 Ω ≤ R ≤ 10Ω ±200 ppm/°C 10 MΩ < R ≤ 22 MΩ ±200 ppm/°C 10 Ω < R ≤ 10 MΩ ±100 ppm/°C Rated Current 1.0 A Maximum Current 2.0 A Jumper Criteria PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PRODUCT TYPE PACKING STYLE REEL DIMENSION QUANTITY PER REEL RC0603 Paper Taping Reel (R) 7" (178 mm) 5,000 units 10" (254 mm) 10,000 units 13" (330 mm) 20,000 units NOTE 1. For paper tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing”. FUNCTIONAL DESCRIPTION POWER RATING RC0603 rated power at 70°C is 1/10 W RATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less handbook, halfpage P (%Prated ) MLB206_2 100 50 0 55 0 50 70 100 155 o Tamb ( C) Where V=Continuous rated DC or AC (rms) working voltage (V) Fig. 5 Maximum dissipation (P) in percentage of rated power as a function of the operating ambient temperature (Tamb) P=Rated power (W) R=Resistance value (X) www.yageo.com Apr 24, 2009 V.4 Product specification Chip Resistor Surface Mount RC SERIES 6 9 0603 (RoHS Compliant) TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Temperature Coefficient of Resistance (T.C.R.) IEC 60115-1 4.8 At +25/–55 °C and +25/+125 °C Refer to table 2 Formula: R2–R1 T.C.R= ------------------------- ×106 (ppm/°C) R1(t2–t1) Where t1=+25 °C or specified room temperature t2=–55 °C or +125 °C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Life/Endurance IEC 60115-1 4.25.1 1,000 hours at 70±5 °C applied RCWV 1.5 hours on, 0.5 hour off, still air required ±(1.0%+0.05 Ω) for 1% tol. ±(3.0%+0.05 Ω) for 5% tol.
RC0603FR-0722R6L AI解析
物料型号:RC0603系列,符合RoHS标准的贴片电阻。
器件简介:RC0603系列是国巨公司生产的通用型贴片电阻,采用厚膜工艺制造,具有无铅端接,符合RoHS要求,减少环境有害废物,提高组件和设备可靠性,节省PCB空间。
引脚分配:文档中未明确说明引脚分配,但通常贴片电阻为两个端子,用于连接电路。
参数特性: - 电阻值范围:1%和5%的容差系列,E24和E96系列。 - 温度系数:不同电阻值范围的电阻具有不同的温度系数。 - 额定功率:在70°C时为1/10瓦。 - 最大工作电压:50V。 - 最大过载电压:100V。 - 尺寸:长1.60mm±0.10mm,宽0.80mm±0.10mm,高0.45mm±0.10mm。
功能详解: - 电阻由高等级陶瓷基板、内部金属电极、厚膜电阻元件、覆盖的第二层玻璃、激光修调至额定电阻值、保护性环氧涂层和外部端接(Ni阻隔层上的亚光锡)组成。 - 电阻的标记方法包括E-24系列和E-96系列,具体标记规则见文档。
应用信息:适用于所有通用目的的应用。
封装信息:RC0603封装,提供7英寸、10英寸和13英寸的卷轴包装,每卷的单位数量分别为5000、10000和20000。
订购信息:提供了全球零件编号和12NC的传统编号系统,以及详细的电阻值编码规则。
电气特性:包括操作温度范围、最大工作电压、最大过载电压、电阻范围、零欧姆跳线、温度系数等。
测试和要求:包括电阻温度系数、寿命/耐久性、高温暴露/耐久性、湿度抵抗、热冲击、短时间过载、板弯曲、低温操作、绝缘电阻、耐电压、耐溶剂、噪声、偏置湿度(稳态)、间歇过载、焊接性-润湿性、耐焊接热、耐浸出和耐焊接热冲击等测试。
修订历史:文档记录了从2004年8月2日的版本1到2009年4月24日的版本4的修订历史,包括测试项目和方法的更新、测试要求的升级等。
*介绍内容由AI识别生成
RC0603FR-0722R6L 价格&库存
很抱歉,暂时无法提供与“RC0603FR-0722R6L”相匹配的价格&库存,您可以联系我们找货
RC0603FR-0722R6L
    • 1+0.01964
    • 100+0.01162
    • 1000+0.00735
    • 2500+0.00498
    • 5000+0.00399
    库存:5000
    RC0603FR-0722R6L
      • 10000+0.0252510000+0.00303
      • 50000+0.0193650000+0.00233
      • 100000+0.01599100000+0.00192
      • 250000+0.01431250000+0.00172
      库存:15000
      RC0603FR-0722R6L
      • 1+0.01083
      • 100+0.01007
      • 300+0.00930
      • 500+0.00853
      • 2000+0.00815
      • 5000+0.00791
      库存:4850
      RC0603FR-0722R6L
      • 1+0.839601+0.10130
      • 10+0.1003010+0.01210
      • 100+0.05830100+0.00710
      • 1000+0.050101000+0.00610
      • 5000+0.025705000+0.00310
      • 50000+0.0163050000+0.00200
      库存:22786
